RTEMS 5.2-rc1
reg_sys.h
1/* The header file is generated by make_header.py from SYS.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_SYS1
40#define LIBBSP_ARM_TMS570_SYS1
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t SYSPC1; /*SYS Pin Control Register 1*/
46 uint32_t SYSPC2; /*SYS Pin Control Register 2*/
47 uint32_t SYSPC3; /*SYS Pin Control Register 3*/
48 uint32_t SYSPC4; /*SYS Pin Control Register 4*/
49 uint32_t SYSPC5; /*SYS Pin Control Register 5*/
50 uint32_t SYSPC6; /*SYS Pin Control Register 6*/
51 uint32_t SYSPC7; /*SYS Pin Control Register 7*/
52 uint32_t SYSPC8; /*SYS Pin Control Register 8*/
53 uint32_t SYSPC9; /*SYS Pin Control Register 9*/
54 uint8_t reserved1 [12];
55 uint32_t CSDIS; /*Clock Source Disable Register*/
56 uint32_t CSDISSET; /*Clock Source Disable Set Register*/
57 uint32_t CSDISCLR; /*Clock Source Disable Clear Register*/
58 uint32_t CDDIS; /*Clock Domain Disable Register*/
59 uint32_t CDDISSET; /*Clock Domain Disable Set Register*/
60 uint32_t CDDISCLR; /*Clock Domain Disable Clear Register*/
61 uint32_t GHVSRC; /*GCLK, HCLK, VCLK, and VCLK2 Source Register*/
62 uint32_t VCLKASRC; /*Peripheral Asynchronous Clock Source Register*/
63 uint32_t RCLKSRC; /*RTI Clock Source Register*/
64 uint32_t CSVSTAT; /*Clock Source Valid Status Register*/
65 uint32_t MSTGCR; /*Memory Self-Test Global Control Register*/
66 uint32_t MINITGCR; /*Memory Hardware Initialization Global Control Register*/
67 uint32_t MSIENA; /*Memory Self-Test/Initialization Enable Register*/
68 uint8_t reserved2 [4];
69 uint32_t MSTCGSTAT; /*MSTC Global Status Register*/
70 uint32_t MINISTAT; /*Memory Hardware Initialization Status Register*/
71 uint32_t PLLCTL1; /*PLL Control Register 1*/
72 uint32_t PLLCTL2; /*PLL Control Register 2*/
73 uint32_t SYSPC10; /*SYS Pin Control Register 10*/
74 uint32_t DIEIDL; /*Die Identification Register, Lower Word*/
75 uint32_t DIEIDH; /*Die Identification Register, Upper Word*/
76 uint8_t reserved3 [4];
77 uint32_t LPOMONCTL; /*LPO/Clock Monitor Control Register*/
78 uint32_t CLKTEST; /*Clock Test Register*/
79 uint32_t DFTCTRLREG1; /*DFT Control Register*/
80 uint32_t DFTCTRLREG2; /*DFT Control Register 2*/
81 uint8_t reserved4 [8];
82 uint32_t GPREG1; /*General Purpose Register*/
83 uint8_t reserved5 [4];
84 uint32_t IMPFASTS; /*Imprecise Fault Status Register*/
85 uint32_t IMPFTADD; /*Imprecise Fault Write Address Register*/
86 uint32_t SSIR1; /*System Software Interrupt Request 1 Register*/
87 uint32_t SSIR2; /*System Software Interrupt Request 2 Register*/
88 uint32_t SSIR3; /*System Software Interrupt Request 3 Register*/
89 uint32_t SSIR4; /*System Software Interrupt Request 4 Register*/
90 uint32_t RAMGCR; /*RAM Control Register*/
91 uint32_t BMMCR1; /*Bus Matrix Module Control Register 1*/
92 uint8_t reserved6 [4];
93 uint32_t CPURSTCR; /*CPU Reset Control Register*/
94 uint32_t CLKCNTL; /*Clock Control Register*/
95 uint32_t ECPCNTL; /*ECP Control Register*/
96 uint8_t reserved7 [4];
97 uint32_t DEVCR1; /*DEV Parity Control Register 1*/
98 uint32_t SYSECR; /*System Exception Control Register*/
99 uint32_t SYSESR; /*System Exception Status Register*/
100 uint32_t SYSTASR; /*System Test Abort Status Register*/
101 uint32_t GLBSTAT; /*Global Status Register*/
102 uint32_t DEVID; /*Device Identification Register*/
103 uint32_t SSIVEC; /*Software Interrupt Vector Register*/
104 uint32_t SSIF; /*System Software Interrupt Flag Register*/
106
107
108/*---------------------TMS570_SYS1_SYSPCx---------------------*/
109/* field: ECPCLKFUN - ECLK function. This bit changes the function of the ECLK pin. */
110#define TMS570_SYS1_SYSPCx_ECPCLKFUN BSP_BIT32(0)
111
112
113/*---------------------TMS570_SYS1_CSDIS---------------------*/
114/* field: CLKSROFF - Clock source[7-0] off. 2 reserved */
115#define TMS570_SYS1_CSDIS_CLKSROFF(val) BSP_FLD32(val,0, 7)
116#define TMS570_SYS1_CSDIS_CLKSROFF_GET(reg) BSP_FLD32GET(reg,0, 7)
117#define TMS570_SYS1_CSDIS_CLKSROFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
118
119/* Clock Source 0 Oscillator */
120#define TMS570_SYS1_CSDIS_CLKSR_OSC_NUM 0
121#define TMS570_SYS1_CSDIS_CLKSROFF_OSC BSP_BIT32(0)
122
123/* Clock Source 1 PLL1 */
