RTEMS 5.2-rc1
18# define _dist_code z__dist_code
19# define _length_code z__length_code
20# define _tr_align z__tr_align
21# define _tr_flush_block z__tr_flush_block
22# define _tr_init z__tr_init
23# define _tr_stored_block z__tr_stored_block
24# define _tr_tally z__tr_tally
25# define adler32 z_adler32
26# define adler32_combine z_adler32_combine
27# define adler32_combine64 z_adler32_combine64
28# define compress z_compress
29# define compress2 z_compress2
30# define compressBound z_compressBound
32# define crc32_combine z_crc32_combine
33# define crc32_combine64 z_crc32_combine64
34# define deflate z_deflate
35# define deflateBound z_deflateBound
36# define deflateCopy z_deflateCopy
37# define deflateEnd z_deflateEnd
38# define deflateInit2_ z_deflateInit2_
39# define deflateInit_ z_deflateInit_
40# define deflateParams z_deflateParams
41# define deflatePrime z_deflatePrime
42# define deflateReset z_deflateReset
43# define deflateSetDictionary z_deflateSetDictionary
44# define deflateSetHeader z_deflateSetHeader
45# define deflateTune z_deflateTune
46# define deflate_copyright z_deflate_copyright
47# define get_crc_table z_get_crc_table
48# define gz_error z_gz_error
49# define gz_intmax z_gz_intmax
50# define gz_strwinerror z_gz_strwinerror
51# define gzbuffer z_gzbuffer
52# define gzclearerr z_gzclearerr
53# define gzclose z_gzclose
54# define gzclose_r z_gzclose_r
55# define gzclose_w z_gzclose_w
56# define gzdirect z_gzdirect
57# define gzdopen z_gzdopen
59# define gzerror z_gzerror
60# define gzflush z_gzflush
61# define gzgetc z_gzgetc
62# define gzgets z_gzgets
63# define gzoffset z_gzoffset
64# define gzoffset64 z_gzoffset64
65# define gzopen z_gzopen
66# define gzopen64 z_gzopen64
67# define gzprintf z_gzprintf
68# define gzputc z_gzputc
69# define gzputs z_gzputs
70# define gzread z_gzread
71# define gzrewind z_gzrewind
72# define gzseek z_gzseek
73# define gzseek64 z_gzseek64
74# define gzsetparams z_gzsetparams
75# define gztell z_gztell
76# define gztell64 z_gztell64
77# define gzungetc z_gzungetc
78# define gzwrite z_gzwrite
79# define inflate z_inflate
80# define inflateBack z_inflateBack
81# define inflateBackEnd z_inflateBackEnd
82# define inflateBackInit_ z_inflateBackInit_
83# define inflateCopy z_inflateCopy
84# define inflateEnd z_inflateEnd
85# define inflateGetHeader z_inflateGetHeader
86# define inflateInit2_ z_inflateInit2_
87# define inflateInit_ z_inflateInit_
88# define inflateMark z_inflateMark
89# define inflatePrime z_inflatePrime
90# define inflateReset z_inflateReset
91# define inflateReset2 z_inflateReset2
92# define inflateSetDictionary z_inflateSetDictionary
93# define inflateSync z_inflateSync
94# define inflateSyncPoint z_inflateSyncPoint
95# define inflateUndermine z_inflateUndermine
96# define inflate_copyright z_inflate_copyright
97# define inflate_fast z_inflate_fast
98# define inflate_table z_inflate_table
99# define uncompress z_uncompress
100# define zError z_zError
101# define zcalloc z_zcalloc
102# define zcfree z_zcfree
103# define zlibCompileFlags z_zlibCompileFlags
104# define zlibVersion z_zlibVersion
108# define Bytef z_Bytef
109# define alloc_func z_alloc_func
110# define charf z_charf
111# define free_func z_free_func
