RTEMS 5.2-rc1
termios_printk.h
1/*===============================================================*\
2| Project: RTEMS remote gdb over serial line |
3+-----------------------------------------------------------------+
4| File: termios_printk.h |
5+-----------------------------------------------------------------+
6| Copyright (c) 2002 IMD |
7| Ingenieurbuero fuer Microcomputertechnik Th. Doerfler |
8| <Thomas.Doerfler@imd-systems.de> |
9| all rights reserved |
10+-----------------------------------------------------------------+
11| this file declares intialization functions to add |
12| printk polled output via termios polled drivers |
13| |
14+-----------------------------------------------------------------+
15| date history ID |
16| ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
17| 13.04.02 creation doe |
18\*===============================================================*/
19#ifndef _TERMIOS_PRINTK_H
20#define _TERMIOS_PRINTK_H
21
22#include <rtems.h>
23#include <termios.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29typedef struct {
30 uint32_t baudrate; /* debug baud rate, e.g. 57600 */
31 void (*callout)(void); /* callout pointer during polling */
32 const char *devname; /* debug device, e.g. "/dev/tty01" */
34
35/*
36 * must be defined in init module...
37 */
38extern termios_printk_conf_t termios_printk_conf;
39
40/*=========================================================================*\
41| Function: |
42\*-------------------------------------------------------------------------*/
43void termios_printk_outputchar
44/*-------------------------------------------------------------------------*\
45| Purpose: |
46| send one character to serial port |
47+---------------------------------------------------------------------------+
48| Input Parameters: |
49\*-------------------------------------------------------------------------*/
50(
51 char c /* character to print */
52 );
53/*-------------------------------------------------------------------------*\
54| Return Value: |
55| <none> |
56\*=========================================================================*/
57
58/*=========================================================================*\
59| Function: |
60\*-------------------------------------------------------------------------*/
61int termios_printk_inputchar
62/*-------------------------------------------------------------------------*\
63| Purpose: |
64| wait for one character from serial port |
65+---------------------------------------------------------------------------+
66| Input Parameters: |
67\*-------------------------------------------------------------------------*/
68(
69 void /* none */
70 );
71/*-------------------------------------------------------------------------*\
72| Return Value: |
73| received character |
74\*=========================================================================*/
75
76
77/*=========================================================================*\
78| Function: |
79\*-------------------------------------------------------------------------*/
80int termios_printk_open
81
82/*-------------------------------------------------------------------------*\
83| Purpose: |
84| try to open given serial debug port |
85+---------------------------------------------------------------------------+
86| Input Parameters: |
87\*-------------------------------------------------------------------------*/
88(
89 const char *dev_name, /* name of device to open */
90 uint32_t baudrate /* baud rate to use */
91 );
92/*-------------------------------------------------------------------------*\
93| Return Value: |
94| 0 on success, -1 and errno otherwise |
95\*=========================================================================*/
96
97#ifdef __cplusplus
98}
99#endif
100
101#endif /* _TERMIOS_PRINTK_H */
Definition: rtemsmain.c:734
Definition: termios_printk.h:29
