RTEMS
5.2-rc1
bsps
arm
tms570
include
bsp
ti_herc
reg_spi.h
1
/* The header file is generated by make_header.py from SPI.json */
2
/* Current script's version can be found at: */
3
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5
6
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7
8
* Czech Technical University in Prague
9
* Zikova 1903/4
10
* 166 36 Praha 6
11
* Czech Republic
12
13
* All rights reserved.
14
15
16
* modification, are permitted provided that the following conditions are met:
17
18
* 1. Redistributions of source code must retain the above copyright notice, this
19
* list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright notice,
21
* this list of conditions and the following disclaimer in the documentation
22
* and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34
35
* The views and conclusions contained in the software and documentation are those
36
* of the authors and should not be interpreted as representing official policies,
37
* either expressed or implied, of the FreeBSD Project.
38
39
#ifndef LIBBSP_ARM_TMS570_SPI
40
#define LIBBSP_ARM_TMS570_SPI
41
42
bsp/utility.h
43
44
typedef
struct
45
uint32_t GCR0;
/*SPI Global Control Register 0*/
46
uint32_t GCR1;
/*SPI Global Control Register 1*/
47
uint32_t INT0;
/*SPI Interrupt Register*/
48
uint32_t LVL;
/*SPI Interrupt Level Register*/
49
uint32_t FLG;
/*SPI Flag Register*/
50
uint32_t PC0;
/*SPI Pin Control Register 0*/
51
uint32_t PC1;
/*SPI Pin Control Register 1*/
52
uint32_t PC2;
/*SPI Pin Control Register 2*/
53
uint32_t PC3;
/*SPI Pin Control Register 3*/
54
uint32_t PC4;
/*SPI Pin Control Register 4*/
55
uint32_t PC5;
/*SPI Pin Control Register 5*/
56
uint32_t PC6;
/*SPI Pin Control Register 6*/
57
uint32_t PC7;
/*SPI Pin Control Register 7*/
58
uint32_t PC8;
/*SPI Pin Control Register 8*/
59
uint32_t DAT0;
/*SPI Transmit Data Register 0*/
60
uint32_t DAT1;
/*SPI Transmit Data Register 1*/
61
uint32_t BUF;
/*SPI Receive Buffer Register*/
62
uint32_t EMU;
/*SPI Emulation Register*/
63
uint32_t DELAY;
/*SPI Delay Register*/
64
uint32_t DEF;
/*SPI Default Chip Select Register*/
65
uint32_t FMT0;
/*SPI Data Format Register 0*/
66
uint32_t FMT1;
/*SPI Data Format Register 1*/
67
uint32_t FMT2;
/*SPI Data Format Register 2*/
68
uint32_t FMT3;
/*SPI Data Format Register 3*/
69
uint32_t INTVECT0;
/*Interrupt Vector 0*/
70
uint32_t INTVECT1;
/*Interrupt Vector 1*/
71
uint8_t reserved1 [4];
72
uint32_t PMCTRL;
/*Parallel/Modulo Mode Control Register*/
73
uint32_t MIBSPIE;
/*Multi-buffer Mode Enable Register*/
74
uint32_t TGITENST;
/*TG Interrupt Enable Set Register*/
75
uint32_t TGITENCR;
/*TG Interrupt Enable Clear Register*/
76
uint32_t TGITLVST;
/*Transfer Group Interrupt Level Set Register*/
77
uint32_t TGITLVCR;
/*Transfer Group Interrupt Level Clear Register*/
78
uint32_t TGINTFLG;
/*Transfer Group Interrupt Flag Register*/
79
uint8_t reserved2 [8];
80
uint32_t TICKCNT;
/*Tick Count Register*/
81
uint32_t LTGPEND;
/*Last TG End Pointer*/
82
uint32_t TGCTRL[16];
/*TG Control Registers*/
83
uint32_t DMACTRL[8];
/*DMA Channel Control Register*/
84
uint32_t DMACOUNT[8];
/*DMA COUNT Register*/
85
uint32_t DMACNTLEN;
/*DMA Large Count*/
86
uint8_t reserved3 [4];
87
uint32_t UERRCTRL;
/*Multi-buffer RAM Uncorrectable Parity Error Control Register*/
88
uint32_t UERRSTAT;
/*Multi-buffer RAM Uncorrectable Parity Error Status Register*/
89
uint32_t UERRADDRRX;
/*RXRAM Uncorrectable Parity Error Address Register*/
90
uint32_t UERRADDRTX;
/*TXRAM Uncorrectable Parity Error Address Register*/
91
uint32_t RXOVRN_BUF_ADDR;
/*RXRAM Overrun Buffer Address Register*/
92
uint32_t IOLPBKTSTCR;
/*I/O Loopback Test Control Register*/
93
uint32_t EXT_PRESCALE1;
/*SPI Extended Prescale Register 1*/
94
uint32_t EXT_PRESCALE2;
/*SPI Extended Prescale Register 2*/
95
tms570_spi_t
96
97
98
/*----------------------TMS570_SPI_GCR0----------------------*/
99
/* field: nRESET - This is the local reset control for the module. */
100
#define TMS570_SPI_GCR0_nRESET BSP_BIT32(0)
101
102
103
/*----------------------TMS570_SPI_GCR1----------------------*/
104
/* field: SPIEN - SPI enable. This bit enables SPI transfers. */
105
#define TMS570_SPI_GCR1_SPIEN BSP_BIT32(24)
106
107
/* field: LOOPBACK - Internal loop-back test mode. The internal self-test option can be enabled by setting this bit. */
108
#define TMS570_SPI_GCR1_LOOPBACK BSP_BIT32(16)
109
110
/* field: POWERDOWN - When active, the SPI state machine enters a power-down state. */
111
#define TMS570_SPI_GCR1_POWERDOWN BSP_BIT32(8)
112
113
/* field: CLKMOD - Clock mode. This bit selects either an internal or external clock source. */
114
#define TMS570_SPI_GCR1_CLKMOD BSP_BIT32(1)
115
116
/* field: MASTER - SPISIMO/SPISOMI pin direction determination. */
117
#define TMS570_SPI_GCR1_MASTER BSP_BIT32(0)
118
119
120
/*----------------------TMS570_SPI_INT0----------------------*/
121
/* field: ENABLEHIGHZ - SPIENA pin high-impedance enable. */
122
#define TMS570_SPI_INT0_ENABLEHIGHZ BSP_BIT32(24)
123
124
/* field: DMAREQEN - DMA request enable. */
125
#define TMS570_SPI_INT0_DMAREQEN BSP_BIT32(16)
126
127
128
/*-----------------------TMS570_SPI_LVL-----------------------*/
129
/* field: TXINTLVL - Transmit interrupt level. */
130
#define TMS570_SPI_LVL_TXINTLVL BSP_BIT32(9)
131
132
/* field: RXINTLVL - Receive interrupt level. */
133
#define TMS570_SPI_LVL_RXINTLVL BSP_BIT32(8)
134
135
/* field: RXOVRNINTLVL - Receive overrun interrupt level. */
136
#define TMS570_SPI_LVL_RXOVRNINTLVL BSP_BIT32(6)
137
138
/* field: BITERRLVL - Bit error interrupt level. */
139
#define TMS570_SPI_LVL_BITERRLVL BSP_BIT32(4)
140
141
/* field: DESYNCLVL - Desynchronized slave interrupt level. (master mode only). */
142
