RTEMS 5.2-rc1
smsc9218i.h
1
9/*
10 * Copyright (c) 2009-2012 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Obere Lagerstr. 30
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#include <bsp.h>
24
30typedef struct {
31 uint32_t rx_fifo_data;
32 uint32_t rx_fifo_data_aliases [7];
33 uint32_t tx_fifo_data;
34 uint32_t tx_fifo_data_aliases [7];
35 uint32_t rx_fifo_status;
36 uint32_t rx_fifo_status_peek;
37 uint32_t tx_fifo_status;
38 uint32_t tx_fifo_status_peek;
39 uint32_t id_rev;
40 uint32_t irq_cfg;
41 uint32_t int_sts;
42 uint32_t int_en;
43 uint32_t reserved_0;
44 uint32_t byte_test;
45 uint32_t fifo_int;
46 uint32_t rx_cfg;
47 uint32_t tx_cfg;
48 uint32_t hw_cfg;
49 uint32_t rx_dp_ctl;
50 uint32_t rx_fifo_inf;
51 uint32_t tx_fifo_inf;
52 uint32_t pmt_ctrl;
53 uint32_t gpio_cfg;
54 uint32_t gpt_cfg;
55 uint32_t gpt_cnt;
56 uint32_t reserved_1;
57 uint32_t word_swap;
58 uint32_t free_run;
59 uint32_t rx_drop;
60 uint32_t mac_csr_cmd;
61 uint32_t mac_csr_data;
62 uint32_t afc_cfg;
63 uint32_t e2p_cmd;
64 uint32_t e2p_data;
66
67/*
68 * SMSC9218 registers are accessed little-endian (address 0x3fff8000, A22 used
69 * as END_SEL).
70 */
71#ifdef SMSC9218I_BIG_ENDIAN_SUPPORT
72 volatile smsc9218i_registers *const smsc9218i =
73 (volatile smsc9218i_registers *) 0x3fff8000;
74 volatile smsc9218i_registers *const smsc9218i_dma =
75 (volatile smsc9218i_registers *) 0x3fff8200;
76#else
77 volatile smsc9218i_registers *const smsc9218i =
78 (volatile smsc9218i_registers *) 0x3fff8000;
79 volatile smsc9218i_registers *const smsc9218i_dma =
80 (volatile smsc9218i_registers *) 0x3fff8000;
81#endif
82
85#ifdef SMSC9218I_BIG_ENDIAN_SUPPORT
86 #define SMSC9218I_BIT_POS(pos) (pos)
87#else
88 #define SMSC9218I_BIT_POS(pos) \
89 ((pos) > 15 ? \
90 ((pos) > 23 ? (pos) - 24 : (pos) - 8) \
91 : ((pos) > 7 ? (pos) + 8 : (pos) + 24))
92#endif
93
94#define SMSC9218I_FLAG(pos) \
95 (1U << SMSC9218I_BIT_POS(pos))
96
97#define SMSC9218I_FIELD_8(val, pos) \
98 (((val) & 0xff) << SMSC9218I_BIT_POS(pos))
99
100#define SMSC9218I_GET_FIELD_8(reg, pos) \
101 (((reg) >> SMSC9218I_BIT_POS(pos)) & 0xff)
102
103#define SMSC9218I_FIELD_16(val, pos) \
104 (SMSC9218I_FIELD_8((val) >> 8, (pos) + 8) \
105 | SMSC9218I_FIELD_8((val), pos))
106
107#define SMSC9218I_GET_FIELD_16(reg, pos) \
108 ((SMSC9218I_GET_FIELD_8(reg, (pos) + 8) << 8) \
109 | SMSC9218I_GET_FIELD_8(reg, pos))
110
111#ifdef SMSC9218I_BIG_ENDIAN_SUPPORT
112 #define SMSC9218I_SWAP(val) (val)
113#else
114 #define SMSC9218I_SWAP(val) \
115 ((((val) >> 24) & 0xff) \
116 | ((((val) >> 16) & 0xff) << 8) \
