RTEMS 6.1
The Zynq is supports the common hard IP that is common to all versions of the Zynq device family.
To access the PL (FPGA Logic) create an MMU table in your application and create the entries that map to your FPGA IP.
Tested only on Qemu.
git clone git://git.qemu.org/qemu.git qemu cd qemu git checkout 1b0d3845b454eaaac0b2064c78926ca4d739a080 mkdir build cd build ../configure –prefix=/opt/qemu –interp-prefix=/opt/qemu make make install export PATH="$PATH:/opt/qemu/bin"
qemu-system-arm -no-reboot -serial null -serial mon:stdio -net none -nographic -M xilinx-zynq-a9 -m 256M -kernel ticker.exe
