RTEMS 5.2-rc1
tlib.h
1/*
2 * Timer Library (TLIB)
3 *
4 * The Library rely on timer drivers, the timer presented by the
5 * timer driver must look like a down-counter timer, which generates
6 * interrupt (if configured) when underflown.
7 *
8 * If Timer hardware is an up-counter the Timer driver must recalculate
9 * into values that would match as if it was a down-counter.
10 *
11 * COPYRIGHT (c) 2011.
12 * Cobham Gaisler AB.
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef __TLIB_H__
20#define __TLIB_H__
21
22#ifdef __cplusplus
23extern "C" {
24#endif
25
26struct tlib_dev;
27
28typedef void (*tlib_isr_t)(void *data);
29
30enum {
31 TLIB_FLAGS_BROADCAST = 0x01
32};
33
34struct tlib_drv {
35 /*** Functions ***/
36 void (*reset)(struct tlib_dev *hand);
37 void (*get_freq)(
38 struct tlib_dev *hand,
39 unsigned int *basefreq,
40 unsigned int *tickrate);
41 int (*set_freq)(struct tlib_dev *hand, unsigned int tickrate);
42 void (*irq_reg)(struct tlib_dev *hand, tlib_isr_t func, void *data, int flags);
43 void (*irq_unreg)(struct tlib_dev *hand, tlib_isr_t func,void *data);
44 void (*start)(struct tlib_dev *hand, int once);
45 void (*stop)(struct tlib_dev *hand);
46 void (*restart)(struct tlib_dev *hand);
47 void (*get_counter)(struct tlib_dev *hand, unsigned int *counter);
48 int (*custom)(struct tlib_dev *hand, int cmd, void *arg);
49 int (*int_pend)(struct tlib_dev *hand, int ack);
50 void (*get_widthmask)(struct tlib_dev *hand, unsigned int *widthmask);
51};
52
53struct tlib_dev {
54 struct tlib_dev *next;
55 char status; /* 0=closed, 1=open, 2=timer started */
56 char index; /* Timer Index */
57 tlib_isr_t isr_func;
58 void *isr_data;
59 struct tlib_drv *drv;
60};
61
62#ifdef RTEMS_DRVMGR_STARTUP
63/* Clock Driver Timer register function. Only used when the TLIB-Clock
64 * driver is used. A specific Timer is registered as the System Clock
65 * timer.
66 */
67extern void Clock_timer_register(int timer_number);
68#endif
69
70/* Register Timer. Called by Timer Drivers in order to register
71 * a Timer to the Timer Library. The registration order determines
72 * the Timer Number used in tlib_open() to identify a specific
73 * Timer.
74 */
75extern int tlib_dev_reg(struct tlib_dev *newdev);
76
77/* Allocate a Timer.
78 *
79 * A Timer handle is returned identifying the timer in later calls.
80 */
81extern void *tlib_open(int timer_no);
82
83/* Close Timer */
84extern void tlib_close(void *hand);
85
86/* Returns Number of Timers currently registered to Timer Library */
87extern int tlib_ntimer(void);
88
89static inline void tlib_reset(void *hand)
90{
91 struct tlib_dev *dev = hand;
92
93 dev->drv->reset(dev);
94}
95/* Get Frequencies:
96 * - Base Frequency (unchangable base freq rate of timer, prescaler, clkinput)
97 * - Current Tick Rate [in multiples of Base Frequency]
98 */
99static inline void tlib_get_freq(
100 void *hand,
101 unsigned int *basefreq,
102 unsigned int *tickrate)
103{
104 struct tlib_dev *dev = hand;
105
106 dev->drv->get_freq(dev, basefreq, tickrate);
107}
108
109/* Set current Tick Rate in number of "Base-Frequency ticks" */
110static inline int tlib_set_freq(void *hand, unsigned int tickrate)
111{
112 struct tlib_dev *dev = hand;
113
114 return dev->drv->set_freq(dev, tickrate);
115}
116
117/* Register ISR at Timer ISR */
118static inline void tlib_irq_unregister(void *hand)
119{
120 struct tlib_dev *dev = hand;
121
122 if ( dev->isr_func ) {
123 dev->drv->irq_unreg(dev, dev->isr_func, dev->isr_data);
124 dev->isr_func = NULL;
125 }
126}
127
128/* Register ISR at Timer ISR */
129static inline void tlib_irq_register(void *hand, tlib_isr_t func, void *data, int flags)
130{
131 struct tlib_dev *dev = hand;
132
133 /* Unregister previous ISR if installed */
134 tlib_irq_unregister(hand);
135 dev->isr_func = func;
136 dev->isr_data = data;
137 dev->drv->irq_reg(dev, func, data, flags);
138}
139
140/* Start Timer, ISRs will be generated if enabled.
141 *
142 * once determines if timer should restart (=0) on underflow automatically,
143 * or stop when underflow is reached (=1).
144 */
145static inline void tlib_start(void *hand, int once)
146{
147 struct tlib_dev *dev = hand;
148
149 dev->drv->start(dev, once);
150}
151
152/* Stop Timer, no more ISRs will be generated */
153static inline void tlib_stop(void *hand)
154{
155 struct tlib_dev *dev = hand;
156
157 dev->drv->stop(dev);
158}
159
160/* Restart/Reload Timer, may be usefull if a Watchdog Timer */
161static inline void tlib_restart(void *hand)
162{
163 struct tlib_dev *dev = hand;
164
165 dev->drv->restart(dev);
166}
167
168/* Get current counter value (since last tick) */
169static inline void tlib_get_counter(void *hand, unsigned int *counter)
170{
171 struct tlib_dev *dev = hand;
172
173 dev->drv->get_counter(dev, counter);
174}
175
176/* Do a custom operation */
177static inline void tlib_custom(void *hand, int cmd, void *arg)
178{
179 struct tlib_dev *dev = hand;
180
181 dev->drv->custom(dev, cmd, arg);
182}
183
184static inline int tlib_interrupt_pending(void *hand, int ack)
185{
186 struct tlib_dev *dev = hand;
187
188 return dev->drv->int_pend(dev, ack);
189}
190
191static inline void tlib_get_widthmask(void *hand, unsigned int *widthmask)
192{
193 struct tlib_dev *dev = hand;
194
195 dev->drv->get_widthmask(dev, widthmask);
196}
197
198#ifdef __cplusplus
199}
200#endif
201
202#endif
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Definition: tlib.h:53
Definition: tlib.h:34
