RTEMS 5.2-rc1
reg_emif.h
1/* The header file is generated by make_header.py from EMIF.json */
2/* Current script's version can be found at: */
3/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
4
5/*
6 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
7 *
8 * Czech Technical University in Prague
9 * Zikova 1903/4
10 * 166 36 Praha 6
11 * Czech Republic
12 *
13 * All rights reserved.
14 *
16 * modification, are permitted provided that the following conditions are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright notice, this
19 * list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright notice,
21 * this list of conditions and the following disclaimer in the documentation
22 * and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
26 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
27 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
28 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
29 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
30 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
31 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
32 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
33 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
34 *
35 * The views and conclusions contained in the software and documentation are those
36 * of the authors and should not be interpreted as representing official policies,
37 * either expressed or implied, of the FreeBSD Project.
38*/
39#ifndef LIBBSP_ARM_TMS570_EMIF
40#define LIBBSP_ARM_TMS570_EMIF
41
42#include <bsp/utility.h>
43
44typedef struct{
45 uint32_t MIDR; /*Module ID Register*/
46 uint32_t AWCC; /*Asynchronous Wait Cycle Configuration Register*/
47 uint32_t SDCR; /*SDRAM Configuration Register*/
48 uint32_t SDRCR; /*SDRAM Refresh Control Register*/
49 uint32_t CE2CFG; /*Asynchronous 1 Configuration Register*/
50 uint32_t CE3CFG; /*Asynchronous 2 Configuration Register*/
51 uint32_t CE4CFG; /*Asynchronous 3 Configuration Register*/
52 uint32_t CE5CFG; /*Asynchronous 4 Configuration Register*/
53 uint32_t SDTIMR; /*SDRAM Timing Register*/
54 uint8_t reserved1 [24];
55 uint32_t SDSRETR; /*SDRAM Self Refresh Exit Timing Register*/
56 uint32_t INTRAW; /*EMIF Interrupt Raw Register*/
57 uint32_t INTMSK; /*EMIF Interrupt Mask Register*/
58 uint32_t INTMSKSET; /*EMIF Interrupt Mask Set Register*/
59 uint32_t INTMSKCLR; /*EMIF Interrupt Mask Clear Register*/
60 uint8_t reserved2 [24];
61 uint32_t PMCR; /*Page Mode Control Register*/
63
64
65/*----------------------TMS570_EMIF_MIDR----------------------*/
66/* field: REV - Module ID of EMIF. See the device-specific data manual. */
67/* Whole 32 bits */
68
69/*----------------------TMS570_EMIF_AWCC----------------------*/
70/* field: WP1 - EMIF_nWAIT[1] polarity bit. This bit defines the polarity of the EMIF_nWAIT[1] pin. */
71#define TMS570_EMIF_AWCC_WP1 BSP_BIT32(29)
72
73/* field: WP0 - EMIF_nWAIT[0] polarity bit. This bit defines the polarity of the EMIF_nWAIT[0] pin. */
74#define TMS570_EMIF_AWCC_WP0 BSP_BIT32(28)
75
76/* field: CS5_WAIT - Chip Select 5 WAIT signal selection. */
77#define TMS570_EMIF_AWCC_CS5_WAIT(val) BSP_FLD32(val,22, 23)
78#define TMS570_EMIF_AWCC_CS5_WAIT_GET(reg) BSP_FLD32GET(reg,22, 23)
79#define TMS570_EMIF_AWCC_CS5_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,22, 23)
80
81/* field: CS4_WAIT - Chip Select 4 WAIT signal selection. */
82#define TMS570_EMIF_AWCC_CS4_WAIT(val) BSP_FLD32(val,20, 21)
83#define TMS570_EMIF_AWCC_CS4_WAIT_GET(reg) BSP_FLD32GET(reg,20, 21)
84#define TMS570_EMIF_AWCC_CS4_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,20, 21)
85
86/* field: CS3_WAIT - be used for memory accesses to chip select 3 memory space. */
87#define TMS570_EMIF_AWCC_CS3_WAIT(val) BSP_FLD32(val,18, 19)
88#define TMS570_EMIF_AWCC_CS3_WAIT_GET(reg) BSP_FLD32GET(reg,18, 19)
89#define TMS570_EMIF_AWCC_CS3_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,18, 19)
90
91/* field: CS2_WAIT - Chip Select 2 WAIT signal selection. */
92#define TMS570_EMIF_AWCC_CS2_WAIT(val) BSP_FLD32(val,16, 17)
