RTEMS 5.2-rc1
regs-edma.h
1
7/*
8 * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
9 *
10 * embedded brains GmbH
11 * Obere Lagerstr. 30
12 * 82178 Puchheim
13 * Germany
14 * <rtems@embedded-brains.de>
15 *
16 * The license and distribution terms for this file may be
17 * found in the file LICENSE in this distribution or at
18 * http://www.rtems.org/license/LICENSE.
19 */
20
21/*********************************************************************
22 *
23 * Copyright:
24 * Freescale Semiconductor, INC. All Rights Reserved.
25 * You are hereby granted a copyright license to use, modify, and
26 * distribute the SOFTWARE so long as this entire notice is
27 * retained without alteration in any modified and/or redistributed
28 * versions, and that such modified versions are clearly identified
29 * as such. No licenses are granted by implication, estoppel or
30 * otherwise under any patents or trademarks of Freescale
31 * Semiconductor, Inc. This software is provided on an "AS IS"
32 * basis and without warranty.
33 *
34 * To the maximum extent permitted by applicable law, Freescale
35 * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
36 * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
37 * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
38 * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
39 * AND ANY ACCOMPANYING WRITTEN MATERIALS.
40 *
41 * To the maximum extent permitted by applicable law, IN NO EVENT
42 * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
43 * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
44 * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
45 * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
46 *
47 * Freescale Semiconductor assumes no responsibility for the
48 * maintenance and support of this software
49 *
50 ********************************************************************/
51
52#ifndef LIBCPU_POWERPC_MPC55XX_REGS_EDMA_H
53#define LIBCPU_POWERPC_MPC55XX_REGS_EDMA_H
54
55#include <stdint.h>
56
57#include <bspopts.h>
58
59#ifdef __cplusplus
60extern "C" {
61#endif
62
63/****************************************************************************/
64/* MODULE : eDMA */
65/****************************************************************************/
66 struct EDMA_tag {
68 uint32_t R;
69 struct {
70#if MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567
71 uint32_t:14;
72 uint32_t CX:1;
73 uint32_t ECX:1;
74#else
75 uint32_t:16;
76#endif
77 uint32_t GRP3PRI:2;
78 uint32_t GRP2PRI:2;
79 uint32_t GRP1PRI:2;
80 uint32_t GRP0PRI:2;
81#if MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567
82 uint32_t EMLM:1;
83 uint32_t CLM:1;
84 uint32_t HALT:1;
85 uint32_t HOE:1;
86#else
87 uint32_t:4;
88#endif
89 uint32_t ERGA:1;
90 uint32_t ERCA:1;
