RTEMS
5.2-rc1
bsps
shared
dev
serial
z85c30_p.h
1
2
* This include file contains all private driver definitions for the
3
* Zilog z85c30.
4
5
* COPYRIGHT (c) 1998 by Radstone Technology
6
7
8
* THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
9
* KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
10
* IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
11
* AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
12
13
* You are hereby granted permission to use, copy, modify, and distribute
14
* this file, provided that this notice, plus the above copyright notice
15
* and disclaimer, appears in all copies. Radstone Technology will provide
16
* no support for this code.
17
18
* COPYRIGHT (c) 1989-1997.
19
* On-Line Applications Research Corporation (OAR).
20
21
* The license and distribution terms for this file may in
22
* the file LICENSE in this distribution or at
23
* http://www.rtems.org/license/LICENSE.
24
25
26
#ifndef __Z85C30_P_H
27
#define __Z85C30_P_H
28
29
#ifdef __cplusplus
30
extern
"C"
31
#endif
32
33
34
* Define Z85C30_STATIC to nothing while debugging so the entry points
35
* will show up in the symbol table.
36
37
38
#define Z85C30_STATIC
39
40
/* #define Z85C30_STATIC static */
41
42
/* bit values for write register 0 */
43
/* command register */
44
45
#define SCC_WR0_SEL_WR0 0x00
46
#define SCC_WR0_SEL_WR1 0x01
47
#define SCC_WR0_SEL_WR2 0x02
48
#define SCC_WR0_SEL_WR3 0x03
49
#define SCC_WR0_SEL_WR4 0x04
50
#define SCC_WR0_SEL_WR5 0x05
51
#define SCC_WR0_SEL_WR6 0x06
52
#define SCC_WR0_SEL_WR7 0x07
53
#define SCC_WR0_SEL_WR8 0x08
54
#define SCC_WR0_SEL_WR9 0x09
55
#define SCC_WR0_SEL_WR10 0x0a
56
#define SCC_WR0_SEL_WR11 0x0b
57
#define SCC_WR0_SEL_WR12 0x0c
58
#define SCC_WR0_SEL_WR13 0x0d
59
#define SCC_WR0_SEL_WR14 0x0e
60
#define SCC_WR0_SEL_WR15 0x0f
61
#define SCC_WR0_SEL_RD0 0x00
62
#define SCC_WR0_SEL_RD1 0x01
63
#define SCC_WR0_SEL_RD2 0x02
64
#define SCC_WR0_SEL_RD3 0x03
65
#define SCC_WR0_SEL_RD4 0x04
66
#define SCC_WR0_SEL_RD5 0x05
67
#define SCC_WR0_SEL_RD6 0x06
68
#define SCC_WR0_SEL_RD7 0x07
69
#define SCC_WR0_SEL_RD8 0x08
70
#define SCC_WR0_SEL_RD9 0x09
71
#define SCC_WR0_SEL_RD10 0x0a
72
#define SCC_WR0_SEL_RD11 0x0b
73
#define SCC_WR0_SEL_RD12 0x0c
74
#define SCC_WR0_SEL_RD13 0x0d
75
#define SCC_WR0_SEL_RD14 0x0e
76
#define SCC_WR0_SEL_RD15 0x0f
77
#define SCC_WR0_NULL_CODE 0x00
78
#define SCC_WR0_RST_INT 0x10
79
#define SCC_WR0_SEND_ABORT 0x18
80
#define SCC_WR0_EN_INT_RX 0x20
81
#define SCC_WR0_RST_TX_INT 0x28
82
#define SCC_WR0_ERR_RST 0x30
83
#define SCC_WR0_RST_HI_IUS 0x38
84
#define SCC_WR0_RST_RX_CRC 0x40
85
#define SCC_WR0_RST_TX_CRC 0x80
86
#define SCC_WR0_RST_TX_UND 0xc0
87
88
/* write register 2 */
89
/* interrupt vector */
90
91
/* bit values for write register 1 */
92
/* tx/rx interrupt and data transfer mode definition */
93
94
#define SCC_WR1_EXT_INT_EN 0x01
95
#define SCC_WR1_TX_INT_EN 0x02
96
#define SCC_WR1_PARITY 0x04
97
#define SCC_WR1_RX_INT_DIS 0x00
98
#define SCC_WR1_RX_INT_FIR 0x08
99
#define SCC_WR1_INT_ALL_RX 0x10
100
#define SCC_WR1_RX_INT_SPE 0x18
