RTEMS 5.2-rc1
39#ifndef LIBBSP_ARM_TMS570_SCI
40#define LIBBSP_ARM_TMS570_SCI
69 uint8_t reserved1 [48];
76#define TMS570_SCI_GCR0_Reserved(val) BSP_FLD32(val,1, 31)
77#define TMS570_SCI_GCR0_Reserved_GET(reg) BSP_FLD32GET(reg,1, 31)
78#define TMS570_SCI_GCR0_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,1, 31)
81#define TMS570_SCI_GCR0_RESET BSP_BIT32(0)
86#define TMS570_SCI_GCR1_TXENA BSP_BIT32(25)
89#define TMS570_SCI_GCR1_RXENA BSP_BIT32(24)
92#define TMS570_SCI_GCR1_CONT BSP_BIT32(17)
95#define TMS570_SCI_GCR1_LOOP_BACK BSP_BIT32(16)
98#define TMS570_SCI_GCR1_POWERDOWN BSP_BIT32(9)
101#define TMS570_SCI_GCR1_SLEEP BSP_BIT32(8)
104#define TMS570_SCI_GCR1_SWnRST BSP_BIT32(7)
107#define TMS570_SCI_GCR1_CLOCK BSP_BIT32(5)
110#define TMS570_SCI_GCR1_STOP BSP_BIT32(4)
113#define TMS570_SCI_GCR1_PARITY BSP_BIT32(3)
116#define TMS570_SCI_GCR1_PARITY_ENA BSP_BIT32(2)
119#define TMS570_SCI_GCR1_TIMING_MODE BSP_BIT32(1)
122#define TMS570_SCI_GCR1_COMM_MODE BSP_BIT32(0)
127#define TMS570_SCI_GCR2_CC BSP_BIT32(17)
130#define TMS570_SCI_GCR2_SC BSP_BIT32(16)
133#define TMS570_SCI_GCR2_GEN_WU BSP_BIT32(8)
136#define TMS570_SCI_GCR2_POWERDOWN BSP_BIT32(0)
141#define TMS570_SCI_SETINT_SET_FE_INT BSP_BIT32(26)
144#define TMS570_SCI_SETINT_SET_OE_INT BSP_BIT32(25)
147#define TMS570_SCI_SETINT_SET_PE_INT BSP_BIT32(24)
150#define TMS570_SCI_SETINT_SET_RX_DMA_ALL BSP_BIT32(18)
153#define TMS570_SCI_SETINT_SET_RX_DMA BSP_BIT32(17)
156#define TMS570_SCI_SETINT_SET_TX_DMA BSP_BIT32(16)
159#define TMS570_SCI_SETINT_SET_RX_INT BSP_BIT32(9)
162#define TMS570_SCI_SETINT_SET_TX_INT BSP_BIT32(8)
165#define TMS570_SCI_SETINT_SET_WAKEUP_INT BSP_BIT32(1)
168#define TMS570_SCI_SETINT_SET_BRKDT_INT BSP_BIT32(0)
173#define TMS570_SCI_CLEARINT_CLR_FE_INT BSP_BIT32(26)
176#define TMS570_SCI_CLEARINT_CLR_CE_INT BSP_BIT32(25)
179#define TMS570_SCI_CLEARINT_CLR_PE_INT BSP_BIT32(24)
182#define TMS570_SCI_CLEARINT_CLR_RX_DMA_ALL BSP_BIT32(18)
185#define TMS570_SCI_CLEARINT_CLR_RX_DMA BSP_BIT32(17)
188#define TMS570_SCI_CLEARINT_CLR_TX_DMA BSP_BIT32(16)
191#define TMS570_SCI_CLEARINT_CLR_RX_INT BSP_BIT32(9)
194#define TMS570_SCI_CLEARINT_CLR_TX_INT BSP_BIT32(8)
197#define TMS570_SCI_CLEARINT_CLR_WAKEUP_INT BSP_BIT32(1)
200#define TMS570_SCI_CLEARINT_CLR_BRKDT_INT BSP_BIT32(0)
205#define TMS570_SCI_SETINTLVL_SET_FE_INT_LVL BSP_BIT32(26)
208#define TMS570_SCI_SETINTLVL_SET_CE_INT_LVL BSP_BIT32(25)
211#define TMS570_SCI_SETINTLVL_SET_PE_INT_LVL BSP_BIT32(24)
214#define TMS570_SCI_SETINTLVL_SET_RX_DMA_ALL_LVL BSP_BIT32(18)
217#define TMS570_SCI_SETINTLVL_SET_RX_INT_LVL BSP_BIT32(9)
220#define TMS570_SCI_SETINTLVL_SET_TX_INT_LVL BSP_BIT32(8)
223#define TMS570_SCI_SETINTLVL_SET_WAKEUP_INT_LVL BSP_BIT32(1)
226#define TMS570_SCI_SETINTLVL_SET_BRKDT_INT_LVL BSP_BIT32(0)
231#define TMS570_SCI_CLEARINTLVL_CLR_FE_INT_LVL BSP_BIT32(26)
234#define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
237#define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
240#define TMS570_SCI_CLEARINTLVL_CLR_PE_INT_LVL BSP_BIT32(24)
243#define TMS570_SCI_CLEARINTLVL_CLR_RX_DMA_ALL_LVL BSP_BIT32(18)
246#define TMS570_SCI_CLEARINTLVL_CLR_RX_INT_LVL BSP_BIT32(9)
249#define TMS570_SCI_CLEARINTLVL_8 BSP_BIT32(8)
252#define TMS570_SCI_CLEARINTLVL_CLR_WAKEUP_INT_LVL BSP_BIT32(1)
255#define TMS570_SCI_CLEARINTLVL_CLR_BRKDT_INT_LVL BSP_BIT32(0)
260#define TMS570_SCI_FLR_FE BSP_BIT32(26)
263#define TMS570_SCI_FLR_OE BSP_BIT32(25)
266#define TMS570_SCI_FLR_PE BSP_BIT32(24)
269#define TMS570_SCI_FLR_RXWAKE BSP_BIT32(12)
272#define TMS570_SCI_FLR_TX_EMPTY BSP_BIT32(11)
275#define TMS570_SCI_FLR_TXWAKE BSP_BIT32(10)
