RTEMS
5.2-rc1
include
system.h
1
11
12
* COPYRIGHT (c) 1989-2007.
13
* On-Line Applications Research Corporation (OAR).
14
15
* The license and distribution terms for this file may be
16
* found in the file LICENSE in this distribution or at
17
* http://www.rtems.org/license/LICENSE.
18
19
20
#ifndef _RTEMS_SYSTEM_H
21
#define _RTEMS_SYSTEM_H
22
23
#include <rtems/score/cpu.h>
24
25
#ifndef _RTEMS_H
26
#warning "This header file is deprecated and will be removed in RTEMS 6"
27
#endif
28
36
#ifdef __cplusplus
37
extern
"C"
38
#endif
39
40
#ifndef ASM
41
42
43
* The use of this variable is deprecated, use rtems_get_version_string()
44
* instead.
45
46
extern
RTEMS_DEPRECATED
const
char
_RTEMS_version[];
47
51
extern
RTEMS_DEPRECATED
const
char
_Copyright_Notice
52
53
typedef
RTEMS_DEPRECATED uint32_t RTEMS_MAXIMUM_NAME_LENGTH;
54
/* The use of this define is deprecated, use sizeof(rtems_name) instead */
55
#define RTEMS_MAXIMUM_NAME_LENGTH sizeof(RTEMS_MAXIMUM_NAME_LENGTH)
56
57
#endif
/* ASM */
58
59
#ifdef __cplusplus
60
61
#endif
62
64
#endif
65
/* end of include file */
_Copyright_Notice
RTEMS_DEPRECATED const char _Copyright_Notice[]