91 uint32_t EDBG:1;
92 uint32_t EBW:1;
93 } B;
94 } CR; /* Control Register */
95
96 union {
97 uint32_t R;
98 struct {
99 uint32_t VLD:1;
100#if MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567
101 uint32_t:14;
102 uint32_t ECX:1;
103#else
104 uint32_t:15;
105#endif
106 uint32_t GPE:1;
107 uint32_t CPE:1;
108 uint32_t ERRCHN:6;
109 uint32_t SAE:1;
110 uint32_t SOE:1;
111 uint32_t DAE:1;
112 uint32_t DOE:1;
113 uint32_t NCE:1;
114 uint32_t SGE:1;
115 uint32_t SBE:1;
116 uint32_t DBE:1;
117 } B;
118 } ESR; /* Error Status Register */
119
120 union {
121 uint32_t R;
122 struct {
123 uint32_t ERQ63:1;
124 uint32_t ERQ62:1;
125 uint32_t ERQ61:1;
126 uint32_t ERQ60:1;
127 uint32_t ERQ59:1;
128 uint32_t ERQ58:1;
129 uint32_t ERQ57:1;
130 uint32_t ERQ56:1;
131 uint32_t ERQ55:1;
132 uint32_t ERQ54:1;
133 uint32_t ERQ53:1;
134 uint32_t ERQ52:1;
135 uint32_t ERQ51:1;
136 uint32_t ERQ50:1;
137 uint32_t ERQ49:1;
138 uint32_t ERQ48:1;
139 uint32_t ERQ47:1;
140 uint32_t ERQ46:1;
141 uint32_t ERQ45:1;
142 uint32_t ERQ44:1;
143 uint32_t ERQ43:1;
144 uint32_t ERQ42:1;
145 uint32_t ERQ41:1;
146 uint32_t ERQ40:1;
147 uint32_t ERQ39:1;
148 uint32_t ERQ38:1;
149 uint32_t ERQ37:1;
150 uint32_t ERQ36:1;
151 uint32_t ERQ35:1;
152 uint32_t ERQ34:1;
153 uint32_t ERQ33:1;
154 uint32_t ERQ32:1;
155 } B;
156 } ERQRH; /* DMA Enable Request Register High */
157
158 union {
159 uint32_t R;
160 struct {
161 uint32_t ERQ31:1;
162 uint32_t ERQ30:1;
163 uint32_t ERQ29:1;
164 uint32_t ERQ28:1;
165 uint32_t ERQ27:1;
166 uint32_t ERQ26:1;
167 uint32_t ERQ25:1;
168 uint32_t ERQ24:1;
169 uint32_t ERQ23:1;
170 uint32_t ERQ22:1;
171 uint32_t ERQ21:1;
172 uint32_t ERQ20:1;
173 uint32_t ERQ19:1;
174 uint32_t ERQ18:1;
175 uint32_t ERQ17:1;
176 uint32_t ERQ16:1;
177 uint32_t ERQ15:1;
178 uint32_t ERQ14:1;
179 uint32_t ERQ13:1;
180 uint32_t ERQ12:1;
181 uint32_t ERQ11:1;
182 uint32_t ERQ10:1;
183 uint32_t ERQ09:1;
184 uint32_t ERQ08:1;
185 uint32_t ERQ07:1;
186 uint32_t ERQ06:1;
187 uint32_t ERQ05:1;
188 uint32_t ERQ04:1;
189 uint32_t ERQ03:1;
190 uint32_t ERQ02:1;
191 uint32_t ERQ01:1;
192 uint32_t ERQ00:1;
193 } B;
194 } ERQRL; /* DMA Enable Request Register Low */
195
196 union {
197 uint32_t R;
198 struct {
199 uint32_t EEI63:1;
200 uint32_t EEI62:1;
201 uint32_t EEI61:1;
202 uint32_t EEI60:1;
203 uint32_t EEI59:1;
204 uint32_t EEI58:1;
205 uint32_t EEI57:1;
206 uint32_t EEI56:1;
207 uint32_t EEI55:1;
208 uint32_t EEI54:1;
209 uint32_t EEI53:1;
210 uint32_t EEI52:1;
211 uint32_t EEI51:1;
212 uint32_t EEI50:1;
213 uint32_t EEI49:1;
214 uint32_t EEI48:1;
215 uint32_t EEI47:1;
216 uint32_t EEI46:1;
217 uint32_t EEI45:1;
218 uint32_t EEI44:1;
219 uint32_t EEI43:1;
220 uint32_t EEI42:1;
221 uint32_t EEI41:1;
222 uint32_t EEI40:1;
