RTEMS 6.1
htif.h
1/*
2 * Copyright (c) 2018 embedded brains GmbH & Co. KG
3 *
4 * Redistribution and use in source and binary forms, with or without
5 * modification, are permitted provided that the following conditions
6 * are met:
7 * 1. Redistributions of source code must retain the above copyright
8 * notice, this list of conditions and the following disclaimer.
9 * 2. Redistributions in binary form must reproduce the above copyright
10 * notice, this list of conditions and the following disclaimer in the
11 * documentation and/or other materials provided with the distribution.
12 *
13 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
14 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
15 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
16 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
17 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
18 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
19 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
20 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
21 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
22 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
23 * SUCH DAMAGE.
24 */
25
26#include <rtems/termiostypes.h>
27
28#ifndef DEV_SERIAL_HTIF_H
29#define DEV_SERIAL_HTIF_H
30
31#ifdef __cplusplus
32extern "C" {
33#endif /* __cplusplus */
34
35typedef struct {
38
39void htif_console_context_init(
41 int device_tree_node
42);
43
44void htif_console_putchar(rtems_termios_device_context *base, char c);
45
46int htif_console_getchar(rtems_termios_device_context *base);
47
48extern const rtems_termios_device_handler htif_console_handler;
49
50#ifdef __cplusplus
51}
52#endif /* __cplusplus */
53
54#endif /* DEV_SERIAL_HTIF_H */
Definition: htif.h:35
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
