RTEMS 5.2-rc1
wkspacesupport.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_CONFDEFS_WKSPACESUPPORT_H
37#define _RTEMS_CONFDEFS_WKSPACESUPPORT_H
38
39#ifndef __CONFIGURATION_TEMPLATE_h
40#error "Do not include this file directly, use <rtems/confdefs.h> instead"
41#endif
42
43#ifdef CONFIGURE_INIT
44
45#include <rtems/score/heap.h>
46
47#define _Configure_Zero_or_one( _number ) ( ( _number ) != 0 ? 1 : 0 )
48
49#define _Configure_Align_up( _val, _align ) \
50 ( ( ( _val ) + ( _align ) - 1) - ( ( _val ) + ( _align ) - 1 ) % ( _align ) )
51
52#define _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
53 _Configure_Align_up( sizeof( Heap_Block ), CPU_HEAP_ALIGNMENT )
54
55#define _Configure_From_workspace( _size ) \
56 ( (uintptr_t) ( _Configure_Zero_or_one( _size ) \
57 * _Configure_Align_up( \
58 _size + HEAP_BLOCK_HEADER_SIZE, \
59 _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
60 ) ) )
61
62#endif /* CONFIGURE_INIT */
63
64#endif /* _RTEMS_CONFDEFS_WKSPACESUPPORT_H */
Heap Handler API.
