RTEMS 5.2-rc1
smc91111.h
1#ifndef _SMC91111_H_
2#define _SMC91111_H_
3
4#include <libchip/smc91111exp.h>
5#include <rtems/bspIo.h>
6
7#define LAN91CXX_TCR 0x00
8#define LAN91CXX_EPH_STATUS 0x01
9#define LAN91CXX_RCR 0x02
10#define LAN91CXX_COUNTER 0x03
11#define LAN91CXX_MIR 0x04
12#define LAN91CXX_MCR 0x05 /* Other than 91C111*/
13#define LAN91CXX_RPCR 0x05 /* 91C111 only*/
14#define LAN91CXX_RESERVED_0 0x06
15#define LAN91CXX_BS 0x07
16#define LAN91CXX_CONFIG 0x08
17#define LAN91CXX_BASE_REG 0x09
18#define LAN91CXX_IA01 0x0a
19#define LAN91CXX_IA23 0x0b
20#define LAN91CXX_IA45 0x0c
21#define LAN91CXX_GENERAL 0x0d /* 91C96 - was "RESERVED_1" for others*/
22#define LAN91CXX_CONTROL 0x0e
23#define LAN91CXX_BS2 0x0f
24#define LAN91CXX_MMU_COMMAND 0x10
25#define LAN91CXX_PNR 0x11
26#define LAN91CXX_FIFO_PORTS 0x12
27#define LAN91CXX_POINTER 0x13
28#define LAN91CXX_DATA_HIGH 0x14
29#define LAN91CXX_DATA 0x15
30#define LAN91CXX_INTERRUPT 0x16
31#define LAN91CXX_BS3 0x17
32#define LAN91CXX_MT01 0x18
33#define LAN91CXX_MT23 0x19
34#define LAN91CXX_MT45 0x1a
35#define LAN91CXX_MT67 0x1b
36#define LAN91CXX_MGMT 0x1c
37#define LAN91CXX_REVISION 0x1d
38#define LAN91CXX_ERCV 0x1e
39#define LAN91CXX_BS4 0x1f
40
41#define LAN91CXX_RCR_SOFT_RST 0x8000 /* soft reset*/
42#define LAN91CXX_RCR_FILT_CAR 0x4000 /* filter carrier*/
43#define LAN91CXX_RCR_ABORT_ENB 0x2000 /* abort on collision*/
44#define LAN91CXX_RCR_STRIP_CRC 0x0200 /* strip CRC*/
45#define LAN91CXX_RCR_RXEN 0x0100 /* enable RX*/
46#define LAN91CXX_RCR_ALMUL 0x0004 /* receive all muticasts*/
47#define LAN91CXX_RCR_PRMS 0x0002 /* promiscuous*/
48#define LAN91CXX_RCR_RX_ABORT 0x0001 /* set when abort due to long frame*/
49
50#define LAN91CXX_TCR_SWFDUP 0x8000 /* Switched Full Duplex mode*/
51#define LAN91CXX_TCR_ETEN_TYPE 0x4000 /* ETEN type (91C96) 0 <=> like a 91C94*/
52#define LAN91CXX_TCR_EPH_LOOP 0x2000 /* loopback mode*/
53#define LAN91CXX_TCR_STP_SQET 0x1000 /* Stop transmission on SQET error*/
54#define LAN91CXX_TCR_FDUPLX 0x0800 /* full duplex*/
55#define LAN91CXX_TCR_MON_CSN 0x0400 /* monitor carrier during tx (91C96)*/
56#define LAN91CXX_TCR_NOCRC 0x0100 /* does not append CRC to frames*/
57#define LAN91CXX_TCR_PAD_EN 0x0080 /* pads frames with 00 to min length*/
58#define LAN91CXX_TCR_FORCOL 0x0004 /* force collision*/
59#define LAN91CXX_TCR_LLOOP 0x0002 /* local loopback (91C96)*/
60#define LAN91CXX_TCR_TXENA 0x0001 /* enable*/
61
62#define LAN91CXX_POINTER_RCV 0x8000
63#define LAN91CXX_POINTER_AUTO_INCR 0x4000
64#define LAN91CXX_POINTER_READ 0x2000
65#define LAN91CXX_POINTER_ETEN 0x1000
66#define LAN91CXX_POINTER_NOT_EMPTY 0x0800
67
68