124#define TMS570_SYS1_CSDIS_CLKSR_PLL1_NUM 1
125#define TMS570_SYS1_CSDIS_CLKSROFF_PLL1 BSP_BIT32(1)
126
127/* Clock Source 3 EXTCLKIN */
128#define TMS570_SYS1_CSDIS_CLKSR_EXTCLKIN_NUM 3
129#define TMS570_SYS1_CSDIS_CLKSROFF_EXTCLKIN BSP_BIT32(3)
130
131/* Clock Source 4 Low Frequency LPO (Low Power Oscillator) clock */
132#define TMS570_SYS1_CSDIS_CLKSR_LPO_NUM 4
133#define TMS570_SYS1_CSDIS_CLKSROFF_LPO BSP_BIT32(4)
134
135/* Clock Source 5 High Frequency LPO (Low Power Oscillator) clock */
136#define TMS570_SYS1_CSDIS_CLKSR_HPO_NUM 5
137#define TMS570_SYS1_CSDIS_CLKSROFF_HPO BSP_BIT32(5)
138
139/* Clock Source 6 PLL2 */
140#define TMS570_SYS1_CSDIS_CLKSR_PLL2_NUM 6
141#define TMS570_SYS1_CSDIS_CLKSROFF_PLL2 BSP_BIT32(6)
142
143/* Clock Source 7 EXTCLKIN2 */
144#define TMS570_SYS1_CSDIS_CLKSR_EXTCLKIN2_NUM 7
145#define TMS570_SYS1_CSDIS_CLKSROFF_EXTCLKIN2 BSP_BIT32(7)
146
147/*--------------------TMS570_SYS1_CSDISSET--------------------*/
148/* field: SETCLKSR_OFF - Set clock source[7-0] to the disabled state. */
149#define TMS570_SYS1_CSDISSET_SETCLKSR_OFF(val) BSP_FLD32(val,0, 7)
150#define TMS570_SYS1_CSDISSET_SETCLKSR_OFF_GET(reg) BSP_FLD32GET(reg,0, 7)
151#define TMS570_SYS1_CSDISSET_SETCLKSR_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
152
153/*--------------------TMS570_SYS1_CSDISCLR--------------------*/
154/* field: CLRCLKSR_OFF - Enables clock source[7-0] */
155#define TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF(val) BSP_FLD32(val,0, 7)
156#define TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF_GET(reg) BSP_FLD32GET(reg,0, 7)
157#define TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
158
159/*---------------------TMS570_SYS1_CDDIS---------------------*/
160/* field: VCLKAOFF - VCLKA4 domain off. */
161#define TMS570_SYS1_CDDIS_VCLKAOFF4 BSP_BIT32(11)
162
163/* field: VCLKAOFF - VCLKA3 domain off. */
164#define TMS570_SYS1_CDDIS_VCLKAOFF3 BSP_BIT32(10)
165
166/* field: VCLK3OFF - VCLK3 domain off. */
167#define TMS570_SYS1_CDDIS_VCLK3OFF BSP_BIT32(8)
168
169/* field: RTICLK1OFF - RTICLK1 domain off. */
170#define TMS570_SYS1_CDDIS_RTICLK1OFF BSP_BIT32(6)
171
172/* field: VCLKAOFF - VCLKA2 domain off. */
173#define TMS570_SYS1_CDDIS_VCLKAOFF2 BSP_BIT32(5)
174
175/* field: VCLKAOFF - VCLKA1 domain off. */
176#define TMS570_SYS1_CDDIS_VCLKAOFF1 BSP_BIT32(4)
177
178/* field: VCLK2OFF - VCLK2 domain off. */
179#define TMS570_SYS1_CDDIS_VCLK2OFF BSP_BIT32(3)
180
181/* field: VCLKPOFF - VCLK_periph domain off. */
182#define TMS570_SYS1_CDDIS_VCLKPOFF BSP_BIT32(2)
183
184/* field: HCLKOFF - HCLK and VCLK_sys domains off. */
185#define TMS570_SYS1_CDDIS_HCLKOFF BSP_BIT32(1)
186
187/* field: GCLKOFF - GCLK domain off. */
188#define TMS570_SYS1_CDDIS_GCLKOFF BSP_BIT32(0)
189
190
191/*--------------------TMS570_SYS1_CDDISSET--------------------*/
192/* field: SETVCLKA_OFF - Set VCLKA[4-3] domain. */
193#define TMS570_SYS1_CDDISSET_SETVCLKA_OFF(val) BSP_FLD32(val,10, 11)
194#define TMS570_SYS1_CDDISSET_SETVCLKA_OFF_GET(reg) BSP_FLD32GET(reg,10, 11)
195#define TMS570_SYS1_CDDISSET_SETVCLKA_OFF_SET(reg,val) BSP_FLD32SET(reg, val,10, 11)
196
197/* field: SETVCLK3OFF - Set VCLK3 domain. */
198#define TMS570_SYS1_CDDISSET_SETVCLK3OFF BSP_BIT32(8)
199
200/* field: SETRTI1CLKOFF - Set RTICLK1 domain. */
201#define TMS570_SYS1_CDDISSET_SETRTI1CLKOFF BSP_BIT32(6)
202
203/* field: SETTVCLKA2OFF - Set VCLKA2 domain. */
204#define TMS570_SYS1_CDDISSET_SETTVCLKA2OFF BSP_BIT32(5)
205
206/* field: SETVCLKA1OFF - Set VCLKA1 domain. */
207#define TMS570_SYS1_CDDISSET_SETVCLKA1OFF BSP_BIT32(4)
208
209/* field: SETVCLK2OFF - Set VCLK2 domain. */
210#define TMS570_SYS1_CDDISSET_SETVCLK2OFF BSP_BIT32(3)
211
212/* field: SETVCLKPOFF - Set VCLK_periph domain. */
213#define TMS570_SYS1_CDDISSET_SETVCLKPOFF BSP_BIT32(2)
214
215/* field: SETHCLKOFF - Set HCLK and VCLK_sys domains. */
216#define TMS570_SYS1_CDDISSET_SETHCLKOFF BSP_BIT32(1)
217
218/* field: SETGCLKOFF - Set GCLK domain. */
219#define TMS570_SYS1_CDDISSET_SETGCLKOFF BSP_BIT32(0)
220
221
222/*--------------------TMS570_SYS1_CDDISCLR--------------------*/
223/* field: CLRVCLKAOFF - Clear VCLKA[4-3] domain. */
224#define TMS570_SYS1_CDDISCLR_CLRVCLKAOFF(val) BSP_FLD32(val,10, 11)
