RTEMS
6.1
bsps
sh
gensh2
include
score
ispsh7045.h
1
2
* This include file contains information pertaining to the Hitachi SH
3
* processor.
4
5
* Authors: Ralf Corsepius (corsepiu@faw.uni-ulm.de) and
6
* Bernd Becker (becker@faw.uni-ulm.de)
7
8
* COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
9
10
* This program is distributed in the hope that it will be useful,
11
* but WITHOUT ANY WARRANTY; without even the implied warranty of
12
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
13
14
15
* COPYRIGHT (c) 1998.
16
* On-Line Applications Research Corporation (OAR).
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
* Modified to reflect isp entries for sh7045 processor:
23
* John M. Mills (jmills@tga.com)
24
* TGA Technologies, Inc.
25
* 100 Pinnacle Way, Suite 140
26
* Norcross, GA 30071 U.S.A.
27
28
29
* This modified file may be copied and distributed in accordance
30
* the above-referenced license. It is provided for critique and
31
* developmental purposes without any warranty nor representation
32
* by the authors or by TGA Technologies.
33
34
35
#ifndef __CPU_ISPS_H
36
#define __CPU_ISPS_H
37
38
#ifdef __cplusplus
39
extern
"C"
40
#endif
41
42
extern
void
__ISR_Handler( uint32_t vector );
43
44
45
46
* interrupt vector table offsets
47
48
#define NMI_ISP_V 11
49
#define USB_ISP_V 12
50
#define IRQ0_ISP_V 64
51
#define IRQ1_ISP_V 65
52
#define IRQ2_ISP_V 66
53
#define IRQ3_ISP_V 67
54
#define IRQ4_ISP_V 68
55
#define IRQ5_ISP_V 69
56
#define IRQ6_ISP_V 70
57
#define IRQ7_ISP_V 71
58
#define DMA0_ISP_V 72
59
#define DMA1_ISP_V 76
60
#define DMA2_ISP_V 80
61
#define DMA3_ISP_V 84
62
63
#define MTUA0_ISP_V 88
64
#define MTUB0_ISP_V 89
65
#define MTUC0_ISP_V 90
66
#define MTUD0_ISP_V 91
67
#define MTUV0_ISP_V 92
68
69
#define MTUA1_ISP_V 96
70
#define MTUB1_ISP_V 97
71
#define MTUV1_ISP_V 100
72
#define MTUU1_ISP_V 101
73
74
#define MTUA2_ISP_V 104
75
#define MTUB2_ISP_V 105
76
#define MTUV2_ISP_V 108
77
#define MTUU2_ISP_V 109
78
79
#define MTUA3_ISP_V 112
80
#define MTUB3_ISP_V 113
81
#define MTUC3_ISP_V 114
82
#define MTUD3_ISP_V 115
83
#define MTUV3_ISP_V 116
84
85
#define MTUA4_ISP_V 120
86
#define MTUB4_ISP_V 121
87
#define MTUC4_ISP_V 122
88
#define MTUD4_ISP_V 123
89
#define MTUV4_ISP_V 124
90
91
#define ERI0_ISP_V 128
92
#define RXI0_ISP_V 129
93
#define TXI0_ISP_V 130
94
#define TEI0_ISP_V 131
95
96
#define ERI1_ISP_V 132
97
#define RXI1_ISP_V 133
98
#define TXI1_ISP_V 134
99
#define TEI1_ISP_V 135
100
101
#define ADI0_ISP_V 136
102
#define ADI1_ISP_V 137
103
#define DTC_ISP_V 140
/* Data Transfer Controller */
104
#define CMT0_ISP_V 144
/* Compare Match Timer */
105
#define CMT1_ISP_V 148
106
#define WDT_ISP_V 152
/* Wtachdog Timer */
107
#define CMI_ISP_V 153
/* BSC RAS interrupt */
108
#define OEI_ISP_V 156
/* I/O Port */
109
#define DREF_ISP_V CMI_ISP_V
/* DRAM Refresh from BSC */
110
#if 0
111
#define PRT_ISP_V
/* parity error - no equivalent */
112
#endif
113
114
/* dummy ISP */
115
extern
void
_dummy_isp(
void
116
117
/* Non Maskable Interrupt */
118
extern
void
_nmi_isp(
void
119
120
/* User Break Controller */
121
extern
void
_usb_isp(
void
122
123
/* External interrupts 0-7 */
124
extern
void
_irq0_isp(
void
125
extern
void
_irq1_isp(
void
126
extern
void
_irq2_isp(
void
127
extern
void
_irq3_isp(
void
128
extern
void
_irq4_isp(
void
129
extern
void
_irq5_isp(
void
130
extern
void
_irq6_isp(
void
131
extern
void
_irq7_isp(
void
132
133
/* DMA - Controller */
134
extern
void
_dma0_isp(
void
135
extern
void
_dma1_isp(
void
136
extern
void
_dma2_isp(
void
137
extern
void
_dma3_isp(
void
138
139
/* Interrupt Timer Unit */
140
/* Timer 0 */
141
extern
void
_mtua0_isp(
void
142
extern
void
_mtub0_isp(
void
143
extern
void
_mtuc0_isp(
void
144
extern
void
_mtud0_isp(
void
145
extern
void
_mtuv0_isp(
void
146
/* Timer 1 */
147
extern
void
_mtua1_isp(
void
148
extern
void
_mtub1_isp(
void
149
extern
void
_mtuv1_isp(
void
150
extern
void
_mtuu1_isp(
void
151
/* Timer 2 */
152
extern
void
_mtua2_isp(
void
153
extern
void
_mtub2_isp(
void
154
extern
void
_mtuv2_isp(
void
155
extern
void
_mtuu2_isp(
void
156
/* Timer 3 */
157
extern
void
_mtua3_isp(
void
158
extern
void
_mtub3_isp(
void
159
extern
void
_mtuc3_isp(
void
160
extern
void
_mtud3_isp(
void
161
extern
void
_mtuv3_isp(
void
162
/* Timer 4 */
163
extern
void
_mtua4_isp(
void
164
extern
void
_mtub4_isp(
void
165
extern
void
_mtuc4_isp(
void
166
extern
void
_mtud4_isp(
void
167
extern
void
_mtuv4_isp(
void
168
169
/* serial interfaces */
170
extern
void
_eri0_isp(
void
171
extern
void
_rxi0_isp(
void
172
extern
void
_txi0_isp(
void
173
extern
void
_tei0_isp(
void
174
extern
void
_eri1_isp(
void
175
extern
void
_rxi1_isp(
void
176
extern
void
_txi1_isp(
void
177
extern
void
_tei1_isp(
void
178
179
/* ADC */
180
extern
void
_adi0_isp(
void
181
extern
void
_adi1_isp(
void
182
183
184
extern
void
_dtci_isp(
void
185
186
187
extern
void
_cmt0_isp(
void
188
extern
void
_cmt1_isp(
void
189
190
/* Watchdog Timer */
191
extern
void
_wdt_isp(
void
192
193
/* DRAM refresh control unit of bus state controller */
194
extern
void
_bsc_isp(
void
195
196
/* I/O Port */
197
extern
void
_oei_isp(
void
198
199
/* Parity Control Unit of the Bus State Controllers */
200
/* extern void _prt_isp( void ); */
201
202
#ifdef __cplusplus
203
204
#endif
205
206
#endif
