RTEMS 5.2-rc1
timespec.h
1
9/*
10 * Copyright (c) 2012.
11 * Krzysztof Miesowicz <krzysztof.miesowicz@gmail.com>
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_TIMESPEC_H
19#define _RTEMS_TIMESPEC_H
20
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
49 const struct timespec *time
50)
51{
52 return _Timespec_Is_valid(time);
53}
54
68 const struct timespec *lhs,
69 const struct timespec *rhs
70)
71{
72 return _Timespec_Less_than(lhs,rhs);
73}
74
87 struct timespec *time,
88 const struct timespec *add
89)
90{
91 return _Timespec_Add_to(time,add);
92}
93
105 const struct timespec *time
106)
107{
108 return _Timespec_To_ticks(time);
109}
110
122 uint32_t ticks,
123 struct timespec *time
124)
125{
126 _Timespec_From_ticks(ticks,time);
127}
128
142 const struct timespec *start,
143 const struct timespec *end,
144 struct timespec *result
145)
146{
147 _Timespec_Subtract(start,end,result);
148}
149
164 const struct timespec *time,
165 uint32_t iterations,
166 struct timespec *result
167)
168{
169 _Timespec_Divide_by_integer(time,iterations,result);
170}
171
186 const struct timespec *lhs,
187 const struct timespec *rhs,
188 uint32_t *ival_percentage,
189 uint32_t *fval_percentage
190)
191{
192 _Timespec_Divide(lhs,rhs,ival_percentage,fval_percentage);
193}
194
206 struct timespec *_time,
207 time_t _seconds,
208 uint32_t _nanoseconds
209)
210{
211 _Timespec_Set( _time, _seconds, _nanoseconds );
212}
213
223 struct timespec *_time
224)
225{
226 _Timespec_Set_to_zero( _time );
227}
228
239 struct timespec *_time
240)
241{
242 return _Timespec_Get_seconds( _time );
243}
244
255 struct timespec *_time
256)
257{
258 return _Timespec_Get_nanoseconds( _time );
259}
260
273 const struct timespec *_lhs,
274 const struct timespec *_rhs
275)
276{
277 return _Timespec_Greater_than( _lhs, _rhs );
278}
291 const struct timespec *lhs,
292 const struct timespec *rhs
293)
294{
295 return _Timespec_Equal_to( lhs, rhs);
296}
297
300#ifdef __cplusplus
301}
302#endif
303
304#endif
305/* end of include file */
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void rtems_timespec_divide_by_integer(const struct timespec *time, uint32_t iterations, struct timespec *result)
Divide timespec by integer.
Definition: timespec.h:163
RTEMS_INLINE_ROUTINE void rtems_timespec_from_ticks(uint32_t ticks, struct timespec *time)
Convert ticks to timespec.
Definition: timespec.h:121
RTEMS_INLINE_ROUTINE void rtems_timespec_divide(const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage)
Divide timespec.
Definition: timespec.h:185
RTEMS_INLINE_ROUTINE void rtems_timespec_set(struct timespec *_time, time_t _seconds, uint32_t _nanoseconds)
Set timespec to seconds nanosecond.
Definition: timespec.h:205
RTEMS_INLINE_ROUTINE uint32_t rtems_timespec_add_to(struct timespec *time, const struct timespec *add)
Add to a timespec.
Definition: timespec.h:86
RTEMS_INLINE_ROUTINE bool rtems_timespec_greater_than(const struct timespec *_lhs, const struct timespec *_rhs)
Timespec greater than operator.
Definition: timespec.h:272
RTEMS_INLINE_ROUTINE void rtems_timespec_subtract(const struct timespec *start, const struct timespec *end, struct timespec *result)
Subtract two timespec.
Definition: timespec.h:141
RTEMS_INLINE_ROUTINE time_t rtems_timespec_get_seconds(struct timespec *_time)
Get seconds portion of timespec.
Definition: timespec.h:238
RTEMS_INLINE_ROUTINE bool rtems_timespec_equal_to(const struct timespec *lhs, const struct timespec *rhs)
Timespec equal to Operator.
Definition: timespec.h:290
RTEMS_INLINE_ROUTINE uint32_t rtems_timespec_to_ticks(const struct timespec *time)
Convert timespec to number of ticks.
Definition: timespec.h:104
RTEMS_INLINE_ROUTINE void rtems_timespec_zero(struct timespec *_time)
Zero timespec.
Definition: timespec.h:222
RTEMS_INLINE_ROUTINE bool rtems_timespec_is_valid(const struct timespec *time)
Is timespec valid.
Definition: timespec.h:48
RTEMS_INLINE_ROUTINE bool rtems_timespec_less_than(const struct timespec *lhs, const struct timespec *rhs)
Timespec less than operator.
Definition: timespec.h:67
RTEMS_INLINE_ROUTINE uint32_t rtems_timespec_get_nanoseconds(struct timespec *_time)
Get nanoseconds portion of timespec.
Definition: timespec.h:254
void _Timespec_Divide(const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage)
Divides a timespec by another timespec.
Definition: timespecdivide.c:25
bool _Timespec_Less_than(const struct timespec *lhs, const struct timespec *rhs)
Checks if the left hand side timespec is less than the right one.
Definition: timespeclessthan.c:25
uint32_t _Timespec_To_ticks(const struct timespec *time)
Converts timespec to number of ticks.
Definition: timespectoticks.c:27
void _Timespec_From_ticks(uint32_t ticks, struct timespec *time)
Converts ticks to timespec.
Definition: timespecfromticks.c:25
#define _Timespec_Get_nanoseconds(_time)
Definition: timespec.h:93
#define _Timespec_Greater_than(_lhs, _rhs)
The Timespec "greater than" operator.
Definition: timespec.h:150
uint32_t _Timespec_Add_to(struct timespec *time, const struct timespec *add)
Adds two timespecs.
Definition: timespecaddto.c:25
#define _Timespec_Set(_time, _seconds, _nanoseconds)
Definition: timespec.h:52
bool _Timespec_Is_valid(const struct timespec *time)
Checks if timespec is valid.
Definition: timespecisvalid.c:24
void _Timespec_Subtract(const struct timespec *start, const struct timespec *end, struct timespec *result)
Subtracts two timespec.
Definition: timespecsubtract.c:24
#define _Timespec_Equal_to(lhs, rhs)
The Timespec "equal to" operator.
Definition: timespec.h:164
#define _Timespec_Get_seconds(_time)
Definition: timespec.h:81
#define _Timespec_Set_to_zero(_time)
Sets the Timespec to Zero.
Definition: timespec.h:66
void _Timespec_Divide_by_integer(const struct timespec *time, uint32_t iterations, struct timespec *result)
Divides timespec by an integer.
Definition: timespecdividebyinteger.c:25
Contains Helpers for Manipulating Timespecs.