#define TMS570_SPI_LVL_DESYNCLVL BSP_BIT32(3)
143
144
/* field: PARERRLVL - Parity error interrupt level. */
145
#define TMS570_SPI_LVL_PARERRLVL BSP_BIT32(2)
146
147
/* field: TIMEOUTLVL - SPIENA pin time-out interrupt level. */
148
#define TMS570_SPI_LVL_TIMEOUTLVL BSP_BIT32(1)
149
150
/* field: DLENERRLVL - Data length error interrupt level (line) select. */
151
#define TMS570_SPI_LVL_DLENERRLVL BSP_BIT32(0)
152
153
154
/*-----------------------TMS570_SPI_FLG-----------------------*/
155
/* field: BUFINITACTIVE - Indicates the status of multi-buffer initialization process. */
156
#define TMS570_SPI_FLG_BUFINITACTIVE BSP_BIT32(24)
157
158
/* field: TXINTFLG - Transmitter-empty interrupt flag. */
159
#define TMS570_SPI_FLG_TXINTFLG BSP_BIT32(9)
160
161
/* field: RXINTFLG - Receiver-full interrupt flag. */
162
#define TMS570_SPI_FLG_RXINTFLG BSP_BIT32(8)
163
164
/* field: RXOVRNINTFLG - Receiver overrun flag. */
165
#define TMS570_SPI_FLG_RXOVRNINTFLG BSP_BIT32(6)
166
167
/* field: BITERRFLG - Mismatch of internal transmit data and transmitted data. */
168
#define TMS570_SPI_FLG_BITERRFLG BSP_BIT32(4)
169
170
/* field: DESYNCFLG - Desynchronization of slave device. */
171
#define TMS570_SPI_FLG_DESYNCFLG BSP_BIT32(3)
172
173
/* field: PARITYERRFLG - Calculated parity differs from received parity bit. */
174
#define TMS570_SPI_FLG_PARITYERRFLG BSP_BIT32(2)
175
176
/* field: TIMEOUTFLG - Time-out caused by nonactivation of ENA signal. */
177
#define TMS570_SPI_FLG_TIMEOUTFLG BSP_BIT32(1)
178
179
/* field: DLENERRFLG - Data-length error flag. */
180
#define TMS570_SPI_FLG_DLENERRFLG BSP_BIT32(0)
181
182
183
/*-----------------------TMS570_SPI_PC0-----------------------*/
184
/* field: SOMIFUN - Slave out, master in function. */
185
#define TMS570_SPI_PC0_SOMIFUN(val) BSP_FLD32(val,24, 31)
186
#define TMS570_SPI_PC0_SOMIFUN_GET(reg) BSP_FLD32GET(reg,24, 31)
187
#define TMS570_SPI_PC0_SOMIFUN_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
188
189
/* field: SIMOFUN - Slave in, master out function. */
190
#define TMS570_SPI_PC0_SIMOFUN(val) BSP_FLD32(val,16, 23)
191
#define TMS570_SPI_PC0_SIMOFUN_GET(reg) BSP_FLD32GET(reg,16, 23)
192
#define TMS570_SPI_PC0_SIMOFUN_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
193
194
/* field: SOMIFUN0 - SOMIFUN0 */
195
#define TMS570_SPI_PC0_SOMIFUN0 BSP_BIT32(11)
196
197
/* field: SIMOFUN0 - Slave in, master out function. */
198
#define TMS570_SPI_PC0_SIMOFUN0 BSP_BIT32(10)
199
200
/* field: CLKFUN - CLKFUN */
201
#define TMS570_SPI_PC0_CLKFUN BSP_BIT32(9)
202
203
/* field: ENAFUN - SPIENA function. */
204
#define TMS570_SPI_PC0_ENAFUN BSP_BIT32(8)
205
206
/* field: SCSFUN - SPISCSx function. */
207
#define TMS570_SPI_PC0_SCSFUN(val) BSP_FLD32(val,0, 7)
208
#define TMS570_SPI_PC0_SCSFUN_GET(reg) BSP_FLD32GET(reg,0, 7)
209
#define TMS570_SPI_PC0_SCSFUN_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
210
211
212
/*-----------------------TMS570_SPI_PC1-----------------------*/
213
/* field: SOMIDIR - SPISOMIx direction. Controls the direction of SPISOMIx when used for general-purpose I/O. */
214
#define TMS570_SPI_PC1_SOMIDIR(val) BSP_FLD32(val,24, 31)
215
#define TMS570_SPI_PC1_SOMIDIR_GET(reg) BSP_FLD32GET(reg,24, 31)
216
#define TMS570_SPI_PC1_SOMIDIR_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
217
218
/* field: SIMODIR - SPISIMOx direction. Controls the direction of SPISIMOx when used for general-purpose I/O. */
219
#define TMS570_SPI_PC1_SIMODIR(val) BSP_FLD32(val,16, 23)
220
#define TMS570_SPI_PC1_SIMODIR_GET(reg) BSP_FLD32GET(reg,16, 23)
221
#define TMS570_SPI_PC1_SIMODIR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
222
223
/* field: SOMIDIR0 - PISOMI0 direction. */
224
#define TMS570_SPI_PC1_SOMIDIR0 BSP_BIT32(11)
225
226
/* field: SIMODIR0 - SPISIMO0 direction. */
227
#define TMS570_SPI_PC1_SIMODIR0 BSP_BIT32(10)
228
229
/* field: CLKDIR - SPICLK direction. */
230
#define TMS570_SPI_PC1_CLKDIR BSP_BIT32(9)
231
232
/* field: ENADIR - SPIENA direction. */
233
#define TMS570_SPI_PC1_ENADIR BSP_BIT32(8)
234
235
/* field: SCSDIR - SPISCSx direction. */
236
#define TMS570_SPI_PC1_SCSDIR(val) BSP_FLD32(val,0, 7)
237
#define TMS570_SPI_PC1_SCSDIR_GET(reg) BSP_FLD32GET(reg,0, 7)
238
#define TMS570_SPI_PC1_SCSDIR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
239
240
241
/*-----------------------TMS570_SPI_PC2-----------------------*/
242
/* field: SOMIDIN - SPISOMIx data in. The value of the SPISOMIx pins. */
243
#define TMS570_SPI_PC2_SOMIDIN(val) BSP_FLD32(val,24, 31)
244
#define TMS570_SPI_PC2_SOMIDIN_GET(reg) BSP_FLD32GET(reg,24, 31)
245
#define TMS570_SPI_PC2_SOMIDIN_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
246
247
/* field: SIMODIN - SPISIMOx data in. The value of the SPISIMOx pins. */
248
#define TMS570_SPI_PC2_SIMODIN(val) BSP_FLD32(val,16, 23)
249
#define TMS570_SPI_PC2_SIMODIN_GET(reg) BSP_FLD32GET(reg,16, 23)
250
#define TMS570_SPI_PC2_SIMODIN_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
251
252
/* field: SOMIDIN0 - SPISOMI0 data in. The value of the SPISOMI0 pin. */
253
#define TMS570_SPI_PC2_SOMIDIN0 BSP_BIT32(11)
254
255
/* field: SIMODIN0 - SPISIMO0 data in. The value of the SPISIMO0 pin. */
256
#define TMS570_SPI_PC2_SIMODIN0 BSP_BIT32(10)
257
258
/* field: CLKDIN - Clock data in. The value of the SPICLK pin. pin. */
259
#define TMS570_SPI_PC2_CLKDIN BSP_BIT32(9)
260
261
/* field: ENADIN - SPIENA data in. The the value of the SPIENA pin. */
262
#define TMS570_SPI_PC2_ENADIN BSP_BIT32(8)
263
264
/* field: SCSDIN - SPISCSx data in. The value of the SPISCSx pin. */
265
#define TMS570_SPI_PC2_SCSDIN(val) BSP_FLD32(val,0, 7)
266
#define TMS570_SPI_PC2_SCSDIN_GET(reg) BSP_FLD32GET(reg,0, 7)
267