93#define TMS570_EMIF_AWCC_CS2_WAIT_GET(reg) BSP_FLD32GET(reg,16, 17)
94#define TMS570_EMIF_AWCC_CS2_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,16, 17)
95
96/* field: MAX_EXT_WAIT - Maximum extended wait cycles. */
97#define TMS570_EMIF_AWCC_MAX_EXT_WAIT(val) BSP_FLD32(val,0, 7)
98#define TMS570_EMIF_AWCC_MAX_EXT_WAIT_GET(reg) BSP_FLD32GET(reg,0, 7)
99#define TMS570_EMIF_AWCC_MAX_EXT_WAIT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
100
101
102/*----------------------TMS570_EMIF_SDCR----------------------*/
103/* field: SR - Self-Refresh mode bit. */
104#define TMS570_EMIF_SDCR_SR BSP_BIT32(31)
105
106/* field: PD - Power Down bit. This bit controls entering and exiting of the power-down mode. */
107#define TMS570_EMIF_SDCR_PD BSP_BIT32(30)
108
109/* field: PDWR - Perform refreshes during power down. */
110#define TMS570_EMIF_SDCR_PDWR BSP_BIT32(29)
111
112/* field: NM - Narrow mode bit. This bit defines whether a 16- or 32-bit-wide SDRAM is connected to the EMIF. */
113#define TMS570_EMIF_SDCR_NM BSP_BIT32(14)
114
115/* field: CL - CAS Latency. */
116#define TMS570_EMIF_SDCR_CL(val) BSP_FLD32(val,9, 11)
117#define TMS570_EMIF_SDCR_CL_GET(reg) BSP_FLD32GET(reg,9, 11)
118#define TMS570_EMIF_SDCR_CL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
119
120/* field: BIT11_9LOCK - Bits 11 to 9 lock. CL can only be written if BIT11_9LOCK is simultaneously written with a 1. */
121#define TMS570_EMIF_SDCR_BIT11_9LOCK BSP_BIT32(8)
122
123/* field: IBANK - Internal SDRAM Bank size. */
124#define TMS570_EMIF_SDCR_IBANK(val) BSP_FLD32(val,4, 6)
125#define TMS570_EMIF_SDCR_IBANK_GET(reg) BSP_FLD32GET(reg,4, 6)
126#define TMS570_EMIF_SDCR_IBANK_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
127
128/* field: PAGESIZE - Page Size. This field defines the internal page size of connected SDRAM devices. */
129#define TMS570_EMIF_SDCR_PAGESIZE(val) BSP_FLD32(val,0, 2)
130#define TMS570_EMIF_SDCR_PAGESIZE_GET(reg) BSP_FLD32GET(reg,0, 2)
131#define TMS570_EMIF_SDCR_PAGESIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
132
133
134/*---------------------TMS570_EMIF_SDRCR---------------------*/
135/* field: RR - Refresh Rate. This field is used to define the SDRAM refresh period in terms of EMIF_CLK cycles. */
136#define TMS570_EMIF_SDRCR_RR(val) BSP_FLD32(val,0, 12)
137#define TMS570_EMIF_SDRCR_RR_GET(reg) BSP_FLD32GET(reg,0, 12)
138#define TMS570_EMIF_SDRCR_RR_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
139
140
141/*---------------------TMS570_EMIF_CE2CFG---------------------*/
142/* field: SS - Select Strobe bit. */
143#define TMS570_EMIF_CE2CFG_SS BSP_BIT32(31)
144
145/* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
146#define TMS570_EMIF_CE2CFG_EW BSP_BIT32(30)
147
148/* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
149#define TMS570_EMIF_CE2CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
150#define TMS570_EMIF_CE2CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
151#define TMS570_EMIF_CE2CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
152
153/* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
154#define TMS570_EMIF_CE2CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
155#define TMS570_EMIF_CE2CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
156#define TMS570_EMIF_CE2CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
157
158/* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
159#define TMS570_EMIF_CE2CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
160#define TMS570_EMIF_CE2CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
161#define TMS570_EMIF_CE2CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
162
163/* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
164#define TMS570_EMIF_CE2CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
165#define TMS570_EMIF_CE2CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
166#define TMS570_EMIF_CE2CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
167
168/* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
169#define TMS570_EMIF_CE2CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