225#define TMS570_SYS1_CDDISCLR_CLRVCLKAOFF_GET(reg) BSP_FLD32GET(reg,10, 11)
226#define TMS570_SYS1_CDDISCLR_CLRVCLKAOFF_SET(reg,val) BSP_FLD32SET(reg, val,10, 11)
227
228/* field: Reserved - Reserved */
229#define TMS570_SYS1_CDDISCLR_Reserved BSP_BIT32(9)
230
231/* field: CLRVCLK3OFF - Clear VCLK3 domain. */
232#define TMS570_SYS1_CDDISCLR_CLRVCLK3OFF BSP_BIT32(8)
233
234/* field: CLRRTI1CLKOFF - Clear RTICLK1 domain. */
235#define TMS570_SYS1_CDDISCLR_CLRRTI1CLKOFF BSP_BIT32(6)
236
237/* field: CLRTVCLKA2OFF - Clear VCLKA2 domain. */
238#define TMS570_SYS1_CDDISCLR_CLRTVCLKA2OFF BSP_BIT32(5)
239
240/* field: CLRVCLKA1OFF - Clear VCLKA1 domain. */
241#define TMS570_SYS1_CDDISCLR_CLRVCLKA1OFF BSP_BIT32(4)
242
243/* field: CLRVCLK2OFF - Clear VCLK2 domain. */
244#define TMS570_SYS1_CDDISCLR_CLRVCLK2OFF BSP_BIT32(3)
245
246/* field: CLRVCLKPOFF - CLRVCLKPOFF */
247#define TMS570_SYS1_CDDISCLR_CLRVCLKPOFF BSP_BIT32(2)
248
249/* field: CLRHCLKOFF - Clear HCLK and VCLK_sys domains. */
250#define TMS570_SYS1_CDDISCLR_CLRHCLKOFF BSP_BIT32(1)
251
252/* field: CLRGCLKOFF - Clear GCLK domain. */
253#define TMS570_SYS1_CDDISCLR_CLRGCLKOFF BSP_BIT32(0)
254
255
256/*---------------------TMS570_SYS1_GHVSRC---------------------*/
257/* field: GHVWAKE - GCLK, HCLK, VCLK, VCLK2 source on wakeup. */
258#define TMS570_SYS1_GHVSRC_GHVWAKE(val) BSP_FLD32(val,24, 27)
259#define TMS570_SYS1_GHVSRC_GHVWAKE_GET(reg) BSP_FLD32GET(reg,24, 27)
260#define TMS570_SYS1_GHVSRC_GHVWAKE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
261
262/* field: HVLPM - HCLK, VCLK, VCLK2 source on wakeup when GCLK is turned off. */
263#define TMS570_SYS1_GHVSRC_HVLPM(val) BSP_FLD32(val,16, 19)
264#define TMS570_SYS1_GHVSRC_HVLPM_GET(reg) BSP_FLD32GET(reg,16, 19)
265#define TMS570_SYS1_GHVSRC_HVLPM_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
266
267/* field: GHVSRC - GCLK, HCLK, VCLK, VCLK2 current source. */
268#define TMS570_SYS1_GHVSRC_GHVSRC(val) BSP_FLD32(val,0, 3)
269#define TMS570_SYS1_GHVSRC_GHVSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
270#define TMS570_SYS1_GHVSRC_GHVSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
271
272
273/*--------------------TMS570_SYS1_VCLKASRC--------------------*/
274/* field: VCLKA2S - Peripheral asynchronous clock2 source. */
275#define TMS570_SYS1_VCLKASRC_VCLKA2S(val) BSP_FLD32(val,8, 11)
276#define TMS570_SYS1_VCLKASRC_VCLKA2S_GET(reg) BSP_FLD32GET(reg,8, 11)
277#define TMS570_SYS1_VCLKASRC_VCLKA2S_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
278
279/* field: VCLKA1S - Peripheral asynchronous clock1 source. */
280#define TMS570_SYS1_VCLKASRC_VCLKA1S(val) BSP_FLD32(val,0, 3)
281#define TMS570_SYS1_VCLKASRC_VCLKA1S_GET(reg) BSP_FLD32GET(reg,0, 3)
282#define TMS570_SYS1_VCLKASRC_VCLKA1S_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
283
284
285/*--------------------TMS570_SYS1_RCLKSRC--------------------*/
286/* field: RTI1DIV - RTI clock1 Divider. */
287#define TMS570_SYS1_RCLKSRC_RTI1DIV(val) BSP_FLD32(val,8, 9)
288#define TMS570_SYS1_RCLKSRC_RTI1DIV_GET(reg) BSP_FLD32GET(reg,8, 9)
289#define TMS570_SYS1_RCLKSRC_RTI1DIV_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
290
291/* field: RTI1SRC - RTI clock1 source. */
292#define TMS570_SYS1_RCLKSRC_RTI1SRC(val) BSP_FLD32(val,0, 3)
293#define TMS570_SYS1_RCLKSRC_RTI1SRC_GET(reg) BSP_FLD32GET(reg,0, 3)
294#define TMS570_SYS1_RCLKSRC_RTI1SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
295
296
297/*--------------------TMS570_SYS1_CSVSTAT--------------------*/
298/* field: CLKSRV - Clock source[7-0] valid. */
299#define TMS570_SYS1_CSVSTAT_CLKSRV(val) BSP_FLD32(val,3, 7)
300#define TMS570_SYS1_CSVSTAT_CLKSRV_GET(reg) BSP_FLD32GET(reg,3, 7)
301#define TMS570_SYS1_CSVSTAT_CLKSRV_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
302
303/* field: CLKSR - Clock source[1-0] valid. */
304#define TMS570_SYS1_CSVSTAT_CLKSR(val) BSP_FLD32(val,0, 1)
305#define TMS570_SYS1_CSVSTAT_CLKSR_GET(reg) BSP_FLD32GET(reg,0, 1)
306#define TMS570_SYS1_CSVSTAT_CLKSR_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
307
308
309/*---------------------TMS570_SYS1_MSTGCR---------------------*/
310/* field: ROM_DIV - Prescaler divider bits for ROM clock source. */
