RTEMS 5.2-rc1
shmimpl.h
1
8/*
9 * Copyright (c) 2016 Gedare Bloom.
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef _RTEMS_POSIX_SHMIMPL_H
17#define _RTEMS_POSIX_SHMIMPL_H
18
19#include <rtems/fs.h>
20#include <rtems/libio.h>
22#include <rtems/posix/shm.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
34RTEMS_INLINE_ROUTINE POSIX_Shm_Control *_POSIX_Shm_Allocate_unprotected( void )
35{
36 return (POSIX_Shm_Control *)
38}
39
46 POSIX_Shm_Control *the_shm
47)
48{
49 _Objects_Free( &_POSIX_Shm_Information, &the_shm->Object );
50}
51
52RTEMS_INLINE_ROUTINE POSIX_Shm_Control *_POSIX_Shm_Get_by_name(
53 const char *name,
54 size_t *name_length_p,
55 Objects_Get_by_name_error *error
56)
57{
60 name,
61 name_length_p,
62 error
63 );
64}
65
66RTEMS_INLINE_ROUTINE void _POSIX_Shm_Update_atime(
68)
69{
70 struct timeval now;
71 gettimeofday( &now, 0 );
72 shm->atime = now.tv_sec;
73}
74
75RTEMS_INLINE_ROUTINE void _POSIX_Shm_Update_mtime_ctime(
77)
78{
79 struct timeval now;
80 gettimeofday( &now, 0 );
81 shm->mtime = now.tv_sec;
82 shm->ctime = now.tv_sec;
83}
84
85static inline POSIX_Shm_Control* iop_to_shm( rtems_libio_t *iop )
86{
87 return (POSIX_Shm_Control*) iop->data1;
88}
89
90static inline POSIX_Shm_Control* loc_to_shm(
92)
93{
94 return (POSIX_Shm_Control*) loc->node_access;
95}
96
97static inline int POSIX_Shm_Attempt_delete(
99)
100{
101 Objects_Control *obj;
102 ISR_lock_Context lock_ctx;
103 int err;
104
105 err = 0;
106
108 --shm->reference_count;
109 if ( shm->reference_count == 0 ) {
110 if ( (*shm->shm_object.ops->object_delete)( &shm->shm_object ) != 0 ) {
111 err = EIO;
112 }
113 }
114 /* check if the object has been unlinked yet. */
115 obj = _Objects_Get( shm->Object.id, &lock_ctx, &_POSIX_Shm_Information );
116 if ( obj == NULL ) {
117 /* if it was unlinked, then it can be freed. */
118 _POSIX_Shm_Free( shm );
119 } else {
120 /* it will be freed when it is unlinked. */
121 _ISR_lock_ISR_enable( &lock_ctx );
122 }
124 return err;
125}
126
129#ifdef __cplusplus
130}
131#endif
132
133#endif
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
RTEMS_INLINE_ROUTINE void _POSIX_Shm_Free(POSIX_Shm_Control *the_shm)
POSIX Shared Memory Free.
Definition: shmimpl.h:45
Objects_Information _POSIX_Shm_Information
The POSIX Shared Memory objects information.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition: isrlock.h:419
Objects_Control * _Objects_Get_by_name(const Objects_Information *information, const char *name, size_t *name_length_p, Objects_Get_by_name_error *error)
Gets an object control block identified by its name.
Definition: objectnametoidstring.c:26
RTEMS_INLINE_ROUTINE void _Objects_Free(Objects_Information *information, Objects_Control *the_object)
Frees an object.
Definition: objectimpl.h:930
RTEMS_INLINE_ROUTINE Objects_Control * _Objects_Allocate_unprotected(Objects_Information *information)
Allocates an object without locking the allocator mutex.
Definition: objectimpl.h:874
RTEMS_INLINE_ROUTINE void _Objects_Allocator_lock(void)
Locks the object allocator mutex.
Definition: objectimpl.h:831
RTEMS_INLINE_ROUTINE void _Objects_Allocator_unlock(void)
Unlocks the object allocator mutex.
Definition: objectimpl.h:843
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:28
Basic Filesystem Types.
Basic IO API.
Inlined Routines in the Object Handler.
POSIX API Implementation.
Internal Support for POSIX Shared Memory.
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:65
Definition: objectdata.h:39
Objects_Id id
Definition: objectdata.h:43
Control for a POSIX Shared Memory Object.
Definition: shm.h:111
int(* object_delete)(POSIX_Shm_Object *shm_obj)
Deletes the shm_obj.
Definition: shm.h:88
const POSIX_Shm_Object_operations * ops
Implementation-specific operations on shm objects.
Definition: shm.h:56
File system location.
Definition: fs.h:53
An open file data structure.
Definition: libio.h:1320
