RTEMS
6.1
bsps
riscv
niosv
include
altera_avalon_epcq_regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
5
* Copyright (C) 2024 Kevin Kirspel
6
7
8
* modification, are permitted provided that the following conditions
9
* are met:
10
* 1. Redistributions of source code must retain the above copyright
11
* notice, this list of conditions and the following disclaimer.
12
* 2. Redistributions in binary form must reproduce the above copyright
13
* notice, this list of conditions and the following disclaimer in the
14
* documentation and/or other materials provided with the distribution.
15
16
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
17
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
20
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
21
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
22
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
23
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
24
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
25
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
26
* SUCH DAMAGE.
27
28
29
#ifndef _ALTERA_AVALON_EPCQ_REGS_H
30
#define _ALTERA_AVALON_EPCQ_REGS_H
31
32
#include <stdbool.h>
33
#include <bsp_system.h>
34
35
36
* EPCQ_RD_STATUS register description macros
37
38
40
#define ALTERA_EPCQ_CONTROLLER2_STATUS_WIP_MASK (0x00000001)
41
#define ALTERA_EPCQ_CONTROLLER2_STATUS_WIP_AVAILABLE (0x00000000)
42
#define ALTERA_EPCQ_CONTROLLER2_STATUS_WIP_BUSY (0x00000001)
44
/* 0.7 sec time out */
45
#define ALTERA_EPCQ_CONTROLLER2_1US_TIMEOUT_VALUE 700000
46
47
48
* EPCQ_RD_SID register description macros
49
50
* Specific device values obtained from Table 14 of:
51
* "Serial Configuration (EPCS) Devices Datasheet"
52
53
#define ALTERA_EPCQ_CONTROLLER2_SID_MASK (0x000000FF)
54
#define ALTERA_EPCQ_CONTROLLER2_SID_EPCS16 (0x00000014)
55
#define ALTERA_EPCQ_CONTROLLER2_SID_EPCS64 (0x00000016)
56
#define ALTERA_EPCQ_CONTROLLER2_SID_EPCS128 (0x00000018)
57
58
59
* EPCQ_RD_RDID register description macros
60
61
* Specific device values obtained from Table 28 of:
62
* "Quad-Serial Configuration
63
* (EPCQ (www.altera.com/literature/hb/cfg/cfg_cf52012.pdf))
64
* Devices Datasheet"
65
66
#define ALTERA_EPCQ_CONTROLLER2_RDID_MASK (0x000000FF)
67
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ16 (0x00000015)
68
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ32 (0x00000016)
69
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ64 (0x00000017)
70
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ128 (0x00000018)
71
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ256 (0x00000019)
72
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ512 (0x00000020)
73
#define ALTERA_EPCQ_CONTROLLER2_RDID_EPCQ1024 (0x00000021)
74
75
76
* EPCQ_MEM_OP register description macros
77
78
#define ALTERA_EPCQ_CONTROLLER2_MEM_OP_CMD_MASK (0x00000003)
79
#define ALTERA_EPCQ_CONTROLLER2_MEM_OP_BULK_ERASE_CMD (0x00000001)
80
#define ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_ERASE_CMD (0x00000002)
81
#define ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_PROTECT_CMD (0x00000003)
82
#define ALTERA_EPCQ_CONTROLLER2_MEM_OP_WRITE_ENABLE_CMD (0x00000004)
83
85
#define ALTERA_EPCQ_CONTROLLER2_MEM_OP_SECTOR_VALUE_MASK (0x00FFFF00)
86
87
88
* EPCQ_ISR register description macros
89
90
#define ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_ERASE_MASK (0x00000001)
91
#define ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_ERASE_ACTIVE (0x00000001)
92
93
#define ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_WRITE_MASK (0x00000002)
94
#define ALTERA_EPCQ_CONTROLLER2_ISR_ILLEGAL_WRITE_ACTIVE (0x00000002)
95
96
97
* EPCQ_IMR register description macros
98
99
#define ALTERA_EPCQ_CONTROLLER2_IMR_ILLEGAL_ERASE_MASK (0x00000001)
100
#define ALTERA_EPCQ_CONTROLLER2_IMR_ILLEGAL_ERASE_ENABLED (0x00000001)
101
102
#define ALTERA_EPCQ_CONTROLLER2_IMR_ILLEGAL_WRITE_MASK (0x00000002)
103
#define ALTERA_EPCQ_CONTROLLER2_IMR_ILLEGAL_WRITE_ENABLED (0x00000002)
104
105
106
* EPCQ_CHIP_SELECT register description macros
107
108
#define ALTERA_EPCQ_CHIP1_SELECT (0x00000001)
109
#define ALTERA_EPCQ_CHIP2_SELECT (0x00000002)
110
#define ALTERA_EPCQ_CHIP3_SELECT (0x00000003)
111
112
#ifdef __cplusplus
113
extern
"C"
114
#endif
115
116
typedef
struct
117
118
volatile
uint32_t rd_status;
119
volatile
uint32_t rd_sid;
120
volatile
uint32_t rd_rdid;
121
volatile
uint32_t mem_op;
122
volatile
uint32_t isr;
123
volatile
uint32_t imr;
124
volatile
uint32_t chip_select;
125
volatile
uint32_t flag_status;
126
volatile
uint32_t dev_id_0;
127
volatile
uint32_t dev_id_1;
128
volatile
uint32_t dev_id_2;
129
volatile
uint32_t dev_id_3;
130
volatile
uint32_t dev_id_4;
131
132
133
#define EPCQ_REGS \
134
(( volatile altera_avalon_epcq_regs* )EPCQ_CONTROLLER_AVL_CSR_BASE )
135
#define EPCQ_MEM \
136
(( volatile uint8_t* )EPCQ_CONTROLLER_AVL_MEM_BASE )
137
#define EPCQ_MEM_32 \
138
(( volatile uint32_t* )EPCQ_CONTROLLER_AVL_MEM_BASE )
139
140
void
epcq_initialize(
void
141
int
epcq_read_buffer(
int
offset, uint8_t *dest_addr,
int
length );
142
int
epcq_write_buffer (
143
int
offset,
144
const
uint8_t* src_addr,
145
int
length,
146
bool
erase
147
148
149
#ifdef __cplusplus
150
151
#endif
152
153
#endif
Definition:
altera_avalon_epcq_regs.h:117