311#define TMS570_SYS1_MSTGCR_ROM_DIV(val) BSP_FLD32(val,8, 9)
312#define TMS570_SYS1_MSTGCR_ROM_DIV_GET(reg) BSP_FLD32GET(reg,8, 9)
313#define TMS570_SYS1_MSTGCR_ROM_DIV_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
314
315/* field: MSTGENA - Memory self-test controller global enable key */
316#define TMS570_SYS1_MSTGCR_MSTGENA(val) BSP_FLD32(val,0, 3)
317#define TMS570_SYS1_MSTGCR_MSTGENA_GET(reg) BSP_FLD32GET(reg,0, 3)
318#define TMS570_SYS1_MSTGCR_MSTGENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
319
320
321/*--------------------TMS570_SYS1_MINITGCR--------------------*/
322/* field: MINITGENA - Memory hardware initialization global enable key. */
323#define TMS570_SYS1_MINITGCR_MINITGENA(val) BSP_FLD32(val,0, 3)
324#define TMS570_SYS1_MINITGCR_MINITGENA_GET(reg) BSP_FLD32GET(reg,0, 3)
325#define TMS570_SYS1_MINITGCR_MINITGENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
326
327
328/*---------------------TMS570_SYS1_MSIENA---------------------*/
329/* field: MSIENA - PBIST controller and memory initialization enable register. */
330/* Whole 32 bits */
331
332/*-------------------TMS570_SYS1_MSTCGSTAT-------------------*/
333/* field: MINIDONE - Memory hardware initialization complete status. */
334#define TMS570_SYS1_MSTCGSTAT_MINIDONE BSP_BIT32(8)
335
336/* field: MSTDONE - Memory self-test run complete status. */
337#define TMS570_SYS1_MSTCGSTAT_MSTDONE BSP_BIT32(0)
338
339
340/*--------------------TMS570_SYS1_MINISTAT--------------------*/
341/* field: MIDONE - Memory hardware initialization status bit. */
342/* Whole 32 bits */
343
344/*--------------------TMS570_SYS1_PLLCTL1--------------------*/
345/* field: ROS - Reset on PLL Slip */
346#define TMS570_SYS1_PLLCTL1_ROS BSP_BIT32(31)
347
348/* field: MASK_SLIP - Mask detection of PLL slip */
349#define TMS570_SYS1_PLLCTL1_MASK_SLIP(val) BSP_FLD32(val,29, 30)
350#define TMS570_SYS1_PLLCTL1_MASK_SLIP_GET(reg) BSP_FLD32GET(reg,29, 30)
351#define TMS570_SYS1_PLLCTL1_MASK_SLIP_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
352
353/* field: PLLDIV - PLL Output Clock Divider */
354#define TMS570_SYS1_PLLCTL1_PLLDIV(val) BSP_FLD32(val,24, 28)
355#define TMS570_SYS1_PLLCTL1_PLLDIV_GET(reg) BSP_FLD32GET(reg,24, 28)
356#define TMS570_SYS1_PLLCTL1_PLLDIV_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
357
358/* field: ROF - Reset on Oscillator Fail */
359#define TMS570_SYS1_PLLCTL1_ROF BSP_BIT32(23)
360
361/* field: REFCLKDIV - Reference Clock Divider */
362#define TMS570_SYS1_PLLCTL1_REFCLKDIV(val) BSP_FLD32(val,16, 21)
363#define TMS570_SYS1_PLLCTL1_REFCLKDIV_GET(reg) BSP_FLD32GET(reg,16, 21)
364#define TMS570_SYS1_PLLCTL1_REFCLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
365
366/* field: PLLMUL - PLL Multiplication Factor */
367#define TMS570_SYS1_PLLCTL1_PLLMUL(val) BSP_FLD32(val,0, 15)
368#define TMS570_SYS1_PLLCTL1_PLLMUL_GET(reg) BSP_FLD32GET(reg,0, 15)
369#define TMS570_SYS1_PLLCTL1_PLLMUL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
370
371
372/*--------------------TMS570_SYS1_PLLCTL2--------------------*/
373/* field: FMENA - Frequency Modulation Enable. */
374#define TMS570_SYS1_PLLCTL2_FMENA BSP_BIT32(31)
375
376/* field: SPREADINGRATE - NS = SPREADINGRATE + 1 */
377#define TMS570_SYS1_PLLCTL2_SPREADINGRATE(val) BSP_FLD32(val,22, 30)
378#define TMS570_SYS1_PLLCTL2_SPREADINGRATE_GET(reg) BSP_FLD32GET(reg,22, 30)
379#define TMS570_SYS1_PLLCTL2_SPREADINGRATE_SET(reg,val) BSP_FLD32SET(reg, val,22, 30)
380
381/* field: MULMOD - Multiplier Correction when Frequency Modulation is enabled. */
382#define TMS570_SYS1_PLLCTL2_MULMOD(val) BSP_FLD32(val,12, 20)
383#define TMS570_SYS1_PLLCTL2_MULMOD_GET(reg) BSP_FLD32GET(reg,12, 20)
384#define TMS570_SYS1_PLLCTL2_MULMOD_SET(reg,val) BSP_FLD32SET(reg, val,12, 20)
385
386/* field: ODPLL - Internal PLL Output Divider. */
387#define TMS570_SYS1_PLLCTL2_ODPLL(val) BSP_FLD32(val,9, 11)
388#define TMS570_SYS1_PLLCTL2_ODPLL_GET(reg) BSP_FLD32GET(reg,9, 11)
389#define TMS570_SYS1_PLLCTL2_ODPLL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
390
391/* field: SPR_AMOUNT - Spreading Amount. */
392#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT(val) BSP_FLD32(val,0, 8)
