RTEMS 5.2-rc1
rtl-archive.h
1/*
2 * COPYRIGHT (c) 2018 Chris Johns <chrisj@rtems.org>
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
29#if !defined (_RTEMS_RTL_ARCHIVE_H_)
30#define _RTEMS_RTL_ARCHIVE_H_
31
32#include <rtems.h>
33#include <rtems/chain.h>
34#include <rtems/printer.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif /* __cplusplus */
39
43#define RTEMS_RTL_ARCHIVE_USER_LOAD (1 << 0)
44#define RTEMS_RTL_ARCHIVE_REMOVE (1 << 1)
45#define RTEMS_RTL_ARCHIVE_LOAD (1 << 2)
51{
62
67{
68 size_t entry;
69 const char* label;
71
76{
77 void* base;
78 size_t size;
79 size_t entries;
80 const char* names;
83
87typedef struct rtems_rtl_archive
88{
90 const char* name;
91 size_t size;
92 time_t mtime;
93 off_t enames;
95 size_t refs;
96 uint32_t flags;
98
102typedef struct rtems_rtl_archives
103{
104 const char* config_name;
107 char* config;
110
114typedef void (*rtems_rtl_archive_error)(int num, const char* text);
115
123void rtems_rtl_archives_open (rtems_rtl_archives* archives, const char* config);
124
131
144
152bool rtems_rtl_archive_load (rtems_rtl_archives* archives, const char* name);
153
163 const char* symbol,
164 bool load);
165
186 size_t fsize,
187 const char** name,
188 off_t* offset,
189 size_t* size,
190 off_t* extended_names,
192
193#ifdef __cplusplus
194}
195#endif /* __cplusplus */
196
197#endif
Chain API.
User print interface to the bspIO print plug in.
void rtems_rtl_archives_close(rtems_rtl_archives *archives)
Definition: rtl-archive.c:567
struct rtems_rtl_archive_symbol rtems_rtl_archive_symbol
bool rtems_rtl_obj_archive_find_obj(int fd, size_t fsize, const char **name, off_t *offset, size_t *size, off_t *extended_names, rtems_rtl_archive_error error)
Definition: rtl-archive.c:1040
rtems_rtl_archive_search rtems_rtl_archive_obj_load(rtems_rtl_archives *archives, const char *symbol, bool load)
Definition: rtl-archive.c:913
struct rtems_rtl_archive_symbols rtems_rtl_archive_symbols
struct rtems_rtl_archive rtems_rtl_archive
Definition: rtl-archive.h:51
@ rtems_rtl_archive_search_found
Definition: rtl-archive.h:54
@ rtems_rtl_archive_search_not_found
Definition: rtl-archive.h:52
@ rtems_rtl_archive_search_no_config
Definition: rtl-archive.h:59
@ rtems_rtl_archive_search_error
Definition: rtl-archive.h:57
@ rtems_rtl_archive_search_loaded
Definition: rtl-archive.h:55
struct rtems_rtl_archives rtems_rtl_archives
bool rtems_rtl_archives_refresh(rtems_rtl_archives *archives)
Definition: rtl-archive.c:761
void(* rtems_rtl_archive_error)(int num, const char *text)
Definition: rtl-archive.h:114
bool rtems_rtl_archive_load(rtems_rtl_archives *archives, const char *name)
Definition: rtl-archive.c:884
void rtems_rtl_archives_open(rtems_rtl_archives *archives, const char *config)
Definition: rtl-archive.c:557
Definition: chain.h:68
Definition: deflate.c:115
Definition: rtl-archive.h:67
size_t entry
Definition: rtl-archive.h:68
const char * label
Definition: rtl-archive.h:69
Definition: rtl-archive.h:76
rtems_rtl_archive_symbol * symbols
Definition: rtl-archive.h:81
size_t entries
Definition: rtl-archive.h:79
void * base
Definition: rtl-archive.h:77
const char * names
Definition: rtl-archive.h:80
size_t size
Definition: rtl-archive.h:78
Definition: rtl-archive.h:88
rtems_chain_node node
Definition: rtl-archive.h:89
time_t mtime
Definition: rtl-archive.h:92
rtems_rtl_archive_symbols symbols
Definition: rtl-archive.h:94
uint32_t flags
Definition: rtl-archive.h:96
const char * name
Definition: rtl-archive.h:90
size_t refs
Definition: rtl-archive.h:95
size_t size
Definition: rtl-archive.h:91
off_t enames
Definition: rtl-archive.h:93
Definition: rtl-archive.h:103
char * config
Definition: rtl-archive.h:107
size_t config_length
Definition: rtl-archive.h:106
time_t config_mtime
Definition: rtl-archive.h:105
const char * config_name
Definition: rtl-archive.h:104
rtems_chain_control archives
Definition: rtl-archive.h:108
unsigned size
Definition: tte.h:1
Definition: chain.h:86
