RTEMS 5.2-rc1
xz_private.h
1/*
2 * Private includes and definitions
3 *
4 * Author: Lasse Collin <lasse.collin@tukaani.org>
5 *
6 * This file has been put into the public domain.
7 * You can do whatever you want with this file.
8 */
9
10#ifndef XZ_PRIVATE_H
11#define XZ_PRIVATE_H
12
13#ifdef __KERNEL__
14# include <linux/xz.h>
15# include <linux/kernel.h>
16# include <asm/unaligned.h>
17 /* XZ_PREBOOT may be defined only via decompress_unxz.c. */
18# ifndef XZ_PREBOOT
19# include <linux/slab.h>
20# include <linux/vmalloc.h>
21# include <linux/string.h>
22# ifdef CONFIG_XZ_DEC_X86
23# define XZ_DEC_X86
24# endif
25# ifdef CONFIG_XZ_DEC_POWERPC
26# define XZ_DEC_POWERPC
27# endif
28# ifdef CONFIG_XZ_DEC_IA64
29# define XZ_DEC_IA64
30# endif
31# ifdef CONFIG_XZ_DEC_ARM
32# define XZ_DEC_ARM
33# endif
34# ifdef CONFIG_XZ_DEC_ARMTHUMB
35# define XZ_DEC_ARMTHUMB
36# endif
37# ifdef CONFIG_XZ_DEC_SPARC
38# define XZ_DEC_SPARC
39# endif
40# define memeq(a, b, size) (memcmp(a, b, size) == 0)
41# define memzero(buf, size) memset(buf, 0, size)
42# endif
43# define get_le32(p) le32_to_cpup((const uint32_t *)(p))
44#else
45 /*
46 * For userspace builds, use a separate header to define the required
47 * macros and functions. This makes it easier to adapt the code into
48 * different environments and avoids clutter in the Linux kernel tree.
49 */
50# include "xz_config.h"
51#endif
52
53/* If no specific decoding mode is requested, enable support for all modes. */
54#if !defined(XZ_DEC_SINGLE) && !defined(XZ_DEC_PREALLOC) \
55 && !defined(XZ_DEC_DYNALLOC)
56# define XZ_DEC_SINGLE
57# define XZ_DEC_PREALLOC
58# define XZ_DEC_DYNALLOC
59#endif
60
61/*
62 * The DEC_IS_foo(mode) macros are used in "if" statements. If only some
63 * of the supported modes are enabled, these macros will evaluate to true or
64 * false at compile time and thus allow the compiler to omit unneeded code.
65 */
66#ifdef XZ_DEC_SINGLE
67# define DEC_IS_SINGLE(mode) ((mode) == XZ_SINGLE)
68#else
69# define DEC_IS_SINGLE(mode) (false)
70#endif
71
72#ifdef XZ_DEC_PREALLOC
73# define DEC_IS_PREALLOC(mode) ((mode) == XZ_PREALLOC)
74#else
75# define DEC_IS_PREALLOC(mode) (false)
76#endif
77
78#ifdef XZ_DEC_DYNALLOC
79# define DEC_IS_DYNALLOC(mode) ((mode) == XZ_DYNALLOC)
80#else
81# define DEC_IS_DYNALLOC(mode) (false)
82#endif
83
84#if !defined(XZ_DEC_SINGLE)
85# define DEC_IS_MULTI(mode) (true)
86#elif defined(XZ_DEC_PREALLOC) || defined(XZ_DEC_DYNALLOC)
87# define DEC_IS_MULTI(mode) ((mode) != XZ_SINGLE)
88#else
89# define DEC_IS_MULTI(mode) (false)
90#endif
91
92/*
93 * If any of the BCJ filter decoders are wanted, define XZ_DEC_BCJ.
94 * XZ_DEC_BCJ is used to enable generic support for BCJ decoders.
95 */
96#ifndef XZ_DEC_BCJ
97# if defined(XZ_DEC_X86) || defined(XZ_DEC_POWERPC) \
98 || defined(XZ_DEC_IA64) || defined(XZ_DEC_ARM) \
99 || defined(XZ_DEC_ARM) || defined(XZ_DEC_ARMTHUMB) \
100 || defined(XZ_DEC_SPARC)
101# define XZ_DEC_BCJ
102# endif
103#endif
104
105/*
106 * Allocate memory for LZMA2 decoder. xz_dec_lzma2_reset() must be used
107 * before calling xz_dec_lzma2_run().
108 */
109XZ_EXTERN struct xz_dec_lzma2 *xz_dec_lzma2_create(enum xz_mode mode,
110 uint32_t dict_max);
111
112/*
113 * Decode the LZMA2 properties (one byte) and reset the decoder. Return
114 * XZ_OK on success, XZ_MEMLIMIT_ERROR if the preallocated dictionary is not
115 * big enough, and XZ_OPTIONS_ERROR if props indicates something that this
116 * decoder doesn't support.
117 */
118XZ_EXTERN enum xz_ret xz_dec_lzma2_reset(struct xz_dec_lzma2 *s,
119 uint8_t props);
120
121/* Decode raw LZMA2 stream from b->in to b->out. */
122XZ_EXTERN enum xz_ret xz_dec_lzma2_run(struct xz_dec_lzma2 *s,
123 struct xz_buf *b);
124
125/* Free the memory allocated for the LZMA2 decoder. */
126XZ_EXTERN void xz_dec_lzma2_end(struct xz_dec_lzma2 *s);
127
128#ifdef XZ_DEC_BCJ
129/*
130 * Allocate memory for BCJ decoders. xz_dec_bcj_reset() must be used before
131 * calling xz_dec_bcj_run().
132 */
133XZ_EXTERN struct xz_dec_bcj *xz_dec_bcj_create(bool single_call);
134
135/*
136 * Decode the Filter ID of a BCJ filter. This implementation doesn't
137 * support custom start offsets, so no decoding of Filter Properties
138 * is needed. Returns XZ_OK if the given Filter ID is supported.
139 * Otherwise XZ_OPTIONS_ERROR is returned.
140 */
141XZ_EXTERN enum xz_ret xz_dec_bcj_reset(struct xz_dec_bcj *s, uint8_t id);
142
143/*
144 * Decode raw BCJ + LZMA2 stream. This must be used only if there actually is
145 * a BCJ filter in the chain. If the chain has only LZMA2, xz_dec_lzma2_run()
146 * must be called directly.
147 */
148XZ_EXTERN enum xz_ret xz_dec_bcj_run(struct xz_dec_bcj *s,
149 struct xz_dec_lzma2 *lzma2,
150 struct xz_buf *b);
151
152/* Free the memory allocated for the BCJ filters. */
153#define xz_dec_bcj_end(s) kfree(s)
154#endif
155
156#endif
Definition: xz.h:140
Definition: xz_dec_lzma2.c:253