393#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT_GET(reg) BSP_FLD32GET(reg,0, 8)
394#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
395
396
397/*--------------------TMS570_SYS1_SYSPC10--------------------*/
398/* field: ECPCLK_SLEW - ECPCLK slew control. This bit controls between the fast or slow slew mode. */
399#define TMS570_SYS1_SYSPC10_ECPCLK_SLEW BSP_BIT32(0)
400
401
402/*---------------------TMS570_SYS1_DIEIDL---------------------*/
403/* field: LOT - These read only bits contain the lower 10 bits of the device lot number. */
404#define TMS570_SYS1_DIEIDL_LOT(val) BSP_FLD32(val,22, 31)
405#define TMS570_SYS1_DIEIDL_LOT_GET(reg) BSP_FLD32GET(reg,22, 31)
406#define TMS570_SYS1_DIEIDL_LOT_SET(reg,val) BSP_FLD32SET(reg, val,22, 31)
407
408/* field: WAFER - These read only bits contain the wafer number of the device. */
409#define TMS570_SYS1_DIEIDL_WAFER(val) BSP_FLD32(val,16, 21)
410#define TMS570_SYS1_DIEIDL_WAFER_GET(reg) BSP_FLD32GET(reg,16, 21)
411#define TMS570_SYS1_DIEIDL_WAFER_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
412
413/* field: Y_WAFER_COORDINATE - These read only bits contain the Y wafer coordinate of the device */
414#define TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE(val) BSP_FLD32(val,8, 15)
415#define TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE_GET(reg) BSP_FLD32GET(reg,8, 15)
416#define TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
417
418/* field: X_WAFER_COORDINATE - These read only bits contain the X wafer coordinate of the device */
419#define TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE(val) BSP_FLD32(val,0, 7)
420#define TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE_GET(reg) BSP_FLD32GET(reg,0, 7)
421#define TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
422
423
424/*---------------------TMS570_SYS1_DIEIDH---------------------*/
425/* field: LOT - This read-only register contains the upper 14 bits of the device lot number. */
426#define TMS570_SYS1_DIEIDH_LOT(val) BSP_FLD32(val,0, 13)
427#define TMS570_SYS1_DIEIDH_LOT_GET(reg) BSP_FLD32GET(reg,0, 13)
428#define TMS570_SYS1_DIEIDH_LOT_SET(reg,val) BSP_FLD32SET(reg, val,0, 13)
429
430
431/*-------------------TMS570_SYS1_LPOMONCTL-------------------*/
432/* field: BIAS_ENABLE - Bias enable. */
433#define TMS570_SYS1_LPOMONCTL_BIAS_ENABLE BSP_BIT32(24)
434
435/* field: OSCFRQCONFIGCNT - Configures the counter based on OSC frequency. */
436#define TMS570_SYS1_LPOMONCTL_OSCFRQCONFIGCNT BSP_BIT32(16)
437
438/* field: HFTRIM - High frequency oscillator trim value. */
439#define TMS570_SYS1_LPOMONCTL_HFTRIM(val) BSP_FLD32(val,8, 12)
440#define TMS570_SYS1_LPOMONCTL_HFTRIM_GET(reg) BSP_FLD32GET(reg,8, 12)
441#define TMS570_SYS1_LPOMONCTL_HFTRIM_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
442
443
444/*--------------------TMS570_SYS1_CLKTEST--------------------*/
445/* field: ALTLIMPCLOCKENABLE - This bit selects a clock driven by the GIOB[0] pin as an alternate limp clock to the clock */
446#define TMS570_SYS1_CLKTEST_ALTLIMPCLOCKENABLE BSP_BIT32(26)
447
448/* field: RANGEDETCTRL - Range detection control. */
449#define TMS570_SYS1_CLKTEST_RANGEDETCTRL BSP_BIT32(25)
450
451/* field: RANGEDETENASSEL - Selects range detection enable. This bit resets asynchronously on power on reset. */
452#define TMS570_SYS1_CLKTEST_RANGEDETENASSEL BSP_BIT32(24)
453
454/* field: CLK_TEST_EN - Clock test enable. This bit enables the clock going to the ECLK pin. */
455#define TMS570_SYS1_CLKTEST_CLK_TEST_EN(val) BSP_FLD32(val,16, 19)
456#define TMS570_SYS1_CLKTEST_CLK_TEST_EN_GET(reg) BSP_FLD32GET(reg,16, 19)
457#define TMS570_SYS1_CLKTEST_CLK_TEST_EN_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
458
459/* field: SEL_GIO_PIN - GIOB[0] pin clock source valid, clock source select */
460#define TMS570_SYS1_CLKTEST_SEL_GIO_PIN(val) BSP_FLD32(val,8, 11)
461#define TMS570_SYS1_CLKTEST_SEL_GIO_PIN_GET(reg) BSP_FLD32GET(reg,8, 11)
462#define TMS570_SYS1_CLKTEST_SEL_GIO_PIN_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
463
464/* field: SEL_ECP_PIN - ECLK pin clock source select */
465#define TMS570_SYS1_CLKTEST_SEL_ECP_PIN(val) BSP_FLD32(val,0, 3)
466#define TMS570_SYS1_CLKTEST_SEL_ECP_PIN_GET(reg) BSP_FLD32GET(reg,0, 3)
