RTEMS 5.2-rc1
residual.h
1/* 7/18/95 */
2/*----------------------------------------------------------------------------*/
3/* Residual Data header definitions and prototypes */
4/*----------------------------------------------------------------------------*/
5
6/* Structure map for RESIDUAL on PowerPC Reference Platform */
7/* residual.h - Residual data structure passed in r3. */
8/* Load point passed in r4 to boot image. */
9/* For enum's: if given in hex then they are bit significant, */
10/* i.e. only one bit is on for each enum */
11/* Reserved fields must be filled with zeros. */
12
13
14#ifndef _RESIDUAL_
15#define _RESIDUAL_
16
17#ifndef ASM
18
19#include <stdint.h>
20
21#define MAX_CPUS 32 /* These should be set to the maximum */
22#define MAX_MEMS 64 /* number possible for this system. */
23#define MAX_DEVICES 256 /* Changing these will change the */
24#define AVE_PNP_SIZE 32 /* structure, hence the version of */
25#define MAX_MEM_SEGS 64 /* this header file. */
26
27/*----------------------------------------------------------------------------*/
28/* Public structures... */
29/*----------------------------------------------------------------------------*/
30
31#include <bsp/pnp.h>
32
33typedef enum _L1CACHE_TYPE {
34 NoneCAC = 0,
35 SplitCAC = 1,
36 CombinedCAC = 2
37 } L1CACHE_TYPE;
38
39typedef enum _TLB_TYPE {
40 NoneTLB = 0,
41 SplitTLB = 1,
42 CombinedTLB = 2
43 } TLB_TYPE;
44
45typedef enum _FIRMWARE_SUPPORT {
46 Conventional = 0x01,
47 OpenFirmware = 0x02,
48 Diagnostics = 0x04,
49 LowDebug = 0x08,
50 Multiboot = 0x10,
51 LowClient = 0x20,
52 Hex41 = 0x40,
53 FAT = 0x80,
54 ISO9660 = 0x0100,
55 SCSI_InitiatorID_Override = 0x0200,
56 Tape_Boot = 0x0400,
57 FW_Boot_Path = 0x0800
58 } FIRMWARE_SUPPORT;
59
60typedef enum _FIRMWARE_SUPPLIERS {
61 IBMFirmware = 0x00,
62 MotoFirmware = 0x01, /* 7/18/95 */
63 FirmWorks = 0x02, /* 10/5/95 */
64 Bull = 0x03, /* 04/03/96 */
65 QEMU = ('q'<<24) | ('e'<<16) | ('m'<<8) | ('u'<<0),
66 } FIRMWARE_SUPPLIERS;
67
68typedef enum _ENDIAN_SWITCH_METHODS {
69 UsePort92 = 0x01,
70 UsePCIConfigA8 = 0x02,
71 UseFF001030 = 0x03,
72 } ENDIAN_SWITCH_METHODS;
73
74typedef enum _SPREAD_IO_METHODS {
75 UsePort850 = 0x00,
76/*UsePCIConfigA8 = 0x02,*/
77 } SPREAD_IO_METHODS;
78
79typedef struct _VPD {
80
81 /* Box dependent stuff */
82 unsigned char PrintableModel[32]; /* Null terminated string.
83 Must be of the form:
84 vvv,<20h>,<model designation>,<0x0>
85 where vvv is the vendor ID
86 e.g. IBM PPS MODEL 6015<0x0> */
87 unsigned char Serial[16]; /* 12/94:
88 Serial Number; must be of the form:
89 vvv<serial number> where vvv is the
90 vendor ID.
