RTEMS 6.1
CTRL - Control Register | |
| #define | SRAM_CTRL_RAM_RD_EN_MASK (0x1U) |
| #define | SRAM_CTRL_RAM_RD_EN_SHIFT (0U) |
| #define | SRAM_CTRL_RAM_RD_EN(x) (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_RD_EN_SHIFT)) & SRAM_CTRL_RAM_RD_EN_MASK) |
| #define | SRAM_CTRL_RAM_WR_EN_MASK (0x2U) |
| #define | SRAM_CTRL_RAM_WR_EN_SHIFT (1U) |
| #define | SRAM_CTRL_RAM_WR_EN(x) (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_WR_EN_SHIFT)) & SRAM_CTRL_RAM_WR_EN_MASK) |
| #define | SRAM_CTRL_PWR_EN_MASK (0x3CU) |
| #define | SRAM_CTRL_PWR_EN_SHIFT (2U) |
| #define | SRAM_CTRL_PWR_EN(x) (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_PWR_EN_SHIFT)) & SRAM_CTRL_PWR_EN_MASK) |
| #define | SRAM_CTRL_TAMPER_BLOCK_EN_MASK (0x40U) |
| #define | SRAM_CTRL_TAMPER_BLOCK_EN_SHIFT (6U) |
| #define | SRAM_CTRL_TAMPER_BLOCK_EN(x) (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_BLOCK_EN_SHIFT)) & SRAM_CTRL_TAMPER_BLOCK_EN_MASK) |
| #define | SRAM_CTRL_TAMPER_PWR_OFF_EN_MASK (0x80U) |
| #define | SRAM_CTRL_TAMPER_PWR_OFF_EN_SHIFT (7U) |
| #define | SRAM_CTRL_TAMPER_PWR_OFF_EN(x) (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_PWR_OFF_EN_SHIFT)) & SRAM_CTRL_TAMPER_PWR_OFF_EN_MASK) |
| #define | SRAM_CTRL_LOCK_BIT_MASK (0xFF0000U) |
| #define | SRAM_CTRL_LOCK_BIT_SHIFT (16U) |
| #define | SRAM_CTRL_LOCK_BIT(x) (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_LOCK_BIT_SHIFT)) & SRAM_CTRL_LOCK_BIT_MASK) |
| #define SRAM_CTRL_LOCK_BIT | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_LOCK_BIT_SHIFT)) & SRAM_CTRL_LOCK_BIT_MASK) |
LOCK_BIT - Lock bits
| #define SRAM_CTRL_PWR_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_PWR_EN_SHIFT)) & SRAM_CTRL_PWR_EN_MASK) |
PWR_EN - Power Enable (with lock)
| #define SRAM_CTRL_RAM_RD_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_RD_EN_SHIFT)) & SRAM_CTRL_RAM_RD_EN_MASK) |
RAM_RD_EN - RAM Read Enable (with lock) 0b0..Disable read access 0b1..Enable read access
| #define SRAM_CTRL_RAM_WR_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_RAM_WR_EN_SHIFT)) & SRAM_CTRL_RAM_WR_EN_MASK) |
RAM_WR_EN - RAM Write Enable (with lock) 0b0..Disable write access 0b1..Enable write access
| #define SRAM_CTRL_TAMPER_BLOCK_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_BLOCK_EN_SHIFT)) & SRAM_CTRL_TAMPER_BLOCK_EN_MASK) |
TAMPER_BLOCK_EN - Tamper Block Enable (with lock) 0b0..Allow R/W access to secure RAM when tamper is detected 0b1..Block R/W access to secure RAM when tamper is detected
| #define SRAM_CTRL_TAMPER_PWR_OFF_EN | ( | x | ) | (((uint32_t)(((uint32_t)(x)) << SRAM_CTRL_TAMPER_PWR_OFF_EN_SHIFT)) & SRAM_CTRL_TAMPER_PWR_OFF_EN_MASK) |
TAMPER_PWR_OFF_EN - Turn off power on tamper event (with lock) 0b0..Disable the turn off function when tamper is detected 0b1..Turn off power for all secure RAM banks when tamper is detected