278#define TMS570_SCI_FLR_RXRDY BSP_BIT32(9)
281#define TMS570_SCI_FLR_TXRDY BSP_BIT32(8)
284#define TMS570_SCI_FLR_BUSY BSP_BIT32(3)
287#define TMS570_SCI_FLR_IDLE BSP_BIT32(2)
290#define TMS570_SCI_FLR_WAKEUP BSP_BIT32(1)
293#define TMS570_SCI_FLR_BRKDT BSP_BIT32(0)
298#define TMS570_SCI_INTVECT0_INVECT0(val) BSP_FLD32(val,0, 3)
299#define TMS570_SCI_INTVECT0_INVECT0_GET(reg) BSP_FLD32GET(reg,0, 3)
300#define TMS570_SCI_INTVECT0_INVECT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
305#define TMS570_SCI_INTVECT1_INVECT1(val) BSP_FLD32(val,0, 3)
306#define TMS570_SCI_INTVECT1_INVECT1_GET(reg) BSP_FLD32GET(reg,0, 3)
307#define TMS570_SCI_INTVECT1_INVECT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
312#define TMS570_SCI_FORMAT_CHAR(val) BSP_FLD32(val,0, 2)
313#define TMS570_SCI_FORMAT_CHAR_GET(reg) BSP_FLD32GET(reg,0, 2)
314#define TMS570_SCI_FORMAT_CHAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
319#define TMS570_SCI_BRS_BAUD(val) BSP_FLD32(val,0, 23)
320#define TMS570_SCI_BRS_BAUD_GET(reg) BSP_FLD32GET(reg,0, 23)
321#define TMS570_SCI_BRS_BAUD_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
326#define TMS570_SCI_ED_ED(val) BSP_FLD32(val,0, 7)
327#define TMS570_SCI_ED_ED_GET(reg) BSP_FLD32GET(reg,0, 7)
328#define TMS570_SCI_ED_ED_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
333#define TMS570_SCI_RD_RD(val) BSP_FLD32(val,0, 7)
334#define TMS570_SCI_RD_RD_GET(reg) BSP_FLD32GET(reg,0, 7)
335#define TMS570_SCI_RD_RD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
340#define TMS570_SCI_TD_TD(val) BSP_FLD32(val,0, 7)
341#define TMS570_SCI_TD_TD_GET(reg) BSP_FLD32GET(reg,0, 7)
342#define TMS570_SCI_TD_TD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
347#define TMS570_SCI_PIO0_TX_FUNC BSP_BIT32(2)
350#define TMS570_SCI_PIO0_RX_FUNC BSP_BIT32(1)
355#define TMS570_SCI_PIO1_TX_DIR BSP_BIT32(2)
358#define TMS570_SCI_PIO1_RX_DIR BSP_BIT32(1)
363#define TMS570_SCI_PIO2_TX_IN BSP_BIT32(2)
366#define TMS570_SCI_PIO2_RX_IN BSP_BIT32(1)
371#define TMS570_SCI_PIO3_TX_OUT BSP_BIT32(2)
374#define TMS570_SCI_PIO3_RX_OUT BSP_BIT32(1)
379#define TMS570_SCI_PIO4_TX_SET BSP_BIT32(2)
382#define TMS570_SCI_PIO4_RX_SET BSP_BIT32(1)
387#define TMS570_SCI_PIO5_TX_CLR BSP_BIT32(2)
390#define TMS570_SCI_PIO5_RX_CLR BSP_BIT32(1)
395#define TMS570_SCI_PIO6_TX_PDR BSP_BIT32(2)
398#define TMS570_SCI_PIO6_RX_PDR BSP_BIT32(1)
403#define TMS570_SCI_PIO7_TX_PD BSP_BIT32(2)
406#define TMS570_SCI_PIO7_RX_PD BSP_BIT32(1)
411#define TMS570_SCI_PIO8_TX_PSL BSP_BIT32(2)
414#define TMS570_SCI_PIO8_RX_PSL BSP_BIT32(1)
419#define TMS570_SCI_IODFTCTRL_FEN BSP_BIT32(26)
422#define TMS570_SCI_IODFTCTRL_PEN BSP_BIT32(25)
425#define TMS570_SCI_IODFTCTRL_BRKD_TENA BSP_BIT32(24)
428#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK(val) BSP_FLD32(val,19, 20)
429#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET(reg) BSP_FLD32GET(reg,19, 20)
430#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET(reg,val) BSP_FLD32SET(reg, val,19, 20)
433#define TMS570_SCI_IODFTCTRL_TX_SHIFT(val) BSP_FLD32(val,16, 18)
434#define TMS570_SCI_IODFTCTRL_TX_SHIFT_GET(reg) BSP_FLD32GET(reg,16, 18)
435#define TMS570_SCI_IODFTCTRL_TX_SHIFT_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
438#define TMS570_SCI_IODFTCTRL_IODFTENA(val) BSP_FLD32(val,8, 11)
439#define TMS570_SCI_IODFTCTRL_IODFTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
440#define TMS570_SCI_IODFTCTRL_IODFTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
443#define TMS570_SCI_IODFTCTRL_LPBENA BSP_BIT32(1)
446#define TMS570_SCI_IODFTCTRL_RXPENA BSP_BIT32(0)
