RTEMS 5.2-rc1
rtems-rfs-trace.h
1
14/*
15 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22
23#if !defined (_RTEMS_RFS_TRACE_H_)
24#define _RTEMS_RFS_TRACE_H_
25
26#include <stddef.h>
27#include <stdbool.h>
28#include <stdint.h>
29#include <stdio.h>
30
34#if !defined (RTEMS_RFS_TRACE)
35#define RTEMS_RFS_TRACE 1
36#endif
37
41typedef uint64_t rtems_rfs_trace_mask;
42
46#define RTEMS_RFS_TRACE_ALL (0xffffffffffffffffULL)
47#define RTEMS_RFS_TRACE_OPEN (1ULL << 0)
48#define RTEMS_RFS_TRACE_CLOSE (1ULL << 1)
49#define RTEMS_RFS_TRACE_MUTEX (1ULL << 2)
50#define RTEMS_RFS_TRACE_BUFFER_OPEN (1ULL << 3)
51#define RTEMS_RFS_TRACE_BUFFER_CLOSE (1ULL << 4)
52#define RTEMS_RFS_TRACE_BUFFER_SYNC (1ULL << 5)
53#define RTEMS_RFS_TRACE_BUFFER_RELEASE (1ULL << 6)
54#define RTEMS_RFS_TRACE_BUFFER_CHAINS (1ULL << 7)
55#define RTEMS_RFS_TRACE_BUFFER_HANDLE_REQUEST (1ULL << 8)
56#define RTEMS_RFS_TRACE_BUFFER_HANDLE_RELEASE (1ULL << 9)
57#define RTEMS_RFS_TRACE_BUFFER_SETBLKSIZE (1ULL << 10)
58#define RTEMS_RFS_TRACE_BUFFERS_RELEASE (1ULL << 11)
59#define RTEMS_RFS_TRACE_BLOCK_FIND (1ULL << 12)
60#define RTEMS_RFS_TRACE_BLOCK_MAP_GROW (1ULL << 13)
61#define RTEMS_RFS_TRACE_BLOCK_MAP_SHRINK (1ULL << 14)
62#define RTEMS_RFS_TRACE_GROUP_OPEN (1ULL << 15)
63#define RTEMS_RFS_TRACE_GROUP_CLOSE (1ULL << 16)
64#define RTEMS_RFS_TRACE_GROUP_BITMAPS (1ULL << 17)
65#define RTEMS_RFS_TRACE_INODE_OPEN (1ULL << 18)
66#define RTEMS_RFS_TRACE_INODE_CLOSE (1ULL << 19)
67#define RTEMS_RFS_TRACE_INODE_LOAD (1ULL << 20)
68#define RTEMS_RFS_TRACE_INODE_UNLOAD (1ULL << 21)
69#define RTEMS_RFS_TRACE_INODE_CREATE (1ULL << 22)
70#define RTEMS_RFS_TRACE_INODE_DELETE (1ULL << 23)
71#define RTEMS_RFS_TRACE_LINK (1ULL << 24)
72#define RTEMS_RFS_TRACE_UNLINK (1ULL << 25)
73#define RTEMS_RFS_TRACE_DIR_LOOKUP_INO (1ULL << 26)
74#define RTEMS_RFS_TRACE_DIR_LOOKUP_INO_CHECK (1ULL << 27)
75#define RTEMS_RFS_TRACE_DIR_LOOKUP_INO_FOUND (1ULL << 28)
76#define RTEMS_RFS_TRACE_DIR_ADD_ENTRY (1ULL << 29)
77#define RTEMS_RFS_TRACE_DIR_DEL_ENTRY (1ULL << 30)
78#define RTEMS_RFS_TRACE_DIR_READ (1ULL << 31)
79#define RTEMS_RFS_TRACE_DIR_EMPTY (1ULL << 32)
80#define RTEMS_RFS_TRACE_SYMLINK (1ULL << 33)
81#define RTEMS_RFS_TRACE_SYMLINK_READ (1ULL << 34)
82#define RTEMS_RFS_TRACE_FILE_OPEN (1ULL << 35)
83#define RTEMS_RFS_TRACE_FILE_CLOSE (1ULL << 36)
84#define RTEMS_RFS_TRACE_FILE_IO (1ULL << 37)
85#define RTEMS_RFS_TRACE_FILE_SET (1ULL << 38)
86
96#if RTEMS_RFS_TRACE
98#else
99#define rtems_rfs_trace(_m) (0)
100#endif
101
109#if RTEMS_RFS_TRACE
111#else
112#define rtems_rfs_trace_set_mask(_m)
113#endif
114
122#if RTEMS_RFS_TRACE
124#else
125#define rtems_rfs_trace_clear_mask(_m)
126#endif
127
131#if RTEMS_RFS_TRACE
132int rtems_rfs_trace_shell_command (int argc, char *argv[]);
133#endif
134
135#endif
Definition: rtems-rfs-trace.h:41
int rtems_rfs_trace_shell_command(int argc, char *argv[])
bool rtems_rfs_trace(rtems_rfs_trace_mask mask)
rtems_rfs_trace_mask rtems_rfs_trace_set_mask(rtems_rfs_trace_mask mask)
rtems_rfs_trace_mask rtems_rfs_trace_clear_mask(rtems_rfs_trace_mask mask)