170#define TMS570_EMIF_CE2CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
171#define TMS570_EMIF_CE2CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
172
173/* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
174#define TMS570_EMIF_CE2CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
175#define TMS570_EMIF_CE2CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
176#define TMS570_EMIF_CE2CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
177
178/* field: TA - Minimum Turn-Around time. */
179#define TMS570_EMIF_CE2CFG_TA(val) BSP_FLD32(val,2, 3)
180#define TMS570_EMIF_CE2CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
181#define TMS570_EMIF_CE2CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
182
183/* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
184#define TMS570_EMIF_CE2CFG_ASIZE(val) BSP_FLD32(val,0, 1)
185#define TMS570_EMIF_CE2CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
186#define TMS570_EMIF_CE2CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
187
188
189/*---------------------TMS570_EMIF_CE3CFG---------------------*/
190/* field: SS - Select Strobe bit. */
191#define TMS570_EMIF_CE3CFG_SS BSP_BIT32(31)
192
193/* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
194#define TMS570_EMIF_CE3CFG_EW BSP_BIT32(30)
195
196/* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
197#define TMS570_EMIF_CE3CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
198#define TMS570_EMIF_CE3CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
199#define TMS570_EMIF_CE3CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
200
201/* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
202#define TMS570_EMIF_CE3CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
203#define TMS570_EMIF_CE3CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
204#define TMS570_EMIF_CE3CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
205
206/* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
207#define TMS570_EMIF_CE3CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
208#define TMS570_EMIF_CE3CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
209#define TMS570_EMIF_CE3CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
210
211/* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
212#define TMS570_EMIF_CE3CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
213#define TMS570_EMIF_CE3CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
214#define TMS570_EMIF_CE3CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
215
216/* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
217#define TMS570_EMIF_CE3CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
218#define TMS570_EMIF_CE3CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
219#define TMS570_EMIF_CE3CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
220
221/* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
222#define TMS570_EMIF_CE3CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
223#define TMS570_EMIF_CE3CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
224#define TMS570_EMIF_CE3CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
225
226/* field: TA - Minimum Turn-Around time. */
227#define TMS570_EMIF_CE3CFG_TA(val) BSP_FLD32(val,2, 3)
228#define TMS570_EMIF_CE3CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
229#define TMS570_EMIF_CE3CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
230
231/* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
232#define TMS570_EMIF_CE3CFG_ASIZE(val) BSP_FLD32(val,0, 1)
233#define TMS570_EMIF_CE3CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
234#define TMS570_EMIF_CE3CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
235
236
237/*---------------------TMS570_EMIF_CE4CFG---------------------*/
238/* field: SS - Select Strobe bit. */
239#define TMS570_EMIF_CE4CFG_SS BSP_BIT32(31)
240
241/* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
242#define TMS570_EMIF_CE4CFG_EW BSP_BIT32(30)
243
244/* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
245#define TMS570_EMIF_CE4CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
