RTEMS 6.1
This is a README file for the MVME167 port of RTEMS 4.5.0.
Please send any comments, improvements, or bug reports to:
Charles-Antoine Gauthier charl.nosp@m.es.g.nosp@m.authi.nosp@m.er@n.nosp@m.rc.ca
or
Darlene Stewart Darle.nosp@m.ne.S.nosp@m.tewar.nosp@m.t@nr.nosp@m.c.ca
Software Engineering Group Institute for Information Technology National Research Council of Canada Ottawa, ON, K1A 0R6 Canada
The National Research Council of Canada is distributing this RTEMS board support package for the Motorola MVME167 as free software; you can redistribute it and/or modify it under terms of the GNU General Public License as published by the Free Software Foundation; either version 2, or (at your option) any later version. This software is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with RTEMS; see file COPYING. If not, write to the Free Software Foundation, 675 Mass Ave, Cambridge, MA 02139, USA.
Under no circumstances will the National Research Council of Canada nor Her Majesty the Queen in right of Canada assume any liablility for the use this software, nor any responsibility for its quality or its support.
Nothing unique to the MVME167. It uses the standard build process for m68k targets. You will need to edit linkcmds to put in the start address of your board. We do TFTP transfers to our target. The mvme167.cfg file builds only the ELF images, which we download to the target, skipping over the first 0x54 bytes; Motorola S-records are not generated. Edit this file if you want S-records.
Port Description
This BSP includes an termios-capable interrupt-driven I/O console driver that supports all four serial ports on the MVME167 model. The port labelled Serial Port 1/Console on the MVME712 is normally used by 167Bug; do not open /dev/tty00 if you are debugging using 167Bug.
Limited support is provided for polled terminal I/O. This is used when running the timing tests, and by the printk() debug output function. Polled I/O may use termios, or it may bypass those services. The printk() function does not use termios. When polled I/O is used, the terminal settings must be set through 167-Bug; trying to change the line settings through RTEMS has no effect.
Three is no support for using interrupt-driven I/O without termios support.
The default configuration is to use polled I/O and to bypass termios. This is done so the test can be built at the same time as the rest of the system. It is highly recommended that the defaults be changed in the mvme167.cfg file to reflect the desired defaults, or that the appropriate parameters be set up in NVRAM to select the appropriate I/O modes at boot time.
When configured for interrupt-driven I/O, the console is initialized with whatever parameters are set up in termios before it calls the firtOpen driver callback, EXCEPT THAT HARDWARE HANDSHAKING IS TURNED OFF, i.e. CLOCAL is set in the struct termios c_cflag field. We use 3-wire cables for I/O, and find hardware handshaking a pain. If you enable hardware handshaking, you must drive CTS* low on the CD2401 for output to occur. If the port is in the DTE configuration, you must drive the RS-232 CTS line to space; if the port is in the DCE configuration, you must drive the RS-232 RTS line to space.
To use interrupt-driven I/O, set the CD2401_IO_MODE manifest constant to 1 in rtems/make/custom/mvme167.cfg, or configure the appropriate parameter in User Area Non-volatile RAM. See the Configuration Parameters section below for instructions on setting up NVRAM.
To use termios, set the CD2401_USE_TERMIOS manifest constant to 1 in rtems/make/custom/mvme167.cfg, or configure the appropriate parameter in User Area Non-volatile RAM. See the Configuration Parameters section below for instructions on setting up NVRAM.
The RTEMS console, i.e. the port used by stdin, stdout and stderr (do not confuse it with the port labelled Console on the MVME712), must be specified in the rtems/make/custom/mvme167.cfg file, or in the NVRAM parameters. Set the value of CONSOLE_MINOR appropriately. See below for a list of choices. See the Configuration Parameters section below for instructions on setting up NVRAM.
The RTEMS printk port, i.e. the port where printk sends it debugging output text, must be specified in the rtems/make/custom/mvme167.cfg file, or in the NVRAM parameters. Set the value of PRINTK_MINOR appropriately. See below for a list of choices. See the Configuration Parameters section below for instructions on setting up NVRAM.
Interrupt-driven and polled I/O cannot be mixed in the MVME167, except that printk always used polled I/O without termios. If interrupt-driven I/O is used and printk is used, do not open the device that printk uses from an RTEMS application.
Console and printk port choices:
Setting the RTEMS console to port 0 when interrupt-driven I/O is specified will prevent 167-Bug from using that port.
To use polled I/O on port 2 or 3, the port must be configured in 167-Bug. See the "PF" command in the "Debugging Package for Motorola 68K CISC CPUs User's Manual", part number 68KBUG.
The MC68040 has a built-in FPU. This FPU does not implement all the instruction of the MC68881/MC68882 floating-point coprocessors in hardware. The -m68040 compilation options instructs gcc to not generate the missing instructions. All of the RTEMS code is built this way. Some of the missing functionality must be supplied by external libraries. The required functions are part of libgcc.a.