101
#define SCC_WR1_RDMA_RECTR 0x20
102
#define SCC_WR1_RDMA_FUNC 0x40
103
#define SCC_WR1_RDMA_EN 0x80
104
105
#define SCC_ENABLE_ALL_INTR \
106
(SCC_WR1_EXT_INT_EN | SCC_WR1_TX_INT_EN | SCC_WR1_INT_ALL_RX)
107
108
#define SCC_DISABLE_ALL_INTR 0x00
109
110
#define SCC_ENABLE_ALL_INTR_EXCEPT_TX \
111
(SCC_WR1_EXT_INT_EN | SCC_WR1_INT_ALL_RX)
112
113
/* bit values for write register 3 */
114
/* receive parameters and control */
115
116
#define SCC_WR3_RX_EN 0x01
117
#define SCC_WR3_SYNC_CHAR 0x02
118
#define SCC_WR3_ADR_SEARCH 0x04
119
#define SCC_WR3_RX_CRC_EN 0x08
120
#define SCC_WR3_ENTER_HUNT 0x10
121
#define SCC_WR3_AUTO_EN 0x20
122
#define SCC_WR3_RX_5_BITS 0x00
123
#define SCC_WR3_RX_7_BITS 0x40
124
#define SCC_WR3_RX_6_BITS 0x80
125
#define SCC_WR3_RX_8_BITS 0xc0
126
127
/* bit values for write register 4 */
128
/* tx/rx misc parameters and modes */
129
130
#define SCC_WR4_PAR_EN 0x01
131
#define SCC_WR4_PAR_EVEN 0x02
132
#define SCC_WR4_SYNC_EN 0x00
133
#define SCC_WR4_1_STOP 0x04
134
#define SCC_WR4_2_STOP 0x0c
135
#define SCC_WR4_8_SYNC 0x00
136
#define SCC_WR4_16_SYNC 0x10
137
#define SCC_WR4_SDLC 0x20
138
#define SCC_WR4_EXT_SYNC 0x30
139
#define SCC_WR4_1_CLOCK 0x00
140
#define SCC_WR4_16_CLOCK 0x40
141
#define SCC_WR4_32_CLOCK 0x80
142
#define SCC_WR4_64_CLOCK 0xc0
143
144
/* bit values for write register 5 */
145
/* transmit parameter and controls */
146
147
#define SCC_WR5_TX_CRC_EN 0x01
148
#define SCC_WR5_RTS 0x02
149
#define SCC_WR5_SDLC 0x04
150
#define SCC_WR5_TX_EN 0x08
151
#define SCC_WR5_SEND_BRK 0x10
152
153
#define SCC_WR5_TX_5_BITS 0x00
154
#define SCC_WR5_TX_7_BITS 0x20
155
#define SCC_WR5_TX_6_BITS 0x40
156
#define SCC_WR5_TX_8_BITS 0x60
157
#define SCC_WR5_DTR 0x80
158
159
/* write register 6 */
160
/* sync chars or sdlc address field */
161
162
/* write register 7 */
163
/* sync char or sdlc flag */
164
165
/* write register 8 */
166
/* transmit buffer */
167
168
/* bit values for write register 9 */
169
/* master interrupt control */
170
171
#define SCC_WR9_VIS 0x01
172
#define SCC_WR9_NV 0x02
173
#define SCC_WR9_DLC 0x04
174
#define SCC_WR9_MIE 0x08
175
#define SCC_WR9_STATUS_HI 0x10
176
#define SCC_WR9_NO_RST 0x00
177
#define SCC_WR9_CH_B_RST 0x40
178
#define SCC_WR9_CH_A_RST 0x80
179
#define SCC_WR9_HDWR_RST 0xc0
180
181
/* bit values for write register 10 */
182
/* misc tx/rx control bits */
183
184
#define SCC_WR10_6_BIT_SYNC 0x01
185
#define SCC_WR10_LOOP_MODE 0x02
186
#define SCC_WR10_ABORT_UND 0x04
187
#define SCC_WR10_MARK_IDLE 0x08
188
#define SCC_WR10_ACT_POLL 0x10
189
#define SCC_WR10_NRZ 0x00
190
#define SCC_WR10_NRZI 0x20
191
#define SCC_WR10_FM1 0x40
192
#define SCC_WR10_FM0 0x60
193
#define SCC_WR10_CRC_PRESET 0x80
194
195
/* bit values for write register 11 */
196
/* clock mode control */
197
198
#define SCC_WR11_OUT_XTAL 0x00
199
#define SCC_WR11_OUT_TX_CLK 0x01
200
#define SCC_WR11_OUT_BR_GEN 0x02
201
#define SCC_WR11_OUT_DPLL 0x03
202
#define SCC_WR11_TRXC_OI 0x04
203
#define SCC_WR11_TX_RTXC 0x00
204
#define SCC_WR11_TX_TRXC 0x08
205
#define SCC_WR11_TX_BR_GEN 0x10
