RTEMS 6.1
gen5200
BSP NAME: gen5200
BOARD: various boards based on MPC5200 Controller:
MicroSys PM520 with Carrier board CR825
BUS: N/A
CPU FAMILY: ppc
CPU: PowerPC MPC5200
COPROCESSORS: Hardware FPU
MODE: 32 bit mode, I and D cache enabled
DEBUG MONITOR: None
PERIPHERALS
TIMERS: GPT
SERIAL PORTS: 3 PSCs
2 CAN IFs
1 I2C IF
REAL-TIME CLOCK: PCF8563
DMA: for Ethernet and CompactFlash
VIDEO: none
SCSI: none
IDE: 1 CompactFlash Slot supported
NETWORKING: 1 FEC Fast Ethernet
DRIVER INFORMATION
CLOCK DRIVER: using one GPT
IOSUPP DRIVER: none
SHMSUPP: none
TIMER DRIVER: Timebase register (lower 32 bits only)
STDIO
PORT: PSC1
ELECTRICAL: RS-232
BAUD: 9600
BITS PER CHARACTER: 8
PARITY: None
STOP BITS: 1
NOTES
On-chip resources:
PSC1 /dev/console /dev/tty00
PSC2 /dev/tty01
PSC3 /dev/tty02
Board description
Clock rate: external clock: 33MHz
Bus width: 32 bit Flash, 32 bit SDRAM
FLASH: 8MByte
RAM: 64MByte SDRAM
Debugging/ Code loading:
Tested using the Lauterbach TRACE32 ICD debugger.
IceCube
IceCube is the nickname for the FreeScale MPC5200LITE evaluation board which seems to be the basis for boards from a number of other vendors. The most complete and up to date information will be found on the RTEMS Wiki. We know of the following boards which are the IceCube:
  • FreeScale MPC5200LITE
  • Embedded Planets EP52000 (does not ship with U-Boot)
U-Boot supports this board very well. When using U-Boot the following command sequence is used to transform an ELF file into a U-Boot image.
powerpc-rtems4.8-objcopy -R -S -O binary hello.exe hello.bin cat hello.bin | gzip -9 >hello.gz /opt/embedded/tools/usr/bin/mkimage \ -A ppc -O rtems -T kernel -a 0x10000 -e 0x10000 -n "RTEMS" \ -d hello.gz hello.img
These ttcp results were between an EP5200 and Dell Insprion 9400 running Fedora 7. A private network was used.
>>> ttcp -t -s 192.168.1.210
ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5001 tcp -> 192.168.1.210
ttcp-t: socket
ttcp-t: connect
ttcp-t: 16777216 bytes in 1.58 real seconds = 10385.86 KB/sec +++
ttcp-t: 2048 I/O calls, msec/call = 0.79, calls/sec = 1298.23
ttcp-t: 0.0user 1.5sys 0:01real 100% 0i+0d 0maxrss 0+0pf 0+0csw
>>> ttcp -r -s
ttcp-r: buflen=8192, nbuf=2048, align=16384/0, port=5001 tcp
ttcp-r: socket
ttcp-r: accept from 192.168.1.210
ttcp-r: 16777216 bytes in 1.78 real seconds = 9194.86 KB/sec +++
ttcp-r: 3499 I/O calls, msec/call = 0.52, calls/sec = 1963.67