69#define LAN91CXX_INTERRUPT_TX_IDLE_M 0x8000 /* (91C96)*/
70#define LAN91CXX_INTERRUPT_ERCV_INT_M 0x4000
71#define LAN91CXX_INTERRUPT_EPH_INT_M 0x2000
72#define LAN91CXX_INTERRUPT_RX_OVRN_INT_M 0x1000
73#define LAN91CXX_INTERRUPT_ALLOC_INT_M 0x0800
74#define LAN91CXX_INTERRUPT_TX_EMPTY_INT_M 0x0400
75#define LAN91CXX_INTERRUPT_TX_INT_M 0x0200
76#define LAN91CXX_INTERRUPT_RCV_INT_M 0x0100
77#define LAN91CXX_INTERRUPT_TX_IDLE 0x0080 /* (91C96)*/
78#define LAN91CXX_INTERRUPT_ERCV_INT 0x0040 /* also ack*/
79#define LAN91CXX_INTERRUPT_EPH_INT 0x0020
80#define LAN91CXX_INTERRUPT_RX_OVRN_INT 0x0010 /* also ack*/
81#define LAN91CXX_INTERRUPT_ALLOC_INT 0x0008
82#define LAN91CXX_INTERRUPT_TX_EMPTY_INT 0x0004 /* also ack*/
83#define LAN91CXX_INTERRUPT_TX_INT 0x0002 /* also ack*/
84#define LAN91CXX_INTERRUPT_RCV_INT 0x0001
85
86#define LAN91CXX_INTERRUPT_TX_SET 0x0006 /* TX_EMPTY + TX*/
87#define LAN91CXX_INTERRUPT_TX_SET_ACK 0x0004 /* TX_EMPTY and not plain TX*/
88#define LAN91CXX_INTERRUPT_TX_FIFO_ACK 0x0002 /* TX alone*/
89#define LAN91CXX_INTERRUPT_TX_SET_M 0x0600 /* TX_EMPTY + TX*/
90
91#define LAN91CXX_CONTROL_RCV_BAD 0x4000
92#define LAN91CXX_CONTROL_AUTO_RELEASE 0x0800
93#define LAN91CXX_CONTROL_LE_ENABLE 0x0080
94#define LAN91CXX_CONTROL_CR_ENABLE 0x0040
95#define LAN91CXX_CONTROL_TE_ENABLE 0x0020
96
97/* These are for setting the MAC address in the 91C96 serial EEPROM*/
98#define LAN91CXX_CONTROL_EEPROM_SELECT 0x0004
99#define LAN91CXX_CONTROL_RELOAD 0x0002
100#define LAN91CXX_CONTROL_STORE 0x0001
101#define LAN91CXX_CONTROL_EEPROM_BUSY 0x0003
102#define LAN91CXX_ESA_EEPROM_OFFSET 0x0020
103
104#define LAN91CXX_STATUS_TX_UNRN 0x8000
105#define LAN91CXX_STATUS_LINK_OK 0x4000
106#define LAN91CXX_STATUS_CTR_ROL 0x1000
107#define LAN91CXX_STATUS_EXC_DEF 0x0800
108#define LAN91CXX_STATUS_LOST_CARR 0x0400
109#define LAN91CXX_STATUS_LATCOL 0x0200
110#define LAN91CXX_STATUS_WAKEUP 0x0100
111#define LAN91CXX_STATUS_TX_DEFR 0x0080
112#define LAN91CXX_STATUS_LTX_BRD 0x0040
113#define LAN91CXX_STATUS_SQET 0x0020
114#define LAN91CXX_STATUS_16COL 0x0010
115#define LAN91CXX_STATUS_LTX_MULT 0x0008
116#define LAN91CXX_STATUS_MUL_COL 0x0004
117#define LAN91CXX_STATUS_SNGL_COL 0x0002
118#define LAN91CXX_STATUS_TX_SUC 0x0001
119
120#define LAN91CXX_MMU_COMMAND_BUSY 0x0001
121
122#define LAN91CXX_MMU_noop 0x0000
123#define LAN91CXX_MMU_alloc_for_tx 0x0020
124#define LAN91CXX_MMU_reset_mmu 0x0040
125#define LAN91CXX_MMU_rem_rx_frame 0x0060
126#define LAN91CXX_MMU_rem_tx_frame 0x0070 /* (91C96) only when TX stopped*/
127#define LAN91CXX_MMU_remrel_rx_frame 0x0080
128#define LAN91CXX_MMU_rel_packet 0x00a0
