RTEMS 5.2-rc1
timex.h
1/*-
2 ***********************************************************************
3 * *
4 * Copyright (c) David L. Mills 1993-2001 *
5 * Copyright (c) Poul-Henning Kamp 2000-2001 *
6 * *
7 * Permission to use, copy, modify, and distribute this software and *
8 * its documentation for any purpose and without fee is hereby *
9 * granted, provided that the above copyright notice appears in all *
10 * copies and that both the copyright notice and this permission *
11 * notice appear in supporting documentation, and that the name *
12 * University of Delaware not be used in advertising or publicity *
13 * pertaining to distribution of the software without specific, *
14 * written prior permission. The University of Delaware makes no *
15 * representations about the suitability this software for any *
16 * purpose. It is provided "as is" without express or implied *
17 * warranty. *
18 * *
19 ***********************************************************************
20 *
21 * $FreeBSD: head/sys/sys/timex.h 298981 2016-05-03 15:14:17Z pfg $
22 *
23 * This header file defines the Network Time Protocol (NTP) interfaces
24 * for user and daemon application programs.
25 *
26 * This file was originally created 17 Sep 93 by David L. Mills, Professor
27 * of University of Delaware, building on work which had already been ongoing
28 * for a decade and a half at that point in time.
29 *
30 * In 2000 the APIs got a upgrade from microseconds to nanoseconds,
31 * a joint work between Poul-Henning Kamp and David L. Mills.
32 *
33 */
34
35#ifndef _SYS_TIMEX_H_
36#define _SYS_TIMEX_H_ 1
37
38#define NTP_API 4 /* NTP API version */
39
40#ifdef __FreeBSD__
41#include <sys/_timespec.h>
42#endif /* __FreeBSD__ */
43
44/*
45 * The following defines establish the performance envelope of the
46 * kernel discipline loop. Phase or frequency errors greater than
47 * NAXPHASE or MAXFREQ are clamped to these maxima. For update intervals
48 * less than MINSEC, the loop always operates in PLL mode; while, for
49 * update intervals greater than MAXSEC, the loop always operates in FLL
50 * mode. Between these two limits the operating mode is selected by the
51 * STA_FLL bit in the status word.
52 */
53
54#define MAXPHASE 500000000L /* max phase error (ns) */
55#define MAXFREQ 500000L /* max freq error (ns/s) */
56#define MINSEC 256 /* min FLL update interval (s) */
57#define MAXSEC 2048 /* max PLL update interval (s) */
58#define NANOSECOND 1000000000L /* nanoseconds in one second */
59#define SCALE_PPM (65536 / 1000) /* crude ns/s to scaled PPM */
60#define MAXTC 10 /* max time constant */
61
62/*
63 * Control mode codes (timex.modes)
64 */
65#define MOD_OFFSET 0x0001 /* set time offset */
66#define MOD_FREQUENCY 0x0002 /* set frequency offset */
67#define MOD_MAXERROR 0x0004 /* set maximum time error */
68#define MOD_ESTERROR 0x0008 /* set estimated time error */
69#define MOD_STATUS 0x0010 /* set clock status bits */
70#define MOD_TIMECONST 0x0020 /* set PLL time constant */
71#define MOD_PPSMAX 0x0040 /* set PPS maximum averaging time */
72#define MOD_TAI 0x0080 /* set TAI offset */
73#define MOD_MICRO 0x1000 /* select microsecond resolution */
74#define MOD_NANO 0x2000 /* select nanosecond resolution */
75#define MOD_CLKB 0x4000 /* select clock B */
76#define MOD_CLKA 0x8000 /* select clock A */
77
78/*
79 * Status codes (timex.status)
80 */
81#define STA_PLL 0x0001 /* enable PLL updates (rw) */
82#define STA_PPSFREQ 0x0002 /* enable PPS freq discipline (rw) */
