RTEMS 5.2-rc1
uti596.h
1/* uti596.h: Contains the defines and structures used by the uti596 driver */
2
3/*
4 * EII: March 11: Created v. 0.0
5 */
6
7#ifndef UTI596_H
8#define UTI596_H
9#include <rtems/error.h>
10#include <rtems/rtems_bsdnet.h>
11
12#include <sys/param.h>
13#include <sys/mbuf.h>
14#include <sys/socket.h>
15#include <sys/sockio.h>
16
17#include <net/if.h>
18
19#include <netinet/in.h>
20#include <netinet/if_ether.h>
21
22/* Ethernet statistics */
23
25 int rx_packets; /* total packets received */
26 int tx_packets; /* total packets transmitted */
27 int rx_errors; /* bad packets received */
28 int tx_errors; /* packet transmit problems */
29 int rx_dropped; /* no space in buffers */
30 int tx_dropped;
31 int tx_retries_exceeded; /* excessive retries */
32 int multicast; /* multicast packets received */
33 int collisions;
34
35 /* detailed rx_errors: */
36 int rx_length_errors;
37 int rx_over_errors; /* receiver ring buff overflow */
38 int rx_crc_errors; /* recved pkt with crc error */
39 int rx_frame_errors; /* recv'd frame alignment error */
40 int rx_fifo_errors; /* recv'r fifo overrun */
41 int rx_missed_errors; /* receiver missed packet */
42
43 /* detailed tx_errors */
44 int tx_aborted_errors;
45 int tx_carrier_errors;
46 int tx_fifo_errors;
47 int tx_heartbeat_errors;
48 int tx_window_errors;
49
50 /* NIC reset errors */
51 int nic_reset_count; /* The number of times uti596reset() has been called. */
52};
53
54#define CMD_EOL 0x8000 /* The last command of the list, stop. */
55#define CMD_SUSP 0x4000 /* Suspend after doing cmd. */
56#define CMD_INTR 0x2000 /* Interrupt after doing cmd. */
57
58#define CMD_FLEX 0x0008 /* Enable flexible memory model */
59
60#define SCB_STAT_CX 0x8000 /* Cmd completes with 'I' bit set */
61#define SCB_STAT_FR 0x4000 /* Frame Received */
62#define SCB_STAT_CNA 0x2000 /* Cmd unit Not Active */
63#define SCB_STAT_RNR 0x1000 /* Receiver Not Ready */
64
65#define SCB_CUS_SUSPENDED 0x0100
66#define SCB_CUS_ACTIVE 0x0200
67
68#define STAT_C 0x8000 /* Set to 1 after execution */
69#define STAT_B 0x4000 /* 1 : Cmd being executed, 0 : Cmd done. */
70#define STAT_OK 0x2000 /* 1: Command executed ok 0 : Error */
71#define STAT_A 0x1000 /* command has been aborted */
72
73#define STAT_S11 0x0800
74#define STAT_S10 0x0400
75#define STAT_S9 0x0200
76#define STAT_S8 0x0100
77#define STAT_S7 0x0080
78#define STAT_S6 0x0040
79#define STAT_S5 0x0020
80#define STAT_MAX_COLLS 0x000F
81
82#define RBD_STAT_P 0x4000 /* prefetch */
83#define RBD_STAT_F 0x4000 /* used */
84
85#define CUC_START 0x0100
86#define CUC_RESUME 0x0200
87#define CUC_SUSPEND 0x0300
88#define CUC_ABORT 0x0400
89#define RX_START 0x0010
90#define RX_RESUME 0x0020
91#define RX_SUSPEND 0x0030
92#define RX_ABORT 0x0040
93
94#define RU_SUSPENDED 0x0010
95#define RU_NO_RESOURCES 0x0020
96#define RU_READY 0x0040
97
98#define I596_NULL ( ( void * ) 0xffffffff)
99#define UTI_596_END_OF_FRAME 0x8000
100
101struct i596_tbd; /* necessary forward declaration */
102
103enum commands {
104 CmdNOp = 0,
105 CmdSASetup = 1,
106 CmdConfigure = 2,
107 CmdMulticastList = 3,
108 CmdTx = 4,
109 CmdTDR = 5,
110 CmdDump = 6,
111 CmdDiagnose = 7
112};
113
114/*
115 * 82596 Dump Command Result
116 */
117typedef volatile struct i596_dump_result {
118 unsigned char bf;
119 unsigned char config_bytes[11];
120 unsigned char reserved1[2];
121 unsigned char ia_bytes[6];
122 unsigned short last_tx_status;
123 unsigned short tx_crc_byte01;
124 unsigned short tx_crc_byte23;