#define TMS570_SPI_PC2_SCSDIN_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
268
269
270
/*-----------------------TMS570_SPI_PC3-----------------------*/
271
/* field: SOMIDOUT - SPISOMIx data out write. */
272
#define TMS570_SPI_PC3_SOMIDOUT(val) BSP_FLD32(val,24, 31)
273
#define TMS570_SPI_PC3_SOMIDOUT_GET(reg) BSP_FLD32GET(reg,24, 31)
274
#define TMS570_SPI_PC3_SOMIDOUT_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
275
276
/* field: SIMODOUT - SPISIMOx data out write. */
277
#define TMS570_SPI_PC3_SIMODOUT(val) BSP_FLD32(val,16, 23)
278
#define TMS570_SPI_PC3_SIMODOUT_GET(reg) BSP_FLD32GET(reg,16, 23)
279
#define TMS570_SPI_PC3_SIMODOUT_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
280
281
/* field: SOMIDOUT0 - SPISOMI0 data out write. */
282
#define TMS570_SPI_PC3_SOMIDOUT0 BSP_BIT32(11)
283
284
/* field: SIMODOUT0 - SPISIMO0 data out write. */
285
#define TMS570_SPI_PC3_SIMODOUT0 BSP_BIT32(10)
286
287
/* field: CLKDOUT - SPICLK data out write. */
288
#define TMS570_SPI_PC3_CLKDOUT BSP_BIT32(9)
289
290
/* field: ENADOUT - SPIENA data out write. */
291
#define TMS570_SPI_PC3_ENADOUT BSP_BIT32(8)
292
293
/* field: SCSDOUT - SPISCSx data out write. */
294
#define TMS570_SPI_PC3_SCSDOUT(val) BSP_FLD32(val,0, 7)
295
#define TMS570_SPI_PC3_SCSDOUT_GET(reg) BSP_FLD32GET(reg,0, 7)
296
#define TMS570_SPI_PC3_SCSDOUT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
297
298
299
/*-----------------------TMS570_SPI_PC4-----------------------*/
300
/* field: SOMISET - SPISOMIx data out set. */
301
#define TMS570_SPI_PC4_SOMISET(val) BSP_FLD32(val,24, 31)
302
#define TMS570_SPI_PC4_SOMISET_GET(reg) BSP_FLD32GET(reg,24, 31)
303
#define TMS570_SPI_PC4_SOMISET_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
304
305
/* field: SIMOSET - SPISIMOx data out set. */
306
#define TMS570_SPI_PC4_SIMOSET(val) BSP_FLD32(val,16, 23)
307
#define TMS570_SPI_PC4_SIMOSET_GET(reg) BSP_FLD32GET(reg,16, 23)
308
#define TMS570_SPI_PC4_SIMOSET_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
309
310
/* field: SOMISET0 - SPISOMI0 data out set. */
311
#define TMS570_SPI_PC4_SOMISET0 BSP_BIT32(11)
312
313
/* field: SIMOSET0 - purpose */
314
#define TMS570_SPI_PC4_SIMOSET0 BSP_BIT32(10)
315
316
/* field: CLKSET - SPICLK data out set. */
317
#define TMS570_SPI_PC4_CLKSET BSP_BIT32(9)
318
319
/* field: ENASET - SPIENA data out set. */
320
#define TMS570_SPI_PC4_ENASET BSP_BIT32(8)
321
322
/* field: SCSSET - SPISCSx data out set. */
323
#define TMS570_SPI_PC4_SCSSET(val) BSP_FLD32(val,0, 7)
324
#define TMS570_SPI_PC4_SCSSET_GET(reg) BSP_FLD32GET(reg,0, 7)
325
#define TMS570_SPI_PC4_SCSSET_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
326
327
328
/*-----------------------TMS570_SPI_PC5-----------------------*/
329
/* field: SOMICLR - SPISOMIx data out clear. */
330
#define TMS570_SPI_PC5_SOMICLR(val) BSP_FLD32(val,24, 31)
331
#define TMS570_SPI_PC5_SOMICLR_GET(reg) BSP_FLD32GET(reg,24, 31)
332
#define TMS570_SPI_PC5_SOMICLR_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
333
334
/* field: SIMOCLR - SPISIMOx data out clear. */
335
#define TMS570_SPI_PC5_SIMOCLR(val) BSP_FLD32(val,16, 23)
336
#define TMS570_SPI_PC5_SIMOCLR_GET(reg) BSP_FLD32GET(reg,16, 23)
337
#define TMS570_SPI_PC5_SIMOCLR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
338
339
/* field: SOMICLR0 - SPISOMI0 data out cleart. */
340
#define TMS570_SPI_PC5_SOMICLR0 BSP_BIT32(11)
341
342
/* field: SIMOCLR0 - SPISIMO0 data out clear. */
343
#define TMS570_SPI_PC5_SIMOCLR0 BSP_BIT32(10)
344
345
/* field: CLKCLR - SPICLK data out clear. */
346
#define TMS570_SPI_PC5_CLKCLR BSP_BIT32(9)
347
348
/* field: ENACLR - SPIENA data out clear. */
349
#define TMS570_SPI_PC5_ENACLR BSP_BIT32(8)
350
351
/* field: SCSCLR - SPISCSx data out clear. */
352
#define TMS570_SPI_PC5_SCSCLR(val) BSP_FLD32(val,0, 7)
353
#define TMS570_SPI_PC5_SCSCLR_GET(reg) BSP_FLD32GET(reg,0, 7)
354
#define TMS570_SPI_PC5_SCSCLR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
355
356
357
/*-----------------------TMS570_SPI_PC6-----------------------*/
358
/* field: SOMIPDR - SPISOMIx open drain enable. */
359
#define TMS570_SPI_PC6_SOMIPDR(val) BSP_FLD32(val,24, 31)
360
#define TMS570_SPI_PC6_SOMIPDR_GET(reg) BSP_FLD32GET(reg,24, 31)
361
#define TMS570_SPI_PC6_SOMIPDR_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
362
363
/* field: SIMOPDR - SPISIMOx open drain enable. */
364
#define TMS570_SPI_PC6_SIMOPDR(val) BSP_FLD32(val,16, 23)
365
#define TMS570_SPI_PC6_SIMOPDR_GET(reg) BSP_FLD32GET(reg,16, 23)
366
#define TMS570_SPI_PC6_SIMOPDR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
367
368
/* field: SOMIPDR0 - SOMI0 open-drain enable. */
369
#define TMS570_SPI_PC6_SOMIPDR0 BSP_BIT32(11)
370
371
/* field: SIMOPDR0 - SPISIMO0 open-drain enable. */
372
#define TMS570_SPI_PC6_SIMOPDR0 BSP_BIT32(10)
373
374
/* field: CLKPDR - CLK open drain enable. */
375
#define TMS570_SPI_PC6_CLKPDR BSP_BIT32(9)
376
377
/* field: ENAPDR - SPIENA pin open drain enable. */
378
#define TMS570_SPI_PC6_ENAPDR BSP_BIT32(8)
379
380
/* field: SCSPDR - SPISCSx open drain enable. */
381
#define TMS570_SPI_PC6_SCSPDR(val) BSP_FLD32(val,0, 7)
382
#define TMS570_SPI_PC6_SCSPDR_GET(reg) BSP_FLD32GET(reg,0, 7)
383
#define TMS570_SPI_PC6_SCSPDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
384
385
386
/*-----------------------TMS570_SPI_PC7-----------------------*/
387
/* field: SOMIDIS - SOMIx pull control enable/disable. */
388
#define TMS570_SPI_PC7_SOMIDIS(val) BSP_FLD32(val,24, 31)
389
#define TMS570_SPI_PC7_SOMIDIS_GET(reg) BSP_FLD32GET(reg,24, 31)
390
#define TMS570_SPI_PC7_SOMIDIS_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
391
392
/* field: SIMODIS - SIMOx pull control enable/disable. */
