RTEMS 5.2-rc1
serdbg.h
1/*===============================================================*\
2| Project: RTEMS remote gdb over serial line |
3+-----------------------------------------------------------------+
4| File: serdbg.h |
5+-----------------------------------------------------------------+
6| Copyright (c) 2002 IMD |
7| Ingenieurbuero fuer Microcomputertechnik Th. Doerfler |
8| <Thomas.Doerfler@imd-systems.de> |
9| all rights reserved |
10+-----------------------------------------------------------------+
11| this file declares intialization functions to add |
12| a gdb remote debug stub to an RTEMS system |
13| |
14+-----------------------------------------------------------------+
15| date history ID |
16| ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
17| 04.04.02 creation doe |
18\*===============================================================*/
19#ifndef _SERDBG_H
20#define _SERDBG_H
21
22#include <rtems.h>
23#include <termios.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29typedef struct {
30 uint32_t baudrate; /* debug baud rate, e.g. 57600 */
31 void (*callout)(void); /* callout pointer during polling */
32 int (*open_io)(const char *dev_name, uint32_t baudrate); /* I/O open fnc */
33 const char *devname; /* debug device, e.g. "/dev/tty01" */
34 bool skip_init_bkpt; /* if TRUE, do not stop when initializing */
36
37/*
38 * must be defined in init module...
39 */
40extern serdbg_conf_t serdbg_conf;
41
42
43/*=========================================================================*\
44| Function: |
45\*-------------------------------------------------------------------------*/
46void putDebugChar
47(
48/*-------------------------------------------------------------------------*\
49| Purpose: |
50| send character to remote debugger |
51+---------------------------------------------------------------------------+
52| Input Parameters: |
53\*-------------------------------------------------------------------------*/
54 char c /* char to send */
55 );
56/*-------------------------------------------------------------------------*\
57| Return Value: |
58| <none> |
59\*=========================================================================*/
60
61/*=========================================================================*\
62| Function: |
63\*-------------------------------------------------------------------------*/
64int getDebugChar
65(
66/*-------------------------------------------------------------------------*\
67| Purpose: |
68| get character from remote debugger |
69+---------------------------------------------------------------------------+
70| Input Parameters: |
71\*-------------------------------------------------------------------------*/
72 void /* <none> */
73 );
74/*-------------------------------------------------------------------------*\
75| Return Value: |
76| <none> |
77\*=========================================================================*/
78
79/*=========================================================================*\
80| Function: |
81\*-------------------------------------------------------------------------*/
82void serdbg_exceptionHandler
83(
84/*-------------------------------------------------------------------------*\
85| Purpose: |
86| hook directly to an exception vector |
87+---------------------------------------------------------------------------+
88| Input Parameters: |
89\*-------------------------------------------------------------------------*/
90 int vecnum, /* vector index to hook at */
91 void *vector /* address of handler function */
92 );
93/*-------------------------------------------------------------------------*\
94| Return Value: |
95| <none> |
96\*=========================================================================*/
97
98/*=========================================================================*\
99| Function: |
100\*-------------------------------------------------------------------------*/
101int serdbg_init
102(
103/*-------------------------------------------------------------------------*\
104| Purpose: |
105| initialize remote gdb session over serial line |
106+---------------------------------------------------------------------------+
107| Input Parameters: |
108\*-------------------------------------------------------------------------*/
109 void
110 );
111/*-------------------------------------------------------------------------*\
112| Return Value: |
113| rtems_status_code |
114\*=========================================================================*/
115
116/*
117 * stuff from serdbgio.c
118 */
119/*=========================================================================*\
120| Function: |
121\*-------------------------------------------------------------------------*/
122int serdbg_open
123
124/*-------------------------------------------------------------------------*\
125| Purpose: |
126| try to open given serial debug port |
127+---------------------------------------------------------------------------+
128| Input Parameters: |
129\*-------------------------------------------------------------------------*/
130(
131 const char *dev_name, /* name of device to open */
132 uint32_t baudrate /* baud rate to use */
133 );
134/*-------------------------------------------------------------------------*\
135| Return Value: |
136| 0 on success, -1 and errno otherwise |
137\*=========================================================================*/
138
139
140extern int serdbg_init_dbg(void);
141
142/*
143 * Assumed to be provided by the BSP
144 */
145extern void set_debug_traps(void);
146extern void breakpoint(void);
147#ifdef __cplusplus
148}
149#endif
150
151#endif /* _SERDBG_H */
Definition: rtemsmain.c:734
Definition: serdbg.h:29
