RTEMS 5.2-rc1
spwcuc.h
1/* SPWCUC - SpaceWire - CCSDS unsegmented Code Transfer Protocol GRLIB core
2 * register driver interface.
3 *
4 * COPYRIGHT (c) 2009.
5 * Cobham Gaisler AB.
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __SPWCUC_H__
13#define __SPWCUC_H__
14
15#define PKT_INIT_IRQ 0x1
16#define PKT_ERR_IRQ 0x2
17#define PKT_RX_IRQ 0x4
18#define WRAP_ERR_IRQ 0x8
19#define WRAP_IRQ 0x10
20#define SYNC_ERR_IRQ 0x20
21#define SYNC_IRQ 0x40
22#define TOL_ERR_IRQ 0x80
23#define TICK_RX_ERR_IRQ 0x100
24#define TICK_RX_WRAP_IRQ 0x200
25#define TICK_RX_IRQ 0x400
26#define TICK_TX_WRAP_IRQ 0x800
27#define TICK_TX_IRQ 0x1000
28
29/* SPWCUC Register layout */
31 volatile unsigned int config; /* 00 */
32 volatile unsigned int status; /* 04 */
33 volatile unsigned int control; /* 08 */
34 volatile unsigned int unused0; /* 0c */
35 volatile unsigned int dla; /* 10 */
36 volatile unsigned int pid; /* 14 */
37 volatile unsigned int offset; /* 18 */
38 volatile unsigned int unused1; /* 1c */
39 volatile unsigned int pkt_ct; /* 20 */
40 volatile unsigned int pkt_ft; /* 24 */
41 volatile unsigned int pkt_pf_crc; /* 28 */
42 volatile unsigned int unused2; /* 2c */
43 volatile unsigned int etct; /* 30 */
44 volatile unsigned int etft; /* 34 */
45 volatile unsigned int etct_next; /* 38 */
46 volatile unsigned int etft_next; /* 3c */
47 volatile unsigned int unused3[8]; /* 40-5c */
48 volatile unsigned int pimsr; /* 60 */
49 volatile unsigned int pimr; /* 64 */
50 volatile unsigned int pisr; /* 68 */
51 volatile unsigned int pir; /* 6c */
52 volatile unsigned int imr; /* 70 */
53 volatile unsigned int picr; /* 74 */
54};
55
56struct spwcuc_cfg {
57 unsigned char sel_out; /* Bits 3-0 enable time code transmission on respective output */
58 unsigned char sel_in; /* Select SpW to receive time codes on, 0-3 */
59 unsigned char mapping; /* Define mapping of time code time info into T-field, 0-31 */
60 unsigned char tolerance; /* Define SpaceWire time code reception tolerance, 0-31 */
61 unsigned char tid; /* Define CUC P-Field time code identification, 1 = Level 1, 2 = Level 2 */
62 unsigned char ctf; /* If 1 check time code flags to be all zero */
63 unsigned char cp; /* If 1 check P-Field time code id against tid */
64
65 unsigned char txen; /* Enable SpaceWire time code transmission */
66 unsigned char rxen; /* Enable SpaceWire time code reception */
67 unsigned char pktsyncen; /* Enable SpaceWire time CUC packet sync */
68 unsigned char pktiniten; /* Enable SpaceWire time CUC packet init */
69 unsigned char pktrxen; /* Enable SpaceWire time CUC packet reception */
70
71 unsigned char dla; /* SpaceWire destination logical address */
72 unsigned char dla_mask; /* SpaceWire destination logical address mask */
73 unsigned char pid; /* SpaceWire protocol ID */
74
75 unsigned int offset; /* Packet reception offset */
76};
77
78/* SPWCUC Statistics gathered by driver */
80
81 /* IRQ Stats */
82 unsigned int nirqs;
83 unsigned int tick_tx;
84 unsigned int tick_tx_wrap;
85 unsigned int tick_rx;
86 unsigned int tick_rx_wrap;
87 unsigned int tick_rx_error;
88 unsigned int tolerr;
89 unsigned int sync;
90 unsigned int syncerr;
91 unsigned int wrap;
92 unsigned int wraperr;
93 unsigned int pkt_rx;
94 unsigned int pkt_err;
95 unsigned int pkt_init;
96};
97
98/* Function ISR callback prototype
99 *
100 * pimr - PIMR/PIR register of the SPWCUC core read by ISR
101 * data - Custom data provided by user
102 */
103typedef void (*spwcuc_isr_t)(unsigned int pimr, void *data);
104
105/* Open a SPWCUC device by minor number. A SPWCUC device can only by opened
106 * once. The handle returned must be used as the input parameter 'spwcuc' in
107 * the rest of the calls in the function interface.
