RTEMS 6.1
lpc24xx
Development Board: QVGA Base Board from Embedded Artists
http://www.embeddedartists.com/products/uclinux/oem_lpc2478.php
Drivers:
o Console
o Clock
o RTC
o SSP (SPI mode)
o Network
o I2C
Howto setup QVGA Base Board?
o Unpack board.
o Connect board via USB to your PC.
o Verify that demo application runs.
o Disconnect board.
o Change jumpers to enable ISP.
o Connect board.
o Load U-Boot image 'u-boot_v1.1.6_lpc2468oem_v1_8_16bit.hex'
(available from the EA support page) into the flash (flash tool
FlashMagic is availabe from NXP).
o Change jumbers back to disable ISP.
o Use a terminal program to change the U-Boot settings via the console.
o U-Boot settings:
    set ethaddr '00:1a:f1:X:X:X'
    set serverip 'X.X.X.X'
    set ipaddr 'X.X.X.X'
    set rtems 'tftp a1000000 lpc2478.img;bootm'
    set bootcmd 'echo Booting RTEMS ...;run rtems'
    saveenv
Howto make a U-Boot image?
mkimage -A arm -O rtems -T kernel -C gzip \ -a a0000000 -e a0000040 -n "RTEMS Application" -d app.bin.gz app.img
Application Board: NCS (Nurse Control Station)
Board:      NextGenNCS
Processor:  NXP LPC2478 or LPC2470
SDRAM:      8MByte, 16 bit wide
Ext. Flash: 1MByte, 16 bit wide
Console:    UART, 115200 Baud
Network:    100Base-T
Application Board: TLI800 TLI800 is a network node using four serial ports produced by Thorn Security Limited. It is used by Tyco Fire & Integrated Solutions for a fire control network.