246#define TMS570_EMIF_CE4CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
247#define TMS570_EMIF_CE4CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
248
249/* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
250#define TMS570_EMIF_CE4CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
251#define TMS570_EMIF_CE4CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
252#define TMS570_EMIF_CE4CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
253
254/* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
255#define TMS570_EMIF_CE4CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
256#define TMS570_EMIF_CE4CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
257#define TMS570_EMIF_CE4CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
258
259/* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
260#define TMS570_EMIF_CE4CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
261#define TMS570_EMIF_CE4CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
262#define TMS570_EMIF_CE4CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
263
264/* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
265#define TMS570_EMIF_CE4CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
266#define TMS570_EMIF_CE4CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
267#define TMS570_EMIF_CE4CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
268
269/* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
270#define TMS570_EMIF_CE4CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
271#define TMS570_EMIF_CE4CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
272#define TMS570_EMIF_CE4CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
273
274/* field: TA - Minimum Turn-Around time. */
275#define TMS570_EMIF_CE4CFG_TA(val) BSP_FLD32(val,2, 3)
276#define TMS570_EMIF_CE4CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
277#define TMS570_EMIF_CE4CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
278
279/* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
280#define TMS570_EMIF_CE4CFG_ASIZE(val) BSP_FLD32(val,0, 1)
281#define TMS570_EMIF_CE4CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
282#define TMS570_EMIF_CE4CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
283
284
285/*---------------------TMS570_EMIF_CE5CFG---------------------*/
286/* field: SS - Select Strobe bit. */
287#define TMS570_EMIF_CE5CFG_SS BSP_BIT32(31)
288
289/* field: EW - Extend Wait bit. This bit defines whether extended wait cycles will be enabled. See Section 17.2.6. */
290#define TMS570_EMIF_CE5CFG_EW BSP_BIT32(30)
291
292/* field: W_SETUP - Write setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
293#define TMS570_EMIF_CE5CFG_W_SETUP(val) BSP_FLD32(val,26, 29)
294#define TMS570_EMIF_CE5CFG_W_SETUP_GET(reg) BSP_FLD32GET(reg,26, 29)
295#define TMS570_EMIF_CE5CFG_W_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,26, 29)
296
297/* field: W_STROBE - Write strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
298#define TMS570_EMIF_CE5CFG_W_STROBE(val) BSP_FLD32(val,20, 25)
299#define TMS570_EMIF_CE5CFG_W_STROBE_GET(reg) BSP_FLD32GET(reg,20, 25)
300#define TMS570_EMIF_CE5CFG_W_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
301
302/* field: W_HOLD - Write hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
303#define TMS570_EMIF_CE5CFG_W_HOLD(val) BSP_FLD32(val,17, 19)
304#define TMS570_EMIF_CE5CFG_W_HOLD_GET(reg) BSP_FLD32GET(reg,17, 19)
305#define TMS570_EMIF_CE5CFG_W_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,17, 19)
306
307/* field: R_SETUP - Read setup width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
308#define TMS570_EMIF_CE5CFG_R_SETUP(val) BSP_FLD32(val,13, 16)
309#define TMS570_EMIF_CE5CFG_R_SETUP_GET(reg) BSP_FLD32GET(reg,13, 16)
310#define TMS570_EMIF_CE5CFG_R_SETUP_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
311
312/* field: R_STROBE - Read strobe width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
313#define TMS570_EMIF_CE5CFG_R_STROBE(val) BSP_FLD32(val,7, 12)