108 */
109extern void *spwcuc_open(int minor);
110
111/* Close a previously opened SPWCUC device */
112extern void spwcuc_close(void *spwcuc);
113
114/* Reset SPWCUC Core */
115extern int spwcuc_reset(void *spwcuc);
116
117/* Enable Interrupts at Interrupt controller */
118extern void spwcuc_int_enable(void *spwcuc);
119
120/* Disable Interrupts at Interrupt controller */
121extern void spwcuc_int_disable(void *spwcuc);
122
123/* Clear Statistics gathered by the driver */
124extern void spwcuc_clr_stats(void *spwcuc);
125
126/* Get Statistics gathered by the driver. The statistics are stored into
127 * the location pointed to by 'stats'.
128 */
129extern void spwcuc_get_stats(void *spwcuc, struct spwcuc_stats *stats);
130
131/* Register an Interrupt handler and custom data, the function call is
132 * removed by setting func to NULL.
133 *
134 * The driver's interrupt handler is installed on open(), however the user
135 * callback called from the driver's ISR is installed using this function.
136 */
137extern void spwcuc_int_register(void *spwcuc, spwcuc_isr_t func, void *data);
138
139/* Configure the spwcuc core. The configuration is taken from the data
140 * structure pointed to by 'cfg'. See data structure spwcuc_cfg fields.
141 */
142extern void spwcuc_config(void *spwcuc, struct spwcuc_cfg *cfg);
143
144/* Return elapsed coarse time */
145extern unsigned int spwcuc_get_et_coarse(void *spwcuc);
146
147/* Return elapsed fine time */
148extern unsigned int spwcuc_get_et_fine(void *spwcuc);
149
150/* Return elapsed time (coarse and fine) 64-bit value */
151extern unsigned long long spwcuc_get_et(void *spwcuc);
152
153/* Return next elapsed coarse time (for use when sending SpW time packet) */
154extern unsigned int spwcuc_get_next_et_coarse(void *spwcuc);
155
156/* Return next elapsed fine time (for use when sending SpW time packet) */
157extern unsigned int spwcuc_get_next_et_fine(void *spwcuc);
158
159/* Return next elapsed time (for use when sending SpW time packet) */
160extern unsigned long long spwcuc_get_next_et(void *spwcuc);
161
162/* Force/Set the elapsed time (coarse 32-bit and fine 24-bit) by writing the
163 * T-Field Time Packet Registers then the FORCE bit.
164 */
165extern void spwcuc_force_et(void *spwcuc, unsigned long long time);
166
167/* Return received (from time packet) elapsed coarse time */
168extern unsigned int spwcuc_get_tp_et_coarse(void *spwcuc);
169
170/* Return received (from time packet) elapsed fine time */
171extern unsigned int spwcuc_get_tp_et_fine(void *spwcuc);
172
173/* Return received (from time packet) elapsed time (coarse and fine) */
174extern unsigned long long spwcuc_get_tp_et(void *spwcuc);
175
176/* Clear interrupts */
177extern void spwcuc_clear_irqs(void *spwcuc, int irqs);
178
179/* Enable interrupts */
180extern void spwcuc_enable_irqs(void *spwcuc, int irqs);
181
182/* Get Register */
183extern struct spwcuc_regs *spwcuc_get_regs(void *spwcuc);
184
185/* Register the SPWCUC Driver to the Driver Manager */
186extern void spwcuc_register(void);
187
188#endif
Definition: deflate.c:115
Definition: intercom.c:74
Definition: spwcuc.h:56
Definition: spwcuc.h:30
Definition: spwcuc.h:79