467#define TMS570_SYS1_CLKTEST_SEL_ECP_PIN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
468
469
470/*------------------TMS570_SYS1_DFTCTRLREG1------------------*/
471/* field: DFTWRITE - DFT logic access. */
472#define TMS570_SYS1_DFTCTRLREG1_DFTWRITE(val) BSP_FLD32(val,12, 13)
473#define TMS570_SYS1_DFTCTRLREG1_DFTWRITE_GET(reg) BSP_FLD32GET(reg,12, 13)
474#define TMS570_SYS1_DFTCTRLREG1_DFTWRITE_SET(reg,val) BSP_FLD32SET(reg, val,12, 13)
475
476/* field: DFTREAD - DFT logic access. */
477#define TMS570_SYS1_DFTCTRLREG1_DFTREAD(val) BSP_FLD32(val,8, 9)
478#define TMS570_SYS1_DFTCTRLREG1_DFTREAD_GET(reg) BSP_FLD32GET(reg,8, 9)
479#define TMS570_SYS1_DFTCTRLREG1_DFTREAD_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
480
481/* field: TEST_MODE_KEY - Test mode key. This register is for internal TI use only. */
482#define TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY(val) BSP_FLD32(val,0, 3)
483#define TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
484#define TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
485
486
487/*------------------TMS570_SYS1_DFTCTRLREG2------------------*/
488/* field: IMPDF - DFT Implementation defined bits. */
489#define TMS570_SYS1_DFTCTRLREG2_IMPDF(val) BSP_FLD32(val,4, 31)
490#define TMS570_SYS1_DFTCTRLREG2_IMPDF_GET(reg) BSP_FLD32GET(reg,4, 31)
491#define TMS570_SYS1_DFTCTRLREG2_IMPDF_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
492
493/* field: TEST_MODE_KEY - Test mode key. This register is for internal TI use only. */
494#define TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY(val) BSP_FLD32(val,0, 3)
495#define TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
496#define TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
497
498
499/*---------------------TMS570_SYS1_GPREG1---------------------*/
500/* field: EMIF_FUNC - Enable EMIF functions to be output. */
501#define TMS570_SYS1_GPREG1_EMIF_FUNC BSP_BIT32(31)
502
503/* field: PLL1_FBSLIP_FILTER__COUNT - FBSLIP down counter programmed value. */
504#define TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT(val) BSP_FLD32(val,20, 25)
505#define TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT_GET(reg) BSP_FLD32GET(reg,20, 25)
506#define TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
507
508/* field: PLL1_RFSLIP_FILTER__KEY - Configures the system response when a FBSLIP is indicated by the */
509#define TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY(val) BSP_FLD32(val,16, 19)
510#define TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
511#define TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
512
513/* field: OUTPUT_BUFFER_LOW_EMI_MODE - Control field for the low-EMI mode of output buffers for */
514#define TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE(val) BSP_FLD32(val,0, 15)
515#define TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_GET(reg) BSP_FLD32GET(reg,0, 15)
516#define TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
517
518
519/*--------------------TMS570_SYS1_IMPFASTS--------------------*/
520/* field: ECPCLKFUN - ECLK function. This bit changes the function of the ECLK pin. */
521#define TMS570_SYS1_IMPFASTS_ECPCLKFUN BSP_BIT32(0)
522
523
524/*--------------------TMS570_SYS1_IMPFTADD--------------------*/
525/* field: IMPFTADD - These bits contain the fault address when an imprecise abort occurs. */
526/* Whole 32 bits */
527
528/*---------------------TMS570_SYS1_SSIRx---------------------*/
529/* field: SSKEY1 - System software interrupt request key. A 075h written to these bits initiates IRQ/FIQ interrupts. */
530#define TMS570_SYS1_SSIRx_SSKEY1(val) BSP_FLD32(val,8, 15)
531#define TMS570_SYS1_SSIRx_SSKEY1_GET(reg) BSP_FLD32GET(reg,8, 15)
532#define TMS570_SYS1_SSIRx_SSKEY1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
533
534/* field: SSDATA1 - System software interrupt data. These bits contain user read/write register bits. */
535#define TMS570_SYS1_SSIRx_SSDATA1(val) BSP_FLD32(val,0, 7)
536#define TMS570_SYS1_SSIRx_SSDATA1_GET(reg) BSP_FLD32GET(reg,0, 7)
537#define TMS570_SYS1_SSIRx_SSDATA1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
538
539
540/*---------------------TMS570_SYS1_RAMGCR---------------------*/
