RTEMS 5.2-rc1
spictrl.h
1/*
2 * SPICTRL SPI Driver interface.
3 *
4 * COPYRIGHT (c) 2009.
5 * Cobham Gaisler AB.
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12#ifndef __SPICTRL_H__
13#define __SPICTRL_H__
14
15#ifdef __cplusplus
16extern "C" {
17#endif
18
19extern void spictrl_register_drv (void);
20
21/*** REGISTER LAYOUT ***/
23 volatile unsigned int capability; /* 0x00 */
24 volatile unsigned int resv[7]; /* 0x04 */
25 volatile unsigned int mode; /* 0x20 */
26 volatile unsigned int event; /* 0x24 */
27 volatile unsigned int mask; /* 0x28 */
28 volatile unsigned int command; /* 0x2c */
29 volatile unsigned int tx; /* 0x30 */
30 volatile unsigned int rx; /* 0x34 */
31 volatile unsigned int slvsel; /* 0x38 */
32 volatile unsigned int am_slvsel; /* 0x3c */
33 volatile unsigned int am_cfg; /* 0x40 */
34 volatile unsigned int am_period; /* 0x44 */
35 int reserved0[2];
36 volatile unsigned int am_mask[4]; /* 0x50-0x5C */
37 int reserved1[(0x200-0x60)/4];
38 volatile unsigned int am_tx[128]; /* 0x200-0x3FC */
39 volatile unsigned int am_rx[128]; /* 0x400-0x5FC */
40};
41
42/* -- About automated periodic transfer mode --
43 *
44 * Core must support this feature.
45 *
46 * The SPI core must be configured in periodic mode before
47 * writing the data into the transfer FIFO which will be used
48 * mutiple times in different transfers, it will also make
49 * the receive FIFO to be updated.
50 *
51 * In periodic mode the following sequence is performed,
52 * 1. start()
53 * 2. ioctl(CONFIG, &config) - Enable periodic mode
54 * 3. set_address()
55 * 4. write() - Fills TX FIFO, this has some constraints
56 * 5. ioctl(START) - Starts the periodic transmission of the TX FIFO
57 * 6. read() - Read one response of the tranistted data. It will
58 * hang until data is available. If hanging is not an
59 * options use ioctl(STATUS)
60 * 7. go back to 6.
61 *
62 * 8. ioctl(STOP) - Stop to set up a new periodic or normal transfer
63 * 9. stop()
64 *
65 * Note that the the read length must equal the total write length.
66 */
67
68/* Custom SPICTRL driver ioctl commands */
69#define SPICTRL_IOCTL_PERIOD_START 5000 /* Start automated periodic transfer mode */
70#define SPICTRL_IOCTL_PERIOD_STOP 5001 /* Stop to SPI core from doing periodic transfers */
71#define SPICTRL_IOCTL_CONFIG 5002 /* Configure Periodic transfer mode (before calling write() and START) */
72#define SPICTRL_IOCTL_STATUS 5003 /* Get status */
73
74#define SPICTRL_IOCTL_PERIOD_READ 5005 /* Write transmit registers and mask register
75 * (only in automatic periodic mode)
76 * Note that it is probably prefferred to read
77 * the received words using the read() using
78 * operations instead.
79 */
80#define SPICTRL_IOCTL_PERIOD_WRITE 5006 /* Read receive registers and mask register
81 * (only in automatic periodic mode) */
82#define SPICTRL_IOCTL_REGS 5007 /* Get SPICTRL Register */
83
84/* SPICTRL_IOCTL_CONFIG argument */
86 int clock_gap; /* Clock GAP between */
87 unsigned int flags; /* Normal mode flags */
88 int periodic_mode; /* 1=Enables Automated periodic transfers if supported by hardware */
89 unsigned int period; /* Number of clocks between automated transfers are started */
90 unsigned int period_flags; /* Options */
91 unsigned int period_slvsel; /* Slave Select when transfer is not active, default is 0xffffffff */
92};
93#define SPICTRL_FLAGS_TAC 0x10
94
95#define SPICTRL_PERIOD_FLAGS_ERPT 0x80 /* Trigger start-period from external signal */
96#define SPICTRL_PERIOD_FLAGS_SEQ 0x40
97#define SPICTRL_PERIOD_FLAGS_STRICT 0x20
98#define SPICTRL_PERIOD_FLAGS_OVTB 0x10
99#define SPICTRL_PERIOD_FLAGS_OVDB 0x08
100#define SPICTRL_PERIOD_FLAGS_ASEL 0x04
101#define SPICTRL_PERIOD_FLAGS_EACT 0x01
103/* SPICTRL_IOCTL_PERIOD_READ and SPICTRL_IOCTL_PERIOD_WRITE Argument data structure
104 *
105 * Note that the order of reading the mask registers are different for read/write
106 * operation. See options notes.
107 */
108struct spictrl_period_io {
109 int options; /* READ: bit0=Read Mask Registers into masks[].
110 * bit1=Read Receive registers according to masks[]
111 * (after reading masks).
112 *
113 * WRITE: bit0=Update Mask accoring to masks[].
114 * bit1=Update Transmit registers according to masks[].
115 * (before reading masks)
116 */
117 unsigned int masks[4];
118
119 void *data; /* Data read sequentially according to masks[] bit. */
120};
121
122#ifdef __cplusplus
123}
124#endif
125
126#endif
Definition: spictrl.h:79
Definition: spictrl.h:102
Definition: spictrl.h:22