117 | ((((val) >> 8) & 0xff) << 16) \
118 | (((val) & 0xff) << 24))
119#endif
120
126#define SMSC9218I_RX_STS_FILTER_FAIL SMSC9218I_FLAG(30)
127#define SMSC9218I_RX_STS_GET_LENGTH(reg) (SMSC9218I_GET_FIELD_16(reg, 16) & 0x3fff)
128#define SMSC9218I_RX_STS_ERROR SMSC9218I_FLAG(15)
129#define SMSC9218I_RX_STS_BROADCAST SMSC9218I_FLAG(13)
130#define SMSC9218I_RX_STS_ERROR_LENGTH SMSC9218I_FLAG(12)
131#define SMSC9218I_RX_STS_ERROR_RUNT_FRAME SMSC9218I_FLAG(11)
132#define SMSC9218I_RX_STS_MULTICAST SMSC9218I_FLAG(10)
133#define SMSC9218I_RX_STS_ERROR_TOO_LONG SMSC9218I_FLAG(7)
134#define SMSC9218I_RX_STS_ERROR_COLLISION SMSC9218I_FLAG(6)
135#define SMSC9218I_RX_STS_TYPE SMSC9218I_FLAG(5)
136#define SMSC9218I_RX_STS_WATCHDOG SMSC9218I_FLAG(4)
137#define SMSC9218I_RX_STS_ERROR_MII SMSC9218I_FLAG(3)
138#define SMSC9218I_RX_STS_DRIBBLING_BIT SMSC9218I_FLAG(2)
139#define SMSC9218I_RX_STS_ERROR_CRC SMSC9218I_FLAG(1)
140
148#define SMSC9218I_TX_STS_GET_TAG(reg) SMSC9218I_GET_FIELD_16(reg, 16)
149#define SMSC9218I_TX_STS_ERROR SMSC9218I_FLAG(15)
150#define SMSC9218I_TX_STS_ERROR_LOSS_OF_CARRIER SMSC9218I_FLAG(11)
151#define SMSC9218I_TX_STS_ERROR_NO_CARRIER SMSC9218I_FLAG(10)
152#define SMSC9218I_TX_STS_ERROR_LATE_COLLISION SMSC9218I_FLAG(9)
153#define SMSC9218I_TX_STS_ERROR_EXCESSIVE_COLLISIONS SMSC9218I_FLAG(8)
154#define SMSC9218I_TX_STS_ERROR_EXCESSIVE_DEFERRAL SMSC9218I_FLAG(2)
155#define SMSC9218I_TX_STS_ERROR_DEFERRED SMSC9218I_FLAG(0)
156
164#define SMSC9218I_TX_A_IOC SMSC9218I_FLAG(31)
165#define SMSC9218I_TX_A_END_ALIGN_4 0
166#define SMSC9218I_TX_A_END_ALIGN_16 SMSC9218I_FLAG(24)
167#define SMSC9218I_TX_A_END_ALIGN_32 SMSC9218I_FLAG(25)
168#define SMSC9218I_TX_A_DOFF(val) SMSC9218I_FIELD_8(val, 16)
169#define SMSC9218I_TX_A_FIRST SMSC9218I_FLAG(13)
170#define SMSC9218I_TX_A_LAST SMSC9218I_FLAG(12)
171#define SMSC9218I_TX_A_FRAGMENT_LENGTH(val) SMSC9218I_FIELD_16(val, 0)
172
180#define SMSC9218I_TX_B_TAG(val) SMSC9218I_FIELD_16(val, 16)
181#define SMSC9218I_TX_B_GET_TAG(reg) SMSC9218I_GET_FIELD_16(reg, 16)
182#define SMSC9218I_TX_B_DISABLE_CRC SMSC9218I_FLAG(13)
183#define SMSC9218I_TX_B_DISABLE_PAD SMSC9218I_FLAG(12)
184#define SMSC9218I_TX_B_FRAME_LENGTH(val) SMSC9218I_FIELD_16(val, 0)
185
193#define SMSC9218I_ID_REV_GET_ID(reg) SMSC9218I_GET_FIELD_16(reg, 16)
194#define SMSC9218I_ID_REV_GET_REV(reg) SMSC9218I_GET_FIELD_16(reg, 0)
195#define SMSC9218I_ID_REV_ID_CHIP_118 0x0118U
196#define SMSC9218I_ID_REV_ID_CHIP_218 0x118aU
197
205#define SMSC9218I_IRQ_CFG_INT_DEAS(val) SMSC9218I_FIELD_8(val, 24)
206#define SMSC9218I_IRQ_CFG_GET_INT_DEAS(reg) SMSC9218I_GET_FIELD_8(reg, 24)