393
#define TMS570_SPI_PC7_SIMODIS(val) BSP_FLD32(val,16, 23)
394
#define TMS570_SPI_PC7_SIMODIS_GET(reg) BSP_FLD32GET(reg,16, 23)
395
#define TMS570_SPI_PC7_SIMODIS_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
396
397
/* field: SOMIPDIS0 - SPISOMI0 pull control enable/disable. */
398
#define TMS570_SPI_PC7_SOMIPDIS0 BSP_BIT32(11)
399
400
/* field: SIMOPDIS0 - SPISIMO0 pull control enable/disable. */
401
#define TMS570_SPI_PC7_SIMOPDIS0 BSP_BIT32(10)
402
403
/* field: CLKPDIS - CLK pull control enable/disable. */
404
#define TMS570_SPI_PC7_CLKPDIS BSP_BIT32(9)
405
406
/* field: ENAPDIS - ENAPDIS ENABLE pull control enable/disable. */
407
#define TMS570_SPI_PC7_ENAPDIS BSP_BIT32(8)
408
409
/* field: SCSPDIS - SCSx pull control enable/disable. */
410
#define TMS570_SPI_PC7_SCSPDIS(val) BSP_FLD32(val,0, 7)
411
#define TMS570_SPI_PC7_SCSPDIS_GET(reg) BSP_FLD32GET(reg,0, 7)
412
#define TMS570_SPI_PC7_SCSPDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
413
414
415
/*-----------------------TMS570_SPI_PC8-----------------------*/
416
/* field: SOMIPSEL - SPISOMIx pull select. This bit selects the type of pull logic at the SOMIx pin. */
417
#define TMS570_SPI_PC8_SOMIPSEL(val) BSP_FLD32(val,24, 31)
418
#define TMS570_SPI_PC8_SOMIPSEL_GET(reg) BSP_FLD32GET(reg,24, 31)
419
#define TMS570_SPI_PC8_SOMIPSEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
420
421
/* field: SIMOPSEL - SIMOPSEL SPISIMOx pull select. This bit selects the type of pull logic at the SPISIMOx pin. */
422
#define TMS570_SPI_PC8_SIMOPSEL(val) BSP_FLD32(val,16, 23)
423
#define TMS570_SPI_PC8_SIMOPSEL_GET(reg) BSP_FLD32GET(reg,16, 23)
424
#define TMS570_SPI_PC8_SIMOPSEL_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
425
426
/* field: SOMIPSEL0 - SOMI pull select. This bit selects the type of pull logic at the SOMI pin. */
427
#define TMS570_SPI_PC8_SOMIPSEL0 BSP_BIT32(11)
428
429
/* field: SIMOPSEL0 - SPISIMO pull select. This bit selects the type of pull logic at the SPISIMO pin. */
430
#define TMS570_SPI_PC8_SIMOPSEL0 BSP_BIT32(10)
431
432
/* field: CLKPSEL - CLK pull select. This bit selects the type of pull logic at the CLK pin. */
433
#define TMS570_SPI_PC8_CLKPSEL BSP_BIT32(9)
434
435
/* field: ENAPSEL - ENABLE pull select. This bit selects the type of pull logic at the ENABLE pin. */
436
#define TMS570_SPI_PC8_ENAPSEL BSP_BIT32(8)
437
438
/* field: SCSPSEL - SCSx pull select. This bit selects the type of pull logic at the SCSx pin. */
439
#define TMS570_SPI_PC8_SCSPSEL(val) BSP_FLD32(val,0, 7)
440
#define TMS570_SPI_PC8_SCSPSEL_GET(reg) BSP_FLD32GET(reg,0, 7)
441
#define TMS570_SPI_PC8_SCSPSEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
442
443
444
/*----------------------TMS570_SPI_DAT0----------------------*/
445
/* field: TXDATA - SPI transmit data. When written, these bits will be copied to the shift register if it is empty. */
446
#define TMS570_SPI_DAT0_TXDATA(val) BSP_FLD32(val,0, 15)
447
#define TMS570_SPI_DAT0_TXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
448
#define TMS570_SPI_DAT0_TXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
449
450
451
/*----------------------TMS570_SPI_DAT1----------------------*/
452
/* field: CSHOLD - Chip select hold mode. */
453
#define TMS570_SPI_DAT1_CSHOLD BSP_BIT32(28)
454
455
/* field: WDEL - Enable the delay counter at the end of the current transaction. */
456
#define TMS570_SPI_DAT1_WDEL BSP_BIT32(26)
457
458
/* field: DFSEL - Data word format select */
459
#define TMS570_SPI_DAT1_DFSEL(val) BSP_FLD32(val,24, 25)
460
#define TMS570_SPI_DAT1_DFSEL_GET(reg) BSP_FLD32GET(reg,24, 25)
461
#define TMS570_SPI_DAT1_DFSEL_SET(reg,val) BSP_FLD32SET(reg, val,24, 25)
462
463
/* field: CSNR - Chip select number. CSNR defines the chip-select that will be activated during the data transfer. */
464
#define TMS570_SPI_DAT1_CSNR(val) BSP_FLD32(val,16, 23)
465
#define TMS570_SPI_DAT1_CSNR_GET(reg) BSP_FLD32GET(reg,16, 23)
466
#define TMS570_SPI_DAT1_CSNR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
467
468
/* field: TXDATA - ransfer data.When written, these bits are copied to the shift register if it is empty. */
469
#define TMS570_SPI_DAT1_TXDATA(val) BSP_FLD32(val,0, 15)
470
#define TMS570_SPI_DAT1_TXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
471
#define TMS570_SPI_DAT1_TXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
472
473
474
/*-----------------------TMS570_SPI_BUF-----------------------*/
475
/* field: RXEMPTY - Receive data buffer empty. */
476
#define TMS570_SPI_BUF_RXEMPTY BSP_BIT32(31)
477
478
/* field: RXOVR - Receive data buffer overrun. */
479
#define TMS570_SPI_BUF_RXOVR BSP_BIT32(30)
480
481
/* field: TXFULL - Transmit data buffer full.This flag is a read-only flag. */
482
#define TMS570_SPI_BUF_TXFULL BSP_BIT32(29)
483
484
/* field: BITERR - Bit error.There was a mismatch of internal transmit data and transmitted data. */
485
#define TMS570_SPI_BUF_BITERR BSP_BIT32(28)
486
487
/* field: DESYNC - Desynchronization of slave device.This bit is valid in master mode only. */
488
#define TMS570_SPI_BUF_DESYNC BSP_BIT32(27)
489
490
/* field: PARITYERR - Parity error.The calculated parity differs from the received parity bit. */
491
#define TMS570_SPI_BUF_PARITYERR BSP_BIT32(26)
492
493
/* field: TIMEOUT - Time-out because of non-activation of ENA pin. */
494
#define TMS570_SPI_BUF_TIMEOUT BSP_BIT32(25)
495
496
/* field: DLENERR - Data length error flag. */
497
#define TMS570_SPI_BUF_DLENERR BSP_BIT32(24)
498
499
/* field: LCSNR - control field. It contains the chip select number that was activated during the last word transfer. */
500
#define TMS570_SPI_BUF_LCSNR(val) BSP_FLD32(val,16, 23)
501
#define TMS570_SPI_BUF_LCSNR_GET(reg) BSP_FLD32GET(reg,16, 23)
