RTEMS 5.2-rc1
schedulerpriorityaffinitysmp.h
1
9/*
10 * COPYRIGHT (c) 2014.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 */
17
18#ifndef _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
19#define _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H
20
25
26#include <sys/cpuset.h>
27
28#ifdef __cplusplus
29extern "C" {
30#endif /* __cplusplus */
31
53#define SCHEDULER_PRIORITY_AFFINITY_SMP_ENTRY_POINTS \
54 { \
55 _Scheduler_priority_SMP_Initialize, \
56 _Scheduler_default_Schedule, \
57 _Scheduler_priority_SMP_Yield, \
58 _Scheduler_priority_affinity_SMP_Block, \
59 _Scheduler_priority_affinity_SMP_Unblock, \
60 _Scheduler_priority_affinity_SMP_Update_priority, \
61 _Scheduler_default_Map_priority, \
62 _Scheduler_default_Unmap_priority, \
63 _Scheduler_priority_affinity_SMP_Ask_for_help, \
64 _Scheduler_priority_affinity_SMP_Reconsider_help_request, \
65 _Scheduler_priority_affinity_SMP_Withdraw_node, \
66 _Scheduler_default_Pin_or_unpin, \
67 _Scheduler_default_Pin_or_unpin, \
68 _Scheduler_priority_affinity_SMP_Add_processor, \
69 _Scheduler_priority_affinity_SMP_Remove_processor, \
70 _Scheduler_priority_affinity_SMP_Node_initialize, \
71 _Scheduler_default_Node_destroy, \
72 _Scheduler_default_Release_job, \
73 _Scheduler_default_Cancel_job, \
74 _Scheduler_default_Tick, \
75 _Scheduler_SMP_Start_idle, \
76 _Scheduler_priority_affinity_SMP_Set_affinity \
77 }
78
91 const Scheduler_Control *scheduler,
92 Scheduler_Node *node,
93 Thread_Control *the_thread,
94 Priority_Control priority
95);
96
105 const Scheduler_Control *scheduler,
106 Thread_Control *thread,
107 Scheduler_Node *node
108);
109
118 const Scheduler_Control *scheduler,
119 Thread_Control *thread,
120 Scheduler_Node *node
121);
122
131 const Scheduler_Control *scheduler,
132 Thread_Control *the_thread,
133 Scheduler_Node *node
134);
135
147 const Scheduler_Control *scheduler,
148 Thread_Control *the_thread,
149 Scheduler_Node *node
150);
151
161 const Scheduler_Control *scheduler,
162 Thread_Control *the_thread,
163 Scheduler_Node *node
164);
165
176 const Scheduler_Control *scheduler,
177 Thread_Control *the_thread,
178 Scheduler_Node *node,
179 Thread_Scheduler_state next_state
180);
181
189 const Scheduler_Control *scheduler,
190 Thread_Control *idle
191);
192
202 const Scheduler_Control *scheduler,
203 struct Per_CPU_Control *cpu
204);
205
218 const Scheduler_Control *scheduler,
219 Thread_Control *thread,
220 Scheduler_Node *node,
221 const Processor_mask *affinity
222);
223
230typedef struct {
235
239 Processor_mask Affinity;
241
244#ifdef __cplusplus
245}
246#endif /* __cplusplus */
247
248#endif /* _RTEMS_SCORE_SCHEDULERPRIORITYAFFINITYSMP_H */
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:70
Thread_Control * _Scheduler_priority_affinity_SMP_Remove_processor(const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
Removes an idle thread from the given cpu.
Definition: schedulerpriorityaffinitysmp.c:519
void _Scheduler_priority_affinity_SMP_Node_initialize(const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
Initializes per thread scheduler information.
Definition: schedulerpriorityaffinitysmp.c:63
void _Scheduler_priority_affinity_SMP_Withdraw_node(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
Withdraws node.
Definition: schedulerpriorityaffinitysmp.c:482
void _Scheduler_priority_affinity_SMP_Add_processor(const Scheduler_Control *scheduler, Thread_Control *idle)
Adds idle to scheduler.
Definition: schedulerpriorityaffinitysmp.c:503
bool _Scheduler_priority_affinity_SMP_Ask_for_help(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Asks for help.
Definition: schedulerpriorityaffinitysmp.c:455
void _Scheduler_priority_affinity_SMP_Block(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Blocks a thread.
Definition: schedulerpriorityaffinitysmp.c:165
bool _Scheduler_priority_affinity_SMP_Set_affinity(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node, const Processor_mask *affinity)
Sets affinity for the priority affinity SMP scheduler.
Definition: schedulerpriorityaffinitysmp.c:534
void _Scheduler_priority_affinity_SMP_Reconsider_help_request(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Reconsiders help.
Definition: schedulerpriorityaffinitysmp.c:466
void _Scheduler_priority_affinity_SMP_Update_priority(const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
Updates the priority of the node.
Definition: schedulerpriorityaffinitysmp.c:430
void _Scheduler_priority_affinity_SMP_Unblock(const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Unblocks a thread.
Definition: schedulerpriorityaffinitysmp.c:341
Thread Manipulation with the Priority-Based Scheduler.
Deterministic Priority SMP Scheduler API.
SMP Scheduler API.
Constants and Structures Associated with the Scheduler.
Per CPU Core Structure.
Definition: percpu.h:347
Scheduler node for per-thread data.
Definition: schedulernode.h:79
Scheduler node specialization for Deterministic Priority SMP schedulers.
Definition: schedulerprioritysmp.h:66
Scheduler node specialization for Deterministic Priority Affinity SMP schedulers.
Definition: schedulerpriorityaffinitysmp.h:230
Scheduler_priority_SMP_Node Base
SMP priority scheduler node.
Definition: schedulerpriorityaffinitysmp.h:234
The thread processor affinity set.
Definition: schedulerpriorityaffinitysmp.h:239
Scheduler control.
Definition: scheduler.h:269
Definition: thread.h:732