206
#define SCC_WR11_TX_DPLL 0x18
207
#define SCC_WR11_RX_RTXC 0x00
208
#define SCC_WR11_RX_TRXC 0x20
209
#define SCC_WR11_RX_BR_GEN 0x40
210
#define SCC_WR11_RX_DPLL 0x60
211
#define SCC_WR11_RTXC_XTAL 0x80
212
213
/* write register 12 */
214
/* lower byte of baud rate generator time constant */
215
216
/* write register 13 */
217
/* upper byte of baud rate generator time constant */
218
219
/* bit values for write register 14 */
220
/* misc control bits */
221
222
#define SCC_WR14_BR_EN 0x01
223
#define SCC_WR14_BR_SRC 0x02
224
#define SCC_WR14_DTR_FUNC 0x04
225
#define SCC_WR14_AUTO_ECHO 0x08
226
#define SCC_WR14_LCL_LOOP 0x10
227
#define SCC_WR14_NULL 0x00
228
#define SCC_WR14_SEARCH 0x20
229
#define SCC_WR14_RST_CLK 0x40
230
#define SCC_WR14_DIS_DPLL 0x60
231
#define SCC_WR14_SRC_BR 0x80
232
#define SCC_WR14_SRC_RTXC 0xa0
233
#define SCC_WR14_FM_MODE 0xc0
234
#define SCC_WR14_NRZI 0xe0
235
236
/* bit values for write register 15 */
237
/* external/status interrupt control */
238
239
#define SCC_WR15_ZERO_CNT 0x02
240
#define SCC_WR15_CD_IE 0x08
241
#define SCC_WR15_SYNC_IE 0x10
242
#define SCC_WR15_CTS_IE 0x20
243
#define SCC_WR15_TX_UND_IE 0x40
244
#define SCC_WR15_BREAK_IE 0x80
245
246
/* bit values for read register 0 */
247
/* tx/rx buffer status and external status */
248
249
#define SCC_RR0_RX_AVAIL 0x01
250
#define SCC_RR0_ZERO_CNT 0x02
251
#define SCC_RR0_TX_EMPTY 0x04
252
#define SCC_RR0_CD 0x08
253
#define SCC_RR0_SYNC 0x10
254
#define SCC_RR0_CTS 0x20
255
#define SCC_RR0_TX_UND 0x40
256
#define SCC_RR0_BREAK 0x80
257
258
/* bit values for read register 1 */
259
260
#define SCC_RR1_ALL_SENT 0x01
261
#define SCC_RR1_RES_CD_2 0x02
262
#define SCC_RR1_RES_CD_1 0x01
263
#define SCC_RR1_RES_CD_0 0x08
264
#define SCC_RR1_PAR_ERR 0x10
265
#define SCC_RR1_RX_OV_ERR 0x20
266
#define SCC_RR1_CRC_ERR 0x40
267
#define SCC_RR1_END_FRAME 0x80
268
269
/* read register 2 */
270
271
272
/* bit values for read register 3 */
273
/* interrupt pending register */
274
275
#define SCC_RR3_B_EXT_IP 0x01
276
#define SCC_RR3_B_TX_IP 0x02
277
#define SCC_RR3_B_RX_IP 0x04
278
#define SCC_RR3_A_EXT_IP 0x08
279
#define SCC_RR3_A_TX_IP 0x10
280
#define SCC_RR3_A_RX_IP 0x20
281
282
/* read register 8 */
283
/* receive data register */
284
285
/* bit values for read register 10 */
286
/* misc status bits */
287
288
#define SCC_RR10_ON_LOOP 0x02
289
#define SCC_RR10_LOOP_SEND 0x10
290
#define SCC_RR10_2_CLK_MIS 0x40
291
#define SCC_RR10_1_CLK_MIS 0x80
292
293
/* read register 12 */
294
/* lower byte of time constant */
295
296
/* read register 13 */
297
/* upper byte of time constant */
298
299
/* bit values for read register 15 */
300
/* external/status ie bits */
301
302
#define SCC_RR15_ZERO_CNT 0x02
303
#define SCC_RR15_CD_IE 0x08
304
#define SCC_RR15_SYNC_IE 0x10
305
#define SCC_RR15_CTS_IE 0x20
306
#define SCC_RR15_TX_UND_IE 0x40
307
#define SCC_RR15_BREAK_IE 0x80
308
309
typedef
struct
_z85c30_context
310
311
uint8_t ucModemCtrl;
312
z85c30_context
313
314
315
* The following macro calculates the Baud constant. For the Z85C30 chip.