129#define LAN91CXX_MMU_enq_packet 0x00c0
130#define LAN91CXX_MMU_reset_tx_fifo 0x00e0
131
132#define LAN91CXX_CONTROLBYTE_CRC 0x1000
133#define LAN91CXX_CONTROLBYTE_ODD 0x2000
134#define LAN91CXX_CONTROLBYTE_RX 0x4000
135
136#define LAN91CXX_RX_STATUS_ALIGNERR 0x8000
137#define LAN91CXX_RX_STATUS_BCAST 0x4000
138#define LAN91CXX_RX_STATUS_BADCRC 0x2000
139#define LAN91CXX_RX_STATUS_ODDFRM 0x1000
140#define LAN91CXX_RX_STATUS_TOOLONG 0x0800
141#define LAN91CXX_RX_STATUS_TOOSHORT 0x0400
142#define LAN91CXX_RX_STATUS_HASHVALMASK 0x007e /* MASK*/
143#define LAN91CXX_RX_STATUS_MCAST 0x0001
144#define LAN91CXX_RX_STATUS_BAD \
145 (LAN91CXX_RX_STATUS_ALIGNERR | \
146 LAN91CXX_RX_STATUS_BADCRC | \
147 LAN91CXX_RX_STATUS_TOOLONG | \
148 LAN91CXX_RX_STATUS_TOOSHORT)
149
150#define LAN91CXX_RX_STATUS_IS_ODD(__cpd,__stat) ((__stat) & LAN91CXX_RX_STATUS_ODDFRM)
151#define LAN91CXX_CONTROLBYTE_IS_ODD(__cpd,__val) ((__val) & LAN91CXX_CONTROLBYTE_ODD)
152
153/* Attribute memory registers in PCMCIA mode*/
154#define LAN91CXX_ECOR 0x8000
155#define LAN91CXX_ECOR_RESET (1<<7)
156#define LAN91CXX_ECOR_LEVIRQ (1<<6)
157#define LAN91CXX_ECOR_ATTWR (1<<2)
158#define LAN91CXX_ECOR_ENABLE (1<<0)
159
160#define LAN91CXX_ECSR 0x8002
161#define LAN91CXX_ECSR_IOIS8 (1<<5)
162#define LAN91CXX_ECSR_PWRDWN (1<<2)
163#define LAN91CXX_ECSR_INTR (1<<1)
164
165/* These are for manipulating the MII interface*/
166#define LAN91CXX_MGMT_MDO 0x0001
167#define LAN91CXX_MGMT_MDI 0x0002
168#define LAN91CXX_MGMT_MCLK 0x0004
169#define LAN91CXX_MGMT_MDOE 0x0008
170
171/* Internal PHY registers (91c111)*/
172#define LAN91CXX_PHY_CTRL 0
173#define LAN91CXX_PHY_STAT 1
174#define LAN91CXX_PHY_ID1 2
175#define LAN91CXX_PHY_ID2 3
176#define LAN91CXX_PHY_AUTO_AD 4
177#define LAN91CXX_PHY_AUTO_CAP 5
178#define LAN91CXX_PHY_CONFIG1 16
179#define LAN91CXX_PHY_CONFIG2 17
180#define LAN91CXX_PHY_STATUS_OUT 18
181#define LAN91CXX_PHY_MASK 19
182
183/* PHY control bits*/
184#define LAN91CXX_PHY_CTRL_COLTST (1 << 7)
185#define LAN91CXX_PHY_CTRL_DPLX (1 << 8)
186#define LAN91CXX_PHY_CTRL_ANEG_RST (1 << 9)
187#define LAN91CXX_PHY_CTRL_MII_DIS (1 << 10)
188#define LAN91CXX_PHY_CTRL_PDN (1 << 11)
189#define LAN91CXX_PHY_CTRL_ANEG_EN (1 << 12)
190#define LAN91CXX_PHY_CTRL_SPEED (1 << 13)
191#define LAN91CXX_PHY_CTRL_LPBK (1 << 14)
192#define LAN91CXX_PHY_CTRL_RST (1 << 15)
193
194/* PHY Configuration Register 1 */
195#define PHY_CFG1_LNKDIS 0x8000 /* 1=Rx Link Detect Function disabled */
196#define PHY_CFG1_XMTDIS 0x4000 /* 1=TP Transmitter Disabled */
197#define PHY_CFG1_XMTPDN 0x2000 /* 1=TP Transmitter Powered Down */
198#define PHY_CFG1_BYPSCR 0x0400 /* 1=Bypass scrambler/descrambler */