223 uint32_t EEI39:1;
224 uint32_t EEI38:1;
225 uint32_t EEI37:1;
226 uint32_t EEI36:1;
227 uint32_t EEI35:1;
228 uint32_t EEI34:1;
229 uint32_t EEI33:1;
230 uint32_t EEI32:1;
231 } B;
232 } EEIRH; /* DMA Enable Error Interrupt Register High */
233
234 union {
235 uint32_t R;
236 struct {
237 uint32_t EEI31:1;
238 uint32_t EEI30:1;
239 uint32_t EEI29:1;
240 uint32_t EEI28:1;
241 uint32_t EEI27:1;
242 uint32_t EEI26:1;
243 uint32_t EEI25:1;
244 uint32_t EEI24:1;
245 uint32_t EEI23:1;
246 uint32_t EEI22:1;
247 uint32_t EEI21:1;
248 uint32_t EEI20:1;
249 uint32_t EEI19:1;
250 uint32_t EEI18:1;
251 uint32_t EEI17:1;
252 uint32_t EEI16:1;
253 uint32_t EEI15:1;
254 uint32_t EEI14:1;
255 uint32_t EEI13:1;
256 uint32_t EEI12:1;
257 uint32_t EEI11:1;
258 uint32_t EEI10:1;
259 uint32_t EEI09:1;
260 uint32_t EEI08:1;
261 uint32_t EEI07:1;
262 uint32_t EEI06:1;
263 uint32_t EEI05:1;
264 uint32_t EEI04:1;
265 uint32_t EEI03:1;
266 uint32_t EEI02:1;
267 uint32_t EEI01:1;
268 uint32_t EEI00:1;
269 } B;
270 } EEIRL; /* DMA Enable Error Interrupt Register Low */
271
272 union { /* DMA Set Enable Request Register */
273 uint8_t R;
274 struct {
275 uint8_t NOP:1;
276 uint8_t SERQ:7;
277 } B;
278 } SERQR;
279
280 union { /* DMA Clear Enable Request Register */
281 uint8_t R;
282 struct {
283 uint8_t NOP:1;
284 uint8_t CERQ:7;
285 } B;
286 } CERQR;
287
288 union { /* DMA Set Enable Error Interrupt Register */
289 uint8_t R;
290 struct {
291 uint8_t NOP:1;
292 uint8_t SEEI:7;
293 } B;
294 } SEEIR;
295
296 union { /* DMA Clear Enable Error Interrupt Register */
297 uint8_t R;
298 struct {
299 uint8_t NOP:1;
300 uint8_t CEEI:7;
301 } B;
302 } CEEIR;
303
304 union { /* DMA Clear Interrupt Request Register */
305 uint8_t R;
306 struct {
307 uint8_t NOP:1;
308 uint8_t CINT:7;
309 } B;
310 } CIRQR;
311
312 union { /* DMA Clear error Register */
313 uint8_t R;
314 struct {
315 uint8_t NOP:1;
316 uint8_t CERR:7;
317 } B;
318 } CER;
319
320 union { /* Set Start Bit Register */
321 uint8_t R;
322 struct {
323 uint8_t NOP:1;
324 uint8_t SSB:7;
325 } B;
326 } SSBR;
327
328 union { /* Clear Done Status Bit Register */
329 uint8_t R;
330 struct {
331 uint8_t NOP:1;
332 uint8_t CDSB:7;
333 } B;
334 } CDSBR;
335
336 union {
337 uint32_t R;
338 struct {
339 uint32_t INT63:1;
340 uint32_t INT62:1;
341 uint32_t INT61:1;
342 uint32_t INT60:1;
343 uint32_t INT59:1;
344 uint32_t INT58:1;
345 uint32_t INT57:1;
346 uint32_t INT56:1;
347 uint32_t INT55:1;
348 uint32_t INT54:1;
349 uint32_t INT53:1;
350 uint32_t INT52:1;
351 uint32_t INT51:1;
352 uint32_t INT50:1;
353 uint32_t INT49:1;
354 uint32_t INT48:1;
355 uint32_t INT47:1;
356 uint32_t INT46:1;
357 uint32_t INT45:1;
358 uint32_t INT44:1;
359 uint32_t INT43:1;
360 uint32_t INT42:1;
361 uint32_t INT41:1;
