RTEMS 5.2-rc1
rbtree.h
1
12/*
13 * Copyright (c) 2010 Gedare Bloom.
14 *
15 * The license and distribution terms for this file may be
16 * found in the file LICENSE in this distribution or at
17 * http://www.rtems.org/license/LICENSE.
18 */
19
20#ifndef _RTEMS_RBTREE_H
21#define _RTEMS_RBTREE_H
22
23#include <rtems/score/rbtree.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
49
55typedef RBTree_Control rtems_rbtree_control;
56
65
80 const RBTree_Node *first,
81 const RBTree_Node *second
82);
83
87#define RTEMS_RBTREE_INITIALIZER_EMPTY(name) \
88 RBTREE_INITIALIZER_EMPTY(name)
89
93#define RTEMS_RBTREE_DEFINE_EMPTY(name) \
94 RBTREE_DEFINE_EMPTY(name)
95
112 rtems_rbtree_control *the_rbtree,
113 rtems_rbtree_compare compare,
114 void *starting_address,
115 size_t number_nodes,
116 size_t node_size,
117 bool is_unique
118);
119
126 rtems_rbtree_control *the_rbtree
127)
128{
129 _RBTree_Initialize_empty( the_rbtree );
130}
131
140)
141{
142 _RBTree_Set_off_tree( node );
143}
144
152 const rtems_rbtree_node *node
153)
154{
155 return _RBTree_Is_node_off_tree( node );
156}
157
164 const rtems_rbtree_control *the_rbtree
165)
166{
167 return _RBTree_Root( the_rbtree );
168}
169
174 const rtems_rbtree_control *the_rbtree
175)
176{
177 return _RBTree_Minimum( the_rbtree );
178}
179
184 const rtems_rbtree_control *the_rbtree
185)
186{
187 return _RBTree_Maximum( the_rbtree );
188}
189
196 const rtems_rbtree_node *the_node
197)
198{
199 return _RBTree_Left( the_node );
200}
201
208 const rtems_rbtree_node *the_node
209)
210{
211 return _RBTree_Right( the_node );
212}
213
218 const rtems_rbtree_node *the_node
219)
220{
221 return _RBTree_Parent( the_node );
222}
223
231 const rtems_rbtree_control *the_rbtree
232)
233{
234 return _RBTree_Is_empty( the_rbtree );
235}
236
244 const rtems_rbtree_control *the_rbtree,
245 const rtems_rbtree_node *the_node
246)
247{
248 return rtems_rbtree_min( the_rbtree ) == the_node;
249}
250
258 const rtems_rbtree_control *the_rbtree,
259 const rtems_rbtree_node *the_node
260)
261{
262 return rtems_rbtree_max( the_rbtree ) == the_node;
263}
264
269 const rtems_rbtree_node *the_node
270)
271{
272 return _RBTree_Is_root( the_node );
273}
274
275RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_equal(
276 rtems_rbtree_compare_result compare_result
277)
278{
279 return compare_result == 0;
280}
281
282RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_greater(
283 rtems_rbtree_compare_result compare_result
284)
285{
286 return compare_result > 0;
287}
288
289RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_lesser(
290 rtems_rbtree_compare_result compare_result
291)
292{
293 return compare_result < 0;
294}
295
311 const rtems_rbtree_control *the_rbtree,
312 const rtems_rbtree_node *the_node,
313 rtems_rbtree_compare compare,
314 bool is_unique
315);
316
321 const rtems_rbtree_node *node
322)
323{
324 return _RBTree_Predecessor( node );
325}
326
331 const rtems_rbtree_node *node
332)
333{
334 return _RBTree_Successor( node );
335}
336
341 rtems_rbtree_control *the_rbtree,
342 rtems_rbtree_node *the_node
343)
344{
345 _RBTree_Extract( the_rbtree, the_node );
346}
347
361 rtems_rbtree_control *the_rbtree
362)
363{
364 rtems_rbtree_node *the_node = rtems_rbtree_min( the_rbtree );
365
366 if ( the_node != NULL ) {
367 rtems_rbtree_extract( the_rbtree, the_node );
368 }
369
370 return the_node;
371}
372
386 rtems_rbtree_control *the_rbtree
387)
388{
389 rtems_rbtree_node *the_node = rtems_rbtree_max( the_rbtree );
390
391 if ( the_node != NULL ) {
392 rtems_rbtree_extract( the_rbtree, the_node );
393 }
394
395 return the_node;
396}
397
406 const rtems_rbtree_control *the_rbtree
407)
408{
409 return rtems_rbtree_min( the_rbtree );
410}
411
420 const rtems_rbtree_control *the_rbtree
421)
422{
423 return rtems_rbtree_max( the_rbtree );
424}
425
443 RBTree_Control *the_rbtree,
444 RBTree_Node *the_node,
445 rtems_rbtree_compare compare,
446 bool is_unique
447);
448
451#ifdef __cplusplus
452}
453#endif
454
455#endif
456/* end of include file */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_max(const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node)
Is this the maximum node on the RBTree.
Definition: rbtree.h:257
Definition: rbtree.h:55
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root(const rtems_rbtree_node *the_node)
Checks if this node is the root node of a red-black tree.