207#define SMSC9218I_IRQ_CFG_INT_DEAS_CLR SMSC9218I_FLAG(14)
208#define SMSC9218I_IRQ_CFG_INT_DEAS_STS SMSC9218I_FLAG(13)
209#define SMSC9218I_IRQ_CFG_IRQ_INT SMSC9218I_FLAG(12)
210#define SMSC9218I_IRQ_CFG_IRQ_EN SMSC9218I_FLAG(8)
211#define SMSC9218I_IRQ_CFG_IRQ_POL SMSC9218I_FLAG(4)
212#define SMSC9218I_IRQ_CFG_IRQ_TYPE SMSC9218I_FLAG(0)
213
221#define SMSC9218I_INT_SW SMSC9218I_FLAG(31)
222#define SMSC9218I_INT_TXSTOP SMSC9218I_FLAG(25)
223#define SMSC9218I_INT_RXSTOP SMSC9218I_FLAG(24)
224#define SMSC9218I_INT_RXDFH SMSC9218I_FLAG(23)
225#define SMSC9218I_INT_TIOC SMSC9218I_FLAG(21)
226#define SMSC9218I_INT_RXD SMSC9218I_FLAG(20)
227#define SMSC9218I_INT_GPT SMSC9218I_FLAG(19)
228#define SMSC9218I_INT_PHY SMSC9218I_FLAG(18)
229#define SMSC9218I_INT_PME SMSC9218I_FLAG(17)
230#define SMSC9218I_INT_TXSO SMSC9218I_FLAG(16)
231#define SMSC9218I_INT_RWT SMSC9218I_FLAG(15)
232#define SMSC9218I_INT_RXE SMSC9218I_FLAG(14)
233#define SMSC9218I_INT_TXE SMSC9218I_FLAG(13)
234#define SMSC9218I_INT_TDFO SMSC9218I_FLAG(10)
235#define SMSC9218I_INT_TDFA SMSC9218I_FLAG(9)
236#define SMSC9218I_INT_TSFF SMSC9218I_FLAG(8)
237#define SMSC9218I_INT_TSFL SMSC9218I_FLAG(7)
238#define SMSC9218I_INT_RSFF SMSC9218I_FLAG(4)
239#define SMSC9218I_INT_RSFL SMSC9218I_FLAG(3)
240#define SMSC9218I_INT_GPIO2 SMSC9218I_FLAG(2)
241#define SMSC9218I_INT_GPIO1 SMSC9218I_FLAG(1)
242#define SMSC9218I_INT_GPIO0 SMSC9218I_FLAG(0)
243
251#define SMSC9218I_BYTE_TEST SMSC9218I_SWAP(0x87654321U)
252
260#define SMSC9218I_FIFO_INT_TDAL(val) SMSC9218I_FIELD_8(val, 24)
261#define SMSC9218I_FIFO_INT_GET_TDAL(reg) SMSC9218I_GET_FIELD_8(reg, 24)
262#define SMSC9218I_FIFO_INT_TSL(val) SMSC9218I_FIELD_8(val, 16)
263#define SMSC9218I_FIFO_INT_GET_TSL(reg) SMSC9218I_GET_FIELD_8(reg, 16)
264#define SMSC9218I_FIFO_INT_RSL(val) SMSC9218I_FIELD_8(val, 0)
265#define SMSC9218I_FIFO_INT_GET_RSL(reg) SMSC9218I_GET_FIELD_8(reg, 0)
266
274#define SMSC9218I_RX_CFG_END_ALIGN_4 0
275#define SMSC9218I_RX_CFG_END_ALIGN_16 SMSC9218I_FLAG(30)
276#define SMSC9218I_RX_CFG_END_ALIGN_32 SMSC9218I_FLAG(31)
277#define SMSC9218I_RX_CFG_DMA_CNT(val) SMSC9218I_FIELD_8(val, 24)
278#define SMSC9218I_RX_CFG_GET_DMA_CNT(reg) SMSC9218I_GET_FIELD_8(reg, 24)
279#define SMSC9218I_RX_CFG_DUMP SMSC9218I_FLAG(15)
280#define SMSC9218I_RX_CFG_DOFF(val) SMSC9218I_FIELD_8(val, 8)
281#define SMSC9218I_RX_CFG_GET_DOFF(reg) SMSC9218I_GET_FIELD_8(reg, 8)
282
290#define SMSC9218I_TX_CFG_SDUMP SMSC9218I_FLAG(15)
291#define SMSC9218I_TX_CFG_DDUMP SMSC9218I_FLAG(14)
292#define SMSC9218I_TX_CFG_SAO SMSC9218I_FLAG(2)