314#define TMS570_EMIF_CE5CFG_R_STROBE_GET(reg) BSP_FLD32GET(reg,7, 12)
315#define TMS570_EMIF_CE5CFG_R_STROBE_SET(reg,val) BSP_FLD32SET(reg, val,7, 12)
316
317/* field: R_HOLD - Read hold width in EMIF_CLK cycles, minus one cycle. See Section 17.2.6.3 for details. */
318#define TMS570_EMIF_CE5CFG_R_HOLD(val) BSP_FLD32(val,4, 6)
319#define TMS570_EMIF_CE5CFG_R_HOLD_GET(reg) BSP_FLD32GET(reg,4, 6)
320#define TMS570_EMIF_CE5CFG_R_HOLD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
321
322/* field: TA - and writes, minus one cycle. See Section 17.2.6.3 for details. */
323#define TMS570_EMIF_CE5CFG_TA(val) BSP_FLD32(val,2, 3)
324#define TMS570_EMIF_CE5CFG_TA_GET(reg) BSP_FLD32GET(reg,2, 3)
325#define TMS570_EMIF_CE5CFG_TA_SET(reg,val) BSP_FLD32SET(reg, val,2, 3)
326
327/* field: ASIZE - Asynchronous Data Bus Width. This field defines the width of the asynchronous device's data bus. */
328#define TMS570_EMIF_CE5CFG_ASIZE(val) BSP_FLD32(val,0, 1)
329#define TMS570_EMIF_CE5CFG_ASIZE_GET(reg) BSP_FLD32GET(reg,0, 1)
330#define TMS570_EMIF_CE5CFG_ASIZE_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
331
332
333/*---------------------TMS570_EMIF_SDTIMR---------------------*/
334/* field: T_RFC - Specifies the Trfc value of the SDRAM. */
335#define TMS570_EMIF_SDTIMR_T_RFC(val) BSP_FLD32(val,27, 31)
336#define TMS570_EMIF_SDTIMR_T_RFC_GET(reg) BSP_FLD32GET(reg,27, 31)
337#define TMS570_EMIF_SDTIMR_T_RFC_SET(reg,val) BSP_FLD32SET(reg, val,27, 31)
338
339/* field: T_RP - Precharge (PRE) to Activate (ACTV) or Refresh (REFR) command, minus 1: */
340#define TMS570_EMIF_SDTIMR_T_RP(val) BSP_FLD32(val,24, 26)
341#define TMS570_EMIF_SDTIMR_T_RP_GET(reg) BSP_FLD32GET(reg,24, 26)
342#define TMS570_EMIF_SDTIMR_T_RP_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
343
344/* field: T_RCD - Specifies the Trcd value of the SDRAM. */
345#define TMS570_EMIF_SDTIMR_T_RCD(val) BSP_FLD32(val,20, 22)
346#define TMS570_EMIF_SDTIMR_T_RCD_GET(reg) BSP_FLD32GET(reg,20, 22)
347#define TMS570_EMIF_SDTIMR_T_RCD_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
348
349/* field: T_WR - Specifies the Twr value of the SDRAM. */
350#define TMS570_EMIF_SDTIMR_T_WR(val) BSP_FLD32(val,16, 18)
351#define TMS570_EMIF_SDTIMR_T_WR_GET(reg) BSP_FLD32GET(reg,16, 18)
352#define TMS570_EMIF_SDTIMR_T_WR_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
353
354/* field: T_RAS - Specifies the Tras value of the SDRAM. */
355#define TMS570_EMIF_SDTIMR_T_RAS(val) BSP_FLD32(val,12, 15)
356#define TMS570_EMIF_SDTIMR_T_RAS_GET(reg) BSP_FLD32GET(reg,12, 15)
357#define TMS570_EMIF_SDTIMR_T_RAS_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
358
359/* field: T_RC - Specifies the Trc value of the SDRAM. */
360#define TMS570_EMIF_SDTIMR_T_RC(val) BSP_FLD32(val,8, 11)
361#define TMS570_EMIF_SDTIMR_T_RC_GET(reg) BSP_FLD32GET(reg,8, 11)
362#define TMS570_EMIF_SDTIMR_T_RC_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
363
364/* field: T_RRD - Specifies the Trrd value of the SDRAM. */
365#define TMS570_EMIF_SDTIMR_T_RRD(val) BSP_FLD32(val,4, 6)
366#define TMS570_EMIF_SDTIMR_T_RRD_GET(reg) BSP_FLD32GET(reg,4, 6)
367#define TMS570_EMIF_SDTIMR_T_RRD_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
368
369
370/*--------------------TMS570_EMIF_SDSRETR--------------------*/
371/* field: T_XS - This field specifies the minimum number of ECLKOUT cycles from Self-Refresh exit to any command, */
372#define TMS570_EMIF_SDSRETR_T_XS(val) BSP_FLD32(val,0, 4)
373#define TMS570_EMIF_SDSRETR_T_XS_GET(reg) BSP_FLD32GET(reg,0, 4)
374#define TMS570_EMIF_SDSRETR_T_XS_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
375
376
377/*---------------------TMS570_EMIF_INTRAW---------------------*/
378/* field: WR - Wait Rise. */
379#define TMS570_EMIF_INTRAW_WR BSP_BIT32(2)
380
381/* field: LT - Line Trap. Set to 1 by hardware to indicate illegal memory access type or invalid cache line size. */
382#define TMS570_EMIF_INTRAW_LT BSP_BIT32(1)
383
384/* field: AT - Asynchronous Timeout. */
385#define TMS570_EMIF_INTRAW_AT BSP_BIT32(0)
386
387
388/*---------------------TMS570_EMIF_INTMSK---------------------*/
