RTEMS 6.1
Valuable information was obtained from the following drivers netbsd: Allegro Networks Inc; Wasabi Systems Inc. linux: MontaVista, Software, Inc; Chris Zankel, Mark A. Greer. Matthew Dharm, rabeeh, Manish Lachwani, Ralf Baechle.
rtems: Brookhaven National Laboratory; Shuchen Kate Feng This BSP also builds on top of the work of others who have contributed to similar RTEMS (powerpc) BSPs, most notably Eric Valette, Eric Norum and others.
In particular, the Author wishes to thank Shuchen Kate Feng (BNL) for many inspiring discussions and Dayle Kotturi (SLAC) for her contributions, support and extensive testing.
See ./LICENSE file.
Note that not all files that are part of this BSP were written by me (most notably, the ethernet drivers if_gfe [netbsd port] and if_em [freebsd port]). Consult individual file headers for copyright and authorship information.
(relevant only if you received this BSP unbundled from the RTEMS distribution)
prepare:
Even though this BSP is binary compatible with the MVME5500 it's primary target was and is the MVME6100 board which in some respects is quite different. In particular, the discovery chip and the VME bridge exhibit significant differences. I am sometimes asked why this BSP provides yet another port of the gfe and em BSD drivers (which had previously been ported for the mvme5500 BSP by Shuchen Kate Feng [BNL]). The answer is simply a matter of time: Once support for the 6100 board was completed I found it easier to use the set of 'quick-and-dirty' wrappers (found in network/porting) that I had developed for other projects and to do a new port from scratch using that framework rather than modifying the mvme5500 BSP's drivers. mvme5500 support was added to this BSP because we own a few of those boards we occasionally play with but we don't want to build and support an additional BSP for them. An important detail – hardware cache snooping – was borrowed from Shuchen Kate Feng's gfe driver port, though.
(some of the headers mentioned below contain more detailed information)
NOTE: The BSP supports both, the mvme6100 and the mvme5500 boards. It detects relevant hardware at run-time.
WARNING: It is extremely important that a MOTLoad "waitProbe", "netShut" sequence be executed before booting RTEMS. Otherwise, network interface interrupt handlers installed by MOTLoad may cause memory corruption
CONSOLE: 2 serial devices, UART driver from 'shared' - no surprises ("/dev/ttyS0", [="/dev/console"], "/dev/ttyS1"). (Only /dev/ttyS0 is accessible from the front panel.)
CLOCK: Decrementer, same as other PPC BSPs. (FIXME: a discovery timer could be used.)
PIC (interrupt controller) (bsp/irq.h): Marvell hostbridge does not implement interrupt priorities. The driver supports priorities in software (masking lower priority lines during execution of higher priority ISR). I believe the design of the IRQ subsystem is as efficient as possible with focus on low latencies. In addition to the rtems IRQ API, calls are available to change IRQ priority and to enable/disable interrupts at the PIC.
EXCEPTIONS: (bspException.h) Routines to install a user callback for (PPC) exception handling.
PCI (bsp/pci.h): The BSP hides the fact that there are effectively two 'root' busses (AKA 'hoses') behind the discovery bridge. Devices are addressed by bus/slot/function-triples and the PCI subsystem transparently figures out what hose to use. In addition to rtems' PCI API, a call is available to scan all devices executing a user callback on each device. BSP_pciConfigDump() is a convenience wrapper dumping essential information (IDs, BAs, IRQ pin/line) to the console or a file.
MEMORY MAP: CHRP; all addresses (MEM + I/O) read from PCI config. space are CPU addresses. For sake of portability, drivers should still use the _IO_BASE, PCI_MEM_BASE, PCI_DRAM_OFFSET constants.
NVRAM: Address constants are defined in bsp.h
FLASH (bsp/flashPgm.h): Routines to write flash. Highest level wrapper writes a file to flash. NOTE: Writing to flash is disabled by default; call BSP_flashWriteEnable().
I2C (bsp.h, rtems/libi2c.h, libchip/i2c-xxx.h): temp. sensor and eeprom are available as device files (bsp.h); lower-level interface is provided by libi2c.h. NOTE: The I2C devices are not registered and the driver is not initialized by default. Call BSP_i2c_initialize() to do that; this will create /dev/i2c0.vpd-eeprom /dev/i2c0.usr-eeprom /dev/i2c0.ds1621 You can then read the board temperature: fd = open("/dev/i2c0.ds1621",O_RDONLY) read(fd,&temp,1) close(fd); printf("Board Temp. is %idegC\n",(int)temp);
VME: (bsp/VME.h, bsp/vme_am_defs.h, bsp/VMEDMA.h). always use VME.h API, if possible; do not use chip drivers (vmeUniverse.h, vmeTsi148.h) directly unless you know what you are doing (i.e., if you need specific features provided by the particular chip; currently, both of the mentioned chip drivers expose entry points that are designed to be compatible).
VMEConfig.h should not be used by applications as it makes them dependent on BSP internals. VMEConfig.h is intended to be used by BSP designers only.
VME interrupt priorities: the VME bridge(s) do not implement priorities in hardware. However, on the 5500/6100 multiple physical interrupt lines/wires connect the VME bridge to the PIC. Hence, it is possible to assign the different wires different priorities at the PIC (see above) and to route VME interrupts to different wires according to their priority. You need to call driver specific routines for this (vmeXXXIntRoute()), however (for driver-specific API consult bsp/vmeUniverse.h, bsp/vmeTsi148.h).
For VME DMA always use the bsp/VMEDMA.h API. DO NOT use chip-specific features. Applications written using the bsp/VMEDMA.h API are portable between the UniverseII and the Tsi148.
HARDWARE TIMERS: (bsp/gt_timer.h). Programmable general-purpose (GPT) and watchdog timers. Routines are provided to setup, start and stop GPTs. The setup routine allows for specifying single-shot or periodic mode and dispatches a user ISR when the GPT expires.
The watchdog timer - when started - issues a hard-reset of the board if not 'petted' within a configurable timeout period.
NETWORK: (bsp/bsp_bsdnet_attach.h). The BSP offers a call to list all available interfaces (name, description, 'attach'-method) for the application to make a selection. Alternatively, there are BSP_auto_network_driver_name and BSP_auto_enet_attach(), the latter with the capability to configure the first NIC with a 'live' link status. All drivers (rewritten 'mve' for the mv64360 NIC (6100) and BSD ports 'gfe'/'em' (5500)) support the SIOCSIFMEDIA/SIOCGIFMEDIA ioctls (rtems/rtems_mii_ioctl.h provides helpers to convert strings from/to control words).
VPD: (bsp/vpd.h). The board's VPD (vital-product-data such as S/N, MAC addresses and so forth) can be retrieved.
BOOTING: BSP has a relocator-header. Clear MSR and jump to the first instruction in the binary. R3 and R4, if non-null, point to the start/end of an optional command line string that is copied into BSP_commandline_string. The BSP is compatible with 'netboot'.
Have fun.
– Till Straumann strau.nosp@m.man@.nosp@m.slac..nosp@m.stan.nosp@m.ford..nosp@m.edu, 2005-2007.