The issue gets complicated because libc, libm and libgcc do not come as m68040-specific variants. The default variants of these libraries are for the MC68020 and MC68030. There are specific variants for the MC68000 (which has limited addressing modes with respect to later family members), and specific variants for systems without a floating-point unit, either a built-in FPU or a coprocessor. These latter variants will be referred to as the msoft-float variants. There is a msoft-float variant for the MC68000, and one for the other family members.
The default variants of libc, libm and libgcc appear to work just fine for the MC68040, AS LONG AS NO FLOATING POINT FUNCTIONS ARE CALLED. In particular, printf() and scanf() raise unimplemented floating-point instruction exceptions at run time. Expect almost every function that must compute a floating-point result to also raise unimplemented floating-point instruction exceptions. Do not use these variants if your application does any floating-point operations, unless you use the Motorola FPSP package (described further down).
The msoft-float variants do print out floating-point numbers properly, but we have not tested them extensively, so use them with caution. In particular, the Paranoia test fails when linked with the msoft-float variants of the libraries; it goes into an infinite loop after milestone 40.
MSOFT_FLOAT VARIANTS MUST BE USED TOGETHER. If you use the msoft-float variant of libc and libm, you must also linked with the msoft-float variant of libgcc, otherwise calls such as printf() print out floating-point values incorrectly.
RTEMS comes with the Motorola FPSP (Floating-Point Support Package) for the MC68040 (rtems/c/src/lib/libcp/m68k/m68040/fpsp). This package emulates the missing floating-point instructions. It is built automatically for the MVME167 and installed in bsp_start().
The FPSP allows the use of the default variants of libc, libm and libgcc. It also runs the paranoia test properly, and prints out the correct results. It should probably be used in preference to the msoft-float libraries, as it appears to work better. The disadvantage of the FPSP is that it increases the size of the executable by about 60KB and that it relies on run time exceptions.
If your application does not do any floating-point operations at all, you should consider disabling the FPSP. In bsp_start(), emove the call to M68KFPSPInstallExceptionHandlers(), and uncomment the three lines in mvme167.cfg that redefine which variants of libc, libm and libgcc to link against.
If Jumper J1-4 is installed, certain configuration parameters may be read from the first 31 bytes of User Area NVRAM starting at 0xFFFC0000. In this case, the remaining J1-[5-7] jumpers are ignored, and the user is responsible for writing the appropriate values in NVRAM (via 167-Bug) in order to alter the default behaviour. A zero value in NVRAM results in the default behaviour. The paramaters that are configurable and their default settings are described below.
Cache Mode (0xFFFC0000 - 1 byte)
Set the following bits in the byte to set the desired cache mode:
bit 0
0 - data cache disable
1 - data cache enable
bit 1
0 - instruction cache disable
1 - instruction cache enable
bits 2 & 3:
00 = cachable, write-through
01 = cachable, copyback
10 = noncachable, serialized
11 = noncachable
Console driver I/O mode (0xFFFC0001 - 1 byte)
Set the following bits in the byte to set the desired I/O mode:
bit 0
0 - do not use termios
1 - use termios
bit 1
0 - polled I/O
1 - interrupt-driven I/O
Console driver ports (0xFFFC0002 - 1 byte)
Set the following bits in the byte to select the console and printk ports:
bit 0 & 1 select the RTEMS console port
00 - /dev/tty0, Serial Port 1/Console on the MVME712M.
01 - /dev/tty1, Serial Port 2/TTY01 on the MVME712M.
10 - /dev/tty2, Serial Port 3 on the MVME712M.
11 - /dev/tty3, Serial Port 4 on the MVME712M.
bit 4 & 5 select the RTEMS printk port
If the printk port is the same as some other port that will be opened by an
RTEMS application, then the driver must use polled I/O, or the printk port
must not be used.
IP Address (0xFFFC0004 - 4 bytes)
write the hexadecimal representation of the IP address of the board in this
locatio, e.g. 192.168.1.2 = 0xC0A80102
default: obtain the IP address from an rtems_bsdnet_ifconfig structure
Netmask (0xFFFC0008 - 4 bytes)
write the hexadecimal representation of the netmask in this location
for example, 255.255.255.0 = 0xFFFFFF00
default: obtain the netmask from an rtems_bsdnet_ifconfig structure
Ethernet Address (0xFFFC000C - 6 bytes)
write the Ethernet address of the board in this location
default: obtain the hardware address from an rtems_bsdnet_ifconfig
structure
Processor ID (0xFFFC0012 - 2 bytes)
reserved for future use
RMA start (0xFFFC0014 - 4 bytes)
VMA start (0xFFFC0018 - 4 bytes)
RamSize (0xFFFC001C - 4 bytes)
If configuration is not obtained from non-volatile RAM (ie. J1-4 is off), cache control is done through the remaining J1 jumpers as follows:
If Jumper J1-7 is installed, the data cache will be turned on. If Jumper J1-6 is installed, the instruction cache will be turned on. (If a jumper is off, its corresponding cache will remain disabled).