362 uint32_t INT40:1;
363 uint32_t INT39:1;
364 uint32_t INT38:1;
365 uint32_t INT37:1;
366 uint32_t INT36:1;
367 uint32_t INT35:1;
368 uint32_t INT34:1;
369 uint32_t INT33:1;
370 uint32_t INT32:1;
371 } B;
372 } IRQRH; /* DMA Interrupt Request High */
373
374 union {
375 uint32_t R;
376 struct {
377 uint32_t INT31:1;
378 uint32_t INT30:1;
379 uint32_t INT29:1;
380 uint32_t INT28:1;
381 uint32_t INT27:1;
382 uint32_t INT26:1;
383 uint32_t INT25:1;
384 uint32_t INT24:1;
385 uint32_t INT23:1;
386 uint32_t INT22:1;
387 uint32_t INT21:1;
388 uint32_t INT20:1;
389 uint32_t INT19:1;
390 uint32_t INT18:1;
391 uint32_t INT17:1;
392 uint32_t INT16:1;
393 uint32_t INT15:1;
394 uint32_t INT14:1;
395 uint32_t INT13:1;
396 uint32_t INT12:1;
397 uint32_t INT11:1;
398 uint32_t INT10:1;
399 uint32_t INT09:1;
400 uint32_t INT08:1;
401 uint32_t INT07:1;
402 uint32_t INT06:1;
403 uint32_t INT05:1;
404 uint32_t INT04:1;
405 uint32_t INT03:1;
406 uint32_t INT02:1;
407 uint32_t INT01:1;
408 uint32_t INT00:1;
409 } B;
410 } IRQRL; /* DMA Interrupt Request Low */
411
412 union {
413 uint32_t R;
414 struct {
415 uint32_t ERR63:1;
416 uint32_t ERR62:1;
417 uint32_t ERR61:1;
418 uint32_t ERR60:1;
419 uint32_t ERR59:1;
420 uint32_t ERR58:1;
421 uint32_t ERR57:1;
422 uint32_t ERR56:1;
423 uint32_t ERR55:1;
424 uint32_t ERR54:1;
425 uint32_t ERR53:1;
426 uint32_t ERR52:1;
427 uint32_t ERR51:1;
428 uint32_t ERR50:1;
429 uint32_t ERR49:1;
430 uint32_t ERR48:1;
431 uint32_t ERR47:1;
432 uint32_t ERR46:1;
433 uint32_t ERR45:1;
434 uint32_t ERR44:1;
435 uint32_t ERR43:1;
436 uint32_t ERR42:1;
437 uint32_t ERR41:1;
438 uint32_t ERR40:1;
439 uint32_t ERR39:1;
440 uint32_t ERR38:1;
441 uint32_t ERR37:1;
442 uint32_t ERR36:1;
443 uint32_t ERR35:1;
444 uint32_t ERR34:1;
445 uint32_t ERR33:1;
446 uint32_t ERR32:1;
447 } B;
448 } ERH; /* DMA Error High */
449
450 union {
451 uint32_t R;
452 struct {
453 uint32_t ERR31:1;
454 uint32_t ERR30:1;
455 uint32_t ERR29:1;
456 uint32_t ERR28:1;
457 uint32_t ERR27:1;
458 uint32_t ERR26:1;
459 uint32_t ERR25:1;
460 uint32_t ERR24:1;
461 uint32_t ERR23:1;
462 uint32_t ERR22:1;
463 uint32_t ERR21:1;
464 uint32_t ERR20:1;
465 uint32_t ERR19:1;
466 uint32_t ERR18:1;
467 uint32_t ERR17:1;
468 uint32_t ERR16:1;
469 uint32_t ERR15:1;
470 uint32_t ERR14:1;
471 uint32_t ERR13:1;
472 uint32_t ERR12:1;
473 uint32_t ERR11:1;
474 uint32_t ERR10:1;
475 uint32_t ERR09:1;
476 uint32_t ERR08:1;
477 uint32_t ERR07:1;
478 uint32_t ERR06:1;
479 uint32_t ERR05:1;
480 uint32_t ERR04:1;
481 uint32_t ERR03:1;
482 uint32_t ERR02:1;
483 uint32_t ERR01:1;
484 uint32_t ERR00:1;
485 } B;
486 } ERL; /* DMA Error Low */
487
488#if MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567
489 union { /* hardware request status high */