91 e.g. IBM60151234567<20h><20h> */
92 unsigned char Reserved[48];
93 unsigned long FirmwareSupplier; /* See FirmwareSuppliers enum */
94 unsigned long FirmwareSupports; /* See FirmwareSupport enum */
95 unsigned long NvramSize; /* Size of nvram in bytes */
96 unsigned long NumSIMMSlots;
97 unsigned short EndianSwitchMethod; /* See EndianSwitchMethods enum */
98 unsigned short SpreadIOMethod; /* See SpreadIOMethods enum */
99 unsigned long SmpIar;
100 unsigned long RAMErrLogOffset; /* Heap offset to error log */
101 unsigned long Reserved5;
102 unsigned long Reserved6;
103 unsigned long ProcessorHz; /* Processor clock frequency in Hertz */
104 unsigned long ProcessorBusHz; /* Processor bus clock frequency */
105 unsigned long Reserved7;
106 unsigned long TimeBaseDivisor; /* (Bus clocks per timebase tic)*1000 */
107 unsigned long WordWidth; /* Word width in bits */
108 unsigned long PageSize; /* Page size in bytes */
109 unsigned long CoherenceBlockSize; /* Unit of transfer in/out of cache
110 for which coherency is maintained;
111 normally <= CacheLineSize. */
112 unsigned long GranuleSize; /* Unit of lock allocation to avoid */
113 /* false sharing of locks. */
114
115 /* L1 Cache variables */
116 unsigned long CacheSize; /* L1 Cache size in KB. This is the */
117 /* total size of the L1, whether */
118 /* combined or split */
119 unsigned long CacheAttrib; /* L1CACHE_TYPE */
120 unsigned long CacheAssoc; /* L1 Cache associativity. Use this
121 for combined cache. If split, put
122 zeros here. */
123 unsigned long CacheLineSize; /* L1 Cache line size in bytes. Use
124 for combined cache. If split, put
125 zeros here. */
126 /* For split L1 Cache: (= combined if combined cache) */
127 unsigned long I_CacheSize;
128 unsigned long I_CacheAssoc;
129 unsigned long I_CacheLineSize;
130 unsigned long D_CacheSize;
131 unsigned long D_CacheAssoc;
132 unsigned long D_CacheLineSize;
133
134 /* Translation Lookaside Buffer variables */
135 unsigned long TLBSize; /* Total number of TLBs on the system */
136 unsigned long TLBAttrib; /* Combined I+D or split TLB */
137 unsigned long TLBAssoc; /* TLB Associativity. Use this for
138 combined TLB. If split, put zeros
139 here. */
140 /* For split TLB: (= combined if combined TLB) */
141 unsigned long I_TLBSize;
142 unsigned long I_TLBAssoc;
143 unsigned long D_TLBSize;
144 unsigned long D_TLBAssoc;
145
146 unsigned long ExtendedVPD; /* Offset to extended VPD area;
147 null if unused */
148 } VPD;
149
150typedef enum _DEVICE_FLAGS {
151 Enabled = 0x4000, /* 1 - PCI device is enabled */
152 Integrated = 0x2000,
153 Failed = 0x1000, /* 1 - device failed POST code tests */
154 Static = 0x0800, /* 0 - dynamically configurable
155 1 - static */
156 Dock = 0x0400, /* 0 - not a docking station device
157 1 - is a docking station device */
158 Boot = 0x0200, /* 0 - device cannot be used for BOOT
159 1 - can be a BOOT device */
