RTEMS 5.2-rc1
sensor-lm75a.h
1
9/*
10 * Copyright (c) 2017 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _DEV_I2C_SENSOR_LM75A_H
24#define _DEV_I2C_SENSOR_LM75A_H
25
26#include <dev/i2c/i2c.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif /* __cplusplus */
31
42int i2c_dev_register_sensor_lm75a(
43 const char *bus_path,
44 const char *dev_path,
45 uint16_t address
46);
47
48typedef enum {
49 SENSOR_LM75A_GET_CONF = I2C_DEV_IO_CONTROL,
50 SENSOR_LM75A_SET_CONF,
51 SENSOR_LM75A_CLEAR_AND_SET_CONF,
52 SENSOR_LM75A_GET_TEMP,
53 SENSOR_LM75A_GET_TOS,
54 SENSOR_LM75A_SET_TOS,
55 SENSOR_LM75A_GET_THYST,
56 SENSOR_LM75A_SET_THYST
57} sensor_lm75a_command;
58
59static inline int sensor_lm75a_get_conf(int fd, uint8_t *val)
60{
61 return ioctl(fd, SENSOR_LM75A_GET_CONF, val);
62}
63
64static inline int sensor_lm75a_set_conf(int fd, uint8_t val)
65{
66 return ioctl(fd, SENSOR_LM75A_SET_CONF, (void *)(uintptr_t) val);
67}
68
69static inline int sensor_lm75a_clear_and_set_conf(
70 int fd,
71 uint8_t clear,
72 uint8_t set
73)
74{
75 uint16_t clear_and_set = (uint16_t) (((uint16_t) set << 8) | clear);
76
77 return ioctl(
78 fd,
79 SENSOR_LM75A_CLEAR_AND_SET_CONF,
80 (void *)(uintptr_t) clear_and_set
81 );
82}
83
84static inline int sensor_lm75a_get_temp(int fd, int16_t *val)
85{
86 return ioctl(fd, SENSOR_LM75A_GET_TEMP, val);
87}
88
89static inline int sensor_lm75a_get_temp_celsius(int fd, double *celsius)
90{
91 int rv;
92 int16_t val;
93
94 rv = ioctl(fd, SENSOR_LM75A_GET_TEMP, &val);
95 *celsius = (((int) val) >> 5) * 0.125;
96 return rv;
97}
98
99static inline int sensor_lm75a_get_tos(int fd, uint16_t *val)
100{
101 return ioctl(fd, SENSOR_LM75A_GET_TOS, val);
102}
103
104static inline int sensor_lm75a_set_tos(int fd, uint16_t val)
105{
106 return ioctl(fd, SENSOR_LM75A_SET_TOS, (void *)(uintptr_t) val);
107}
108
109static inline int sensor_lm75a_get_thyst(int fd, uint16_t *val)
110{
111 return ioctl(fd, SENSOR_LM75A_GET_THYST, val);
112}
113
114static inline int sensor_lm75a_set_thyst(int fd, uint16_t val)
115{
116 return ioctl(fd, SENSOR_LM75A_SET_THYST, (void *)(uintptr_t) val);
117}
118
121#ifdef __cplusplus
122}
123#endif /* __cplusplus */
124
125#endif /* _DEV_I2C_SENSOR_LM75A_H */
Inter-Integrated Circuit (I2C) Driver API.
#define I2C_DEV_IO_CONTROL
Base number for device IO control commands.
Definition: i2c.h:287