389/* field: WR_MASKED - Wait Rise Masked. */
390#define TMS570_EMIF_INTMSK_WR_MASKED BSP_BIT32(2)
391
392/* field: LT_MASKED - Masked Line Trap. */
393#define TMS570_EMIF_INTMSK_LT_MASKED BSP_BIT32(1)
394
395/* field: AT_MASKED - Asynchronous Timeout Masked. */
396#define TMS570_EMIF_INTMSK_AT_MASKED BSP_BIT32(0)
397
398
399/*-------------------TMS570_EMIF_INTMSKSET-------------------*/
400/* field: WR_MASK_SET - Wait Rise Mask Set. This bit determines whether or not the wait rise Interrupt is enabled. */
401#define TMS570_EMIF_INTMSKSET_WR_MASK_SET BSP_BIT32(2)
402
403/* field: LT_MASK_SET - LT_MASK_SET Mask set for LT_MASKED bit in the EMIF interrupt mask register (INTMSK). */
404#define TMS570_EMIF_INTMSKSET_LT_MASK_SET BSP_BIT32(1)
405
406/* field: AT_MASK_SET - Asynchronous Timeout Mask Set. */
407#define TMS570_EMIF_INTMSKSET_AT_MASK_SET BSP_BIT32(0)
408
409
410/*-------------------TMS570_EMIF_INTMSKCLR-------------------*/
411/* field: WR_MASK_CLR - Wait Rise Mask Clear. This bit determines whether or not the wait rise interrupt is enabled. */
412#define TMS570_EMIF_INTMSKCLR_WR_MASK_CLR BSP_BIT32(2)
413
414/* field: LT_MASK_CLR - 1 to this bit clears this bit, clears the LT_MASK_SET bit in the EMIF interrupt mask set register */
415#define TMS570_EMIF_INTMSKCLR_LT_MASK_CLR BSP_BIT32(1)
416
417/* field: AT_MASK_CLR - Asynchronous Timeout Mask Clear. */
418#define TMS570_EMIF_INTMSKCLR_AT_MASK_CLR BSP_BIT32(0)
419
420
421/*----------------------TMS570_EMIF_PMCR----------------------*/
422/* field: CS5_PG_DEL - Page access delay for NOR Flash connected on CS5. CS5 is not available on this device. */
423#define TMS570_EMIF_PMCR_CS5_PG_DEL(val) BSP_FLD32(val,26, 31)
424#define TMS570_EMIF_PMCR_CS5_PG_DEL_GET(reg) BSP_FLD32GET(reg,26, 31)
425#define TMS570_EMIF_PMCR_CS5_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,26, 31)
426
427/* field: CS5_PG_SIZE - Page Size for NOR Flash connected on CS5. CS5 is not available on this device. */
428#define TMS570_EMIF_PMCR_CS5_PG_SIZE BSP_BIT32(25)
429
430/* field: CS5_PG_MD_EN - Page Mode enable for NOR Flash connected on CS5. CS5 is not available on this device. */
431#define TMS570_EMIF_PMCR_CS5_PG_MD_EN BSP_BIT32(24)
432
433/* field: CS4_PG_DEL - Page access delay for NOR Flash connected on CS4. */
434#define TMS570_EMIF_PMCR_CS4_PG_DEL(val) BSP_FLD32(val,18, 23)
435#define TMS570_EMIF_PMCR_CS4_PG_DEL_GET(reg) BSP_FLD32GET(reg,18, 23)
436#define TMS570_EMIF_PMCR_CS4_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,18, 23)
437
438/* field: CS4_PG_SIZE - Page Size for NOR Flash connected on CS4. */
439#define TMS570_EMIF_PMCR_CS4_PG_SIZE BSP_BIT32(17)
440
441/* field: CS4_PG_MD_EN - Page Mode enable for NOR Flash connected on CS4. */
442#define TMS570_EMIF_PMCR_CS4_PG_MD_EN BSP_BIT32(16)
443
444/* field: CS3_PG_DEL - the page read data to be valid, minus one cycle. This value must not be cleared to 0. */
445#define TMS570_EMIF_PMCR_CS3_PG_DEL(val) BSP_FLD32(val,10, 15)
446#define TMS570_EMIF_PMCR_CS3_PG_DEL_GET(reg) BSP_FLD32GET(reg,10, 15)
447#define TMS570_EMIF_PMCR_CS3_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,10, 15)
448
449/* field: CS3_PG_SIZE - Page Size for NOR Flash connected on CS3. */
450#define TMS570_EMIF_PMCR_CS3_PG_SIZE BSP_BIT32(9)
451
452/* field: CS3_PG_MD_EN - Page Mode enable for NOR Flash connected on CS3. */
453#define TMS570_EMIF_PMCR_CS3_PG_MD_EN BSP_BIT32(8)
454
455/* field: CS2_PG_DEL - Page access delay for NOR Flash connected on CS2. */
456#define TMS570_EMIF_PMCR_CS2_PG_DEL(val) BSP_FLD32(val,2, 7)
457#define TMS570_EMIF_PMCR_CS2_PG_DEL_GET(reg) BSP_FLD32GET(reg,2, 7)
458#define TMS570_EMIF_PMCR_CS2_PG_DEL_SET(reg,val) BSP_FLD32SET(reg, val,2, 7)
459
460/* field: CS2_PG_SIZE - Page Size for NOR Flash connected on CS2. */
461#define TMS570_EMIF_PMCR_CS2_PG_SIZE BSP_BIT32(1)
462
463/* field: CS2_PG_MD_EN - Page Mode enable for NOR Flash connected on CS2. */
464#define TMS570_EMIF_PMCR_CS2_PG_MD_EN BSP_BIT32(0)
465
466
467
468#endif /* LIBBSP_ARM_TMS570_EMIF */
Utility macros.
Definition: reg_emif.h:44