502
#define TMS570_SPI_BUF_LCSNR_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
503
504
/* field: RXDATA - SPI receive data. */
505
#define TMS570_SPI_BUF_RXDATA(val) BSP_FLD32(val,0, 15)
506
#define TMS570_SPI_BUF_RXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
507
#define TMS570_SPI_BUF_RXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
508
509
510
/*-----------------------TMS570_SPI_EMU-----------------------*/
511
/* field: EMU_RXDATA - SPI receive data. The SPI emulation register is a mirror of the SPIBUF register. */
512
#define TMS570_SPI_EMU_EMU_RXDATA(val) BSP_FLD32(val,0, 15)
513
#define TMS570_SPI_EMU_EMU_RXDATA_GET(reg) BSP_FLD32GET(reg,0, 15)
514
#define TMS570_SPI_EMU_EMU_RXDATA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
515
516
517
/*----------------------TMS570_SPI_DELAY----------------------*/
518
/* field: C2TDELAY - Chip-select-active to transmit-start delay. See Figure 25-45 for an example. */
519
#define TMS570_SPI_DELAY_C2TDELAY(val) BSP_FLD32(val,24, 31)
520
#define TMS570_SPI_DELAY_C2TDELAY_GET(reg) BSP_FLD32GET(reg,24, 31)
521
#define TMS570_SPI_DELAY_C2TDELAY_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
522
523
/* field: T2CDELAY - T2CDELAY */
524
#define TMS570_SPI_DELAY_T2CDELAY(val) BSP_FLD32(val,16, 23)
525
#define TMS570_SPI_DELAY_T2CDELAY_GET(reg) BSP_FLD32GET(reg,16, 23)
526
#define TMS570_SPI_DELAY_T2CDELAY_SET(reg,val) BSP_FLD32SET(reg, val,16, 23)
527
528
/* field: T2EDELAY - Transmit-data-finished to ENA-pin-inactive time-out. T2EDELAY is used in master mode only. */
529
#define TMS570_SPI_DELAY_T2EDELAY(val) BSP_FLD32(val,8, 15)
530
#define TMS570_SPI_DELAY_T2EDELAY_GET(reg) BSP_FLD32GET(reg,8, 15)
531
#define TMS570_SPI_DELAY_T2EDELAY_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
532
533
/* field: C2EDELAY - Chip-select-active to ENA-signal-active time-out. */
534
#define TMS570_SPI_DELAY_C2EDELAY(val) BSP_FLD32(val,0, 7)
535
#define TMS570_SPI_DELAY_C2EDELAY_GET(reg) BSP_FLD32GET(reg,0, 7)
536
#define TMS570_SPI_DELAY_C2EDELAY_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
537
538
539
/*-----------------------TMS570_SPI_DEF-----------------------*/
540
/* field: CDEF - Chip select default pattern. Master-mode only. */
541
#define TMS570_SPI_DEF_CDEF(val) BSP_FLD32(val,0, 7)
542
#define TMS570_SPI_DEF_CDEF_GET(reg) BSP_FLD32GET(reg,0, 7)
543
#define TMS570_SPI_DEF_CDEF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
544
545
546
/*----------------------TMS570_SPI_FMTx----------------------*/
547
/* field: WDELAY - Delay in between transmissions for data format x (x= 0,1,2,3). */
548
#define TMS570_SPI_FMTx_WDELAY(val) BSP_FLD32(val,24, 31)
549
#define TMS570_SPI_FMTx_WDELAY_GET(reg) BSP_FLD32GET(reg,24, 31)
550
#define TMS570_SPI_FMTx_WDELAY_SET(reg,val) BSP_FLD32SET(reg, val,24, 31)
551
552
/* field: PARPOL - Parity polarity: even or odd. PARPOLx can be modified in privilege mode only. */
553
#define TMS570_SPI_FMTx_PARPOL BSP_BIT32(23)
554
555
/* field: PARITYENA - Parity enable for data format x. */
556
#define TMS570_SPI_FMTx_PARITYENA BSP_BIT32(22)
557
558
/* field: WAITENA - The master waits for the ENA signal from slave for data format x. */
559
#define TMS570_SPI_FMTx_WAITENA BSP_BIT32(21)
560
561
/* field: SHIFTDIR - Shift direction for data format x. */
562
#define TMS570_SPI_FMTx_SHIFTDIR BSP_BIT32(20)
563
564
/* field: HDUPLEX_ENAx - Half Duplex transfer mode enable for Data Format x. */
565
#define TMS570_SPI_FMTx_HDUPLEX_ENAx BSP_BIT32(19)
566
567
/* field: DIS_CS_TIMERS - Disable chip-select timers for this format. */
568
#define TMS570_SPI_FMTx_DIS_CS_TIMERS BSP_BIT32(18)
569
570
/* field: POLARITY - POLARITY */
571
#define TMS570_SPI_FMTx_POLARITY BSP_BIT32(17)
572
573
/* field: PHASE - SPI data format x clock delay. PHASEx defines the clock delay of data format x. */
574
#define TMS570_SPI_FMTx_PHASE BSP_BIT32(16)
575
576
/* field: PRESCALE - SPI data format x prescaler. */
577
#define TMS570_SPI_FMTx_PRESCALE(val) BSP_FLD32(val,8, 15)
578
#define TMS570_SPI_FMTx_PRESCALE_GET(reg) BSP_FLD32GET(reg,8, 15)
579
#define TMS570_SPI_FMTx_PRESCALE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
580
581
/* field: CHARLEN - SPI data format x data-word length. CHARLENx defines the word length of data format x. */
582
#define TMS570_SPI_FMTx_CHARLEN(val) BSP_FLD32(val,0, 4)
583
#define TMS570_SPI_FMTx_CHARLEN_GET(reg) BSP_FLD32GET(reg,0, 4)
584
#define TMS570_SPI_FMTx_CHARLEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
585
586
587
/*--------------------TMS570_SPI_INTVECT0--------------------*/
588
/* field: INTVECT0 - INTVECT0. Interrupt vector for interrupt line INT0. */
589
#define TMS570_SPI_INTVECT0_INTVECT0(val) BSP_FLD32(val,1, 5)
590
#define TMS570_SPI_INTVECT0_INTVECT0_GET(reg) BSP_FLD32GET(reg,1, 5)
591
#define TMS570_SPI_INTVECT0_INTVECT0_SET(reg,val) BSP_FLD32SET(reg, val,1, 5)
592
593
/* field: SUSPEND0 - Transfer suspended / Transfer finished interrupt flag. */
594
#define TMS570_SPI_INTVECT0_SUSPEND0 BSP_BIT32(0)
595
596
597
/*--------------------TMS570_SPI_INTVECT1--------------------*/
598
/* field: INTVECT1 - INTVECT1. Interrupt vector for interrupt line INT1. */
599
#define TMS570_SPI_INTVECT1_INTVECT1(val) BSP_FLD32(val,1, 5)
600
#define TMS570_SPI_INTVECT1_INTVECT1_GET(reg) BSP_FLD32GET(reg,1, 5)
601
#define TMS570_SPI_INTVECT1_INTVECT1_SET(reg,val) BSP_FLD32SET(reg, val,1, 5)
602
603
/* field: SUSPEND1 - Transfer suspended / Transfer finished interrupt flag. */
604
#define TMS570_SPI_INTVECT1_SUSPEND1 BSP_BIT32(0)
605
606
607
/*---------------------TMS570_SPI_PMCTRL---------------------*/
608
/* field: MOD_CLK_POL_3 - Modulo mode SPICLK polarity. */