490 uint32_t R;
491 struct {
492 uint32_t HRS63:1;
493 uint32_t HRS62:1;
494 uint32_t HRS61:1;
495 uint32_t HRS60:1;
496 uint32_t HRS59:1;
497 uint32_t HRS58:1;
498 uint32_t HRS57:1;
499 uint32_t HRS56:1;
500 uint32_t HRS55:1;
501 uint32_t HRS54:1;
502 uint32_t HRS53:1;
503 uint32_t HRS52:1;
504 uint32_t HRS51:1;
505 uint32_t HRS50:1;
506 uint32_t HRS49:1;
507 uint32_t HRS48:1;
508 uint32_t HRS47:1;
509 uint32_t HRS46:1;
510 uint32_t HRS45:1;
511 uint32_t HRS44:1;
512 uint32_t HRS43:1;
513 uint32_t HRS42:1;
514 uint32_t HRS41:1;
515 uint32_t HRS40:1;
516 uint32_t HRS39:1;
517 uint32_t HRS38:1;
518 uint32_t HRS37:1;
519 uint32_t HRS36:1;
520 uint32_t HRS35:1;
521 uint32_t HRS34:1;
522 uint32_t HRS33:1;
523 uint32_t HRS32:1;
524 } B;
525 } HRSH;
526
527 union { /* hardware request status low */
528 uint32_t R;
529 struct {
530 uint32_t HRS31:1;
531 uint32_t HRS30:1;
532 uint32_t HRS29:1;
533 uint32_t HRS28:1;
534 uint32_t HRS27:1;
535 uint32_t HRS26:1;
536 uint32_t HRS25:1;
537 uint32_t HRS24:1;
538 uint32_t HRS23:1;
539 uint32_t HRS22:1;
540 uint32_t HRS21:1;
541 uint32_t HRS20:1;
542 uint32_t HRS19:1;
543 uint32_t HRS18:1;
544 uint32_t HRS17:1;
545 uint32_t HRS16:1;
546 uint32_t HRS15:1;
547 uint32_t HRS14:1;
548 uint32_t HRS13:1;
549 uint32_t HRS12:1;
550 uint32_t HRS11:1;
551 uint32_t HRS10:1;
552 uint32_t HRS09:1;
553 uint32_t HRS08:1;
554 uint32_t HRS07:1;
555 uint32_t HRS06:1;
556 uint32_t HRS05:1;
557 uint32_t HRS04:1;
558 uint32_t HRS03:1;
559 uint32_t HRS02:1;
560 uint32_t HRS01:1;
561 uint32_t HRS00:1;
562 } B;
563 } HRSL;
564
565 uint32_t eDMA_reserved0038[50]; /* 0x0038-0x00FF */
566#else
567 uint32_t edma_reserved1[52];
568#endif
569
570 union {
571 uint8_t R;
572 struct {
573 uint8_t ECP:1;
574#if MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567
575 uint8_t DPA:1;
576#else
577 uint8_t:1;
578#endif
579 uint8_t GRPPRI:2;
580 uint8_t CHPRI:4;
581 } B;
582 } CPR[64];
583
584 uint32_t edma_reserved2[944];
585
586/****************************************************************************/
587/* DMA2 Transfer Control Descriptor */
588/****************************************************************************/
589 struct tcd_t {
590 uint32_t SADDR; /* source address */
591
592 /* Source and destination fields */
594 uint32_t R;
595 struct {
596 uint16_t SMOD:5; /* source address modulo */
597 uint16_t SSIZE:3; /* source transfer size */
598 uint16_t DMOD:5; /* destination address modulo */
599 uint16_t DSIZE:3; /* destination transfer size */
600 int16_t SOFF; /* signed source address offset */
601 } B;
602 } SDF;
603
604 uint32_t NBYTES; /* inner (“minor”) byte count */
605
606 int32_t SLAST; /* last destination address adjustment, or
607 scatter/gather address (if e_sg = 1) */
608