199#define PHY_CFG1_UNSCDS 0x0200 /* 1=Unscramble Idle Reception Disable */
200#define PHY_CFG1_EQLZR 0x0100 /* 1=Rx Equalizer Disabled */
201#define PHY_CFG1_CABLE 0x0080 /* 1=STP(150ohm), 0=UTP(100ohm) */
202#define PHY_CFG1_RLVL0 0x0040 /* 1=Rx Squelch level reduced by 4.5db */
203#define PHY_CFG1_TLVL_SHIFT 2 /* Transmit Output Level Adjust */
204#define PHY_CFG1_TLVL_MASK 0x003C
205#define PHY_CFG1_TRF_MASK 0x0003 /* Transmitter Rise/Fall time */
206
207/* PHY Configuration Register 2 */
208#define PHY_CFG2_REG 0x11
209#define PHY_CFG2_APOLDIS 0x0020 /* 1=Auto Polarity Correction disabled */
210#define PHY_CFG2_JABDIS 0x0010 /* 1=Jabber disabled */
211#define PHY_CFG2_MREG 0x0008 /* 1=Multiple register access (MII mgt) */
212#define PHY_CFG2_INTMDIO 0x0004 /* 1=Interrupt signaled with MDIO pulseo */
213
214/* PHY Status Output (and Interrupt status) Register */
215#define PHY_INT_REG 0x12 /* Status Output (Interrupt Status) */
216#define PHY_INT_INT 0x8000 /* 1=bits have changed since last read */
217#define PHY_INT_LNKFAIL 0x4000 /* 1=Link Not detected */
218#define PHY_INT_LOSSSYNC 0x2000 /* 1=Descrambler has lost sync */
219#define PHY_INT_CWRD 0x1000 /* 1=Invalid 4B5B code detected on rx */
220#define PHY_INT_SSD 0x0800 /* 1=No Start Of Stream detected on rx */
221#define PHY_INT_ESD 0x0400 /* 1=No End Of Stream detected on rx */
222#define PHY_INT_RPOL 0x0200 /* 1=Reverse Polarity detected */
223#define PHY_INT_JAB 0x0100 /* 1=Jabber detected */
224#define PHY_INT_SPDDET 0x0080 /* 1=100Base-TX mode, 0=10Base-T mode */
225#define PHY_INT_DPLXDET 0x0040 /* 1=Device in Full Duplex */
226
227/* PHY Interrupt/Status Mask Register */
228#define PHY_MASK_REG 0x13 /* Interrupt Mask */
229
230#define LAN91CXX_RPCR_LEDA_LINK (0 << 2)
231#define LAN91CXX_RPCR_LEDA_TXRX (4 << 2)
232#define LAN91CXX_RPCR_LEDA_RX (6 << 2)
233#define LAN91CXX_RPCR_LEDA_TX (7 << 2)
234#define LAN91CXX_RPCR_LEDB_LINK (0 << 5)
235#define LAN91CXX_RPCR_LEDB_TXRX (4 << 5)
236#define LAN91CXX_RPCR_LEDB_RX (6 << 5)
237#define LAN91CXX_RPCR_LEDB_TX (7 << 5)
238#define LAN91CXX_RPCR_ANEG (1 << 11)
239#define LAN91CXX_RPCR_DPLX (1 << 12)
240#define LAN91CXX_RPCR_SPEED (1 << 13)
241
242/* PHY Control Register */
243#define PHY_CNTL_REG 0x00
244#define PHY_CNTL_RST 0x8000 /* 1=PHY Reset */
245#define PHY_CNTL_LPBK 0x4000 /* 1=PHY Loopback */
246#define PHY_CNTL_SPEED 0x2000 /* 1=100Mbps, 0=10Mpbs */
247#define PHY_CNTL_ANEG_EN 0x1000 /* 1=Enable Auto negotiation */
248#define PHY_CNTL_PDN 0x0800 /* 1=PHY Power Down mode */
249#define PHY_CNTL_MII_DIS 0x0400 /* 1=MII 4 bit interface disabled */
