RTEMS 5.2-rc1
rtemscompat1.h
1#ifndef RTEMS_COMPAT1_BSD_NET_H
2#define RTEMS_COMPAT1_BSD_NET_H
3
4/* BSD -> RTEMS conversion wrappers; stuff that must be defined
5 * after most BSD headers are included.
6 */
7
8#include <netinet/in.h>
9#include <netinet/if_ether.h>
10
11/* Copyright: Till Straumann <strauman@slac.stanford.edu>, 2005;
12 * License: see LICENSE file.
13 */
14
15typedef struct device {
16 struct NET_SOFTC d_softc; /* MUST BE FIRST FIELD */
17 char *d_name;
18 char *d_desc;
19 int d_unit;
20 int flags;
21 /* pointer to ifconfig only valid during excution of
22 * the n_attach/n_detach methods (see below)
23 */
24 struct rtems_bsdnet_ifconfig *d_ifconfig;
25} netdev_t;
26
27#define THEDEVS NET_EMBEMB(the_,NETDRIVER_PREFIX,_devs)
28#define NETDEV_DECL netdev_t THEDEVS[NETDRIVER_SLOTS]
29
30extern NETDEV_DECL;
31
32typedef struct _net_drv_tbl {
33 int (*n_probe)(device_t);
34 int (*n_attach)(device_t);
35 int (*n_detach)(device_t);
36 void (*n_intr)(void *);
38
39static inline netdev_t *
40net_dev_get(struct rtems_bsdnet_ifconfig *config)
41{
42 int unitNo;
43 char *unitName;
44
45 unitNo = rtems_bsdnet_parse_driver_name(config, &unitName);
46 if ( unitNo < 0 )
47 return 0;
48
49 if ( unitNo <=0 || unitNo > NETDRIVER_SLOTS ) {
50 device_printf(dev, "Bad "NETDRIVER" unit number.\n");
51 return 0;
52 }
53
54 if ( THEDEVS[unitNo-1].d_unit && THEDEVS[unitNo-1].d_unit != unitNo ) {
55 device_printf(dev, "Unit # mismatch !!??\n");
56 return 0;
57 }
58
59 THEDEVS[unitNo-1].d_unit = unitNo;
60 THEDEVS[unitNo-1].d_name = unitName;
61 THEDEVS[unitNo-1].d_ifconfig = config;
62
63 return &THEDEVS[unitNo - 1];
64}
65
66/* kludge; that's why softc needs to be first */
67static inline netdev_t *
68softc_get_device(struct NET_SOFTC *sc)
69{
70 return (netdev_t *)sc;
71}
72
73static inline struct NET_SOFTC *
74device_get_softc(netdev_t *dev)
75{ return &dev->d_softc; }
76
77static inline int
78device_get_unit(netdev_t *dev)
79{ return dev->d_unit; }
80
81static inline char *
82device_get_name(netdev_t *dev)
83{ return dev->d_name; }
84
85static inline void
86if_initname(struct ifnet *ifp, char *name, int unit)
87{
88 ifp->if_name = name;
89 ifp->if_unit = unit;
90}
91
92static inline void
93device_set_desc(netdev_t *dev, char *str)
94{
95 dev->d_desc = str;
96}
97
98static inline void
99device_set_desc_copy(netdev_t *dev, char *str)
100{
101 dev->d_desc = strdup(str);
102}
103
104
105static inline int
106device_is_attached(netdev_t *dev)
107{
108 return dev->d_softc.arpcom.ac_if.if_addrlist && dev->d_softc.arpcom.ac_if.if_init;
109}
110
111#ifdef NETDRIVER_PCI
112#include NETDRIVER_PCI
113#include "pcireg.h"
114
115static inline unsigned
116pci_read_config(device_t dev, unsigned addr, unsigned width)
117{
118rtemscompat_32_t d;
119unsigned short s;
120unsigned char b;
121struct NET_SOFTC *sc = device_get_softc(dev);
122 switch (width) {
123 case 1: pci_read_config_byte(sc->b, sc->d, sc->f, addr, &b);
124 return b;
125 case 2: pci_read_config_word(sc->b, sc->d, sc->f, addr, &s);
126 return s;
127 case 4: pci_read_config_dword(sc->b, sc->d, sc->f, addr, &d);
128 return d;
129 default:
130 break;
131 }
132 return 0xdeadbeef;
133}
134
135static inline void
136pci_write_config(device_t dev, unsigned addr, unsigned width, unsigned val)
137{
138struct NET_SOFTC *sc = device_get_softc(dev);
139 switch (width) {
140 case 1: pci_write_config_byte(sc->b, sc->d, sc->f, addr, val);
141 return ;
142 case 2: pci_write_config_word(sc->b, sc->d, sc->f, addr, val);
143 return ;
144 case 4: pci_write_config_dword(sc->b, sc->d, sc->f, addr, val);
145 return ;
146 default:
147 break;
148 }
149}
150
151
152static inline unsigned short
153pci_get_vendor(device_t dev)
154{
155 return pci_read_config(dev, PCIR_VENDOR, 2);
156}
157
158static inline unsigned short
159pci_get_device(device_t dev)
160{
161 return pci_read_config(dev, PCIR_DEVICE, 2);
162}
163
164static inline unsigned short
165pci_get_subvendor(device_t dev)
166{
167 return pci_read_config(dev, PCIR_SUBVEND_0, 2);
168}
169
170static inline unsigned short
171pci_get_subdevice(device_t dev)
172{
173 return pci_read_config(dev, PCIR_SUBDEV_0, 2);
174}
175
176
177static inline void
178pci_enable_busmaster(device_t dev)
179{
180 pci_write_config(
181 dev,
182 PCIR_COMMAND,
183 2,
184 pci_read_config(dev, PCIR_COMMAND, 2)
185 | PCIM_CMD_BUSMASTEREN);
186}
187
188#define mtx_init(a,b,c,d) do {} while(0)
189#define mtx_initialized(ma) (1)
190#define mtx_destroy(ma) do {} while(0)
191#define mtx_lock(a) do {} while(0)
192#define mtx_unlock(a) do {} while(0)
193#define mtx_assert(a,b) do {} while(0)
194
195#define callout_handle_init(x) do {} while (0)
196#define untimeout(a...) do {} while (0)
197
198#if !ISMINVERSION(4,6,99)
199#define pci_bus_count BusCountPCI
200#endif
201
202#endif
203
204/* Ugly hack to allow unloading/reloading the driver core.
205 * Needed because rtems' bsdnet release doesn't implement
206 * if_detach(). Therefore, we bring the interface down but
207 * keep the device record alive...
208 */
209static inline void
210__ether_ifdetach(struct ifnet *ifp)
211{
212 ifp->if_flags = 0;
213 ifp->if_ioctl = 0;
214 ifp->if_start = 0;
215 ifp->if_watchdog = 0;
216 ifp->if_init = 0;
217}
218
219#endif
Definition: rtemscompat1.h:32
Definition: deflate.c:115
Definition: rtemscompat1.h:15