609 uint32_t DADDR; /* destination address */
610
611 /* CITER and destination fields */
613 uint32_t R;
614 struct {
615 uint16_t CITERE_LINK:1;
616 uint16_t CITER:15;
617 int16_t DOFF; /* signed destination address offset */
618 } B;
619 struct {
620 uint16_t CITERE_LINK:1;
621 uint16_t CITERLINKCH:6;
622 uint16_t CITER:9;
623 int16_t DOFF;
624 } B_ALT;
625 struct {
626 uint16_t CITER;
627 int16_t DOFF;
628 } B_NOLINK;
629 } CDF;
630
631 int32_t DLAST_SGA;
632
633 /* BITER and misc fields */
635 uint32_t R;
636 struct {
637 uint32_t BITERE_LINK:1; /* beginning ("major") iteration count */
638 uint32_t BITER:15;
639 uint32_t BWC:2; /* bandwidth control */
640 uint32_t MAJORLINKCH:6; /* enable channel-to-channel link */
641 uint32_t DONE:1; /* channel done */
642 uint32_t ACTIVE:1; /* channel active */
643 uint32_t MAJORE_LINK:1; /* enable channel-to-channel link */
644 uint32_t E_SG:1; /* enable scatter/gather descriptor */
645 uint32_t D_REQ:1; /* disable ipd_req when done */
646 uint32_t INT_HALF:1; /* interrupt on citer = (biter >> 1) */
647 uint32_t INT_MAJ:1; /* interrupt on major loop completion */
648 uint32_t START:1; /* explicit channel start */
649 } B;
650 struct {
651 uint32_t BITERE_LINK:1;
652 uint32_t BITERLINKCH:6;
653 uint32_t BITER:9;
654 uint32_t BWC:2;
655 uint32_t MAJORLINKCH:6;
656 uint32_t DONE:1;
657 uint32_t ACTIVE:1;
658 uint32_t MAJORE_LINK:1;
659 uint32_t E_SG:1;
660 uint32_t D_REQ:1;
661 uint32_t INT_HALF:1;
662 uint32_t INT_MAJ:1;
663 uint32_t START:1;
664 } B_ALT;
665 struct {
666 uint16_t BITER;
667 uint16_t BWC:2;
668 uint16_t MAJORLINKCH:6;
669 uint16_t DONE:1;
670 uint16_t ACTIVE:1;
671 uint16_t MAJORE_LINK:1;
672 uint16_t E_SG:1;
673 uint16_t D_REQ:1;
674 uint16_t INT_HALF:1;
675 uint16_t INT_MAJ:1;
676 uint16_t START:1;
677 } B_NOLINK;
678 } BMF;
679 } TCD[64]; /* transfer_control_descriptor */
680 };
681
682#ifndef __cplusplus
683 static const struct tcd_t EDMA_TCD_DEFAULT = {
684 .SADDR = 0,
685 .SDF = { .R = 0 },
686 .NBYTES = 0,
687 .SLAST = 0,
688 .DADDR = 0,
689 .CDF = { .R = 0 },
690 .DLAST_SGA = 0,
691 .BMF = { .R = 0 }
692 };
693#endif /* __cplusplus */
694
695#define EDMA_TCD_BITER_MASK 0x7fff
696
697#define EDMA_TCD_BITER_SIZE (EDMA_TCD_BITER_MASK + 1)
698
699#define EDMA_TCD_BITER_LINKED_MASK 0x1ff
700
701#define EDMA_TCD_BITER_LINKED_SIZE (EDMA_TCD_BITER_LINKED_MASK + 1)
702
703#define EDMA_TCD_LINK_AND_BITER(link, biter) \
704 (((link) << 9) + ((biter) & EDMA_TCD_BITER_LINKED_MASK))
705
706#ifdef __cplusplus
707}
708#endif /* __cplusplus */
709
710#endif /* LIBCPU_POWERPC_MPC55XX_REGS_EDMA_H */
Definition: regs-edma.h:589
Definition: regs-edma.h:66
Definition: regs-edma.h:67
Definition: regs-edma.h:634
Definition: regs-edma.h:612
Definition: regs-edma.h:593
