RTEMS 5.2-rc1
rtc_calib.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
40typedef struct {
41 int8_t Tempr;
42 int16_t PPM;
43 uint8_t NEGPPM;
44 uint8_t HIGHPPM;
45 uint16_t CORRECTION;
47
48
49extern void RTC_ClockCalibration(Rtc *pRtc, int32_t CurrentTempr);
Definition: rtc_calib.h:40
Rtc hardware registers.
Definition: component_rtc.h:41
