RTEMS 5.2-rc1
uuidd.h
1/*
2 * Definitions used by the uuidd daemon
3 *
4 * Copyright (C) 2007 Theodore Ts'o.
5 *
6 * %Begin-Header%
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, and the entire permission notice in its entirety,
12 * including the disclaimer of warranties.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 * 3. The name of the author may not be used to endorse or promote
17 * products derived from this software without specific prior
18 * written permission.
19 *
20 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
21 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
22 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ALL OF
23 * WHICH ARE HEREBY DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
26 * OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
27 * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
28 * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
29 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
30 * USE OF THIS SOFTWARE, EVEN IF NOT ADVISED OF THE POSSIBILITY OF SUCH
31 * DAMAGE.
32 * %End-Header%
33 */
34
35#ifndef _UUID_UUIDD_H
36#define _UUID_UUIDD_H
37
38#define UUIDD_SOCKET_PATH "/var/lib/libuuid/request"
39#define UUIDD_PIDFILE_PATH "/var/lib/libuuid/uuidd.pid"
40#define UUIDD_PATH "/usr/sbin/uuidd"
41
42#define UUIDD_OP_GETPID 0
43#define UUIDD_OP_GET_MAXOP 1
44#define UUIDD_OP_TIME_UUID 2
45#define UUIDD_OP_RANDOM_UUID 3
46#define UUIDD_OP_BULK_TIME_UUID 4
47#define UUIDD_OP_BULK_RANDOM_UUID 5
48#define UUIDD_MAX_OP UUIDD_OP_BULK_RANDOM_UUID
49
50extern void uuid__generate_time(uuid_t out, int *num);
51extern void uuid__generate_random(uuid_t out, int *num);
52
53#endif /* _UUID_UUID_H */