125 unsigned short rx_crc_byte01;
126 unsigned short rx_crc_byte23;
127 unsigned short rx_temp_mem01;
128 unsigned short rx_temp_mem23;
129 unsigned short rx_temp_mem45;
130 unsigned short last_rx_status;
131 unsigned short hash_reg01;
132 unsigned short hash_reg23;
133 unsigned short hash_reg45;
134 unsigned short hash_reg67;
135 unsigned short slot_time_counter;
136 unsigned short wait_time_counter;
137 unsigned short rx_frame_length;
138 unsigned long reserved2;
139 unsigned long cb_in3;
140 unsigned long cb_in2;
141 unsigned long cb_in1;
142 unsigned long la_cb_addr;
143 unsigned long rdb_pointer;
144 unsigned long int_memory;
145 unsigned long rfd_size;
146 unsigned long tbd_pointer;
147 unsigned long base_addr;
148 unsigned long ru_temp_reg;
149 unsigned long tcb_count;
150 unsigned long next_rb_size;
151 unsigned long next_rb_addr;
152 unsigned long curr_rb_size;
153 unsigned long la_rbd_addr;
154 unsigned long next_rbd_addr;
155 unsigned long curr_rbd_addr;
156 unsigned long curr_rb_count;
157 unsigned long next_fd_addr;
158 unsigned long curr_fd_add;
159 unsigned long temp_cu_reg;
160 unsigned long next_tb_count;
161 unsigned long buffer_addr;
162 unsigned long la_tbd_addr;
163 unsigned long next_tbd_addr;
164 unsigned long cb_command;
165 unsigned long next_cb_addr;
166 unsigned long curr_cb_addr;
167 unsigned long scb_cmd_word;
168 unsigned long scb_pointer;
169 unsigned long cb_stat_word;
170 unsigned long mm_lfsr;
171 unsigned char micro_machine_bit_array[28];
172 unsigned char cu_port[16];
173 unsigned long mm_alu;
174 unsigned long reserved3;
175 unsigned long mm_temp_a_rr;
176 unsigned long mm_temp_a;
177 unsigned long tx_dma_b_cnt;
178 unsigned long mm_input_port_addr_reg;
179 unsigned long tx_dma_addr;
180 unsigned long mm_port_reg1;
181 unsigned long rx_dma_b_cnt;
182 unsigned long mm_port_reg2;
183 unsigned long rx_dma_addr;
184 unsigned long reserved4;
185 unsigned long bus_t_timers;
186 unsigned long diu_cntrl_reg;
187 unsigned long reserved5;
188 unsigned long sysbus;
189 unsigned long biu_cntrl_reg;
190 unsigned long mm_disp_reg;
191 unsigned long mm_status_reg;
192 unsigned short dump_status;
194
195typedef volatile struct i596_selftest {
196 unsigned long rom_signature;
197 unsigned long results;
199
200/*
201 * Action commands
202 * (big endian, linear mode)
203 */
204typedef volatile struct i596_cmd {
205 unsigned short status;
206 unsigned short command;
207 volatile struct i596_cmd *next;
208} i596_cmd;
209
210typedef volatile struct i596_nop {
211 i596_cmd cmd;
212} i596_nop;
213
214typedef volatile struct i596_set_add {
215 i596_cmd cmd;
216 char data[8];
218
219typedef volatile struct i596_configure {
220 i596_cmd cmd;
221 char data[16];
223
224typedef volatile struct i596_tx {
225 i596_cmd cmd;
226 volatile struct i596_tbd *pTbd;
227 unsigned short count;
228 unsigned short pad;
229 char data[6];
230 unsigned short length;
231} i596_tx;
232
233typedef volatile struct i596_tdr {
234 i596_cmd cmd;
235 unsigned long data;
236} i596_tdr;
237
238typedef volatile struct i596_dump {
239 i596_cmd cmd;
240 char *pData;
241} i596_dump;
242
243/*
244 * Transmit buffer descriptor
245 */
246typedef volatile struct i596_tbd {
247 unsigned short size;
248 unsigned short pad;
249 volatile struct i596_tbd *next;
250 char *data;
251} i596_tbd;
252
253/*
254 * Receive buffer descriptor
255 * (flexible memory structure)
256 */
257typedef volatile struct i596_rbd {
258 unsigned short count;
259 unsigned short offset;