160 Configurable = 0x0100, /* 1 - device is configurable */
161 Disableable = 0x80, /* 1 - device can be disabled */
162 PowerManaged = 0x40, /* 0 - not managed; 1 - managed */
163 ReadOnly = 0x20, /* 1 - device is read only */
164 Removable = 0x10, /* 1 - device is removable */
165 ConsoleIn = 0x08,
166 ConsoleOut = 0x04,
167 Input = 0x02,
168 Output = 0x01
169 } DEVICE_FLAGS;
170
171typedef enum _BUS_ID {
172 ISADEVICE = 0x01,
173 EISADEVICE = 0x02,
174 PCIDEVICE = 0x04,
175 PCMCIADEVICE = 0x08,
176 PNPISADEVICE = 0x10,
177 MCADEVICE = 0x20,
178 MXDEVICE = 0x40, /* Devices on mezzanine bus */
179 PROCESSORDEVICE = 0x80, /* Devices on processor bus */
180 VMEDEVICE = 0x100,
181 } BUS_ID;
182
183typedef struct _DEVICE_ID {
184 unsigned long BusId; /* See BUS_ID enum above */
185 unsigned long DevId; /* Big Endian format */
186 unsigned long SerialNum; /* For multiple usage of a single
187 DevId */
188 unsigned long Flags; /* See DEVICE_FLAGS enum above */
189 unsigned char BaseType; /* See pnp.h for bit definitions */
190 unsigned char SubType; /* See pnp.h for bit definitions */
191 unsigned char Interface; /* See pnp.h for bit definitions */
192 unsigned char Spare;
193 } DEVICE_ID;
194
195typedef union _BUS_ACCESS {
197 unsigned char CSN;
198 unsigned char LogicalDevNumber;
199 unsigned short ReadDataPort;
200 } PnPAccess;
202 unsigned char SlotNumber; /* ISA Slot Number generally not
203 available; 0 if unknown */
204 unsigned char LogicalDevNumber;
205 unsigned short ISAReserved;
206 } ISAAccess;
208 unsigned char SlotNumber;
209 unsigned char LogicalDevNumber;
210 unsigned short MCAReserved;
211 } MCAAccess;
213 unsigned char SlotNumber;
214 unsigned char LogicalDevNumber;
215 unsigned short PCMCIAReserved;
216 } PCMCIAAccess;
218 unsigned char SlotNumber;
219 unsigned char FunctionNumber;
220 unsigned short EISAReserved;
221 } EISAAccess;
223 unsigned char BusNumber;
224 unsigned char DevFuncNumber;
225 unsigned short PCIReserved;
226 } PCIAccess;
228 unsigned char BusNumber;
229 unsigned char BUID;
230 unsigned short ProcBusReserved;
231 } ProcBusAccess;
232 } BUS_ACCESS;
233
234/* Per logical device information */
235typedef struct _PPC_DEVICE {
236 DEVICE_ID DeviceId;
237 BUS_ACCESS BusAccess;
238
239 /* The following three are offsets into the DevicePnPHeap */
240 /* All are in PnP compressed format */
241 unsigned long AllocatedOffset; /* Allocated resource description */
242 unsigned long PossibleOffset; /* Possible resource description */
243 unsigned long CompatibleOffset; /* Compatible device identifiers */
244 } PPC_DEVICE;
245
246typedef enum _CPU_STATE {
247 CPU_GOOD = 0, /* CPU is present, and active */
248 CPU_GOOD_FW = 1, /* CPU is present, and in firmware */
249 CPU_OFF = 2, /* CPU is present, but inactive */
250 CPU_FAILED = 3, /* CPU is present, but failed POST */
251 CPU_NOT_PRESENT = 255 /* CPU not present */
252 } CPU_STATE;