541/* field: RAM_DFT_EN - Functional mode RAM DFT (Design For Test) port enable key. */
542#define TMS570_SYS1_RAMGCR_RAM_DFT_EN(val) BSP_FLD32(val,16, 19)
543#define TMS570_SYS1_RAMGCR_RAM_DFT_EN_GET(reg) BSP_FLD32GET(reg,16, 19)
544#define TMS570_SYS1_RAMGCR_RAM_DFT_EN_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
545
546/* field: WST_AENA0 - eSRAM data phase wait state enable bit. */
547#define TMS570_SYS1_RAMGCR_WST_AENA0 BSP_BIT32(2)
548
549/* field: WST_DENA0 - eSRAM data phase wait state enable bit. */
550#define TMS570_SYS1_RAMGCR_WST_DENA0 BSP_BIT32(0)
551
552
553/*---------------------TMS570_SYS1_BMMCR1---------------------*/
554/* field: MEMSW - Memory swap key. */
555#define TMS570_SYS1_BMMCR1_MEMSW(val) BSP_FLD32(val,0, 3)
556#define TMS570_SYS1_BMMCR1_MEMSW_GET(reg) BSP_FLD32GET(reg,0, 3)
557#define TMS570_SYS1_BMMCR1_MEMSW_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
558
559
560/*--------------------TMS570_SYS1_CPURSTCR--------------------*/
561/* field: CPU_RESET - CPU Reset. */
562#define TMS570_SYS1_CPURSTCR_CPU_RESET BSP_BIT32(0)
563
564
565/*--------------------TMS570_SYS1_CLKCNTL--------------------*/
566/* field: VCLK2R - VBUS clock2 ratio. */
567#define TMS570_SYS1_CLKCNTL_VCLK2R(val) BSP_FLD32(val,24, 27)
568#define TMS570_SYS1_CLKCNTL_VCLK2R_GET(reg) BSP_FLD32GET(reg,24, 27)
569#define TMS570_SYS1_CLKCNTL_VCLK2R_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
570
571/* field: VCLKR - VBUS clock ratio. */
572#define TMS570_SYS1_CLKCNTL_VCLKR(val) BSP_FLD32(val,16, 19)
573#define TMS570_SYS1_CLKCNTL_VCLKR_GET(reg) BSP_FLD32GET(reg,16, 19)
574#define TMS570_SYS1_CLKCNTL_VCLKR_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
575
576/* field: PENA - Peripheral enable bit. */
577#define TMS570_SYS1_CLKCNTL_PENA BSP_BIT32(8)
578
579
580/*--------------------TMS570_SYS1_ECPCNTL--------------------*/
581/* field: ECPSSEL - This bit allows the selection between VCLK and OSCIN as the clock source for ECLK. */
582#define TMS570_SYS1_ECPCNTL_ECPSSEL BSP_BIT32(24)
583
584/* field: ECPCOS - ECP continue on suspend. */
585#define TMS570_SYS1_ECPCNTL_ECPCOS BSP_BIT32(23)
586
587/* field: ECPINSEL - Select ECP input clock source. */
588#define TMS570_SYS1_ECPCNTL_ECPINSEL(val) BSP_FLD32(val,6, 17)
589#define TMS570_SYS1_ECPCNTL_ECPINSEL_GET(reg) BSP_FLD32GET(reg,6, 17)
590#define TMS570_SYS1_ECPCNTL_ECPINSEL_SET(reg,val) BSP_FLD32SET(reg, val,6, 17)
591
592/* field: ECPDIV - ECP divider value. */
593#define TMS570_SYS1_ECPCNTL_ECPDIV(val) BSP_FLD32(val,0, 15)
594#define TMS570_SYS1_ECPCNTL_ECPDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
595#define TMS570_SYS1_ECPCNTL_ECPDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
596
597
598/*---------------------TMS570_SYS1_DEVCR1---------------------*/
599/* field: DEVPARSEL - Device parity select bit key. */
600#define TMS570_SYS1_DEVCR1_DEVPARSEL(val) BSP_FLD32(val,0, 3)
601#define TMS570_SYS1_DEVCR1_DEVPARSEL_GET(reg) BSP_FLD32GET(reg,0, 3)
602#define TMS570_SYS1_DEVCR1_DEVPARSEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
603
604
605/*---------------------TMS570_SYS1_SYSECR---------------------*/
606/* field: RESET - Software reset bits. Setting RESET1 or clearing RESET0 causes a system software reset. */
607#define TMS570_SYS1_SYSECR_RESET(val) BSP_FLD32(val,14, 15)
608#define TMS570_SYS1_SYSECR_RESET_GET(reg) BSP_FLD32GET(reg,14, 15)
609#define TMS570_SYS1_SYSECR_RESET_SET(reg,val) BSP_FLD32SET(reg, val,14, 15)
610
611
612/*---------------------TMS570_SYS1_SYSESR---------------------*/
613/* field: PORST - Power-up reset. This bit is set when VCCOR (VCC Out of Range) is detected. */
614#define TMS570_SYS1_SYSESR_PORST BSP_BIT32(15)
615
616/* field: OSCRST - Reset caused by an oscillator failure or PLL cycle slip. */
617#define TMS570_SYS1_SYSESR_OSCRST BSP_BIT32(14)
618
619/* field: WDRST - Watchdog reset flag. */
620#define TMS570_SYS1_SYSESR_WDRST BSP_BIT32(13)
621
622/* field: CPURST - CPU reset flag. This bit is set when the CPU is reset. */
623#define TMS570_SYS1_SYSESR_CPURST BSP_BIT32(5)
624
625/* field: SWRST - Software reset flag. This bit is set when a software system reset has occurred. */