609
#define TMS570_SPI_PMCTRL_MOD_CLK_POL_3 BSP_BIT32(29)
610
611
/* field: MMODE_3 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
612
#define TMS570_SPI_PMCTRL_MMODE_3(val) BSP_FLD32(val,26, 28)
613
#define TMS570_SPI_PMCTRL_MMODE_3_GET(reg) BSP_FLD32GET(reg,26, 28)
614
#define TMS570_SPI_PMCTRL_MMODE_3_SET(reg,val) BSP_FLD32SET(reg, val,26, 28)
615
616
/* field: PMODE_3 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
617
#define TMS570_SPI_PMCTRL_PMODE_3(val) BSP_FLD32(val,24, 25)
618
#define TMS570_SPI_PMCTRL_PMODE_3_GET(reg) BSP_FLD32GET(reg,24, 25)
619
#define TMS570_SPI_PMCTRL_PMODE_3_SET(reg,val) BSP_FLD32SET(reg, val,24, 25)
620
621
/* field: MOD_CLK_POL_2 - Modulo mode SPICLK polarity. */
622
#define TMS570_SPI_PMCTRL_MOD_CLK_POL_2 BSP_BIT32(21)
623
624
/* field: MMODE_2 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
625
#define TMS570_SPI_PMCTRL_MMODE_2(val) BSP_FLD32(val,18, 20)
626
#define TMS570_SPI_PMCTRL_MMODE_2_GET(reg) BSP_FLD32GET(reg,18, 20)
627
#define TMS570_SPI_PMCTRL_MMODE_2_SET(reg,val) BSP_FLD32SET(reg, val,18, 20)
628
629
/* field: PMODE_2 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
630
#define TMS570_SPI_PMCTRL_PMODE_2(val) BSP_FLD32(val,16, 17)
631
#define TMS570_SPI_PMCTRL_PMODE_2_GET(reg) BSP_FLD32GET(reg,16, 17)
632
#define TMS570_SPI_PMCTRL_PMODE_2_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
633
634
/* field: MOD_CLK_POL_1 - Modulo mode SPICLK polarity. */
635
#define TMS570_SPI_PMCTRL_MOD_CLK_POL_1 BSP_BIT32(13)
636
637
/* field: MMODE_1 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
638
#define TMS570_SPI_PMCTRL_MMODE_1(val) BSP_FLD32(val,10, 12)
639
#define TMS570_SPI_PMCTRL_MMODE_1_GET(reg) BSP_FLD32GET(reg,10, 12)
640
#define TMS570_SPI_PMCTRL_MMODE_1_SET(reg,val) BSP_FLD32SET(reg, val,10, 12)
641
642
/* field: PMODE_1 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
643
#define TMS570_SPI_PMCTRL_PMODE_1(val) BSP_FLD32(val,8, 9)
644
#define TMS570_SPI_PMCTRL_PMODE_1_GET(reg) BSP_FLD32GET(reg,8, 9)
645
#define TMS570_SPI_PMCTRL_PMODE_1_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
646
647
/* field: MOD_CLK_POL_0 - Modulo mode SPICLK polarity. */
648
#define TMS570_SPI_PMCTRL_MOD_CLK_POL_0 BSP_BIT32(5)
649
650
/* field: MMODE_0 - These bits determine whether the SPI/MibSPI operates with 1, 2, 4, 5, or 6 data lines (if */
651
#define TMS570_SPI_PMCTRL_MMODE_0(val) BSP_FLD32(val,2, 4)
652
#define TMS570_SPI_PMCTRL_MMODE_0_GET(reg) BSP_FLD32GET(reg,2, 4)
653
#define TMS570_SPI_PMCTRL_MMODE_0_SET(reg,val) BSP_FLD32SET(reg, val,2, 4)
654
655
/* field: PMODE_0 - Parallel mode bits determine whether the SPI/MibSPI operates with 1, 2, 4 or 8 data lines. */
656
#define TMS570_SPI_PMCTRL_PMODE_0(val) BSP_FLD32(val,0, 1)
657
#define TMS570_SPI_PMCTRL_PMODE_0_GET(reg) BSP_FLD32GET(reg,0, 1)
658
#define TMS570_SPI_PMCTRL_PMODE_0_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
659
660
661
/*---------------------TMS570_SPI_MIBSPIE---------------------*/
662
/* field: RXRAM_ACCESS - Receive-RAM access control. */
663
#define TMS570_SPI_MIBSPIE_RXRAM_ACCESS BSP_BIT32(16)
664
665
/* field: MSPIENA - Multi-buffer mode enable. */
666
#define TMS570_SPI_MIBSPIE_MSPIENA BSP_BIT32(0)
667
668
669
/*--------------------TMS570_SPI_TGITENST--------------------*/
670
/* field: SET_INTENRDY - TG interrupt set (enable) when transfer finished. */
671
#define TMS570_SPI_TGITENST_SET_INTENRDY(val) BSP_FLD32(val,16, 31)
672
#define TMS570_SPI_TGITENST_SET_INTENRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
673
#define TMS570_SPI_TGITENST_SET_INTENRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
674
675
/* field: SET_INTENSUS - TG interrupt set (enabled) when transfer suspended */
676
#define TMS570_SPI_TGITENST_SET_INTENSUS(val) BSP_FLD32(val,0, 15)
677
#define TMS570_SPI_TGITENST_SET_INTENSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
678
#define TMS570_SPI_TGITENST_SET_INTENSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
679
680
681
/*--------------------TMS570_SPI_TGITENCR--------------------*/
682
/* field: CLR_INTENRDY - TG interrupt clear (disabled) when transfer finished. */
683
#define TMS570_SPI_TGITENCR_CLR_INTENRDY(val) BSP_FLD32(val,16, 31)
684
#define TMS570_SPI_TGITENCR_CLR_INTENRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
685
#define TMS570_SPI_TGITENCR_CLR_INTENRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
686
687
/* field: CLR_INTENSUS - CLR INTENSUS */
688
#define TMS570_SPI_TGITENCR_CLR_INTENSUS(val) BSP_FLD32(val,0, 15)
689
#define TMS570_SPI_TGITENCR_CLR_INTENSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
690
#define TMS570_SPI_TGITENCR_CLR_INTENSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
691
692
693
/*--------------------TMS570_SPI_TGITLVST--------------------*/
694
/* field: SET_INTLVLRDY - Transfer-group completed interrupt level set. */
695
#define TMS570_SPI_TGITLVST_SET_INTLVLRDY(val) BSP_FLD32(val,16, 31)
696
#define TMS570_SPI_TGITLVST_SET_INTLVLRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
697
#define TMS570_SPI_TGITLVST_SET_INTLVLRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
698
699
/* field: SET_INTLVLSUS - Transfer-group suspended interrupt level set. */
700
#define TMS570_SPI_TGITLVST_SET_INTLVLSUS(val) BSP_FLD32(val,0, 15)
701
#define TMS570_SPI_TGITLVST_SET_INTLVLSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
702
#define TMS570_SPI_TGITLVST_SET_INTLVLSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
703
704
705
/*--------------------TMS570_SPI_TGITLVCR--------------------*/
706
/* field: CLR_INTLVLRDY - Transfer-group completed interrupt level clear. */
707
#define TMS570_SPI_TGITLVCR_CLR_INTLVLRDY(val) BSP_FLD32(val,16, 31)
