RTEMS 5.2-rc1
sparse-disk.h
1
9/*
10 * Copyright (c) 2012 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef SPARSE_DISK_H
24#define SPARSE_DISK_H
25
26#include <stddef.h>
27#include <stdint.h>
28#include <rtems.h>
29#include <rtems/diskdevs.h>
30#include <rtems/thread.h>
31
32#ifdef __cplusplus
33extern "C" {
34#endif /* __cplusplus */
35
44typedef struct {
46 void *data;
48
50
51typedef void (*rtems_sparse_disk_delete_handler)(rtems_sparse_disk *sparse_disk);
52
54 rtems_mutex mutex;
55 rtems_blkdev_bnum blocks_with_buffer;
56 size_t used_count;
57 uint32_t media_block_size;
58 rtems_sparse_disk_delete_handler delete_handler;
59 uint8_t fill_pattern;
60 rtems_sparse_disk_key *key_table;
61};
62
85 const char *device_file_name,
86 uint32_t media_block_size,
87 rtems_blkdev_bnum blocks_with_buffer,
88 rtems_blkdev_bnum media_block_count,
89 uint8_t fill_pattern
90);
91
97void rtems_sparse_disk_free( rtems_sparse_disk *sparse_disk );
98
123 const char *device_file_name,
124 rtems_sparse_disk *sparse_disk,
125 uint32_t media_block_size,
126 rtems_blkdev_bnum blocks_with_buffer,
127 rtems_blkdev_bnum media_block_count,
128 uint8_t fill_pattern,
129 rtems_sparse_disk_delete_handler sparse_disk_delete
130);
131
134#ifdef __cplusplus
135}
136#endif /* __cplusplus */
137
138#endif /* SPARSE_DISK_H */
Block Device Disk Management API.
rtems_status_code
Classic API Status.
Definition: status.h:43
uint32_t rtems_blkdev_bnum
Block device block index type.
Definition: diskdevs.h:45
rtems_status_code rtems_sparse_disk_create_and_register(const char *device_file_name, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern)
Creates and registers a sparse disk.
Definition: sparse-disk.c:306
rtems_status_code rtems_sparse_disk_register(const char *device_file_name, rtems_sparse_disk *sparse_disk, uint32_t media_block_size, rtems_blkdev_bnum blocks_with_buffer, rtems_blkdev_bnum media_block_count, uint8_t fill_pattern, rtems_sparse_disk_delete_handler sparse_disk_delete)
Initializes and registers a sparse disk.
Definition: sparse-disk.c:336
void rtems_sparse_disk_free(rtems_sparse_disk *sparse_disk)
Frees a sparse disk.
Definition: sparse-disk.c:301
Definition: mutex.h:4
Definition: sparse-disk.h:44
Definition: sparse-disk.h:53