626#define TMS570_SYS1_SYSESR_SWRST BSP_BIT32(4)
627
628/* field: EXTRST - External reset flag. This bit is set when a reset is caused by the external reset pin nRST. */
629#define TMS570_SYS1_SYSESR_EXTRST BSP_BIT32(3)
630
631/* field: MPMODE - This indicates the current memory protection unit (MPU) mode. */
632#define TMS570_SYS1_SYSESR_MPMODE BSP_BIT32(0)
633
634
635/*--------------------TMS570_SYS1_SYSTASR--------------------*/
636/* field: EFUSE_Abort - Test Abort status flag. */
637#define TMS570_SYS1_SYSTASR_EFUSE_Abort(val) BSP_FLD32(val,0, 4)
638#define TMS570_SYS1_SYSTASR_EFUSE_Abort_GET(reg) BSP_FLD32GET(reg,0, 4)
639#define TMS570_SYS1_SYSTASR_EFUSE_Abort_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
640
641
642/*--------------------TMS570_SYS1_GLBSTAT--------------------*/
643/* field: FBSLIP - PLL over cycle slip detection. */
644#define TMS570_SYS1_GLBSTAT_FBSLIP BSP_BIT32(9)
645
646/* field: RFSLIP - PLL under cycle slip detection. */
647#define TMS570_SYS1_GLBSTAT_RFSLIP BSP_BIT32(8)
648
649/* field: OSCFAIL - Oscillator fail flag bit. */
650#define TMS570_SYS1_GLBSTAT_OSCFAIL BSP_BIT32(0)
651
652
653/*---------------------TMS570_SYS1_DEVID---------------------*/
654/* field: CP15 - CP15 CPU. This bit indicates whether the CPU has a coprocessor 15 (CP15). */
655#define TMS570_SYS1_DEVID_CP15 BSP_BIT32(31)
656
657/* field: TECH - These bits define the process technology by which the device was manufactured. */
658#define TMS570_SYS1_DEVID_TECH(val) BSP_FLD32(val,13, 16)
659#define TMS570_SYS1_DEVID_TECH_GET(reg) BSP_FLD32GET(reg,13, 16)
660#define TMS570_SYS1_DEVID_TECH_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
661
662/* field: I_O_VOLTAGE - Input/output voltage. This bit defines the I/O voltage of the device. */
663#define TMS570_SYS1_DEVID_I_O_VOLTAGE BSP_BIT32(12)
664
665/* field: PERIPHERAL_PARITY - The peripheral memories have no parity. */
666#define TMS570_SYS1_DEVID_PERIPHERAL_PARITY BSP_BIT32(11)
667
668/* field: FLASH_ECC - These bits indicate which parity is present for the program memory. */
669#define TMS570_SYS1_DEVID_FLASH_ECC(val) BSP_FLD32(val,9, 10)
670#define TMS570_SYS1_DEVID_FLASH_ECC_GET(reg) BSP_FLD32GET(reg,9, 10)
671#define TMS570_SYS1_DEVID_FLASH_ECC_SET(reg,val) BSP_FLD32SET(reg, val,9, 10)
672
673/* field: RAM_ECC - RAM ECC. This bit indicates whether or not RAM memory ECC is present. */
674#define TMS570_SYS1_DEVID_RAM_ECC BSP_BIT32(8)
675
676/* field: VERSION - Version. These bits provide the revision of the device. */
677#define TMS570_SYS1_DEVID_VERSION(val) BSP_FLD32(val,3, 7)
678#define TMS570_SYS1_DEVID_VERSION_GET(reg) BSP_FLD32GET(reg,3, 7)
679#define TMS570_SYS1_DEVID_VERSION_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
680
681/* field: PLATFORM_ID - The device is part of the TMS570Px family. The TMS570Px ID is always 5h. */
682#define TMS570_SYS1_DEVID_PLATFORM_ID(val) BSP_FLD32(val,0, 2)
683#define TMS570_SYS1_DEVID_PLATFORM_ID_GET(reg) BSP_FLD32GET(reg,0, 2)
684#define TMS570_SYS1_DEVID_PLATFORM_ID_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
685
686
687/*---------------------TMS570_SYS1_SSIVEC---------------------*/
688/* field: SSIDATA - System software interrupt data key. */
689#define TMS570_SYS1_SSIVEC_SSIDATA(val) BSP_FLD32(val,8, 15)
690#define TMS570_SYS1_SSIVEC_SSIDATA_GET(reg) BSP_FLD32GET(reg,8, 15)
691#define TMS570_SYS1_SSIVEC_SSIDATA_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
692
693/* field: SSIVECT - These bits contain the source for the system software interrupt. */
694#define TMS570_SYS1_SSIVEC_SSIVECT(val) BSP_FLD32(val,0, 7)
695#define TMS570_SYS1_SSIVEC_SSIVECT_GET(reg) BSP_FLD32GET(reg,0, 7)
696#define TMS570_SYS1_SSIVEC_SSIVECT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
697
698
699/*----------------------TMS570_SYS1_SSIF----------------------*/
700/* field: SSI_FLAG - System software interrupt flag[4-1]. */
701#define TMS570_SYS1_SSIF_SSI_FLAG(val) BSP_FLD32(val,0, 3)
702#define TMS570_SYS1_SSIF_SSI_FLAG_GET(reg) BSP_FLD32GET(reg,0, 3)
703#define TMS570_SYS1_SSIF_SSI_FLAG_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
704
705
706
707#endif /* LIBBSP_ARM_TMS570_SYS1 */
Utility macros.
Definition: reg_sys.h:44