708
#define TMS570_SPI_TGITLVCR_CLR_INTLVLRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
709
#define TMS570_SPI_TGITLVCR_CLR_INTLVLRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
710
711
/* field: CLR_INTLVLSUS - Transfer group suspended interrupt level clear. */
712
#define TMS570_SPI_TGITLVCR_CLR_INTLVLSUS(val) BSP_FLD32(val,0, 15)
713
#define TMS570_SPI_TGITLVCR_CLR_INTLVLSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
714
#define TMS570_SPI_TGITLVCR_CLR_INTLVLSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
715
716
717
/*--------------------TMS570_SPI_TGINTFLG--------------------*/
718
/* field: INTFLGRDY - Transfer-group interrupt flag for a transfer-completed interrupt. */
719
#define TMS570_SPI_TGINTFLG_INTFLGRDY(val) BSP_FLD32(val,16, 31)
720
#define TMS570_SPI_TGINTFLG_INTFLGRDY_GET(reg) BSP_FLD32GET(reg,16, 31)
721
#define TMS570_SPI_TGINTFLG_INTFLGRDY_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
722
723
/* field: INTFLGSUS - ransfer-group interrupt flag for a transfer-suspend interrupt. */
724
#define TMS570_SPI_TGINTFLG_INTFLGSUS(val) BSP_FLD32(val,0, 15)
725
#define TMS570_SPI_TGINTFLG_INTFLGSUS_GET(reg) BSP_FLD32GET(reg,0, 15)
726
#define TMS570_SPI_TGINTFLG_INTFLGSUS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
727
728
729
/*---------------------TMS570_SPI_TICKCNT---------------------*/
730
/* field: TICKENA - Tick counter enable. */
731
#define TMS570_SPI_TICKCNT_TICKENA BSP_BIT32(31)
732
733
/* field: RELOAD - Pre-load the tick counter. */
734
#define TMS570_SPI_TICKCNT_RELOAD BSP_BIT32(30)
735
736
/* field: CLKCTRL - Tick counter clock source control. */
737
#define TMS570_SPI_TICKCNT_CLKCTRL(val) BSP_FLD32(val,28, 29)
738
#define TMS570_SPI_TICKCNT_CLKCTRL_GET(reg) BSP_FLD32GET(reg,28, 29)
739
#define TMS570_SPI_TICKCNT_CLKCTRL_SET(reg,val) BSP_FLD32SET(reg, val,28, 29)
740
741
/* field: TICKVALUE - counter is loaded with the contents of TICKVALUE every time an underflow condition occurs and */
742
#define TMS570_SPI_TICKCNT_TICKVALUE(val) BSP_FLD32(val,0, 15)
743
#define TMS570_SPI_TICKCNT_TICKVALUE_GET(reg) BSP_FLD32GET(reg,0, 15)
744
#define TMS570_SPI_TICKCNT_TICKVALUE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
745
746
747
/*---------------------TMS570_SPI_LTGPEND---------------------*/
748
/* field: TG_IN_SERVICE - The TG number currently being serviced by the sequencer. */
749
#define TMS570_SPI_LTGPEND_TG_IN_SERVICE(val) BSP_FLD32(val,24, 28)
750
#define TMS570_SPI_LTGPEND_TG_IN_SERVICE_GET(reg) BSP_FLD32GET(reg,24, 28)
751
#define TMS570_SPI_LTGPEND_TG_IN_SERVICE_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
752
753
/* field: LPEND - Last TG end pointer. */
754
#define TMS570_SPI_LTGPEND_LPEND(val) BSP_FLD32(val,8, 14)
755
#define TMS570_SPI_LTGPEND_LPEND_GET(reg) BSP_FLD32GET(reg,8, 14)
756
#define TMS570_SPI_LTGPEND_LPEND_SET(reg,val) BSP_FLD32SET(reg, val,8, 14)
757
758
759
/*---------------------TMS570_SPI_TGCTRL---------------------*/
760
/* field: TGENA - TGx enable. */
761
#define TMS570_SPI_TGCTRL_TGENA BSP_BIT32(31)
762
763
/* field: ONESHOTx - Single transfer for TGx. */
764
#define TMS570_SPI_TGCTRL_ONESHOTx BSP_BIT32(30)
765
766
/* field: PRSTx - TGx pointer reset mode. Configures the way to resolve trigger events during an ongoing transfer. */
767
#define TMS570_SPI_TGCTRL_PRSTx BSP_BIT32(29)
768
769
/* field: TGTDx - TG triggered. */
770
#define TMS570_SPI_TGCTRL_TGTDx BSP_BIT32(28)
771
772
773
/*---------------------TMS570_SPI_DMACTRL---------------------*/
774
/* field: ONESHOT - Auto-disable of DMA channel after ICOUNT+1 transfers. */
775
#define TMS570_SPI_DMACTRL_ONESHOT BSP_BIT32(31)
776
777
/* field: BUFIDx - Buffer utilized for DMA transfer. */
778
#define TMS570_SPI_DMACTRL_BUFIDx(val) BSP_FLD32(val,24, 30)
779
#define TMS570_SPI_DMACTRL_BUFIDx_GET(reg) BSP_FLD32GET(reg,24, 30)
780
#define TMS570_SPI_DMACTRL_BUFIDx_SET(reg,val) BSP_FLD32SET(reg, val,24, 30)
781
782
/* field: RXDMA_MAPx - Each MibSPI DMA channel can be linked to two physical DMA Request lines of the DMA */
783
#define TMS570_SPI_DMACTRL_RXDMA_MAPx(val) BSP_FLD32(val,20, 23)
784
#define TMS570_SPI_DMACTRL_RXDMA_MAPx_GET(reg) BSP_FLD32GET(reg,20, 23)
785
#define TMS570_SPI_DMACTRL_RXDMA_MAPx_SET(reg,val) BSP_FLD32SET(reg, val,20, 23)
786
787
/* field: TXDMA_MAPx - Each MibSPI DMA channel can be linked to two physical DMA Request lines of the DMA */
788
#define TMS570_SPI_DMACTRL_TXDMA_MAPx(val) BSP_FLD32(val,16, 19)
789
#define TMS570_SPI_DMACTRL_TXDMA_MAPx_GET(reg) BSP_FLD32GET(reg,16, 19)
790
#define TMS570_SPI_DMACTRL_TXDMA_MAPx_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
791
792
/* field: RXDMAENAx - Receive data DMA channel enable. */
793
#define TMS570_SPI_DMACTRL_RXDMAENAx BSP_BIT32(15)
794
795
/* field: TXDAMENAx - Transmit data DMA channel enable. */
796
#define TMS570_SPI_DMACTRL_TXDAMENAx BSP_BIT32(14)
797
798
/* field: NOBRKx - Non-interleaved DMA block transfer. This bit is available in master mode only. */
799
#define TMS570_SPI_DMACTRL_NOBRKx BSP_BIT32(13)
800
801
/* field: ICOUNTx - Initial count of DMA transfers. */
802
#define TMS570_SPI_DMACTRL_ICOUNTx(val) BSP_FLD32(val,8, 12)
803
#define TMS570_SPI_DMACTRL_ICOUNTx_GET(reg) BSP_FLD32GET(reg,8, 12)
804
#define TMS570_SPI_DMACTRL_ICOUNTx_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
805
806
/* field: COUNT_BIT17x - The 17th bit of the COUNT field of DMAxCOUNT register. */
807
#define TMS570_SPI_DMACTRL_COUNT_BIT17x BSP_BIT32(6)
808
809
/* field: COUNTx - Actual number of remaining DMA transfers. */
810
#define TMS570_SPI_DMACTRL_COUNTx(val) BSP_FLD32(val,0, 5)
811
#define TMS570_SPI_DMACTRL_COUNTx_GET(reg) BSP_FLD32GET(reg,0, 5)
812