293#define SMSC9218I_TX_CFG_ON SMSC9218I_FLAG(1)
294#define SMSC9218I_TX_CFG_STOP SMSC9218I_FLAG(0)
295
303#define SMSC9218I_HW_CFG_LED_3 SMSC9218I_FLAG(30)
304#define SMSC9218I_HW_CFG_LED_2 SMSC9218I_FLAG(29)
305#define SMSC9218I_HW_CFG_LED_1 SMSC9218I_FLAG(28)
306#define SMSC9218I_HW_CFG_AMDIX SMSC9218I_FLAG(24)
307#define SMSC9218I_HW_CFG_MBO SMSC9218I_FLAG(20)
308#define SMSC9218I_HW_CFG_TX_FIF_SZ(val) SMSC9218I_FIELD_8(val, 16)
309#define SMSC9218I_HW_CFG_GET_TX_FIF_SZ(reg) SMSC9218I_GET_FIELD_8(reg, 16)
310#define SMSC9218I_HW_CFG_BITMD_32 SMSC9218I_FLAG(2)
311#define SMSC9218I_HW_CFG_SRST_TO SMSC9218I_FLAG(1)
312#define SMSC9218I_HW_CFG_SRST SMSC9218I_FLAG(0)
313
321#define SMSC9218I_RX_DP_CTRL_FFWD SMSC9218I_FLAG(31)
322
330#define SMSC9218I_RX_FIFO_INF_GET_SUSED(reg) SMSC9218I_GET_FIELD_8(reg, 16)
331#define SMSC9218I_RX_FIFO_INF_GET_DUSED(reg) SMSC9218I_GET_FIELD_16(reg, 0)
332
340#define SMSC9218I_TX_FIFO_INF_GET_SUSED(reg) SMSC9218I_GET_FIELD_8(reg, 16)
341#define SMSC9218I_TX_FIFO_INF_GET_FREE(reg) SMSC9218I_GET_FIELD_16(reg, 0)
342
350#define SMSC9218I_PMT_CTRL_PM_MODE_D0 0
351#define SMSC9218I_PMT_CTRL_PM_MODE_D1 SMSC9218I_FLAG(12)
352#define SMSC9218I_PMT_CTRL_PM_MODE_D2 SMSC9218I_FLAG(13)
353#define SMSC9218I_PMT_CTRL_PHY_RST SMSC9218I_FLAG(10)
354#define SMSC9218I_PMT_CTRL_WOL_EN SMSC9218I_FLAG(9)
355#define SMSC9218I_PMT_CTRL_ED_EN SMSC9218I_FLAG(8)
356#define SMSC9218I_PMT_CTRL_PME_TYPE_PUPU SMSC9218I_FLAG(6)
357#define SMSC9218I_PMT_CTRL_WUPS_NO 0
358#define SMSC9218I_PMT_CTRL_WUPS_ENERGY SMSC9218I_FLAG(4)
359#define SMSC9218I_PMT_CTRL_WUPS_MAGIC SMSC9218I_FLAG(5)
360#define SMSC9218I_PMT_CTRL_PME_IND SMSC9218I_FLAG(3)
361#define SMSC9218I_PMT_CTRL_PME_POL SMSC9218I_FLAG(2)
362#define SMSC9218I_PMT_CTRL_PME_EN SMSC9218I_FLAG(1)
363#define SMSC9218I_PMT_CTRL_READY SMSC9218I_FLAG(0)
364
372#define SMSC9218I_GPIO_CFG_LED3 SMSC9218I_FLAG(30)
373#define SMSC9218I_GPIO_CFG_LED2 SMSC9218I_FLAG(29)
374#define SMSC9218I_GPIO_CFG_LED1 SMSC9218I_FLAG(28)
375#define SMSC9218I_GPIO_CFG_GPIO2_INT_POL SMSC9218I_FLAG(26)
376#define SMSC9218I_GPIO_CFG_GPIO1_INT_POL SMSC9218I_FLAG(25)
377#define SMSC9218I_GPIO_CFG_GPIO0_INT_POL SMSC9218I_FLAG(24)
378#define SMSC9218I_GPIO_CFG_GPIOBUF2 SMSC9218I_FLAG(18)
379#define SMSC9218I_GPIO_CFG_GPIOBUF1 SMSC9218I_FLAG(17)
380#define SMSC9218I_GPIO_CFG_GPIOBUF0 SMSC9218I_FLAG(16)
381#define SMSC9218I_GPIO_CFG_GPIODIR2 SMSC9218I_FLAG(10)
382#define SMSC9218I_GPIO_CFG_GPIODIR1 SMSC9218I_FLAG(9)
383#define SMSC9218I_GPIO_CFG_GPIODIR0 SMSC9218I_FLAG(8)
384#define SMSC9218I_GPIO_CFG_GPO4 SMSC9218I_FLAG(4)