253
254typedef struct _PPC_CPU {
255 unsigned long CpuType; /* Result of mfspr from Processor
256 Version Register (PVR).
257 PVR(0-15) = Version (e.g. 601)
258 PVR(16-31 = EC Level */
259 unsigned char CpuNumber; /* CPU Number for this processor */
260 unsigned char CpuState; /* CPU State, see CPU_STATE enum */
261 unsigned short Reserved;
262 } PPC_CPU;
263
264typedef struct _PPC_MEM {
265 unsigned long SIMMSize; /* 0 - absent or bad
266 8M, 32M (in MB) */
267 } PPC_MEM;
268
269typedef enum _MEM_USAGE {
270 Other = 0x8000,
271 ResumeBlock = 0x4000, /* for use by power management */
272 SystemROM = 0x2000, /* Flash memory (populated) */
273 UnPopSystemROM = 0x1000, /* Unpopulated part of SystemROM area */
274 IOMemory = 0x0800,
275 SystemIO = 0x0400,
276 SystemRegs = 0x0200,
277 PCIAddr = 0x0100,
278 PCIConfig = 0x80,
279 ISAAddr = 0x40,
280 Unpopulated = 0x20, /* Unpopulated part of System Memory */
281 Free = 0x10, /* Free part of System Memory */
282 BootImage = 0x08, /* BootImage part of System Memory */
283 FirmwareCode = 0x04, /* FirmwareCode part of System Memory */
284 FirmwareHeap = 0x02, /* FirmwareHeap part of System Memory */
285 FirmwareStack = 0x01 /* FirmwareStack part of System Memory*/
286 } MEM_USAGE;
287
288typedef struct _MEM_MAP {
289 unsigned long Usage; /* See MEM_USAGE above */
290 unsigned long BasePage; /* Page number measured in 4KB pages */
291 unsigned long PageCount; /* Page count measured in 4KB pages */
292 } MEM_MAP;
293
294typedef struct _RESIDUAL {
295 unsigned long ResidualLength; /* Length of Residual */
296 unsigned char Version; /* of this data structure */
297 unsigned char Revision; /* of this data structure */
298 unsigned short EC; /* of this data structure */
299 /* VPD */
300 VPD VitalProductData;
301 /* CPU */
302 unsigned short MaxNumCpus; /* Max CPUs in this system */
303 unsigned short ActualNumCpus; /* ActualNumCpus < MaxNumCpus means */
304 /* that there are unpopulated or */
305 /* otherwise unusable cpu locations */
306 PPC_CPU Cpus[MAX_CPUS];
307 /* Memory */
308 unsigned long TotalMemory; /* Total amount of memory installed */
309 unsigned long GoodMemory; /* Total amount of good memory */
310 unsigned long ActualNumMemSegs;
311 MEM_MAP Segs[MAX_MEM_SEGS];
312 unsigned long ActualNumMemories;
313 PPC_MEM Memories[MAX_MEMS];
314 /* Devices */
315 unsigned long ActualNumDevices;
316 PPC_DEVICE Devices[MAX_DEVICES];
317 unsigned char DevicePnPHeap[2*MAX_DEVICES*AVE_PNP_SIZE];
318 } RESIDUAL;
319
320#ifndef NULL
321#define NULL 0
322#endif
323
324static inline int
325residual_fw_is_qemu(RESIDUAL *r)
326{
327 return QEMU == r->VitalProductData.FirmwareSupplier;
328}
329
330extern RESIDUAL residualCopy;
331
332extern void print_residual_device_info(void);
333#ifndef __BOOT__
334extern PPC_DEVICE *residual_find_device(RESIDUAL *res, unsigned long BusMask,
335 unsigned char * DevID, int BaseType,
336 int SubType, int Interface, int n);
337#else
338extern PPC_DEVICE *residual_find_device(unsigned long BusMask,
339 unsigned char * DevID, int BaseType,
340 int SubType, int Interface, int n);
341#endif
342extern PnP_TAG_PACKET *PnP_find_packet(unsigned char *p, unsigned packet_tag,
343 int n);
344extern PnP_TAG_PACKET *PnP_find_small_vendor_packet(unsigned char *p,
345 unsigned packet_type,
346 int n);
347extern PnP_TAG_PACKET *PnP_find_large_vendor_packet(unsigned char *p,
348 unsigned packet_type,
349 int n);
350/*
351 * Prototypes for methods called only from .S for dependency tracking
352 */
353uint32_t res_copy(void);
354
355#endif /* ASM */
356#endif /* ndef _RESIDUAL_ */
Definition: residual.h:217
Definition: residual.h:201
Definition: residual.h:207
Definition: residual.h:222
Definition: residual.h:212
Definition: residual.h:196
Definition: residual.h:227
Definition: residual.h:183
Definition: residual.h:288
Definition: residual.h:254
Definition: residual.h:235
Definition: residual.h:264
Definition: residual.h:294
Definition: residual.h:79
unsigned p
Definition: tte.h:17
Definition: residual.h:195
Definition: pnp.h:505