250#define PHY_CNTL_ANEG_RST 0x0200 /* 1=Reset Auto negotiate */
251#define PHY_CNTL_DPLX 0x0100 /* 1=Full Duplex, 0=Half Duplex */
252#define PHY_CNTL_COLTST 0x0080 /* 1= MII Colision Test */
253
254/* PHY Status Register */
255#define PHY_STAT_REG 0x01
256#define PHY_STAT_CAP_T4 0x8000 /* 1=100Base-T4 capable */
257#define PHY_STAT_CAP_TXF 0x4000 /* 1=100Base-X full duplex capable */
258#define PHY_STAT_CAP_TXH 0x2000 /* 1=100Base-X half duplex capable */
259#define PHY_STAT_CAP_TF 0x1000 /* 1=10Mbps full duplex capable */
260#define PHY_STAT_CAP_TH 0x0800 /* 1=10Mbps half duplex capable */
261#define PHY_STAT_CAP_SUPR 0x0040 /* 1=recv mgmt frames with not preamble */
262#define PHY_STAT_ANEG_ACK 0x0020 /* 1=ANEG has completed */
263#define PHY_STAT_REM_FLT 0x0010 /* 1=Remote Fault detected */
264#define PHY_STAT_CAP_ANEG 0x0008 /* 1=Auto negotiate capable */
265#define PHY_STAT_LINK 0x0004 /* 1=valid link */
266#define PHY_STAT_JAB 0x0002 /* 1=10Mbps jabber condition */
267#define PHY_STAT_EXREG 0x0001 /* 1=extended registers implemented */
268#define PHY_STAT_RESERVED 0x0780 /* Reserved bits mask. */
269
270/* PHY Identifier Registers */
271#define PHY_ID1_REG 0x02 /* PHY Identifier 1 */
272#define PHY_ID2_REG 0x03 /* PHY Identifier 2 */
273
274/* PHY Auto-Negotiation Advertisement Register */
275#define PHY_AD_REG 0x04
276#define PHY_AD_NP 0x8000 /* 1=PHY requests exchange of Next Page */
277#define PHY_AD_ACK 0x4000 /* 1=got link code word from remote */
278#define PHY_AD_RF 0x2000 /* 1=advertise remote fault */
279#define PHY_AD_T4 0x0200 /* 1=PHY is capable of 100Base-T4 */
280#define PHY_AD_TX_FDX 0x0100 /* 1=PHY is capable of 100Base-TX FDPLX */
281#define PHY_AD_TX_HDX 0x0080 /* 1=PHY is capable of 100Base-TX HDPLX */
282#define PHY_AD_10_FDX 0x0040 /* 1=PHY is capable of 10Base-T FDPLX */
283#define PHY_AD_10_HDX 0x0020 /* 1=PHY is capable of 10Base-T HDPLX */
284#define PHY_AD_CSMA 0x0001 /* 1=PHY is capable of 802.3 CMSA */
285
286
287static int debugflag_out = 0;
288
289#define dbc_printf(lvl,format, args...) do { \
290 if (!debugflag_out) { \
291 if (lvl & DEBUG) { \
292 printk(format,##args); \
293 } \
294 } \
295} while(0)
296
297#define db64_printf(format, args...) dbc_printf(64,format,##args);
298#define db16_printf(format, args...) dbc_printf(16,format,##args);
299#define db9_printf(format, args...) dbc_printf(9,format,##args);
300#define db4_printf(format, args...) dbc_printf(4,format,##args);
301#define db2_printf(format, args...) dbc_printf(2,format,##args);
302#define db1_printf(format, args...) dbc_printf(1,format,##args);
303#define db_printf(format, args...) dbc_printf(0xffff,format,##args);