385#define SMSC9218I_GPIO_CFG_GPO3 SMSC9218I_FLAG(3)
386#define SMSC9218I_GPIO_CFG_GPIO0 SMSC9218I_FLAG(0)
387#define SMSC9218I_GPIO_CFG_GPIO2 SMSC9218I_FLAG(2)
388#define SMSC9218I_GPIO_CFG_GPIO1 SMSC9218I_FLAG(1)
389
397#define SMSC9218I_GPT_CFG_TIMER_EN SMSC9218I_FLAG(29)
398#define SMSC9218I_GPT_CFG_LOAD(val) SMSC9218I_FIELD_16(val, 0)
399#define SMSC9218I_GPT_CFG_GET_LOAD(reg) SMSC9218I_GET_FIELD_16(reg, 0)
400
408#define SMSC9218I_GPT_CNT_GET_CNT SMSC9218I_GET_FIELD_16(reg, 0)
409
417#define SMSC9218I_ENDIAN_BIG 0xffffffffU
418
426#define SMSC9218I_FREE_RUN_GET(reg) SMSC9218I_SWAP(reg)
427
435#define SMSC9218I_RX_DROP_GET(reg) SMSC9218I_SWAP(reg)
436
444#define SMSC9218I_E2P_CMD_EPC_BUSY SMSC9218I_FLAG(31)
445
453#define SMSC9218I_MAC_CSR_CMD_BUSY SMSC9218I_FLAG(31)
454#define SMSC9218I_MAC_CSR_CMD_READ SMSC9218I_FLAG(30)
455#define SMSC9218I_MAC_CSR_CMD_ADDR(val) SMSC9218I_FIELD_8(val, 0)
456#define SMSC9218I_MAC_CSR_CMD_GET_ADDR(reg) SMSC9218I_GET_FIELD_8(reg, 0)
457
465#define SMSC9218I_MAC_CR 0x00000001U
466#define SMSC9218I_MAC_CR_RXALL 0x80000000U
467#define SMSC9218I_MAC_CR_HBDIS 0x10000000U
468#define SMSC9218I_MAC_CR_RCVOWN 0x00800000U
469#define SMSC9218I_MAC_CR_LOOPBK 0x00200000U
470#define SMSC9218I_MAC_CR_FDPX 0x00100000U
471#define SMSC9218I_MAC_CR_MCPAS 0x00080000U
472#define SMSC9218I_MAC_CR_PRMS 0x00040000U
473#define SMSC9218I_MAC_CR_INVFILT 0x00020000U
474#define SMSC9218I_MAC_CR_PASSBAD 0x00010000U
475#define SMSC9218I_MAC_CR_HFILT 0x00008000U
476#define SMSC9218I_MAC_CR_HPFILT 0x00002000U
477#define SMSC9218I_MAC_CR_LCOLL 0x00001000U
478#define SMSC9218I_MAC_CR_BCAST 0x00000800U
479#define SMSC9218I_MAC_CR_DISRTY 0x00000400U
480#define SMSC9218I_MAC_CR_PADSTR 0x00000100U
481#define SMSC9218I_MAC_CR_BOLMT_MASK 0x000000c0U
482#define SMSC9218I_MAC_CR_BOLMT_10 0x00000000U
483#define SMSC9218I_MAC_CR_BOLMT_8 0x00000040U
484#define SMSC9218I_MAC_CR_BOLMT_4 0x00000080U
485#define SMSC9218I_MAC_CR_BOLMT_1 0x000000c0U
486#define SMSC9218I_MAC_CR_DFCHK 0x00000020U
487#define SMSC9218I_MAC_CR_TXEN 0x00000008U
488#define SMSC9218I_MAC_CR_RXEN 0x00000004U
489
497#define SMSC9218I_MAC_ADDRH 0x00000002U
498#define SMSC9218I_MAC_ADDRH_MASK 0x0000ffffU
499
507#define SMSC9218I_MAC_ADDRL 0x00000003U
508#define SMSC9218I_MAC_ADDRL_MASK 0xffffffffU
509
517#define SMSC9218I_MAC_HASHH 0x00000004U
518#define SMSC9218I_MAC_HASHH_MASK 0xffffffffU
519
527#define SMSC9218I_MAC_HASHL 0x00000005U
528#define SMSC9218I_MAC_HASHL_MASK 0xffffffffU
529
537#define SMSC9218I_MAC_MII_ACC 0x00000006U
538#define SMSC9218I_MAC_MII_ACC_PHY_DEFAULT (1U << 11)
