RTEMS 5.2-rc1
slicetimer.h
1/*===============================================================*\
2| Project: RTEMS generic MPC5200 BSP |
3+-----------------------------------------------------------------+
4| Partially based on the code references which are named below. |
5| Adaptions, modifications, enhancements and any recent parts of |
6| the code are: |
7| Copyright (c) 2005 |
8| Embedded Brains GmbH |
9| Obere Lagerstr. 30 |
10| D-82178 Puchheim |
11| Germany |
12| rtems@embedded-brains.de |
13+-----------------------------------------------------------------+
14| The license and distribution terms for this file may be |
15| found in the file LICENSE in this distribution or at |
16| |
17| http://www.rtems.org/license/LICENSE. |
18| |
19+-----------------------------------------------------------------+
20| this file declares functions to use the slice timer module
21\*===============================================================*/
22#ifndef __SLICETIMER_H__
23#define __SLICETIMER_H__
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29#define SLT0 0
30#define SLT1 1
31
32#define SLT0_INT_FREQUENCY 10000
33#define SLT1_INT_FREQUENCY 0
34
35#define SLT_CNTRL_RW (1 << 26)
36#define SLT_CNTRL_INTEN (1 << 25)
37#define SLT_CNTRL_TIMEN (1 << 24)
38
39#define SLT_TSR_ST (1 << 24)
40
41#define SLT_TSR_COUNT(freq) ((freq) ? ((IPB_CLOCK)/(freq)) : (0xFFFFFF))
42
43rtems_device_driver slt_initialize( rtems_device_major_number,
44 rtems_device_minor_number,
45 void *
46 );
47
48#define SLTIME_DRIVER_TABLE_ENTRY \
49 { slt_initialize, NULL, NULL, \
50 NULL, NULL, NULL }
51
52void mpc5200_slt_isr(uint32_t);
53rtems_isr mpc5200_slt0_isr(rtems_irq_hdl_param);
54rtems_isr mpc5200_slt1_isr(rtems_irq_hdl_param);
55void mpc5200_init_slt(uint32_t);
56void mpc5200_set_slt_count(uint32_t);
57void mpc5200_enable_slt_int(uint32_t);
58void mpc5200_disable_slt_int(uint32_t);
59uint32_t mpc5200_check_slt_status(uint32_t);
60/*void sltOn(const rtems_irq_connect_data *);
61void sltOff(const rtems_irq_connect_data *);
62int sltIsOn(const rtems_irq_connect_data *);*/
63void Install_slt(rtems_device_minor_number);
64
65#ifdef __cplusplus
66}
67#endif
68
69#endif /* __SLICETIMER_H__ */
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition: intr.h:52
rtems_status_code
Classic API Status.
Definition: status.h:43