304
305#if DEBUG & 1
306#define DEBUG_FUNCTION() do { db_printf("# %s\n", __FUNCTION__); } while (0)
307#else
308#define DEBUG_FUNCTION() do {} while(0)
309#endif
310
311
312/* ------------------------------------------------------------------------*/
313
315 unsigned int tx_good ;
316 unsigned int tx_max_collisions ;
317 unsigned int tx_late_collisions ;
318 unsigned int tx_underrun ;
319 unsigned int tx_carrier_loss ;
320 unsigned int tx_deferred ;
321 unsigned int tx_sqetesterrors ;
322 unsigned int tx_single_collisions;
323 unsigned int tx_mult_collisions ;
324 unsigned int tx_total_collisions ;
325 unsigned int rx_good ;
326 unsigned int rx_crc_errors ;
327 unsigned int rx_align_errors ;
328 unsigned int rx_resource_errors ;
329 unsigned int rx_overrun_errors ;
330 unsigned int rx_collisions ;
331 unsigned int rx_short_frames ;
332 unsigned int rx_too_long_frames ;
333 unsigned int rx_symbol_errors ;
334 unsigned int interrupts ;
335 unsigned int rx_count ;
336 unsigned int rx_deliver ;
337 unsigned int rx_resource ;
338 unsigned int rx_restart ;
339 unsigned int tx_count ;
340 unsigned int tx_complete ;
341 unsigned int tx_dropped ;
342};
343#define INCR_STAT(c,n) (((c)->stats.n)++)
344
345struct lan91cxx_priv_data;
346
347typedef struct lan91cxx_priv_data {
348
349 /* frontend */
350 struct arpcom arpcom;
351 rtems_id rxDaemonTid;
352 rtems_id txDaemonTid;
353
355
356 /* backend */
357 int rpc_cur_mode;
358 int autoneg_active;
359 int phyaddr;
360 unsigned int lastPhy18;
361
362 int txbusy; /* A packet has been sent*/
363 unsigned long txkey; /* Used to ack when packet sent*/
364 unsigned short* base; /* Base I/O address of controller*/
365 /* (as it comes out of reset)*/
366 int interrupt; /* Interrupt vector used by controller*/
367 unsigned char enaddr[6]; /* Controller ESA*/
368 /* Function to configure the ESA - may fetch ESA from EPROM or */
369 /* RedBoot config option. Use of the 'config_enaddr()' function*/
370 /* is depreciated in favor of the 'provide_esa()' function and*/
371 /* 'hardwired_esa' boolean*/
372 void (*config_enaddr)(struct lan91cxx_priv_data* cpd);
373 int hardwired_esa;
374 int txpacket;
375 int rxpacket;
376 int within_send;
377 int c111_reva; /* true if this is a revA LAN91C111*/
378 struct smsc_lan91cxx_stats stats;
380
381/* ------------------------------------------------------------------------*/
382
383#ifdef LAN91CXX_32BIT_RX
384typedef unsigned int rxd_t;
385#else
386typedef unsigned short rxd_t;
387#endif
388
389typedef struct _debug_regs_pair {
390 int reg; char *name; struct _debug_regs_pair *bits;
392
393static debug_regs_pair debug_regs[] = {
