RTEMS 5.2-rc1
schedulerprioritysmp.h
1
9/*
10 * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
11 *
12 * embedded brains GmbH
13 * Dornierstr. 4
14 * 82178 Puchheim
15 * Germany
16 * <rtems@embedded-brains.de>
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H
24#define _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H
25
29
30#ifdef __cplusplus
31extern "C" {
32#endif /* __cplusplus */
33
56typedef struct {
59 Chain_Control Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
61
66typedef struct {
71
77
81#define SCHEDULER_PRIORITY_SMP_ENTRY_POINTS \
82 { \
83 _Scheduler_priority_SMP_Initialize, \
84 _Scheduler_default_Schedule, \
85 _Scheduler_priority_SMP_Yield, \
86 _Scheduler_priority_SMP_Block, \
87 _Scheduler_priority_SMP_Unblock, \
88 _Scheduler_priority_SMP_Update_priority, \
89 _Scheduler_default_Map_priority, \
90 _Scheduler_default_Unmap_priority, \
91 _Scheduler_priority_SMP_Ask_for_help, \
92 _Scheduler_priority_SMP_Reconsider_help_request, \
93 _Scheduler_priority_SMP_Withdraw_node, \
94 _Scheduler_default_Pin_or_unpin, \
95 _Scheduler_default_Pin_or_unpin, \
96 _Scheduler_priority_SMP_Add_processor, \
97 _Scheduler_priority_SMP_Remove_processor, \
98 _Scheduler_priority_SMP_Node_initialize, \
99 _Scheduler_default_Node_destroy, \
100 _Scheduler_default_Release_job, \
101 _Scheduler_default_Cancel_job, \
102 _Scheduler_default_Tick, \
103 _Scheduler_SMP_Start_idle \
104 SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
105 }
106
115
125 const Scheduler_Control *scheduler,
126 Scheduler_Node *node,
127 Thread_Control *the_thread,
128 Priority_Control priority
129);
130
139 const Scheduler_Control *scheduler,
140 Thread_Control *thread,
141 Scheduler_Node *node
142);
143
152 const Scheduler_Control *scheduler,
153 Thread_Control *thread,
154 Scheduler_Node *node
155);
156
165 const Scheduler_Control *scheduler,
166 Thread_Control *the_thread,
167 Scheduler_Node *node
168);
169
181 const Scheduler_Control *scheduler,
182 Thread_Control *the_thread,
183 Scheduler_Node *node
184);
185
195 const Scheduler_Control *scheduler,
196 Thread_Control *the_thread,
197 Scheduler_Node *node
198);
199
210 const Scheduler_Control *scheduler,
211 Thread_Control *the_thread,
212 Scheduler_Node *node,
213 Thread_Scheduler_state next_state
214);
215
223 const Scheduler_Control *scheduler,
224 Thread_Control *idle
225);
226
236 const Scheduler_Control *scheduler,
237 struct Per_CPU_Control *cpu
238);
239
248 const Scheduler_Control *scheduler,
249 Thread_Control *thread,
250 Scheduler_Node *node
251);
252
255#ifdef __cplusplus
256}
257#endif /* __cplusplus */
258
259#endif /* _RTEMS_SCORE_SCHEDULERPRIORITYSMP_H */
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
void _Scheduler_priority_SMP_Unblock(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Unblocks the thread.
Definition: schedulerprioritysmp.c:152
void _Scheduler_priority_SMP_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Adds idle to scheduler.
Definition: schedulerprioritysmp.c:256
void _Scheduler_priority_SMP_Yield(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Performs the yield of a thread.
Definition: schedulerprioritysmp.c:287
void _Scheduler_priority_SMP_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Withdraws node operation.
Definition: schedulerprioritysmp.c:235
void _Scheduler_priority_SMP_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the node.
Definition: schedulerprioritysmp.c:188
void _Scheduler_priority_SMP_Initialize(const Scheduler_Control *scheduler)
Initializes the priority SMP scheduler.
Definition: schedulerprioritysmp.c:35
void _Scheduler_priority_SMP_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Reconsiders help operation.
Definition: schedulerprioritysmp.c:219
void _Scheduler_priority_SMP_Block(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Blocks the thread.
Definition: schedulerprioritysmp.c:93
void _Scheduler_priority_SMP_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes the node with the given priority.
Definition: schedulerprioritysmp.c:48
Thread_Control * _Scheduler_priority_SMP_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Removes an idle thread from the given cpu.
Definition: schedulerprioritysmp.c:272
bool _Scheduler_priority_SMP_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Asks for help operation.
Definition: schedulerprioritysmp.c:208
Thread Manipulation with the Priority-Based Scheduler.
SMP Scheduler API.
Constants and Structures Associated with the Scheduler.
Per CPU Core Structure.
Definition: percpu.h:347
Definition: prioritybitmap.h:42
Scheduler node for per-thread data.
Definition: schedulernode.h:79
Scheduler context specialization for SMP schedulers.
Definition: schedulersmp.h:46
Scheduler node specialization for SMP schedulers.
Definition: schedulersmp.h:100
Data for ready queue operations.
Definition: schedulerpriority.h:85
Scheduler context specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:56
Scheduler node specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:66
Scheduler_priority_Ready_queue Ready_queue
The associated ready queue of this node.
Definition: schedulerprioritysmp.h:75
Scheduler_SMP_Node Base
SMP scheduler node.
Definition: schedulerprioritysmp.h:70
Scheduler control.
Definition: scheduler.h:269
Definition: thread.h:732
Definition: chain.h:86