539#define SMSC9218I_MAC_MII_ACC_WRITE (1U << 1)
540#define SMSC9218I_MAC_MII_ACC_BUSY (1U << 0)
541#define SMSC9218I_MAC_MII_ACC_ADDR(addr) ((addr) << 6)
542
550#define SMSC9218I_MAC_MII_DATA 0x00000007U
551
559#define SMSC9218I_MAC_FLOW 0x00000008U
560#define SMSC9218I_MAC_FLOW_FCPT_MASK 0xffff0000U
561#define SMSC9218I_MAC_FLOW_FCPASS 0x00000004U
562#define SMSC9218I_MAC_FLOW_FCEN 0x00000002U
563#define SMSC9218I_MAC_FLOW_FCBSY 0x00000001U
564
572#define SMSC9218I_MAC_VLAN1 0x00000009U
573
581#define SMSC9218I_MAC_VLAN2 0x0000000aU
582
590#define SMSC9218I_MAC_WUFF 0x0000000bU
591
599#define SMSC9218I_MAC_WUCSR 0x0000000cU
600#define SMSC9218I_MAC_WUCSR_GUE 0x00000200U
601#define SMSC9218I_MAC_WUCSR_WUFR 0x00000040U
602#define SMSC9218I_MAC_WUCSR_MPR 0x00000020U
603#define SMSC9218I_MAC_WUCSR_WUEN 0x00000004U
604#define SMSC9218I_MAC_WUCSR_MPEN 0x00000002U
605
613#define SMSC9218I_PHY_ID1_LAN9118 0x7
614
622#define SMSC9218I_PHY_ID2_LAN9218 0xc0c3
623
631#define SMSC9218I_PHY_MCSR 0x00000011U
632#define SMSC9218I_PHY_MCSR_EDPWRDOWN 0x00002000U
633#define SMSC9218I_PHY_MCSR_ENERGYON 0x00000002U
634
642#define SMSC9218I_PHY_SPMODES 0x00000012U
643
651#define SMSC9218I_PHY_CSIR 0x0000001bU
652#define SMSC9218I_PHY_CSIR_SQEOFF 0x00000800U
653#define SMSC9218I_PHY_CSIR_FEFIEN 0x00000020U
654#define SMSC9218I_PHY_CSIR_XPOL 0x00000010U
655
663#define SMSC9218I_PHY_ISR 0x0000001dU
664#define SMSC9218I_PHY_ISR_INT7 0x00000080U
665#define SMSC9218I_PHY_ISR_INT6 0x00000040U
666#define SMSC9218I_PHY_ISR_INT5 0x00000020U
667#define SMSC9218I_PHY_ISR_INT4 0x00000010U
668#define SMSC9218I_PHY_ISR_INT3 0x00000008U
669#define SMSC9218I_PHY_ISR_INT2 0x00000004U
670#define SMSC9218I_PHY_ISR_INT1 0x00000002U
671
679#define SMSC9218I_PHY_IMR 0x0000001eU
680#define SMSC9218I_PHY_IMR_INT7 0x00000080U
681#define SMSC9218I_PHY_IMR_INT6 0x00000040U
682#define SMSC9218I_PHY_IMR_INT5 0x00000020U
683#define SMSC9218I_PHY_IMR_INT4 0x00000010U
684#define SMSC9218I_PHY_IMR_INT3 0x00000008U
685#define SMSC9218I_PHY_IMR_INT2 0x00000004U
686#define SMSC9218I_PHY_IMR_INT1 0x00000002U
687
695#define SMSC9218I_PHY_PHYSCSR 0x0000001fU
696#define SMSC9218I_PHY_PHYSCSR_ANDONE 0x00001000U
697#define SMSC9218I_PHY_PHYSCSR_4B5B_EN 0x00000040U
698#define SMSC9218I_PHY_PHYSCSR_SPEED_MASK 0x0000001cU
699#define SMSC9218I_PHY_PHYSCSR_SPEED_10HD 0x00000004U
700#define SMSC9218I_PHY_PHYSCSR_SPEED_10FD 0x00000014U
701#define SMSC9218I_PHY_PHYSCSR_SPEED_100HD 0x00000008U
702#define SMSC9218I_PHY_PHYSCSR_SPEED_100FD 0x00000018U
703
Definition: smsc9218i.h:30
