RTEMS 6.1
Multi-channel DMA API
Release Notes
Version 0.3
  • MCD_INCLUDE_EU functionality supported(microcode changes for all tasks except ethernet).
  • Fixed bug when using MCD_END_FRAME which would cause the DMA to transfer zero bytes and then complete.
  • Code cleanup.
Version 0.2 (Slight Update)
  • Modified casts and task table implementations that were causing warnings (and even errors on certain compilers)
  • Cosmetic changes to clean up MCD_dmaApi.c and MCD_dma.h
  • Fixed table declarations so that MCD_tasks.c will compile if MCD_INCLUDE_EU is defined (Note: EU functionality still not supported)
Version 0.1 (Initial release)
Alpha version MCD_INCLUDE_EU functionality not supported. MCD_INCLUDE_JBIG not supported.