394 {LAN91CXX_TCR , "LAN91CXX_TCR" ,0},
395 {LAN91CXX_EPH_STATUS , "LAN91CXX_EPH_STATUS",0},
396 {LAN91CXX_RCR , "LAN91CXX_RCR" ,0},
397 {LAN91CXX_COUNTER , "LAN91CXX_COUNTER" ,0},
398 {LAN91CXX_MIR , "LAN91CXX_MIR" ,0},
399 {LAN91CXX_MCR , "LAN91CXX_MCR" ,0},
400 {LAN91CXX_RPCR , "LAN91CXX_RPCR" ,0},
401 {LAN91CXX_RESERVED_0 , "LAN91CXX_RESERVED_0",0},
402 {LAN91CXX_BS , "LAN91CXX_BS" ,0},
403 {LAN91CXX_CONFIG , "LAN91CXX_CONFIG" ,0},
404 {LAN91CXX_BASE_REG , "LAN91CXX_BASE_REG" ,0},
405 {LAN91CXX_IA01 , "LAN91CXX_IA01" ,0},
406 {LAN91CXX_IA23 , "LAN91CXX_IA23" ,0},
407 {LAN91CXX_IA45 , "LAN91CXX_IA45" ,0},
408 {LAN91CXX_GENERAL , "LAN91CXX_GENERAL" ,0},
409 {LAN91CXX_CONTROL , "LAN91CXX_CONTROL" ,0},
410 {LAN91CXX_BS2 , "LAN91CXX_BS2" ,0},
411 {LAN91CXX_MMU_COMMAND, "LAN91CXX_MMU_COMMAND",0},
412 {LAN91CXX_PNR , "LAN91CXX_PNR" ,0},
413 {LAN91CXX_FIFO_PORTS , "LAN91CXX_FIFO_PORTS" ,0},
414 {LAN91CXX_POINTER , "LAN91CXX_POINTER" ,0},
415 {LAN91CXX_DATA_HIGH , "LAN91CXX_DATA_HIGH" ,0},
416 {LAN91CXX_DATA , "LAN91CXX_DATA" ,0},
417 {LAN91CXX_INTERRUPT , "LAN91CXX_INTERRUPT" ,0},
418 {LAN91CXX_BS3 , "LAN91CXX_BS3" ,0},
419 {LAN91CXX_MT01 , "LAN91CXX_MT01" ,0},
420 {LAN91CXX_MT23 , "LAN91CXX_MT23" ,0},
421 {LAN91CXX_MT45 , "LAN91CXX_MT45" ,0},
422 {LAN91CXX_MT67 , "LAN91CXX_MT67" ,0},
423/*{LAN91CXX_MGMT , "LAN91CXX_MGMT" ,0}, */
424 {LAN91CXX_REVISION , "LAN91CXX_REVISION" ,0},
425 {LAN91CXX_ERCV , "LAN91CXX_ERCV" ,0},
426 {LAN91CXX_BS4 , "LAN91CXX_BS4" ,0},
427
428
429
430 {-1,0}
431};
432
433static char *dbg_prefix = "";
434
435#ifndef SMSC_PLATFORM_DEFINED_GET_REG
436static __inline__ unsigned short
437get_reg(struct lan91cxx_priv_data *cpd, int regno)
438{
439 unsigned short val; debug_regs_pair *dbg = debug_regs; int c;
440 uint32_t Irql;
441
442 /*rtems_interrupt_disable(Irql);*/
443
444 HAL_WRITE_UINT16(cpd->base+(LAN91CXX_BS), CYG_CPU_TO_LE16(regno>>3));
445 HAL_READ_UINT16(cpd->base+((regno&0x7)), val);
446 val = CYG_LE16_TO_CPU(val);
447
448 /*rtems_interrupt_enable(Irql);*/
449
450#if DEBUG & 32
451 while ((c = dbg->reg) != -1) {
452 if (c == regno) {
453 db_printf("%sread reg [%d:%x] -> 0x%04x (%-20s)\n", dbg_prefix, regno>>3,(regno&0x7)*2, val, dbg->name);
454 break;
455 }
456 dbg++;
457 }
458#else
459 db2_printf("%sread reg %d:%x -> 0x%04x\n", dbg_prefix, regno>>3,(regno&0x7)*2, val);
460#endif
461
462 return val;
463}
464#endif /* SMSC_PLATFORM_DEFINED_GET_REG*/
465
466#ifndef SMSC_PLATFORM_DEFINED_PUT_REG
467static __inline__ void
468put_reg(struct lan91cxx_priv_data *cpd, int regno, unsigned short val)
469{
470 debug_regs_pair *dbg = debug_regs; int c;
471 uint32_t Irql;