If Jumper J1-5 is installed, the data cache will be placed in copyback mode. If it is removed, it will be placed in writethrough mode.
Currently, block address translation is set up to map the virtual 0x00000000–0x7FFFFFFF to the physical range 0x00000000–0x7FFFFFFF. The port relies on the hardware to raise exceptions when addressing non-existent memory. Caching is not controllable on a finer grain.
If configuration is not obtained from non-volatile RAM (ie. J1-4 is off), the networking parameters shown above must be specified in an initialized rtems_bsdnet_ifconfig struct. This structure is declared and initialized to specify any network devices and includes entries for ip_address, ip_netmask and hardware_address. See the Network Device Configuration section of the RTEMS Networking Supplement.
When non-default (non-zero) networking paramaters are provided in NVRAM (ie. j1-4 is on), the user MUST ensure that the corresponding entries in the ifconfig struct are NULL. Failing to do so is an error, because it causes the memory allocated for the initialized struct values to be lost.
The timer and clock drivers were patterned after the MVME162 and MVME152 ports.
At this time, we do not have an MPCI layer for the MVME167. We are planning to write one.
This port supplies its own fatal_error_handler, which attempts to print some error message through 167Bug (on the Serial Port 1/Console on the MVME712M).
The port was initially developed on an RS-6000 running AIX 4.2. The following tools were used:
- GNU gcc 2.8.1 configured for a powerpc-ibm-aix4.2.0.0 host and m68k-rtems target; - GNU binutils 2.9.1 configured for a powerpc-ibm-aix4.2.0.0 host and m68k-rtems target;
It was also tested on a Pentium II-based PC running Windows NT Workstation 4.0 and the Cygnus Cygwin32 release b20.1 environment, with the following tools:
- EGCS 1.1.1 configured for a i586-cygwin32 host and m68k-rtems target; - GNU binutils 2.9.4 configured for a i586-cygwin32 host and m68k-rtems target;
With the latter environment, be patient; builds take a very looong time...
Current development is done on a Pentium III PC running RedHat Linux 6.1. At the time this README was composed, the latest working compiler that was used successfully was gcc version 2.96 20000213 (experimental). Both the C and C++ compilers were working. Binutils 2.10 are used.
Polled I/O without termios may not work very well on input. The problem is that input processing is not done: applications may get characters too early, and may get characters that they normally would not get, such as backspace or delete. Furthermore, input is not buffered at all. The latest versions of rtems seem to set the count field in the rtems_libio_rw_args_t argument to the buffer size, not to the number of characters expected on input. Rather than wait for 1024 characters on each call, the driver returns each character when it is received.
The cdtest will not run with interrupt-driven I/O. The reason is that the constructors for the static objects are called at boot time when the interrupts are still disabled. The output buffer fills up, but never empties, and the application goes into an infinite loop waiting for buffer space. This should have been documented in the rtems/c/src/tests/PROBLEMS file. The moral of this story is: do not do I/O from the constructors or destructors of static objects.
Output stops prematurely in the termios test when the console is operating in interrupt-driven mode because the serial port is re-initialized before all characters in the last raw output buffer are sent. Adding calls to tcdrain() in the test task helps, but it does not solve the problem. What happens is that the CD2401 raises a transmit interrupt when the last character in the DMA buffer is written into the transmit FIFO, not when the last character has been transmitted. When tcdrain() returns, there might be up to 16 characters in the output FIFO. The call to tcsetattr() causes the serial port to re-initialize, at which point the output FIFO is cleared. We could not find a way to detect whether characters are still in the FIFO and to wait for them to be transmitted.
The first raw buffer to be transmitted after the console is re-initialized with tcsetattr() is garbled. At this time, it does not seem worth while to track this problem down.
In the stackchk test, an access fault exception is raised after the stack is blown. This is one case were overwritting the first or last 16 bytes of the stack does cause problems (but hey, an exception occurred, which is better than propagating the error).
When using interrupt-driven I/O, psx08 produces all the expected output, but it does not return control to 167Bug. Is this test supposed to work with interrupt-driven console I/O?
Support for Java is being actively worked on.
Board: Motorola MVME167 CPU: Motorola MC68040 Clock Speed: 25 MHz RAM: 4 MBytes of 32-bit DRAM with parity Cache Configuration: Instruction cache on; data cache on, copyback mode. Times Reported in: microseconds Timer Source: VMEchip2 Tick Timer 1 GCC Flags: -m68040 -g -O4 -fomit-frame-pointer Console: Operate in polled mode. Set CD2401_POLLED_IO to 1 in rtems/c/src/lib/libbsp/m68k/mvme167/console/console.c.
Single processor tests: All tests passed, except the following ones:
Multi-processort tests: not applicable – No MPCI layer yet.
Timing tests: See rtems/c/src/lib/libbsp/m68k/mvme167/times