83#define STA_PPSTIME 0x0004 /* enable PPS time discipline (rw) */
84#define STA_FLL 0x0008 /* enable FLL mode (rw) */
85#define STA_INS 0x0010 /* insert leap (rw) */
86#define STA_DEL 0x0020 /* delete leap (rw) */
87#define STA_UNSYNC 0x0040 /* clock unsynchronized (rw) */
88#define STA_FREQHOLD 0x0080 /* hold frequency (rw) */
89#define STA_PPSSIGNAL 0x0100 /* PPS signal present (ro) */
90#define STA_PPSJITTER 0x0200 /* PPS signal jitter exceeded (ro) */
91#define STA_PPSWANDER 0x0400 /* PPS signal wander exceeded (ro) */
92#define STA_PPSERROR 0x0800 /* PPS signal calibration error (ro) */
93#define STA_CLOCKERR 0x1000 /* clock hardware fault (ro) */
94#define STA_NANO 0x2000 /* resolution (0 = us, 1 = ns) (ro) */
95#define STA_MODE 0x4000 /* mode (0 = PLL, 1 = FLL) (ro) */
96#define STA_CLK 0x8000 /* clock source (0 = A, 1 = B) (ro) */
97
98#define STA_RONLY (STA_PPSSIGNAL | STA_PPSJITTER | STA_PPSWANDER | \
99 STA_PPSERROR | STA_CLOCKERR | STA_NANO | STA_MODE | STA_CLK)
100
101/*
102 * Clock states (ntptimeval.time_state)
103 */
104#define TIME_OK 0 /* no leap second warning */
105#define TIME_INS 1 /* insert leap second warning */
106#define TIME_DEL 2 /* delete leap second warning */
107#define TIME_OOP 3 /* leap second in progress */
108#define TIME_WAIT 4 /* leap second has occurred */
109#define TIME_ERROR 5 /* error (see status word) */
110
111/*
112 * NTP user interface -- ntp_gettime(2) - used to read kernel clock values
113 */
115 struct timespec time; /* current time (ns) (ro) */
116 long maxerror; /* maximum error (us) (ro) */
117 long esterror; /* estimated error (us) (ro) */
118 long tai; /* TAI offset */
119 int time_state; /* time status */
120};
121
122/*
123 * NTP daemon interface -- ntp_adjtime(2) -- used to discipline CPU clock
124 * oscillator and control/determine status.
125 *
126 * Note: The offset, precision and jitter members are in microseconds if
127 * STA_NANO is zero and nanoseconds if not.
128 */
129struct timex {
130 unsigned int modes; /* clock mode bits (wo) */
131 long offset; /* time offset (ns/us) (rw) */
132 long freq; /* frequency offset (scaled PPM) (rw) */
133 long maxerror; /* maximum error (us) (rw) */
134 long esterror; /* estimated error (us) (rw) */
135 int status; /* clock status bits (rw) */
136 long constant; /* poll interval (log2 s) (rw) */
137 long precision; /* clock precision (ns/us) (ro) */
138 long tolerance; /* clock frequency tolerance (scaled
139 * PPM) (ro) */
140 /*
141 * The following read-only structure members are implemented
142 * only if the PPS signal discipline is configured in the
143 * kernel. They are included in all configurations to insure
144 * portability.
145 */
146 long ppsfreq; /* PPS frequency (scaled PPM) (ro) */
147 long jitter; /* PPS jitter (ns/us) (ro) */
148 int shift; /* interval duration (s) (shift) (ro) */
149 long stabil; /* PPS stability (scaled PPM) (ro) */
150 long jitcnt; /* jitter limit exceeded (ro) */
151 long calcnt; /* calibration intervals (ro) */
152 long errcnt; /* calibration errors (ro) */
153 long stbcnt; /* stability limit exceeded (ro) */
154};
155
156#ifdef __FreeBSD__
157
158#ifdef _KERNEL
159void ntp_update_second(int64_t *adjustment, time_t *newsec);
160#else /* !_KERNEL */
161#include <sys/cdefs.h>
162
163__BEGIN_DECLS
164int ntp_adjtime(struct timex *);
165int ntp_gettime(struct ntptimeval *);
166__END_DECLS
167#endif /* _KERNEL */
168
169#endif /* __FreeBSD__ */
170
171#endif /* !_SYS_TIMEX_H_ */
Definition: timex.h:114
Definition: timex.h:129