260 volatile struct i596_rbd *next;
261 char *data;
262 unsigned short size;
263 unsigned short pad;
264} i596_rbd;
265
266/*
267 * Receive Frame Descriptor
268 */
269typedef volatile struct i596_rfd {
270 unsigned short stat;
271 unsigned short cmd;
272 volatile struct i596_rfd *next;
273 i596_rbd *pRbd;
274 unsigned short count;
275 unsigned short size;
276 char data [1532];
277} i596_rfd;
278
279/*
280 * System Control Block
281 */
282typedef volatile struct i596_scb {
283 unsigned short status;
284 unsigned short command;
285 unsigned long cmd_pointer;
286 unsigned long rfd_pointer;
287 unsigned long crc_err;
288 unsigned long align_err;
289 unsigned long resource_err;
290 unsigned long over_err;
291 unsigned long rcvdt_err;
292 unsigned long short_err;
293 unsigned short t_off;
294 unsigned short t_on;
295 i596_cmd *pCmd;
296 i596_rfd *pRfd;
297} i596_scb;
298
299/*
300 * Intermediate System Configuration Pointer
301 */
302typedef volatile struct i596_iscp {
303 uint8_t null1; /* Always zero */
304 uint8_t busy; /* Busy byte */
305 unsigned short scb_offset; /* Not used in linear mode */
306 unsigned long scb_pointer; /* Swapped pointer to scb */
307 i596_scb *scb; /* Real pointer to scb */
308} i596_iscp;
309
310/*
311 * System Configuration Pointer
312 */
313typedef volatile struct i596_scp {
314 unsigned long sysbus; /* Only low 8 bits are used */
315 unsigned long pad; /* Must be zero */
316 unsigned long iscp_pointer; /* Swapped pointer to iscp */
317 i596_iscp *iscp; /* Real pointer to iscp */
318} i596_scp;
319
320/*
321 * Device Dependent Data Structure
322 */
323typedef volatile struct uti596_softc {
324 struct arpcom arpcom;
325 i596_scp *pScp; /* Block aligned on 16 byte boundary */
326 i596_scp *base_scp; /* Unaligned block. Need for free() */
327 i596_iscp iscp;
328 i596_scb scb;
329 i596_set_add set_add;
330 i596_configure set_conf;
331 i596_tdr tdr;
333 i596_tx *pTxCmd;
334 i596_tbd *pTbd;
335
336 i596_rfd *pBeginRFA;
337 i596_rfd *pEndRFA;
338 i596_rfd *pLastUnkRFD;
339 i596_rbd *pLastUnkRBD;
340 i596_rfd *pEndSavedQueue;
341 i596_cmd *pCmdHead;
342 i596_cmd *pCmdTail; /* unneeded, as chaining not used, but implemented */
343
344 rtems_id rxDaemonTid;
345 rtems_id txDaemonTid;
346 rtems_id resetDaemonTid;
347
348 struct enet_statistics stats;
349 int started;
350 unsigned long rxInterrupts;
351 unsigned long txInterrupts;
352 volatile int cmdOk;
353 unsigned short * pCurrent_command_status;
354 int resetDone;
355 unsigned long txRawWait;
356 i596_rfd *pInboundFrameQueue;
357 short int rxBdCount;
358 short int txBdCount;
359 short int countRFD;
360 short int savedCount;
361 i596_rfd *pSavedRfdQueue;
362 rtems_name semaphore_name;
363 rtems_id semaphore_id;
364 char zeroes[64];
365 unsigned long rawsndcnt;
366 int nic_reset; /* flag for requesting that ISR issue a reset quest */
368
369#endif /* UTI596_H */
RTEMS Error Reporting.
uint32_t rtems_name
Classic API object name type.
Definition: types.h:77
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
#define nop()
Definition: sparc.h:175
Definition: uti596.h:24
Definition: uti596.h:204
Definition: uti596.h:219
Definition: uti596.h:117
Definition: uti596.h:238
Definition: uti596.h:302
Definition: uti596.h:210
Definition: uti596.h:257
Definition: uti596.h:269
Definition: uti596.h:282
Definition: uti596.h:313
Definition: uti596.h:195
Definition: uti596.h:214
Definition: uti596.h:246
Definition: uti596.h:233
Definition: uti596.h:224
Definition: uti596.h:323
