RTEMS 5.2-rc1
timerdata.h
1
9/*
10 * COPYRIGHT (c) 1989-2011.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Copyright (c) 2009, 2016 embedded brains GmbH.
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef _RTEMS_RTEMS_TIMERDATA_H
21#define _RTEMS_RTEMS_TIMERDATA_H
22
23#include <rtems/rtems/timer.h>
26
27#ifdef __cplusplus
28extern "C" {
29#endif
30
41typedef struct {
51 void *user_data;
59
64
74#define TIMER_INFORMATION_DEFINE( max ) \
75 OBJECTS_INFORMATION_DEFINE( \
76 _Timer, \
77 OBJECTS_CLASSIC_API, \
78 OBJECTS_RTEMS_TIMERS, \
79 Timer_Control, \
80 max, \
81 OBJECTS_NO_STRING_NAME, \
82 NULL \
83 )
84
87#ifdef __cplusplus
88}
89#endif
90
91#endif
92/* end of include file */
Classic Timer Manager API.
Constants and Structures Associated with Watchdog Timers.
Objects_Information _Timer_Information
The Classic Timer objects information.
rtems_timer_service_routine(* rtems_timer_service_routine_entry)(rtems_id, void *)
Definition: timer.h:101
Timer_Classes
Definition: timer.h:56
uint32_t Watchdog_Interval
Type is used to specify the length of intervals.
Definition: watchdogticks.h:38
Object Handler Data Structures.
Definition: objectdata.h:39
The information structure used to manage each API class of objects.
Definition: objectdata.h:176
Definition: timerdata.h:41
Watchdog_Interval stop_time
Definition: timerdata.h:57
Timer_Classes the_class
Definition: timerdata.h:47
Watchdog_Interval start_time
Definition: timerdata.h:55
rtems_timer_service_routine_entry routine
Definition: timerdata.h:49
Watchdog_Interval initial
Definition: timerdata.h:53
Objects_Control Object
Definition: timerdata.h:43
void * user_data
Definition: timerdata.h:51
Watchdog_Control Ticker
Definition: timerdata.h:45
The control block used to manage each watchdog timer.
Definition: watchdog.h:90
