RTEMS 6.1
vme
libbsp/shared/vmeUniverse/VME.h: VME API; BSP and bridge-chip independent VMEConfig.h: defines BSP specific constants for VME configuration vmeconfig.c configures the VME bridge using the VME.h API calls and BSP specific constants from VMEConfig.h. Independent of the bridge chip, however. vme_universe.c: implements VME.h for the vmeUniverse driver. vme_universe_dma.c: implements VMEDMA.h for the vmeUniverse driver.
o other universe BSP --> use its own VMEConfig.h; may reuse vmeconfig.c, vme_universe.c o other non-universe BSP --> use its own VMEConfig.h and vme_xxx.c; may reuse vmeconfig.c
Porting
NOTE: (T.S, 2007/1) The information in this file is outdated (but some portions may still be useful). Some more information about how to use the Universe and Tsi148 drivers in new BSPs can be found in
README.universe, libbsp/powerpc/shared/vme/VMEConfig.h,
source files in this directory and libbsp/powerpc/shared/vme
The vmeUniverse driver needs some support from the BSP for
a) PCI configuration space access b) PCI interrupt acknowledgement c) PCI interrupt handler installation
The driver was developed using the powerpc/shared/ BSP (it also supports vxWorks) and by default uses that BSP's a) PCI access API b,c) irq handling API (AKA 'new' style BSP_install_rtems_irq_handler() API).
Some hooks exist in the driver to ease porting to other BSPs. The following information has been assembled when answering a question regarding a ppcn_60x BSP port:
I looked through the ppcn_60x BSP. Here's what I found:
  • this BSP does NOT adhere to neither the 'old' nor the 'new' API but provides its own (startup/setvec.c: set_vector()).
  • the BSP has a 'driver' for vmeUniverse although mine is far more complete (including support for VME interrupts, DMA etc.).
  • Porting my driver to your BSP should not be too hard:
    1) vmeUniverse needs PCI configuration space support from the BSP: a) a routine 'pciFindDevice' (need to be macro-aliased to the proper routine/wrapper of your BSP) who scans PCI config space for the universe bridge. You could add 'libbsp/powerpc/shared/pci/pcifinddevice.c' to your BSP substituting the pci_read_config_xxx calls by the ones present on your BSP (see step 2)) b) routines to read PCI config registers (byte and longword) [on your BSP these are PCIConfigRead32/PCIConfigRead8; hence you could replace the macros on top with #define pciConfigInLong PCIConfigRead32 2) vmeUniverse needs to know how to acknowledge a PCI interrupt In your case, nothing needs to be done #define BSP_PIC_DO_EOI do {} while (0) 3) Install the VME ISR dispatcher: replace the 'new' style interrupt installer (BSP_install_rtems_irq_handler()) by a proper call to 'set_vector()' 4) I might have missed something...
I attach the latest version of the vmeUniverse driver in case you want to try to do the port (should be easy).
For the sake of ease of maintenance, I just added a few hooks making it possible to override some things without having to modify the driver code.
1,2) PCI config space access macros may be overriden via CFLAGS when compiling vmeUniverse.c, hence: CFLAGS += -DBSP_PIC_DO_EOI=do{}while(0) CFLAGS += -DBSP_PCI_CONFIG_IN_LONG=PCIConfigRead32 CFLAGS += -DBSP_PCI_CONFIG_IN_BYTE=PCIConfigRead8 (you still need to supply pci_find_device) 3) create your own version of vmeUniverseInstallIrqMgr(): copy to a separate file and replace
BSP_rtems_install_irq_handler() by a proper call to set_vector.
4) Send me email :-)
USAGE NOTE: To fully initialize the driver, the following steps can/must be performed:
vmeUniverseInit(); /* MANDATORY: Driver Initialization */ vmeUniverseReset(); /* OPTIONAL: Reset most registers to a known state;
  • if this step is omitted, firmware setup is
  • preserved */ vmeUniverseMasterPortCfg(...); /* OPTIONAL: setup the master windows
    • (current setup preserved if omitted) */ vmeUniverseSlavePortCfg(...); /* OPTIONAL: setup the slave windows
    • (current setup preserved if omitted) */ vmeUniverseInstallIrqMgr(); /* NEEDED FOR VME INTERRUPT SUPPRORT
    • initialize the interrupt manager.
    • NOTE: you need to call your own
    • version of this routine here */
For an example of init/setup, consult libbsp/powerpc/shared/vme/vmeconfig.c
Universe
The tundra drivers are in a separate subdir because they are maintained at SSRL outside of the rtems CVS tree. The directory is called 'vmeUniverse' for historic reasons. 'tundra' would be better since we now support the tundra tsi148 as well...
Till Straumann strau.nosp@m.man@.nosp@m.slac..nosp@m.stan.nosp@m.ford..nosp@m.edu 1/2002, 2005, 2007
A BSP that wants to use these drivers must implement the following headers / functionality:
  • <bsp/pci.h> offering an API like 'libbsp/powerpc/shared/pci'
  • <bsp/irq.h> offering the 'new style' RTEMS irq API (like 'libbsp/powerpc/shared/irq').
  • <libcpu/io.h> for the I/O operations (out_le32,in_le32, ..., out_be32,...)
  • <libcpu/byteorder.h> for byte-swapping (st_le32, ld_le32, ..., st_be32,...)
  • glue code that implements the 'VME.h' and 'VMEDMA.h' APIs using the vmeUniverse and/or vmeTsi148 driver code. The 'glue' code initializes appropriate VME/PCI windows when booting and installs the VME interrupt manager.
    The 'glue' may also use the 'bspVmeDmaList' code to implement generic parts of linked-list DMA.
    Boards with a 'universe' chip may use a pretty generic version of the glue code that is defined in libbsp/powerpc/shared/vmeconfig.c, libbsp/powerpc/shared/vme_universe.c, and libbsp/powerpc/shared/vme_universe_dma.c. The board-specific parameters are defined in a single BSP-specific file 'VMEConfig.h'. That's where the actual addresses of VME/PCI windows are configured and where interrupt wires can be assigned etc.
    Read libbsp/powerpc/shared/VMEConfig.h for more information and use it as a template. Note that BSP implementors should try not to clone 'vmeconfig.c' but use the constants in VMEConfig.h
  • The BSP should export 'VME.h' and 'VMEDMA.h' to applications and encourage them to only use the API defined there in order to make application code driver-independent. This will ensure seamless portability of applications between the universe and Tsi148 drivers.
TESTING: A valuable tool for testing are the (substitute XXX for 'Universe' or 'Tsi148') routines: vmeXXXMapCRG() maps the controller registers to VME space so you can test if you successfully can read/write from VME. You can read or DMA the PCI configuration registers and compare to what you expect (beware of endianness).
vmeXXXIntLoopbackTest() this installs an ISR and then asserts an IRQ on the VME backplane so you can verify that your interrupt routing and handling really works.
NOTES: The universe may always issue MBLTs if a data width of 64-bit is enabled (default for non-BLT addressing modes – the VME_AM_STD_xx_BLT / VME_AM_EXT_xx_BLT enforce 32-bit transfers).
Therefore, if you want to setup a outbound window that always uses single cycles then you must explicitely request a data width < 64, e.g.,
vmeUniverseMasterPortCfg(port, VME_AM_EXT_SUP_DATA | VME_MODE_DBW32, vme_addr, pci_addr, size);
