RTEMS 5.2-rc1
1#ifndef _SMC91111_CONFIG_H_
2#define _SMC91111_CONFIG_H_
8#define INTERRUPT_EVENT RTEMS_EVENT_1
14#define START_TRANSMIT_EVENT RTEMS_EVENT_2
17#define SMC91111_TX_WAIT_EVENT RTEMS_EVENT_3
28#if (MCLBYTES < RBUF_SIZE)
29# error "Driver must have MCLBYTES > RBUF_SIZE"
34#define LAN91CXX_32BIT_RX
35#define LAN91CXX_IS_LAN91C111
41typedef uint32_t CYG_WORD;
42typedef uint8_t CYG_BYTE;
43typedef uint16_t CYG_WORD16;
44typedef uint32_t CYG_WORD32;
47# define CYG_SWAP16(_x_) \
48 ({ uint16_t _x = (_x_); ((_x << 8) | (_x >> 8)); })
52# define CYG_SWAP32(_x_) \
53 ({ uint32_t _x = (_x_); \
55 ((0x0000FF00UL & _x) << 8) | \
56 ((0x00FF0000UL & _x) >> 8) | \
60# define CYG_CPU_TO_BE16(_x_) (_x_)
61# define CYG_CPU_TO_BE32(_x_) (_x_)
62# define CYG_BE16_TO_CPU(_x_) (_x_)
63# define CYG_BE32_TO_CPU(_x_) (_x_)
65# define CYG_CPU_TO_LE16(_x_) CYG_SWAP16((_x_))
66# define CYG_CPU_TO_LE32(_x_) CYG_SWAP32((_x_))
67# define CYG_LE16_TO_CPU(_x_) CYG_SWAP16((_x_))
68# define CYG_LE32_TO_CPU(_x_) CYG_SWAP32((_x_))
70#define CYG_MACRO_START do {
71#define CYG_MACRO_END } while (0)
72#define HAL_IO_BARRIER() \
73 __asm__ volatile ( "" : : : "memory" )
75#define HAL_READ_UINT8( _register_, _value_ ) \
77 ((_value_) = *((volatile CYG_BYTE *)(_register_))); \
81#define HAL_WRITE_UINT8( _register_, _value_ ) \
83 (*((volatile CYG_BYTE *)(_register_)) = (_value_)); \
87#define HAL_READ_UINT16( _register_, _value_ ) \
89 ((_value_) = *((volatile CYG_WORD16 *)(_register_))); \
93#define HAL_WRITE_UINT16( _register_, _value_ ) \
95 (*((volatile CYG_WORD16 *)(_register_)) = (_value_)); \
99#define HAL_READ_UINT32( _register_, _value_ ) \
101 ((_value_) = *((volatile CYG_WORD32 *)(_register_))); \
105#define HAL_READ_UINT16( _register_, _value_ ) \
107 ((_value_) = *((volatile CYG_WORD16 *)(_register_))); \
111#define CYG_ASSERT(c,p) do { if (!(c)) { while(1) { printf(p);} }; } while(0)
113#define HAL_DELAY_US(p) rtems_task_wake_after (RTEMS_MICROSECONDS_TO_TICKS (p))
