RTEMS 5.2-rc1
uint32_t dma_table_address
uint32_t dma_data_address
uint32_t dma_bytecount
uint32_t dma_data_holding
uint16_t timer1_preload
uint16_t timer1_count
uint16_t timer2_preload
uint16_t timer2_count
uint8_t timer1_int_control
uint8_t timer1_control
uint8_t timer2_int_control
uint8_t timer2_control
uint8_t acfail_int_control
uint8_t watchdog_control
uint8_t printer_int_control
uint8_t printer_control
uint8_t dma_int_control
uint8_t dma_control
uint8_t bus_error_int_control
uint8_t dma_status
uint8_t abort_int_control
uint8_t table_address_function_code
uint8_t serial_port_int_control
uint8_t general_purpose_control
uint8_t lan_int_control
uint8_t general_purpose_status
uint8_t scsi_port_int_control
uint8_t slave_base_address
uint8_t software_int_1_control
uint8_t int_base_vector
uint8_t software_int_2_control
uint8_t revision_level
The documentation for this struct was generated from the following files:
