RTEMS 5.2-rc1
status-checks.h
1
10/*
11 * Copyright (c) 2008
12 * Embedded Brains GmbH
13 * Obere Lagerstr. 30
14 * D-82178 Puchheim
15 * Germany
16 * rtems@embedded-brains.de
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef RTEMS_STATUS_CHECKS_H
24#define RTEMS_STATUS_CHECKS_H
25
26#include <rtems/bspIo.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif /* __cplusplus */
31
47#ifdef DEBUG
48 #ifndef RTEMS_DEBUG_PRINT
49 #ifdef RTEMS_STATUS_CHECKS_USE_PRINTK
50 #define RTEMS_DEBUG_PRINT( fmt, ...) \
51 printk( "%s: " fmt, __func__, ##__VA_ARGS__)
52 #else /* RTEMS_STATUS_CHECKS_USE_PRINTK */
53 #include <stdio.h>
54 #define RTEMS_DEBUG_PRINT( fmt, ...) \
55 printf( "%s: " fmt, __func__, ##__VA_ARGS__)
56 #endif /* RTEMS_STATUS_CHECKS_USE_PRINTK */
57 #endif /* RTEMS_DEBUG_PRINT */
58#else /* DEBUG */
59 #ifdef RTEMS_DEBUG_PRINT
60 #warning RTEMS_DEBUG_PRINT was defined, but DEBUG was undefined
61 #undef RTEMS_DEBUG_PRINT
62 #endif /* RTEMS_DEBUG_PRINT */
63 #define RTEMS_DEBUG_PRINT( fmt, ...)
64#endif /* DEBUG */
65
69#define RTEMS_DEBUG_OK( msg) \
70 RTEMS_DEBUG_PRINT( "Ok: %s\n", msg)
71
75#ifndef RTEMS_SYSLOG_PRINT
76 #ifdef RTEMS_STATUS_CHECKS_USE_PRINTK
77 #define RTEMS_SYSLOG_PRINT( fmt, ...) \
78 printk( fmt, ##__VA_ARGS__)
79 #else /* RTEMS_STATUS_CHECKS_USE_PRINTK */
80 #include <stdio.h>
81 #define RTEMS_SYSLOG_PRINT( fmt, ...) \
82 printf( fmt, ##__VA_ARGS__)
83 #endif /* RTEMS_STATUS_CHECKS_USE_PRINTK */
84#endif /* RTEMS_SYSLOG_PRINT */
85
89#define RTEMS_SYSLOG( fmt, ...) \
90 RTEMS_SYSLOG_PRINT( "%s: " fmt, __func__, ##__VA_ARGS__)
91
95#define RTEMS_SYSLOG_WARNING( fmt, ...) \
96 RTEMS_SYSLOG( "Warning: " fmt, ##__VA_ARGS__)
97
102#define RTEMS_SYSLOG_WARNING_SC( sc, msg) \
103 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
104 RTEMS_SYSLOG_WARNING( "SC = %i: %s\n", (int) sc, msg); \
105 }
106
110#define RTEMS_SYSLOG_ERROR( fmt, ...) \
111 RTEMS_SYSLOG( "Error: " fmt, ##__VA_ARGS__)
112
116#define RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg) \
117 RTEMS_SYSLOG_ERROR( "SC = %i: %s\n", (int) sc, msg);
118
122#define RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg) \
123 RTEMS_SYSLOG_ERROR( "RV = %i: %s\n", (int) rv, msg);
124
129#define RTEMS_SYSLOG_ERROR_SC( sc, msg) \
130 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
131 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
132 }
133
138#define RTEMS_SYSLOG_ERROR_RV( rv, msg) \
139 if ((int) (rv) < 0) { \
140 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
141 }
142
154#define RTEMS_CHECK_SC( sc, msg) \
155 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
156 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
157 return (rtems_status_code) sc; \
158 } else { \
159 RTEMS_DEBUG_OK( msg); \
160 }
161
166#define RTEMS_CHECK_SC_RV( sc, msg) \
167 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
168 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
169 return -((int) (sc)); \
170 } else { \
171 RTEMS_DEBUG_OK( msg); \
172 }
173
178#define RTEMS_CHECK_SC_VOID( sc, msg) \
179 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
180 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
181 return; \
182 } else { \
183 RTEMS_DEBUG_OK( msg); \
184 }
185
190#define RTEMS_CHECK_SC_TASK( sc, msg) \
191 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
192 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
193 rtems_task_exit(); \
194 return; \
195 } else { \
196 RTEMS_DEBUG_OK( msg); \
197 }
198
203#define RTEMS_CHECK_RV( rv, msg) \
204 if ((int) (rv) < 0) { \
205 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
206 return (int) rv; \
207 } else { \
208 RTEMS_DEBUG_OK( msg); \
209 }
210
215#define RTEMS_CHECK_RV_SC( rv, msg) \
216 if ((int) (rv) < 0) { \
217 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
218 return RTEMS_IO_ERROR; \
219 } else { \
220 RTEMS_DEBUG_OK( msg); \
221 }
222
227#define RTEMS_CHECK_RV_VOID( rv, msg) \
228 if ((int) (rv) < 0) { \
229 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
230 return; \
231 } else { \
232 RTEMS_DEBUG_OK( msg); \
233 }
234
239#define RTEMS_CHECK_RV_TASK( rv, msg) \
240 if ((int) (rv) < 0) { \
241 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
242 rtems_task_exit(); \
243 return; \
244 } else { \
245 RTEMS_DEBUG_OK( msg); \
246 }
247
259#define RTEMS_CLEANUP_SC( sc, label, msg) \
260 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
261 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
262 goto label; \
263 } else { \
264 RTEMS_DEBUG_OK( msg); \
265 }
266
272#define RTEMS_CLEANUP_SC_RV( sc, rv, label, msg) \
273 if ((rtems_status_code) (sc) != RTEMS_SUCCESSFUL) { \
274 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
275 rv = -((int) (sc)); \
276 goto label; \
277 } else { \
278 RTEMS_DEBUG_OK( msg); \
279 }
280
285#define RTEMS_CLEANUP_RV( rv, label, msg) \
286 if ((int) (rv) < 0) { \
287 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
288 goto label; \
289 } else { \
290 RTEMS_DEBUG_OK( msg); \
291 }
292
298#define RTEMS_CLEANUP_RV_SC( rv, sc, label, msg) \
299 if ((int) (rv) < 0) { \
300 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
301 sc = RTEMS_IO_ERROR; \
302 goto label; \
303 } else { \
304 RTEMS_DEBUG_OK( msg); \
305 }
306
310#define RTEMS_DO_CLEANUP( label, msg) \
311 do { \
312 RTEMS_SYSLOG_ERROR( msg); \
313 goto label; \
314 } while (0)
315
320#define RTEMS_DO_CLEANUP_SC( val, sc, label, msg) \
321 do { \
322 sc = (rtems_status_code) val; \
323 RTEMS_SYSLOG_ERROR_WITH_SC( sc, msg); \
324 goto label; \
325 } while (0)
326
331#define RTEMS_DO_CLEANUP_RV( val, rv, label, msg) \
332 do { \
333 rv = (int) val; \
334 RTEMS_SYSLOG_ERROR_WITH_RV( rv, msg); \
335 goto label; \
336 } while (0)
337
342#ifdef __cplusplus
343}
344#endif /* __cplusplus */
345
346#endif /* RTEMS_STATUS_CHECKS_H */
Interface to Kernel Print Methods.