316
317
* Note: baud constant = ((clock frequency / Clock_X) / (2 * Baud Rate)) - 2
318
* eg ((10,000,000 / 16) / (2 * Baud Rate)) - 2
319
320
321
#define Z85C30_Baud( _clock, _baud_rate ) \
322
( ((_clock) /( 16 * 2 * _baud_rate)) - 2)
323
324
#define Z85C30_Status_Is_RX_character_available(_status) \
325
((_status) & SCC_RR0_RX_AVAIL)
326
327
#define Z85C30_Status_Is_TX_buffer_empty(_status) \
328
((_status) & SCC_RR0_TX_EMPTY)
329
330
#define Z85C30_Status_Is_CTS_asserted(_status) \
331
((_status) & SCC_RR0_CTS)
332
333
#define Z85C30_Status_Is_break_abort(_status) \
334
((_status) & SCC_RR0_BREAK)
335
336
337
* Private routines
338
339
340
Z85C30_STATIC
void
z85c30_initialize_port(
341
int
minor
342
343
344
Z85C30_STATIC
void
z85c30_init(
int
minor);
345
346
Z85C30_STATIC
int
z85c30_set_attributes(
347
int
minor,
348
const
struct
termios *t
349
350
351
Z85C30_STATIC
int
z85c30_open(
352
int
major,
353
int
minor,
354
void
* arg
355
356
357
Z85C30_STATIC
int
z85c30_close(
358
int
major,
359
int
minor,
360
void
* arg
361
362
363
Z85C30_STATIC
void
z85c30_write_polled(
364
int
minor,
365
char
cChar
366
367
368
Z85C30_STATIC
int
z85c30_assert_RTS(
369
int
minor
370
371
372
Z85C30_STATIC
int
z85c30_negate_RTS(
373
int
minor
374
375
376
Z85C30_STATIC
int
z85c30_assert_DTR(
377
int
minor
378
379
380
Z85C30_STATIC
int
z85c30_negate_DTR(
381
int
minor
382
383
384
Z85C30_STATIC
void
z85c30_initialize_interrupts(
int
minor);
385
386
Z85C30_STATIC ssize_t z85c30_write_support_int(
387
int
minor,
388
const
char
*buf,
389
size_t
len
390
391
392
Z85C30_STATIC ssize_t z85c30_write_support_polled(
393
int
minor,
394
const
char
*buf,
395
size_t
len
396
397
398
Z85C30_STATIC
int
z85c30_inbyte_nonblocking_polled(
399
int
minor
400
401
402
Z85C30_STATIC
void
z85c30_enable_interrupts(
403
int
minor,
404
int
interrupt_mask
405
406
407
Z85C30_STATIC
void
z85c30_process(
408
int
minor,
409
uint8_t ucIntPend
410
411
412
Z85C30_STATIC
rtems_isr
z85c30_isr(
413
rtems_vector_number
vector
414
415
416
#ifdef __cplusplus
417
418
#endif
419
420
#endif
rtems_isr
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition:
intr.h:52
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
_z85c30_context
Definition:
z85c30_p.h:310