Definition: rbtree.h:268
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_successor(const rtems_rbtree_node *node)
Returns the successor of a node.
Definition: rbtree.h:330
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_get_max(rtems_rbtree_control *the_rbtree)
Gets a node with the maximal key value from the red-black tree.
Definition: rbtree.h:385
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_node_off_tree(const rtems_rbtree_node *node)
Is the Node off RBTree.
Definition: rbtree.h:151
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_right(const rtems_rbtree_node *the_node)
Return pointer to the right child node from this node.
Definition: rbtree.h:207
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_min(const rtems_rbtree_control *the_rbtree)
Returns the minimum node of the red-black tree.
Definition: rbtree.h:173
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_empty(const rtems_rbtree_control *the_rbtree)
Is the RBTree empty.
Definition: rbtree.h:230
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_peek_min(const rtems_rbtree_control *the_rbtree)
Peek at the min node on a rbtree.
Definition: rbtree.h:405
rtems_rbtree_compare_result(* rtems_rbtree_compare)(const RBTree_Node *first, const RBTree_Node *second)
Compares two red-black tree nodes.
Definition: rbtree.h:79
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_left(const rtems_rbtree_node *the_node)
Return pointer to the left child node from this node.
Definition: rbtree.h:195
void rtems_rbtree_initialize(rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
Initialize a RBTree header.
Definition: rbtree.c:23
rtems_rbtree_node * rtems_rbtree_find(const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
Tries to find a node for the specified key in the tree.
Definition: rbtreefind.c:23
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_min(const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node)
Is this the minimum node on the RBTree.
Definition: rbtree.h:243
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_max(const rtems_rbtree_control *the_rbtree)
Returns the maximum node of the red-black tree.
Definition: rbtree.h:183
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_parent(const rtems_rbtree_node *the_node)
Returns a pointer to the parent of this node.
Definition: rbtree.h:217
RTEMS_INLINE_ROUTINE void rtems_rbtree_extract(rtems_rbtree_control *the_rbtree, rtems_rbtree_node *the_node)
Extracts (removes) the node from the red-black tree.
Definition: rbtree.h:340
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_get_min(rtems_rbtree_control *the_rbtree)
Gets a node with the minimum key value from the red-black tree.
Definition: rbtree.h:360
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_root(const rtems_rbtree_control *the_rbtree)
Return pointer to RBTree root.
Definition: rbtree.h:163
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_predecessor(const rtems_rbtree_node *node)
Returns the predecessor of a node.
Definition: rbtree.h:320
rtems_rbtree_node * rtems_rbtree_insert(RBTree_Control *the_rbtree, RBTree_Node *the_node, rtems_rbtree_compare compare, bool is_unique)
Inserts the node into the red-black tree.
Definition: sapirbtreeinsert.c:26
RTEMS_INLINE_ROUTINE void rtems_rbtree_set_off_tree(rtems_rbtree_node *node)
Set off RBtree.
Definition: rbtree.h:138
RBTree_Node rtems_rbtree_node
Definition: rbtree.h:48
long rtems_rbtree_compare_result
Integer type for compare results.
Definition: rbtree.h:64
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize_empty(rtems_rbtree_control *the_rbtree)
Initialize this RBTree as Empty.
Definition: rbtree.h:125
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_peek_max(const rtems_rbtree_control *the_rbtree)
Peek at the max node on a rbtree.
Definition: rbtree.h:419
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RBTree_Node * _RBTree_Predecessor(const RBTree_Node *node)
Definition: rbtreenext.c:51
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Parent(const RBTree_Node *the_node)
Definition: rbtree.h:295
RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty(const RBTree_Control *the_rbtree)
Checks if the RBTree is empty.
Definition: rbtree.h:375
void _RBTree_Extract(RBTree_Control *the_rbtree, RBTree_Node *the_node)
Definition: rbtreeextract.c:35
RBTree_Node * _RBTree_Maximum(const RBTree_Control *the_rbtree)
Definition: rbtreenext.c:41
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty(RBTree_Control *the_rbtree)
Initializes this RBTree as empty.
Definition: rbtree.h:410
RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_tree(const RBTree_Node *the_node)
Checks if this red-black tree node is off-tree.
Definition: rbtree.h:103
RTEMS_INLINE_ROUTINE void _RBTree_Set_off_tree(RBTree_Node *the_node)
Sets a red-black tree node as off-tree.
Definition: rbtree.h:88
RTEMS_INLINE_ROUTINE bool _RBTree_Is_root(const RBTree_Node *the_node)
Definition: rbtree.h:396
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Right(const RBTree_Node *the_node)
Returns pointer to the right of this node.
Definition: rbtree.h:342
RBTree_Node * _RBTree_Successor(const RBTree_Node *node)
Definition: rbtreenext.c:46
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Left(const RBTree_Node *the_node)
Returns pointer to the left of this node.
Definition: rbtree.h:311
RBTree_Node * _RBTree_Minimum(const RBTree_Control *the_rbtree)
Definition: rbtreenext.c:36
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Root(const RBTree_Control *the_rbtree)
Returns a pointer to root node of the red-black tree.
Definition: rbtree.h:246
Constants and Structures Associated with the Red-Black Tree Handler.
Red-black tree node.