112# define gzFile z_gzFile
113# define gz_header z_gz_header
114# define gz_headerp z_gz_headerp
115# define in_func z_in_func
117# define out_func z_out_func
119# define uIntf z_uIntf
120# define uLong z_uLong
121# define uLongf z_uLongf
122# define voidp z_voidp
123# define voidpc z_voidpc
124# define voidpf z_voidpf
127# define gz_header_s z_gz_header_s
128# define internal_state z_internal_state
132#if defined(__MSDOS__) && !defined(MSDOS)
135#if (defined(OS_2) || defined(__OS2__)) && !defined(OS2)
138#if defined(_WINDOWS) && !defined(WINDOWS)
141#if defined(_WIN32) || defined(_WIN32_WCE) || defined(__WIN32__)
146#if (defined(MSDOS) || defined(OS2) || defined(WINDOWS)) && !defined(WIN32)
147# if !defined(__GNUC__) && !defined(__FLAT__) && !defined(__386__)
165#ifdef __STDC_VERSION__
169# if __STDC_VERSION__ >= 199901L
175#if !defined(STDC) && (defined(__STDC__) || defined(__cplusplus))
178#if !defined(STDC) && (defined(__GNUC__) || defined(__BORLANDC__))
181#if !defined(STDC) && (defined(MSDOS) || defined(WINDOWS) || defined(WIN32))
184#if !defined(STDC) && (defined(OS2) || defined(__HOS_AIX__))
188#if defined(__OS400__) && !defined(STDC)
199#if defined(__MWERKS__)||defined(applec)||defined(THINK_C)||defined(__SC__)
200# define NO_DUMMY_DECL
206# define MAX_MEM_LEVEL 8
208# define MAX_MEM_LEVEL 9
238# define OF(args) args
251# if defined(M_I86SM) || defined(M_I86MM)
260# if (defined(__SMALL__) || defined(__MEDIUM__))
271#if defined(WINDOWS) || defined(WIN32)
276# if defined(WIN32) && (!defined(__BORLANDC__) || (__BORLANDC__ >= 0x500))
278# define ZEXTERN extern __declspec(dllexport)
280# define ZEXTERN extern __declspec(dllimport)
295# define ZEXPORT WINAPI
297# define ZEXPORTVA WINAPIV
299# define ZEXPORTVA FAR CDECL
304#if defined (__BEOS__)
307# define ZEXPORT __declspec(dllexport)
308# define ZEXPORTVA __declspec(dllexport)
310# define ZEXPORT __declspec(dllimport)
311# define ZEXPORTVA __declspec(dllimport)
317# define ZEXTERN extern
330#if !defined(__MACTYPES__)
331typedef unsigned char Byte;
333typedef unsigned int uInt;
334typedef unsigned long uLong;
338# define Bytef Byte FAR
340 typedef Byte FAR Bytef;
342typedef char FAR charf;
344typedef uInt FAR uIntf;
345typedef uLong FAR uLongf;
348 typedef void const *voidpc;
349 typedef void FAR *voidpf;
352 typedef Byte
const *voidpc;
353 typedef Byte FAR *voidpf;
358# define Z_HAVE_UNISTD_H
362# include <sys/types.h>
371#if -_LARGEFILE64_SOURCE - -1 == 1
372# undef _LARGEFILE64_SOURCE
375#if defined(Z_HAVE_UNISTD_H) || defined(_LARGEFILE64_SOURCE)
381# define z_off_t off_t
395#if defined(_LARGEFILE64_SOURCE) && _LFS64_LARGEFILE-0
396# define z_off64_t off64_t
398# define z_off64_t z_off_t
401#if defined(__OS400__)
411 #pragma map(deflateInit_,"DEIN")
412 #pragma map(deflateInit2_,"DEIN2")
413 #pragma map(deflateEnd,"DEEND")
414 #pragma map(deflateBound,"DEBND")
415 #pragma map(inflateInit_,"ININ")
416 #pragma map(inflateInit2_,"ININ2")
417 #pragma map(inflateEnd,"INEND")
418 #pragma map(inflateSync,"INSY")
419 #pragma map(inflateSetDictionary,"INSEDI")
420 #pragma map(compressBound,"CMBND")
421 #pragma map(inflate_table,"INTABL")
422 #pragma map(inflate_fast,"INFA")
423 #pragma map(inflate_copyright,"INCOPY")
