6.4. Documentation Guidelines
6.4.1. Application Configuration Options
Add at least an index entry and a label for the configuration option. Use a pattern of CONFIGURE_[A-Z0-9_]+ for the option name. Use the following template for application configuration feature options:
.. index:: CONFIGURE_FEATURE
.. _CONFIGURE_FEATURE:
CONFIGURE_FEATURE
CONSTANT:
    ``CONFIGURE_FEATURE``
OPTION TYPE:
    This configuration option is a boolean feature define.
DEFAULT CONFIGURATION:
    If this configuration option is undefined, then the described feature is not
    enabled.
DESCRIPTION:
    In case this configuration option is defined, then feature happens.
NOTES:
    Keep the description short.  Add all special cases, usage notes, error
    conditions, configuration dependencies, references, etc. here to the notes.
Use the following template for application configuration integer and initializer options:
.. index:: CONFIGURE_VALUE
.. _CONFIGURE_VALUE:
CONFIGURE_VALUE
CONSTANT:
    ``CONFIGURE_VALUE``
OPTION TYPE:
    This configuration option is an integer (or initializer) define.
DEFAULT VALUE:
    The default value is X.
VALUE CONSTRAINTS:
    The value of this configuration option shall satisfy all of the following
    constraints:
    * It shall be greater than or equal to A.
    * It shall be less than or equal to B.
    * It shall meet C.
DESCRIPTION:
    The value of this configuration option defines the Y of Z in W.
NOTES:
