RTEMS 5.2-rc1
xilinx-axi-i2c.h
1/*
2 * Copyright (c) 2016-2017 Chris Johns <chrisj@rtems.org> All rights reserved.
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
8
9/*
10 * Xilinx AXI IIC Interface v2.0. See PG090.pdf.
11 *
12 * Note, only master support is provided and no dynamic mode by design.
13 *
14 * The clock set up is to be handled by the IP integrator. There are too many
15 * factors handling this in software.
16 */
17
18
19#ifndef XILINX_AXI_I2C_H
20#define XILINX_AXI_I2C_H
21
22#include <dev/i2c/i2c.h>
23
24/*
25 * The PL integrator controls the timing. This interface allows software to
26 * override those settings. It pays to check the timing with ChipScope.
27 *
28 * If you set the AXI bus frequency you can use the clock speed ioctl call to
29 * change the speed dymanically. The ioctl call overrides the defaults passed
30 * in.
31 *
32 * Set the valid mask to the values that are to be set.
33 */
34#define XILINX_AIX_I2C_AXI_CLOCK (1 << 0)
35#define XILINX_AIX_I2C_TSUSTA (1 << 1)
36#define XILINX_AIX_I2C_TSUSTO (1 << 2)
37#define XILINX_AIX_I2C_THDSTA (1 << 3)
38#define XILINX_AIX_I2C_TSUDAT (1 << 4)
39#define XILINX_AIX_I2C_TBUF (1 << 5)
40#define XILINX_AIX_I2C_THIGH (1 << 6)
41#define XILINX_AIX_I2C_TLOW (1 << 7)
42#define XILINX_AIX_I2C_THDDAT (1 << 8)
43#define XILINX_AIX_I2C_ALL_REGS (XILINX_AIX_I2C_TSUSTA | \
44 XILINX_AIX_I2C_TSUSTO | \
45 XILINX_AIX_I2C_THDSTA | \
46 XILINX_AIX_I2C_TSUDAT | \
47 XILINX_AIX_I2C_TBUF | \
48 XILINX_AIX_I2C_THIGH | \
49 XILINX_AIX_I2C_TLOW | \
50 XILINX_AIX_I2C_THDDAT)
51typedef struct
52{
53 uint32_t valid_mask;
54 uint32_t AXI_CLOCK;
55 uint32_t SCL_INERTIAL_DELAY;
56 uint32_t TSUSTA;
57 uint32_t TSUSTO;
58 uint32_t THDSTA;
59 uint32_t TSUDAT;
60 uint32_t TBUF;
61 uint32_t THIGH;
62 uint32_t TLOW;
63 uint32_t THDDAT;
65
66/*
67 * Register the driver.
68 *
69 * The driver can multipex a number of I2C buses (in master mode only) using
70 * the GPO port. The PL designer can use the output pins to select a bus. This
71 * is useful if connecting a number of slave devices that have limit selectable
72 * addresses.
73 *
74 * @param bus_path The driver's device path.
75 * @param register_base AXI base address.
76 * @param irq AXI FPGA interrupt.
77 * @param gpio_address Bits 12:15 of a slave address it written to the GPO.
78 * @param timing Override the default timing. NULL means no changes.
79 */
80int i2c_bus_register_xilinx_aix_i2c(const char* bus_path,
81 uintptr_t register_base,
83 bool ten_gpio,
84 const xilinx_aix_i2c_timing* timing);
85
86#endif
Inter-Integrated Circuit (I2C) Driver API.
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition: intr.h:47
Definition: xilinx-axi-i2c.h:52