#define TMS570_SPI_DMACTRL_COUNTx_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
813
814
815
/*--------------------TMS570_SPI_DMACOUNT--------------------*/
816
/* field: ICOUNTx - Every time COUNTx hits zero, it is reloaded with ICOUNTx. */
817
#define TMS570_SPI_DMACOUNT_ICOUNTx(val) BSP_FLD32(val,16, 31)
818
#define TMS570_SPI_DMACOUNT_ICOUNTx_GET(reg) BSP_FLD32GET(reg,16, 31)
819
#define TMS570_SPI_DMACOUNT_ICOUNTx_SET(reg,val) BSP_FLD32SET(reg, val,16, 31)
820
821
/* field: COUNTx - The actual number of remaining DMA transfers. */
822
#define TMS570_SPI_DMACOUNT_COUNTx(val) BSP_FLD32(val,0, 15)
823
#define TMS570_SPI_DMACOUNT_COUNTx_GET(reg) BSP_FLD32GET(reg,0, 15)
824
#define TMS570_SPI_DMACOUNT_COUNTx_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
825
826
827
/*--------------------TMS570_SPI_DMACNTLEN--------------------*/
828
/* field: LARGE_COUNT - Select either the 16-bit DMAxCOUNT counters or the smaller counters in DMAxCTRL. */
829
#define TMS570_SPI_DMACNTLEN_LARGE_COUNT BSP_BIT32(0)
830
831
832
/*--------------------TMS570_SPI_UERRCTRL--------------------*/
833
/* field: PTESTEN - Parity memory test enable. */
834
#define TMS570_SPI_UERRCTRL_PTESTEN BSP_BIT32(8)
835
836
/* field: EDEN - Error detection enable. These bits enable parity error detection. */
837
#define TMS570_SPI_UERRCTRL_EDEN(val) BSP_FLD32(val,0, 3)
838
#define TMS570_SPI_UERRCTRL_EDEN_GET(reg) BSP_FLD32GET(reg,0, 3)
839
#define TMS570_SPI_UERRCTRL_EDEN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
840
841
842
/*--------------------TMS570_SPI_UERRSTAT--------------------*/
843
/* field: EDFLG1 - RXRAM. */
844
#define TMS570_SPI_UERRSTAT_EDFLG1 BSP_BIT32(1)
845
846
/* field: EDFLG0 - Uncorrectable parity error detection flag. */
847
#define TMS570_SPI_UERRSTAT_EDFLG0 BSP_BIT32(0)
848
849
850
/*-------------------TMS570_SPI_UERRADDRRX-------------------*/
851
/* field: OVERADDR1 - Uncorrectable parity error address for RXRAM. */
852
#define TMS570_SPI_UERRADDRRX_OVERADDR1(val) BSP_FLD32(val,0, 9)
853
#define TMS570_SPI_UERRADDRRX_OVERADDR1_GET(reg) BSP_FLD32GET(reg,0, 9)
854
#define TMS570_SPI_UERRADDRRX_OVERADDR1_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
855
856
857
/*-------------------TMS570_SPI_UERRADDRTX-------------------*/
858
/* field: UERRADDR0 - a parity error is generated while reading from TXRAM. */
859
#define TMS570_SPI_UERRADDRTX_UERRADDR0(val) BSP_FLD32(val,0, 8)
860
#define TMS570_SPI_UERRADDRTX_UERRADDR0_GET(reg) BSP_FLD32GET(reg,0, 8)
861
#define TMS570_SPI_UERRADDRTX_UERRADDR0_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
862
863
864
/*-----------------TMS570_SPI_RXOVRN_BUF_ADDR-----------------*/
865
/* field: RXOVRN_BUF_ADDR - Address in RXRAM at which an overwrite occurred. */
866
#define TMS570_SPI_RXOVRN_BUF_ADDR_RXOVRN_BUF_ADDR(val) BSP_FLD32(val,0, 9)
867
#define TMS570_SPI_RXOVRN_BUF_ADDR_RXOVRN_BUF_ADDR_GET(reg) BSP_FLD32GET(reg,0, 9)
868
#define TMS570_SPI_RXOVRN_BUF_ADDR_RXOVRN_BUF_ADDR_SET(reg,val) BSP_FLD32SET(reg, val,0, 9)
869
870
871
/*-------------------TMS570_SPI_IOLPBKTSTCR-------------------*/
872
/* field: SCS_FAIL_FLG - Bit indicating a failure on SPISCS pin compare during analog loopback. */
873
#define TMS570_SPI_IOLPBKTSTCR_SCS_FAIL_FLG BSP_BIT32(24)
874
875
/* field: CTRL_BITERR - Controls inducing of BITERR during I/O loopback test mode. */
876
#define TMS570_SPI_IOLPBKTSTCR_CTRL_BITERR BSP_BIT32(20)
877
878
/* field: CTRL_DESYNC - Controls inducing of the desync error during I/O loopback test mode. */
879
#define TMS570_SPI_IOLPBKTSTCR_CTRL_DESYNC BSP_BIT32(19)
880
881
/* field: CTRL_PARERR - Controls inducing of the parity errors during I/O loopback test mode. */
882
#define TMS570_SPI_IOLPBKTSTCR_CTRL_PARERR BSP_BIT32(18)
883
884
/* field: CTRL_TIMEOUT - Controls inducing of the timeout error during I/O loopback test mode. */
885
#define TMS570_SPI_IOLPBKTSTCR_CTRL_TIMEOUT BSP_BIT32(17)
886
887
/* field: CTRL_DLENERR - Controls inducing of the data length error during I/O loopback test mode. */
888
#define TMS570_SPI_IOLPBKTSTCR_CTRL_DLENERR BSP_BIT32(16)
889
890
/* field: IOLPBKSTENA - Module I/O loopback test enable key. */
891
#define TMS570_SPI_IOLPBKTSTCR_IOLPBKSTENA(val) BSP_FLD32(val,8, 11)
892
#define TMS570_SPI_IOLPBKTSTCR_IOLPBKSTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
893
#define TMS570_SPI_IOLPBKTSTCR_IOLPBKSTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
894
895
/* field: ERR_SCS_PIN - Inject error on chip-select pin number x. */
896
#define TMS570_SPI_IOLPBKTSTCR_ERR_SCS_PIN(val) BSP_FLD32(val,3, 5)
897
#define TMS570_SPI_IOLPBKTSTCR_ERR_SCS_PIN_GET(reg) BSP_FLD32GET(reg,3, 5)
898
#define TMS570_SPI_IOLPBKTSTCR_ERR_SCS_PIN_SET(reg,val) BSP_FLD32SET(reg, val,3, 5)
899
900
/* field: CTRL_SCS_PIN - Enable/disable the injection of an error on the SPISCS[3:0] pins. */
901
#define TMS570_SPI_IOLPBKTSTCR_CTRL_SCS_PIN BSP_BIT32(2)
902
903
/* field: LPBK_TYPE - Module I/O loopback type (analog/digital). */
904
#define TMS570_SPI_IOLPBKTSTCR_LPBK_TYPE BSP_BIT32(1)
905
906
/* field: RXP_ENA - Enable analog loopback through the receive pin. */
907
#define TMS570_SPI_IOLPBKTSTCR_RXP_ENA BSP_BIT32(0)
908
909
910
/*------------------TMS570_SPI_EXT_PRESCALEx------------------*/
911
/* field: EPRESCALE_FMTx - EPRESCALE_FMTx. Extended Prescale value for SPIFMTx. */
912
#define TMS570_SPI_EXT_PRESCALEx_EPRESCALE_FMTx(val) BSP_FLD32(val,16, 26)
913
#define TMS570_SPI_EXT_PRESCALEx_EPRESCALE_FMTx_GET(reg) BSP_FLD32GET(reg,16, 26)
914
#define TMS570_SPI_EXT_PRESCALEx_EPRESCALE_FMTx_SET(reg,val) BSP_FLD32SET(reg, val,16, 26)
915
916
917
918
#endif
/* LIBBSP_ARM_TMS570_SPI */
utility.h
Utility macros.
tms570_spi_t
Definition:
reg_spi.h:44