472
473#if DEBUG & 32
474 while ((c = dbg->reg) != -1) {
475 if (c == regno) {
476 db_printf("%swrite reg [%d:%x] <- 0x%04x (%-20s)\n", dbg_prefix, regno>>3, (regno&0x07)*2, val, dbg->name);
477 break;
478 }
479 dbg++;
480 }
481#else
482 db2_printf("%swrite reg %d:%x <- 0x%04x\n", dbg_prefix, regno>>3,(regno&0x7)*2, val);
483#endif
484
485 /*rtems_interrupt_disable(Irql);*/
486
487 HAL_WRITE_UINT16(cpd->base+(LAN91CXX_BS), CYG_CPU_TO_LE16(regno>>3));
488 HAL_WRITE_UINT16(cpd->base+((regno&0x7)), CYG_CPU_TO_LE16(val));
489
490 /*rtems_interrupt_enable(Irql);*/
491
492}
493#endif /* SMSC_PLATFORM_DEFINED_PUT_REG*/
494
495#ifndef SMSC_PLATFORM_DEFINED_PUT_DATA
496/* ------------------------------------------------------------------------*/
497/* Assumes bank2 has been selected*/
498static __inline__ void
499put_data(struct lan91cxx_priv_data *cpd, unsigned short val)
500{
501 db2_printf("%s[wdata] <- 0x%04x\n", dbg_prefix, val);
502
503 HAL_WRITE_UINT16(cpd->base+((LAN91CXX_DATA & 0x7)), val);
504
505}
506
507/* Assumes bank2 has been selected*/
508static __inline__ void
509put_data8(struct lan91cxx_priv_data *cpd, unsigned char val)
510{
511 db2_printf("%s[bdata] <- 0x%02x\n", dbg_prefix, val);
512
513 HAL_WRITE_UINT8(((unsigned char *)(cpd->base+((LAN91CXX_DATA & 0x7))))+1, val);
514
515}
516
517#endif /* SMSC_PLATFORM_DEFINED_PUT_DATA*/
518
519#ifndef SMSC_PLATFORM_DEFINED_GET_DATA
520/* Assumes bank2 has been selected*/
521static __inline__ rxd_t
522get_data(struct lan91cxx_priv_data *cpd)
523{
524 rxd_t val;
525
526#ifdef LAN91CXX_32BIT_RX
527 HAL_READ_UINT32(cpd->base+((LAN91CXX_DATA_HIGH & 0x7)), val);
528#else
529 HAL_READ_UINT16(cpd->base+((LAN91CXX_DATA & 0x7)), val);
530#endif
531
532 db2_printf("%s[rdata] -> 0x%08x\n", dbg_prefix, val);
533 return val;
534}
535#endif /* SMSC_PLATFORM_DEFINED_GET_DATA*/
536
537/* ------------------------------------------------------------------------*/
538/* Read the bank register (this one is bank-independent)*/
539#ifndef SMSC_PLATFORM_DEFINED_GET_BANKSEL
540static __inline__ unsigned short
541get_banksel(struct lan91cxx_priv_data *cpd)
542{
543 unsigned short val;
544
545 HAL_READ_UINT16(cpd->base+(LAN91CXX_BS), val);
546 val = CYG_LE16_TO_CPU(val);
547 db2_printf("read bank sel val 0x%04x\n", val);
548 return val;
549}
550#endif
551
552
553
554
555
556#endif /* _SMC_91111_H_ */
557
558
Interface to Kernel Print Methods.
Objects_Id rtems_id
Used to manage and manipulate RTEMS object identifiers.
Definition: types.h:83
Definition: smc91111.h:389
Definition: deflate.c:115
Definition: smc91111.h:347
Definition: smc91111exp.h:6
Definition: smc91111.h:314
